Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Show changes
Commits on Source (294)
Showing
with 1136 additions and 343 deletions
...@@ -10,3 +10,22 @@ build/* ...@@ -10,3 +10,22 @@ build/*
.DAWN* .DAWN*
*/*.pyc */*.pyc
**.pyc **.pyc
images/*
doc/*
accelerator
eic_ip6
eic
ip6_build
ip6
*.swp
fieldmaps
manifest.txt
acts.txt
acts2.txt
materials-map.cbor
...@@ -6,35 +6,48 @@ workflow: ...@@ -6,35 +6,48 @@ workflow:
- if: '$CI_PIPELINE_SOURCE == "web"' - if: '$CI_PIPELINE_SOURCE == "web"'
- if: '$CI_PIPELINE_SOURCE == "webide"' - if: '$CI_PIPELINE_SOURCE == "webide"'
- if: '$CI_COMMIT_BRANCH == "master"' - if: '$CI_COMMIT_BRANCH == "master"'
- if: '$CI_COMMIT_BRANCH == "acadia"'
- if: '$CI_COMMIT_TAG' - if: '$CI_COMMIT_TAG'
default: default:
before_script: before_script:
- mkdir -p images && mkdir -p doc/ - source .local/bin/env.sh
- git clone https://eicweb.phy.anl.gov/EIC/detectors/accelerator.git && ln -s accelerator/eic
- git clone https://eicweb.phy.anl.gov/EIC/detectors/ip6.git eic_ip6 && mkdir ip6_build && cd ip6_build && cmake ../eic_ip6/. -DCMAKE_INSTALL_PREFIX=/usr/local && make -j20 && make install && cd .. && ln -s eic_ip6/ip6
- mkdir build && cd build && cmake ../. -DCMAKE_INSTALL_PREFIX=/usr/local && make -j20 && make install && cd ..
artifacts: artifacts:
expire_in: 1 week
paths: paths:
- images/ - .local/detector
- doc/ - .local/lib
- .local/bin
- .local/include
- .local/share
- results
- config
- images
- doc
- juggler.env
- geo
reports: reports:
dotenv: juggler.env dotenv: juggler.env
stages: stages:
- config - config
- build - build
- test
- docs - docs
- test - collect
- finalize - finalize
- deploy - deploy
env: common:setup:
stage: config stage: config
rules:
- if: '$CI_SERVER_HOST == "eicweb.phy.anl.gov"'
before_script:
- git clone https://eicweb.phy.anl.gov/EIC/benchmarks/common_bench.git setup
script: script:
- export JUGGLER_DETECTOR="reference_detector" - export JUGGLER_DETECTOR="athena"
if [[ "x${CI_PIPELINE_SOURCE}" == "xmerge_request_event" || "$CI_COMMIT_BRANCH" == "master" ]]; then # if [[ "x${CI_PIPELINE_SOURCE}" == "xmerge_request_event" || "$CI_COMMIT_BRANCH" == "master" ]]; then
export JUGGLER_DETECTOR_VERSION="${CI_COMMIT_REF_NAME}" export JUGGLER_DETECTOR_VERSION="${CI_COMMIT_REF_NAME}"
echo "BEAMLINE_CONFIG = ${BEAMLINE_CONFIG}" echo "BEAMLINE_CONFIG = ${BEAMLINE_CONFIG}"
echo "BEAMLINE_CONFIG_VERSION = ${BEAMLINE_CONFIG_VERSION}" echo "BEAMLINE_CONFIG_VERSION = ${BEAMLINE_CONFIG_VERSION}"
...@@ -42,88 +55,220 @@ env: ...@@ -42,88 +55,220 @@ env:
echo "JUGGLER_DETECTOR_VERSION = ${CI_COMMIT_REF_NAME}" echo "JUGGLER_DETECTOR_VERSION = ${CI_COMMIT_REF_NAME}"
echo "JUGGLER_DETECTOR_VERSION=$CI_COMMIT_REF_NAME" >> juggler.env echo "JUGGLER_DETECTOR_VERSION=$CI_COMMIT_REF_NAME" >> juggler.env
echo "JUGGLER_DETECTOR=$JUGGLER_DETECTOR" >> juggler.env echo "JUGGLER_DETECTOR=$JUGGLER_DETECTOR" >> juggler.env
fi #fi
artifacts: - source setup/bin/env.sh && ./setup/bin/install_common.sh
reports:
dotenv: juggler.env
common:detector:
stage: build
needs:
- common:setup
script:
#- source .local/bin/env.sh && build_detector.sh
- build_detector.sh
- mkdir -p results
- mkdir -p config
- mkdir -p doc
- mkdir -p geo
- print_env.sh
compile: build:simple:
stage: build stage: build
needs:
- ["env"]
script: script:
- mkdir -p build && cd build && cmake ../. -DCMAKE_INSTALL_PREFIX=/usr/local && make -j20 && make install && cd .. - mkdir -p build && cd build && cmake ../. -DCMAKE_INSTALL_PREFIX=/usr/local && make -j20 && make install && cd ..
- echo "Build successful." - echo "Build successful."
