Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
A
athena
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
Subhadip Pal
athena
Commits
92d9cbd6
Commit
92d9cbd6
authored
3 years ago
by
Wouter Deconinck
Browse files
Options
Downloads
Patches
Plain Diff
Solenoid offset 10 cm in hadron direction
parent
ef97d84c
No related branches found
No related tags found
No related merge requests found
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
compact/definitions.xml
+4
-3
4 additions, 3 deletions
with
4 additions
and
3 deletions
4
3
View file @
92d9cbd6
@@ -294,9 +294,10 @@
- "rmin", "rmax", "thickness" all refer to the radial direction.
- "zmin", "zmax", "length", "offset" all refer to the z direction.
- Positive and Negative are "EndcapP" and "EndcapN", respectively.
- All values are positive. When refering to a negative endcap z position, the values are
- All values are positive (except offsets, which are positive in the hadron direction, i.e. towards EndCapP).
also positive then negated when required. (Many endcap constructions are mirrored,
hence a postive value.
- We will try to keep the subsystem component name first and the parameter after an "_" (eg, EcalBarrel_length").
TODO: fix parameter naming to be uniform in the above convention.
@@ -311,7 +312,7 @@
@@ -311,7 +312,7 @@
<constant
name=
"Solenoid_length"
value=
"3840.0*mm"
<constant
name=
"Solenoid_length"
value=
"3840.0*mm"
<constant
name=
"Solenoid_rmin"
value=
"1600.0*mm"
<constant
name=
"Solenoid_rmin"
value=
"1600.0*mm"
<constant
name=
"Solenoid_thickness"
value=
"640*mm"
<constant
name=
value=
"640*mm"
<constant
name=
"Solenoid_offset"
value=
0.
0*mm"
<constant
name=
"Solenoid_offset"
value=
1
0*mm"
<constant
name=
"Solenoid_rmax"
value=
"Solenoid_rmin + Solenoid_thickness"
<constant
name=
"Solenoid_rmax"
value=
<constant
name=
"SolenoidBarrel_rmin"
value=
"Solenoid_rmin"
<constant
name=
value=
"Solenoid_rmin"
This diff is collapsed.
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
