Skip to content
Snippets Groups Projects
Commit 92d9cbd6 authored by Wouter Deconinck's avatar Wouter Deconinck
Browse files
Solenoid offset 10 cm in hadron direction
parent ef97d84c
No related branches found
No related tags found
No related merge requests found
......@@ -294,9 +294,10 @@
- "rmin", "rmax", "thickness" all refer to the radial direction.
- "zmin", "zmax", "length", "offset" all refer to the z direction.
- Positive and Negative are "EndcapP" and "EndcapN", respectively.
- All values are positive. When refering to a negative endcap z position, the values are
- All values are positive (except offsets, which are positive in the hadron direction, i.e. towards EndCapP).
also positive then negated when required. (Many endcap constructions are mirrored,
hence a postive value.
hence a postive value.)
- We will try to keep the subsystem component name first and the parameter after an "_" (eg, EcalBarrel_length").
TODO: fix parameter naming to be uniform in the above convention.
......@@ -311,7 +312,7 @@
<constant name="Solenoid_length" value="3840.0*mm"/>
<constant name="Solenoid_rmin" value="1600.0*mm"/>
<constant name="Solenoid_thickness" value="640*mm"/>
<constant name="Solenoid_offset" value="0.0*mm"/>
<constant name="Solenoid_offset" value="10*mm"/>
<constant name="Solenoid_rmax" value="Solenoid_rmin + Solenoid_thickness"/>
<constant name="SolenoidBarrel_rmin" value="Solenoid_rmin"/>
0% Loading or .
Please register or to comment