.views: .views:
stage: docs stage: docs
tags:
- phy-scratch
before_script:
- env
- pip3 install psutil
needs: needs:
- ["compile"] - ["common:detector"]
artifacts:
paths:
- images/
- doc/
include: include:
- local: 'views/generate_prim_files.yml'
- local: 'views/view1.yml' - local: 'views/view1.yml'
- local: 'views/view2.yml' - local: 'views/view2.yml'
- local: 'views/view3.yml' - local: 'views/view3.yml'
- local: 'views/view6.yml' - local: 'views/view6.yml'
- local: 'views/view7.yml' - local: 'views/view7.yml'
- local: 'views/config.yml' - local: 'views/view11.yml'
- local: 'views/view12.yml'
- local: 'views/view13.yml'
- local: 'views/view14.yml'
- local: 'views/view15.yml'
- local: 'views/view20.yml'
dump_geometry:
stage: test
needs:
- common:detector
script:
- echo "dumping geometry"
## DEBUG
- echo "LD_LIBRARY_PATH - $LD_LIBRARY_PATH"
- echo "PATH - $PATH"
- print_env.sh
## DEBUG
- mkdir -p geo
sed -i -e '/<detectors>/,/<\/detectors>/d' ${DETECTOR_PATH}/compact/tracking_config*.xml
mv ${DETECTOR_PATH}/compact/display_geoviewer.xml ${DETECTOR_PATH}/compact/display.xml
for xml in ${DETECTOR_PATH}/compact/subsystem_views/*.xml; do
echo $xml
geo_name=`basename $xml .xml`_geo.root
cp $xml ${DETECTOR_PATH}/geo.xml
dd_web_display --output geo/${geo_name} ${DETECTOR_PATH}/geo.xml
done
## Lower-resolution display of the pfRICH sensors for global views
- sed -i 's/_default"\/>/_lores"\/>/' ${DETECTOR_PATH}/compact/pfrich.xml
## full geo with downstream beamline
- dd_web_display --output geo/detector_geo_full.root ${DETECTOR_PATH}/athena.xml
## only central detector geo
- sed -i '/forward_ion_beamline/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/beampipe_hadron_B0/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/B0_/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/far_forward_offM/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/far_forward_detectors/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/roman_pots/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/inner_vacuum_FF_magnets/d' ${DETECTOR_PATH}/athena.xml
- dd_web_display --output geo/detector_geo.root ${DETECTOR_PATH}/athena.xml
## print some useful output
echo "Geometry viewer at:"
echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all"
echo " - Central detector view at: "
echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all"
echo " - Subsystem view for `basename $xml .xml` at:"
echo " https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/${geo_name}?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all"
done
detector_documentation:
stage: docs
needs:
- common:detector
script:
- mkdir -p doc
- bash bin/build_documentation | tee doc/detector.md
# xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/athena.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee doc/detector.md
# xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/ip6/definitions.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
# for afile in ${DETECTOR_PATH}/compact/*.xml ; do
# xmllint --format --xpath '//comment/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
# done
report: report:
stage: finalize stage: finalize
needs: needs:
- view_01 - view_01
- dawn_view_02:detector - view_02
- dawn_view_03:detector - view_03
artifacts: - view_06
paths: - view_07
- images/ - view_11
- doc/ - view_12
- view_13
- view_14
- view_15
- view_20
- dump_constants
- dump_geometry
- dump_gdml
script: script:
- pip3 install jinja2 && ls -lrth - pip3 install jinja2 && ls -lrth
- ./bin/make_images > doc/dawn_views.md - ./bin/make_images > doc/dawn_views.md
- echo "Geometry viewer at https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo_full.root?job=finalize&item=default;1&opt=clipxyz;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all&"
dump_constants:
stage: test
needs:
script:
- npdet_info dump ${DETECTOR_PATH}/athena.xml | tee doc/constants.out
overlap_check_tgeo:
stage: test
needs:
script:
## disable fibers in ECAL for normal overlap check
- sed -i '/<fiber/,+6d' ${DETECTOR_PATH}/compact/ecal_barrel_interlayers.xml
- sed -i '/<fiber/,+4d' ${DETECTOR_PATH}/ip6/far_forward/ZDC_Ecal_WSciFi.xml
- checkOverlaps -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_tgeo.out
- echo "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l) overlaps..."
- if [[ "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi
overlap_check: overlap_check_geant4:full_fast:
stage: test stage: test
needs: needs:
script: script:
- checkOverlaps -c reference_detector.xml | tee doc/overlap_check.out ## disable fibers in ECAL for normal overlap check
- echo "$(cat doc/overlap_check.out | grep ovlp | wc -l) overlaps..." - sed -i '/<fiber/,+6d' ${DETECTOR_PATH}/compact/ecal_barrel_interlayers.xml
- if [[ "$(cat doc/overlap_check.out | grep ovlp | wc -l)" -gt "1" ]] ; then echo "Overlaps exist!" && false ; fi - sed -i '/<fiber/,+4d' ${DETECTOR_PATH}/ip6/far_forward/ZDC_Ecal_WSciFi.xml
## reduce the number of fibers in Hadron EMCal for overlap check
## not needed, as we are running with a different setup now
#- sed -i 's/radius="EcalEndcapP_FiberRadius"/radius="EcalEndcapP_FiberRadius*10"/' ${DETECTOR_PATH}/compact/ci_ecal_scfi.xml
- python scripts/checkOverlaps.py -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_geant4.out
- echo "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l) overlaps..."
- if [[ "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi
## TODO: add real full overlap check as child pipeline to run on branches only
overlap_check_geant4:inner_detector:
stage: test
needs:
script:
- cp ${DETECTOR_PATH}/compact/subsystem_views/inner_detector.xml ${DETECTOR_PATH}/inner_detector.xml
- python scripts/checkOverlaps.py -c ${DETECTOR_PATH}/inner_detector.xml | tee doc/overlap_check_geant4.out
dump_gdml:
stage: test
needs:
script:
- mkdir -p geo
python scripts/convert_to_gdml.py --compact ${DETECTOR_PATH}/athena.xml --output geo/athena.gdml
gdml_name=`basename $xml .xml`.gdml
python scripts/convert_to_gdml.py --compact ${DETECTOR_PATH}/geo.xml --output geo/${gdml_name}
done
tracking_geometry_debug:
stage: test
needs:
script:
- root -b -q "scripts/test_ACTS.cxx+(\"${DETECTOR_PATH}/athena.xml\")" | tee geo/tracking_geometry_debug.out
- ./bin/acts_geo_check geo/tracking_geometry_debug.out
detector:config_testing: detector:config_testing:
needs: needs:
script: script:
- checkOverlaps -c reference_detector.xml | tee doc/overlap_check.out | wc -l - checkOverlaps -o 's' -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check.out | wc -l
- cat doc/overlap_check.out - cat doc/overlap_check.out
allow_failure: true
#benchmarks:reconstruction:
# stage: deploy
# variables:
# JUGGLER_DETECTOR: "$JUGGLER_DETECTOR"
# JUGGLER_DETECTOR_VERSION: "$JUGGLER_DETECTOR_VERSION"
# trigger:
# project: EIC/benchmarks/reconstruction_benchmarks
# strategy: depend
# needs: ["env","overlap_check","report"]
#benchmarks:physics:
# stage: deploy
# variables:
# trigger:
# project: EIC/benchmarks/physics_benchmarks
# strategy: depend
benchmarks:detector:
stage: deploy
variables:
trigger:
project: EIC/benchmarks/detector_benchmarks
strategy: depend
needs:
- overlap_check_geant4:full_fast
- common:detector
cmake_minimum_required(VERSION 3.3 FATAL_ERROR) cmake_minimum_required(VERSION 3.12 FATAL_ERROR)
PROJECT(reference_detector
# CMP0074: find_package() uses <PackageName>_ROOT variables
cmake_policy(SET CMP0074 NEW)
PROJECT(athena
VERSION 0.0.1 VERSION 0.0.1
LANGUAGES CXX LANGUAGES CXX
DESCRIPTION "A template dd4hep+acts detector" DESCRIPTION "A template dd4hep+acts detector"
find_package( DD4hep REQUIRED COMPONENTS DDCore DDG4 ) set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Werror")
#find_package(Acts REQUIRED COMPONENTS Core IdentificationPlugin TGeoPlugin DD4hepPlugin PATHS /home/whit/lib/cmake NO_DEFAULT_PATH) find_package(DD4hep REQUIRED COMPONENTS DDCore DDG4)
#find_package(Acts REQUIRED COMPONENTS Core PluginIdentification PluginTGeo PluginDD4hep ) find_package(ActsDD4hep)
if(ActsDD4hep_FOUND)
add_compile_definitions(USE_ACTSDD4HEP)
set(ActsDD4hep ActsDD4hep::ActsDD4hep)
else()
find_package(Acts REQUIRED COMPONENTS Core PluginIdentification PluginTGeo PluginDD4hep)
set(ActsDD4hep ActsCore ActsPluginDD4hep)
endif()
find_package(fmt REQUIRED)
set(a_lib_name reference_detector) set(a_lib_name athena)
dd4hep_configure_output() dd4hep_configure_output()
dd4hep_add_plugin(${a_lib_name} SOURCES src/*.cpp dd4hep_add_plugin(${a_lib_name} SOURCES
# USES ActsCore ActsPluginDD4hep src/BarrelBarDetectorWithSideFrame_geo.cpp
src/BarrelCalorimeter_geo.cpp
src/BarrelCalorimeterInterlayers_geo.cpp
src/BarrelTrackerWithFrame_geo.cpp
src/CompositeTracker_geo.cpp
src/CylinderTrackerBarrel_geo.cpp
src/DIRC_geo.cpp
src/DRICH_geo.cpp
src/PFRICH_geo.cpp
src/FileLoader.cpp
src/FieldMapBrBz.cpp
src/GaseousRICH_geo.cpp
src/GeometryHelpers.cpp
src/HomogeneousCalorimeter_geo.cpp
src/HybridCalorimeter_geo.cpp
src/MRich_geo.cpp
src/PolyhedraEndcapCalorimeter2_geo.cpp
src/ScFiCalorimeter_geo.cpp
src/ShashlikCalorimeter_geo.cpp
src/SimpleDiskDetector_geo.cpp
src/SolenoidCoil_geo.cpp
src/TrapEndcapTracker_geo.cpp
USES ${ActsDD4hep}
target_link_libraries(${a_lib_name} target_link_libraries(${a_lib_name}
PUBLIC DD4hep::DDCore DD4hep::DDRec PUBLIC DD4hep::DDCore DD4hep::DDRec fmt::fmt
...@@ -28,3 +63,15 @@ install(DIRECTORY compact/ ...@@ -28,3 +63,15 @@ install(DIRECTORY compact/
DESTINATION share/${PROJECT_NAME}/${a_lib_name} DESTINATION share/${PROJECT_NAME}/${a_lib_name}
FILES_MATCHING PATTERN "*.xml" FILES_MATCHING PATTERN "*.xml"
DESTINATION share/${PROJECT_NAME}/compact
install(FILES athena.xml
# Install the detector calibration files.
install(DIRECTORY calibrations/
DESTINATION share/${PROJECT_NAME}/calibrations
Overview Overview
The reference detector at IP6 for Electron-Ion Collider experiment. The Athena Detector at IP6 for Electron-Ion Collider experiment.
**Detector geometry viewer:**
- [Central detector](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Full Detector (including beamline)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
- [Inner detector (without calorimetry)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/inner_detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- Subsystem views:
- [Calorimetry](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/calorimeters_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [PID](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/pid_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [dRICH](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/drich_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
- [pfRICH](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/pfrich_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom55;ROTY49;ROTZ350;trz0;trr0;ctrl;all&)
- [DIRC](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/dirc_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [ToF](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/tof_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom55;ROTY49;ROTZ350;trz0;trr0;ctrl;all&)
- [Tracking](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/tracking_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Vertex detector](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/vertex_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Far-forward](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/ip6_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom40;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
<a href="https://eicweb.phy.anl.gov/api/v4/projects/447/jobs/artifacts/master/raw/images/view01.pdf?job=report"> <a href="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/447/jobs/artifacts/master/raw/images/view01.png?job=report" width="600px" /> <img src="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01.png?job=report" width="400px" />
</a> </a>
<br />
<a href="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01_top.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01_top.png?job=report" width="400px" />
</a>
[Browse latest](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/browse/images?job=report)
[Detector views](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/doc/dawn_views.md?job=report)
[Constants listing](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/doc/constants.out?job=report)
Getting Started
You will likely want to use this repository along with the IP6 repository:
```bash
git clone https://eicweb.phy.anl.gov/EIC/detectors/athena.git
ln -s ../ip6/ip6 athena/ip6
### Adding/changing detector geometry
Hint: **Use the CI/CD pipelines**.
To avoid dealing with setting up all the software, we recommend using the CI/CD to make changes.
Any feedback to help this process is appreciated.
Here is how to begin:
1. Look at existing detector constructions and reuse if possible. Note that "compact detector descriptions" -> xml files, and "detector construction" -> cpp file.
2. Modify xml file or detector construction.
3. Create a WIP (or draft) merge request and look at the CI output for debugging. Then go to back to 2 if changes are needed.
4. Remove the WIP/Draft part of the merge request if you would like to see your changes merged into the master.
See:
- [Talk at computing round table](https://indico.jlab.org/event/420/#17-automated-workflow-for-end)
### Compiling (avoid it)
First, see if the use case above is best for you. It most likely is and can save a lot of time for newcomers.
To run the simulation locally, we suggest using the singularity image.
More details can be found at the links below:
- https://dd4hep.web.cern.ch/dd4hep/page/beginners-guide/
- https://eic.phy.anl.gov/tutorials/eic_tutorial/
- https://eicweb.phy.anl.gov/containers/eic_container/
Related useful links Related useful links
- [Reference_Detector_doc] (https://escalate.readthedocs.io/projects/g4e/en/latest/detector_naming.html) - [Athena_Detector_doc] (https://escalate.readthedocs.io/projects/g4e/en/latest/detector_naming.html)
- [g4e] (https://gitlab.com/eic/escalate/g4e) - [g4e] (https://gitlab.com/eic/escalate/g4e)
- [eic_tutorial] (https://argonne_eic.gitlab.io/tutorial/eic_tutorial/part2/adding_detectors/) - [eic_tutorial] (https://argonne_eic.gitlab.io/tutorial/eic_tutorial/part2/adding_detectors/)
- [DD4hep] (https://github.com/AIDAsoft/DD4hep) - [DD4hep] (https://github.com/AIDAsoft/DD4hep)
<lccdd xmlns:compact="http://www.lcsim.org/schemas/compact/1.0"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xs:noNamespaceSchemaLocation="http://www.lcsim.org/schemas/compact/1.0/compact.xsd">
<debug>
<type name="surface" value="0"/>
<type name="material" value="0"/>
<type name="readout" value="0"/>
<type name="segmentation" value="0"/>
<type name="limits" value="0"/>
<type name="region" value="0"/>
<type name="includes" value="0"/>
</debug>
<documentation level="-1">
# Athena Detector
- https://eicweb.phy.anl.gov/EIC/detectors/athena.git
- https://eicweb.phy.anl.gov/EIC/detectors/ip6.git
</documentation>
<!-- Some information about detector -->
<info name="Athena Detector" title="Athena Detector"
author="Athena Collaboration"
url="https://eicweb.phy.anl.gov/EIC/detectors/athena.git"
status="development"
version="v1 2021-03-16">
<comment> Athena </comment>
</info>
<define>
<documentation level="2">
## Main Constant Definitions
The ip6 (or other ip) defines should be included first.
These files have only a define tags.
</documentation>
<include ref="ip6/definitions.xml" />
<include ref="ip6/far_forward/fields_275.xml" />
<include ref="compact/definitions.xml" />
</define>
<includes>
<gdmlFile ref="compact/elements.xml"/>
<gdmlFile ref="compact/materials.xml"/>
<file ref="compact/optical_materials.xml"/>
</includes>
<limits>
<limitset name="EICBeamlineLimits">
<limit name="step_length_max" particles="*" value="1.0" unit="mm" />
<limit name="track_length_max" particles="*" value="1.0" unit="mm" />
<limit name="time_max" particles="*" value="0.1" unit="ns" />
<limit name="ekin_min" particles="*" value="0.001" unit="MeV" />
<limit name="range_min" particles="*" value="0.1" unit="mm" />
</limitset>
<limitset name="cal_limits">
<limit name="step_length_max" particles="*" value="5.0" unit="mm"/>
</limitset>
</limits>
<display>
<include ref="compact/colors.xml" />
<!--include ref="compact/colors2.xml"/-->
<include ref="compact/display.xml" />
<!--include ref="compact/display_detailed.xml"/-->
</display>
<documentation level="0">
## Detector Subsystems
### IP Subsystems
The interaction point subsystems are included before the central detector subsystems.
This is becuase the IP subsystems, for exmaple the beampipe, will define paramters
which are subsquently used in the central detector construction -- e.g. the vertex tracker
uses the beampipe OD to help define its placement.
The IP subsystems include the Far forward and backward regions. The list of subsystem includes:
- Interaction region beampipe
- B0 tracker
- Off-momentum tracker
- Far forward roman pots
- Zero Degree Calorimeter
- Beam line magnets.
- and more...
</documentation>
<documentation level="5">
## Main magnet
Note: When changing magnet, also select dimensions in definitions.xml.
</documentation>
<include ref="compact/solenoid.xml"/>
<documentation level="10">
## Central tracking detectors
</documentation>
<!--include ref="compact/tracking_config_acadia.xml"/-->
<!--include ref="compact/tracking_config_canyonlands.xml"/-->
<include ref="compact/tracking_config_deathvalley.xml"/>
### PID detectors
</documentation>
<!--include ref="compact/pid_config_acadia.xml" /-->
<!--include ref="compact/pid_config_canyonlands.xml" /-->
<include ref="compact/pid_config_deathvalley.xml" />
## Central calorimetry
</documentation>
<include ref="compact/ecal.xml"/>
<include ref="compact/hcal.xml"/>
<documentation level="11">
## Far foward detectors
</documentation>
<include ref="ip6/central_beampipe.xml"/>
</documentation>
<include ref="ip6/far_forward.xml"/>
## Far backward detectors
</documentation>
<include ref="ip6/far_backward.xml"/>
<comment>
FB elements
None (TODO)
What is FB?
</comment>
<readouts>
</readouts>
</lccdd>
#!/bin/bash
logfile=$1
# parse the verobse output of scripts/test_ACTS.cxx
res=0
nlines=$(grep -in error ${logfile} | grep -in D2A_ | wc -l)
if [[ "$nlines" > "0" ]] ; then
echo " ACTS geometry error: "
res="1"
fi
nlines=$(grep -in warn ${logfile} | grep -in D2A_ | wc -l)
res="1"
fi
exit ${res}
#!/bin/bash
#included files
detector_file="./athena.xml"
#filelist=$(xmllint --format --xpath '//include/@ref' ${detector_file} | sed 's/ref=\"//g' | sed 's/\"/\n/g' )
#echo $filelist
# Searches for included files two levels down
get_includes() {
local input_file="${1}"
#echo ${1}
local filelist=$(xmllint --format --xpath '//include/@ref' ${input_file} | sed 's/ref=\"//g' | sed 's/\"//g' )
for afile in $filelist ; do
xmllint --format --xpath '//include/@ref' ${input_file} &> /dev/null
local res="$?"
if [ "${res}" == "0" ] ; then
local subincluded=$(xmllint --format --xpath '//include/@ref' ${input_file} 2> /dev/null | sed 's/ref=\"//g' | sed 's/\"//g' )
filelist="${filelist} ${subincluded}"
#echo "sub include $afile"
fi
done
# <includes > <gdmlFile > <file>
local otherfiles=$(xmllint --format --xpath '//includes/file/@ref | //includes/gdmlFile/@ref' ${input_file} | sed 's/ref=\"//g' | sed 's/\"/\n/g' )
#echo $otherfiles
filelist=$(echo "${filelist} ${otherfiles}" | sed 's/ /\n/g' | sort | uniq )
echo "$input_file $filelist"
xml_files=$(get_includes ${detector_file})
#echo $xml_files
get_doc_levels() {
# levels
local levels=0
for afile in $xml_files ; do
xmllint --format --xpath '//documentation/@level' $afile &> /dev/null
local res="$?"
local new_levels=$(xmllint --format --xpath '//documentation/@level' $afile 2> /dev/null | sed 's/level=\"/ /g' | sed 's/\"//g' )
levels="${levels} ${new_levels}"
fi
# see if there are tags without level attribute
xmllint --format --xpath '//documentation[not(@level)]' $afile &> /dev/null
if [ "${?}" == "0" ] ; then
#echo "DERP"
levels="${levels} 100"
fi
done
echo "$levels" | sed 's/ /\n/g' | sort | uniq
all_levels=$(get_doc_levels ${xml_file_array})
#echo " levels: "
#echo $all_levels
for alevel in $(echo ${all_levels} | sed 's/ /\n/g' | sort -n | uniq ) ; do
#echo " doing level $alevel ..."
for afile in $(echo $xml_files | sed 's/ / \n/g') ; do
#echo $afile
#xmllint --format --xpath '//documentation[@level="'"$alevel"'"]/text()' $afile
level_doc=$(xmllint --format --xpath '//documentation[@level="'$alevel'"]' ${afile} 2> /dev/null )
if [ "$?" -eq "0" ] ; then
xmllint --format --xpath '//documentation[@level="'$alevel'"]/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/g'
fi
# sets the tags without attribute level to 100
xmllint --format --xpath '//documentation[not(@level)]/text()' ${afile} &> /dev/null
if [ "$alevel" -eq "100" ] ; then
xmllint --format --xpath '//documentation[not(@level)]/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/g'
fi
fi
done
done
#${DETECTOR_PATH}=.
#xmllint --format --xpath '//documentation/text()' ${DETECTOR_PATH}/athena.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee doc/detector.md
#xmllint --format --xpath '//documentation/text()' ${DETECTOR_PATH}/ip6/ip6_defs.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
#for afile in ${DETECTOR_PATH}/compact/*.xml ; do
# xmllint --format --xpath '//documentation/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
#done
...@@ -8,12 +8,13 @@ OUT_FILE=".DAWN_1.history" ...@@ -8,12 +8,13 @@ OUT_FILE=".DAWN_1.history"
function print_the_help { function print_the_help {
echo "USAGE: ${0} [-s <skip_events>] -d <dawn_run_dir> " echo "USAGE: ${0} [-s <skip_events>] -d <dawn_run_dir> "
echo " OPTIONS: " echo " OPTIONS: "
echo " -x targeted x coordinate position" echo " -x targeted x coordinate position"
echo " -y targeted x coordinate position" echo " -y targeted x coordinate position"
echo " -z targeted x coordinate position" echo " -z targeted x coordinate position"
echo " --theta viewing angle" echo " --theta viewing angle"
echo " --phi viewing angle" echo " --phi viewing angle"
echo " -m,--mag magnification" echo " -m,--mag magnification"
echo " --draw draw style "
echo " -d,--dawn-dir <dawn_run_dir> Directory with the .DAWN files and a generate script " echo " -d,--dawn-dir <dawn_run_dir> Directory with the .DAWN files and a generate script "
exit exit
...@@ -91,6 +92,27 @@ do ...@@ -91,6 +92,27 @@ do
shift # past argument shift # past argument
shift # past value shift # past value
--draw)
echo "updating drawing to ${2}"
sed -i '9d' ${DAWN_RUN_DIR}/${OUT_FILE}
sed -i '9i'${2} ${DAWN_RUN_DIR}/${OUT_FILE}
shift # past value
--light-theta)
sed -i '19d' ${DAWN_RUN_DIR}/${OUT_FILE}
sed -i '19i'${2} ${DAWN_RUN_DIR}/${OUT_FILE}
shift # past value
--light-phi)
sed -i '18d' ${DAWN_RUN_DIR}/${OUT_FILE}
sed -i '18i'${2} ${DAWN_RUN_DIR}/${OUT_FILE}
shift # past value
-i|--input) -i|--input)
OUT_FILE="$2" OUT_FILE="$2"
#!/bin/bash
npsim --enableG4GPS \
--compact athena.xml \
--runType vis \
--macro macro/mrich_vis.mac \
-O derp.root
#!/usr/local/bin/python
# same as make_dawn_views but stops at generating the prim file.
# W. Armstrong (ANL), original bash script
# C. Peng (ANL), translate to python and add flexible run time for simulation
import os
import signal
import subprocess
import argparse
import atexit
import time
from datetime import datetime
import fcntl
import psutil
def readline_nonblocking(output):
fd = output.fileno()
fl = fcntl.fcntl(fd, fcntl.F_GETFL)
fcntl.fcntl(fd, fcntl.F_SETFL, fl | os.O_NONBLOCK)
try:
return output.readline()
except:
return ''
# arguments
parser = argparse.ArgumentParser()
parser.add_argument('-c', '--compact-file', type=str, dest='compact',
default=os.path.join(os.environ.get('DETECTOR_PATH', '.'), 'athena.xml'),
help='Top level compact file for detectors')
parser.add_argument('-s', '--skip', type=int,
default=0,
help='Number of events number to skip in the input')
parser.add_argument('-i', '--input', type=str,
default='scripts/input_data/few_events.hepmc',
help='Input hepmc file')
parser.add_argument('-o', '--output-dir', type=str, dest='out_dir',
default='sim_output',
help='output directory')
parser.add_argument('-D', '--detector-only', action='store_true', dest='detector_only',
help='only generate the prim files for the detector geometry')
parser.add_argument('-t', '--tag', type=str,dest='file_tag',
default='view',
help='Output file tag')
parser.add_argument('--timeout', type=int,
default=3600,
help='Timeout in seconds')
parser.add_argument('passthrough', nargs='*')
args = parser.parse_args()
macro = 'macro/dawn_picture.mac' if args.detector_only else 'macro/dawn_picture2.mac'
# raise error if cannot create a temporary working dir
# os.makedirs('dawn_view_tmp', exist_ok=False)
os.makedirs(args.out_dir, exist_ok=True)
# use absolute path so the chdir does not affect them
args.input = os.path.abspath(args.input)
args.out_dir = os.path.abspath(args.out_dir)
args.compact = os.path.abspath(args.compact)
macro = os.path.abspath(macro)
# adjust fiber radius to reduce the number of fibers
compact_dir = os.path.dirname(os.path.realpath(args.compact))
ci_ecal = os.path.join(compact_dir, 'compact', 'ci_ecal_scfi.xml')
os.system('sed -i \'s/radius=\"EcalEndcapP_FiberRadius\"/radius=\"EcalEndcapP_FiberRadius*10\"/\' {}'.format(ci_ecal))
prim_file = 'g4_0000.prim'
dawn_env = os.environ.copy()
dawn_env['DAWN_BATCH'] = 'a'
# sdir = os.path.dirname(os.path.realpath(__file__))
# Using a python warpper such as npsim introduces some problem in managing the subprocess.
# The process1 managed by subprocess will generate another process with proc2_pid = proc1_pid + 1, which will not
# be terminated by terminating or killing the process1.
# In addition, running Geant4 with vis mode will never exit automatically (it waits for input).
# Thus the created process 2 will occupy the system resources.
sim_cmd = ['npsim', '--runType', 'vis',
'--compact', args.compact,
'--inputFiles', args.input,
'--outputFile', 'derp.root',
'--numberOfEvents', '1',
'--skipNEvents', str(args.skip),
'--macroFile', macro]
start = datetime.now()
elapse = datetime.now() - start
last_update = datetime.now()
finished = False
# run simulation
print(' '.join(sim_cmd))
p = subprocess.Popen(args=sim_cmd, env=dawn_env,
stdout=subprocess.PIPE, stderr=subprocess.PIPE, stdin=subprocess.PIPE)
__child_pid = p.pid
while elapse.seconds < args.timeout:
line = readline_nonblocking(p.stdout)
time_left = args.timeout - elapse.seconds
time_str = '[{:02d}:{:02d}]'.format(elapse.seconds // 60, elapse.seconds % 60)
if time_left < 10:
print('{} === TIMEOUT ===: Terminating in {:d} seconds'.format(time_str, time_left))
if line:
decoded_line = line.decode('utf-8').strip()
print('{} {}'.format(time_str, decoded_line))
# what we are looking for
if decoded_line == 'File {} is generated.'.format(prim_file):
print('{} === FINISHED ===: Got the prim file, terminating.'.format(time_str))
finished = True
break
if decoded_line == 'Idle>':
p.stdin.write(b'exit')
break
# do not sleep
continue
# ended early before file
if p.poll() is not None:
print(p.poll())
break
time.sleep(1)
p.kill()
# use to kill the subprocess generated from the python wrapper
# this is unsafe so maybe more checks required
for proc in psutil.process_iter():
pinfo = proc.as_dict(attrs=['pid', 'name', 'create_time'])
if pinfo['pid'] == p.pid + 1 and pinfo['name'] == 'python':
print('kill {}, generated from {}'.format(pinfo, p.pid))
os.kill(pinfo['pid'], signal.SIGTERM)
# revert the change
os.system('sed -i \'s/radius=\"EcalEndcapP_FiberRadius*10\"/radius=\"EcalEndcapP_FiberRadius\"/\' {}'.format(ci_ecal))
line = b'stderr outputs:\n'
while line:
print(line.decode('utf-8'), end='')
line = readline_nonblocking(p.stderr)
if finished:
print('Simulation finished')
else:
print('Simulation failed')
exit(1)
# move the prim files (which can be quite large)
# to the local pipeline storage path
os.system('mv g4_0000.prim {}/{}.prim'.format(args.out_dir,args.file_tag))
#!/bin/bash #!/usr/local/bin/python
# get dawn view of detectors
import os
import signal
import subprocess
import argparse
import atexit
import time
import fcntl
import psutil
try:
except:
return ''
# arguments
default=0,
parser.add_argument('-i', '--input', type=str, dest='input',
default='images',
parser.add_argument('-d', '--dawn-dir', type=str, dest='dawn_dir',
default='scripts/view1',
help='Directory to dawn script dir (with .DAWN files and a generate_eps script)')
default='view',
default=60,
# generate DAWN images
input_file = os.path.abspath(args.input)
#prim_file = '{}/{}.prim'.format(input_dir,args.file_tag)
#prim_file = os.path.abspath(prim_file)
owd = os.getcwd()
os.chdir(args.dawn_dir)
subprocess.run(['pwd'])
subprocess.run(['./generate_eps', '-t', args.file_tag, '-i', input_file] + args.passthrough)
subprocess.run(['ls', '-lrth'])
# upload the results
os.system('cp *.pdf {}'.format(out_dir))
os.system('cp *.png {}'.format(out_dir))
os.chdir(owd)
#git clone --depth 1 https://eicweb.phy.anl.gov/EIC/datasets.git
export DAWN_PS_PREVIEWER="ls "
export G4DAWNFILE_VIEWER="ls -lrth "
export G4DAWNFILE_PS_VIEWER="ls "
echo " OPTIONS: "
echo " -D,--detector-only Only generate the prim files for the detector geometry."
echo " -s,--skip <skip_events> Required run number"
echo " -i,--input <input_file> Input hepmc file"
echo " -t,--tag <file_tag> Output file tag"
exit
function yes_or_no {
while true; do
read -p "$* [y/n]: " yn
case $yn in
[Yy]*) return 0 ;;
[Nn]*) echo "No entered" ; return 1 ;;
esac
done
if [[ $# -eq 0 ]] ; then
print_the_help
exit
fi
SKIP_EVENTS=0
DETECTOR_ONLY=0
FILE_TAG="view"
DAWN_RUN_DIR="scripts/view1"
DETECTOR_FILE="reference_detector.xml"
POSITIONAL=()
while [[ $# -gt 0 ]]
do
key="$1"
case $key in
-h|--help)
print_the_help
-c|--compact-file)
DETECTOR_FILE="$2"
shift # past value
-s|--skip)
SKIP_EVENTS="$2"
shift # past value
-i|--input)
INPUT_FILE="$2"
shift # past value
-o|--ouput-dir)
OUTPUT_DIR="$2"
shift # past value
-D|--detector-only)
DETECTOR_ONLY=1
#shift # past value
-d|--dawn-dir)
DAWN_RUN_DIR=$2
shift # past value
-t|--tag)
FILE_TAG=$2
shift # past value
*) # unknown option
#POSITIONAL+=("$1") # save it in an array for later
echo "unknown option $1"
print_the_help
esac
done
set -- "${POSITIONAL[@]}" # restore positional parameters
rm -f *.prim
if [ "${DETECTOR_ONLY}" -eq "1" ] ; then
./scripts/run_detector_simulation.py -i scripts/input_data/few_events.hepmc \
-o derp.root -n 1 \
--ui csh --vis -b -m macro/dawn_picture.mac &
sleep 10
echo "sleeping 20 secs .. "
sleep 10
echo "sleeping 10 secs "
sleep 5
echo "sleeping 5 secs "
sleep 5
kill %1
else
echo " Running simulation for tracks"
-o derp.root -s ${SKIP_EVENTS} -n 1 \
--ui csh --vis -b -m macro/dawn_picture2.mac &
sleep 40
kill %1
fi
#./scripts/run_detector_simulation.py -i scripts/input_data/few_events.hepmc \
# -o derp.root -s 2 -n 1 \
# --ui csh --vis -b -m macro/dawn_picture2.mac &
#sleep 20
#kill %1
# -o derp.root -s 5 -n 1 \
#sleep 20
#kill %1
# -o derp.root -s 6 -n 1 \
#sleep 20
#kill %1
[[ -f "g4_0000.prim" ]] || exit -1
echo "simulating done"
#npsim --runType vis \
# -v WARNING \
# --macroFile macro/dawn_picture.mac \
# --numberOfEvents 1 \
# --compactFile topside.xml \
# --inputFiles scripts/input_data/few_events.hepmc \
# --outputFile derp.root \
# --dumpSteeringFile >> derp.out
ls -lrth
mkdir -p images
#mkdir -p images/prim
pushd ${DAWN_RUN_DIR}
./generate_eps -t ${FILE_TAG} -i ../../g4_0000.prim
else
fi
ls -lrth
cp *.pdf ../../images/.
cp *.png ../../images/.
#cp *.prim ../../images/prim/.
popd
#./generate_eps -t view1_ev2 -i ../../g4_0002.prim
#./generate_eps -t view1_ev3 -i ../../g4_0003.prim
#./generate_eps -t view1_ev4 -i ../../g4_0004.prim
#cp *.pdf ../../images/.
#cp *.png ../../images/.
#popd
#pushd scripts/view2
#./generate_eps -t view2 -i ../../g4_0000.prim
##./generate_eps -t view2_ev1 -i ../../g4_0001.prim
##./generate_eps -t view2_ev2 -i ../../g4_0002.prim
##./generate_eps -t view2_ev3 -i ../../g4_0003.prim
##./generate_eps -t view2_ev4 -i ../../g4_0004.prim
#popd
#pushd scripts/view3
#./generate_eps ../../g4_0000.prim
#popd
#pushd scripts/view4
#cp *.eps ../../images/.
#popd
#pushd scripts/view5
#popd
#pushd scripts/view6
#./generate_eps -t view6 -i ../../g4_0000.prim
##./generate_eps -t view6_ev1 -i ../../g4_0001.prim
##./generate_eps -t view6_ev2 -i ../../g4_0002.prim
##./generate_eps -t view6_ev3 -i ../../g4_0003.prim
##./generate_eps -t view6_ev4 -i ../../g4_0004.prim
#popd
#pushd scripts/view7
#./generate_eps -t view7 -i ../../g4_0000.prim
##./generate_eps -t view7_ev1 -i ../../g4_0001.prim
##./generate_eps -t view7_ev2 -i ../../g4_0002.prim
##./generate_eps -t view7_ev3 -i ../../g4_0003.prim
##./generate_eps -t view7_ev4 -i ../../g4_0004.prim
#popd
#pushd scripts/view11
#./generate_eps -t view11 -i ../../g4_0000.prim
#./generate_eps -t view11_ev1 -i ../../g4_0001.prim
##./generate_eps -t view11_ev2 -i ../../g4_0002.prim
##./generate_eps -t view11_ev3 -i ../../g4_0003.prim
##./generate_eps -t view11_ev4 -i ../../g4_0004.prim
#popd
#pushd scripts/view12
#./generate_eps -t view12 -i ../../g4_0000.prim
#./generate_eps -t view12_ev1 -i ../../g4_0001.prim
#./generate_eps -t view12_ev2 -i ../../g4_0002.prim
##./generate_eps -t view12_ev3 -i ../../g4_0003.prim
##./generate_eps -t view12_ev4 -i ../../g4_0004.prim
#popd
#pushd scripts/view13
#./generate_eps -t view13 -i ../../g4_0000.prim
#./generate_eps -t view13_ev1 -i ../../g4_0001.prim
##./generate_eps -t view13_ev2 -i ../../g4_0002.prim
##./generate_eps -t view13_ev3 -i ../../g4_0003.prim
##./generate_eps -t view13_ev4 -i ../../g4_0004.prim
#popd
...@@ -7,9 +7,15 @@ env = Environment( ...@@ -7,9 +7,15 @@ env = Environment(
autoescape=select_autoescape(['html', 'xml']) autoescape=select_autoescape(['html', 'xml'])
import os
import glob import glob
base_url = "https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw" if "CI_PROJECT_ID" in os.environ:
CI_PROJECT_ID = str(os.environ["CI_PROJECT_ID"])
else:
CI_PROJECT_ID = "473"
base_url = f"https://eicweb.phy.anl.gov/api/v4/projects/{CI_PROJECT_ID}/jobs/artifacts/master/raw"
#images = ["images/view2a.png","images/view2b.png", "images/view1.png"] #images = ["images/view2a.png","images/view2b.png", "images/view1.png"]
images = glob.glob("images/*.png") images = glob.glob("images/*.png")
#!/bin/bash
echo "USAGE: --ebeam E --pbeam E -c compact.xml"
echo "REQUIRED ARGUMENTS:"
echo " -h|--help Print this message"
echo " --ebeam Electron beam energy (5, 10 or 18)"
echo " --pbeam Ion beam energy (41, 100 or 275)"
echo " -c|--compact Compact file to set beam energy for"
exit
EBEAM=
PBEAM=
COMPACT=
while [ $# -gt 0 ]
do
key="$1"
case $key in
-h|--help)
print_the_help
--ebeam)
EBEAM=$2
shift
shift
--pbeam)
PBEAM=$2
shift
shift
-c|--compact)
COMPACT=$2
shift
shift
*) # unknown option
echo "unknown option"
exit 1
esac
done
echo "Setting beam energies to $EBEAM on $PBEAM for $COMPACT"
if [ -z $COMPACT ]; then
echo "Error: no compact file given, use -h for help"
exit 1
fi
if [ -z $EBEAM ]; then
echo "Error: --ebeam argument missing, use -h for help"
exit 1
fi
if [ -z $PBEAM ]; then
echo "Error: --pbeam argument missing, use -h for help"
exit 1
fi
if [[ $PBEAM != "41" && $PBEAM != "100" && $PBEAM != "275" ]]; then
echo "Error: Ion beam energy should be 41, 100, or 275 GeV"
exit 1
fi
if [[ $EBEAM != 5 && $EBEAM != 10 && $EBEAM != 18 ]]; then
echo "Error: Electron beam energy should be 5, 10, or 18 GeV"
exit 1
fi
if [ ! -f ${COMPACT} ]; then
echo "Error: Compact file ${COMPACT} does not exist"
exit 1
fi
sed -i "s?far_forward_fields_.\{2,3\}.xml?far_forward_fields_${PBEAM}.xml?" athena.xml
sed -i "s?far_backward_fields_.\{1,2\}.xml?far_backward_fields_${EBEAM}.xml?" athena.xml
## Calibrations for the ATHENA detector
Calibrations and constants for this ATHENA detector setup. These values are used in the
reconstruction. Each relevant subsystem that requires calibration data should have
its own subdirectory with relevant calibration files, preferably in JSON format.
Note that these calibrations are strongly versioned and tied directy to this specific
detector configuration. Therefore, please do not add an extra layer of versioning in the
file names, but rather only add those calibrations relevant for this particular setup.
"ecal_neg_endcap": {
"readout": "module",
"dynamicRange": "20*GeV",
"capacityBitsADC": 14,
"pedestalMean": 100,
"pedestalSigma": 1,
"thresholdValue": 3
"hcal_neg_endcap": {
"readout": "tile",
"dynamicRange": "20*MeV",
"capacityBitsADC": 8,
"pedestalMean": 20,
"pedestalSigma": 0.3,
"thresholdValue": 1
"ecal_pos_endcap": {
"dynamicRange": "3*GeV",
"pedestalSigma": 0.7,
"thresholdValue": 2
"hcal_pos_endcap": {
"readout": "tile",
"dynamicRange": "3.6*GeV",
"capacityBitsADC": 10,
"pedestalMean": 20,
"pedestalSigma": 0.8,
"thresholdValue": 3
"ecal_barrel_imaging": {
"readout": "pixel",
"dynamicRange": "3*MeV",
"capacityBitsADC": 13,
"pedestalSigma": 14,
"thresholdValue": 50
"ecal_barrel_scfi": {
"readout": "light_guide",
"dynamicRange": "750*MeV",
"pedestalMean": 20,
"thresholdValue": 1
"hcal_barrel": {
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 1
"pedestalSigma": 1,
"thresholdValue": 3
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 1
"thresholdValue": 2
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 3
"readout": "pixel",
"pedestalMean": 20,
"thresholdValue": 1
"hcal_barrel": {
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 1
calo_digi_canyonlands.json
\ No newline at end of file
File added
"electron": {
"particle_name": "electron",
"sampling_fraction": 0.1053739677993623,
"sampling_fraction_error": 0.00014385360879111712,
"sampling_fraction_error_img": 7.262477989358573e-05,
"sampling_fraction_error_scfi": 0.0001238835428684493,
"sampling_fraction_img": 0.006008855583640059,
"sampling_fraction_scfi": 0.09940809338992981,
"thrown_energy": 5.000000028019361
"ffi_zdc_ecal": {
"sampling_fraction": 1.0,
"minClusterCenterEdep": "3.*MeV",
"minClusterHitEdep": "0.1*MeV",
"localDistXY": ["50*mm", "50*mm"],
"splitCluster": true
"ffi_zdc_hcal": {
"minClusterCenterEdep": "1.*MeV",
"localDistXY": ["200*mm", "200*mm"],
"splitCluster": false
