Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
A
athena
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package Registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
Subhadip Pal
athena
Commits
fdfdd14d
Commit
fdfdd14d
authored
3 years ago
by
Sylvester Joosten
Browse files
Options
Downloads
Patches
Plain Diff
Updated negative endcap to use all available space
parent
6f3b4039
No related branches found
No related tags found
No related merge requests found
Changes
3
Hide whitespace changes
Inline
Side-by-side
Showing
3 changed files
.gitlab-ci.yml
+1
-0
1 addition, 0 deletions
.gitlab-ci.yml
compact/definitions.xml
+13
-21
13 additions, 21 deletions
manifest.txt
+0
-169
0 additions, 169 deletions
manifest.txt
with
14 additions
and
190 deletions
.gitlab-ci.yml
1
0
View file @
fdfdd14d
@@ -6,6 +6,7 @@ workflow:
if
$CI_PIPELINE_SOURCE
"web"'
if
$CI_PIPELINE_SOURCE
"web"'
if
$CI_PIPELINE_SOURCE
"webide"'
if
$CI_PIPELINE_SOURCE
"webide"'
if
$CI_COMMIT_BRANCH
"master"'
if
$CI_COMMIT_BRANCH
"master"'
if
$CI_COMMIT_BRANCH
"acadia"'
if
$CI_COMMIT_TAG'
if
$CI_COMMIT_TAG'
default
default
This diff is collapsed.
13
21
View file @
fdfdd14d
@@ -331,7 +331,7 @@ Examples:
<!--constant name="BackwardPID_rmax" value="83.65*cm"/-->
<constant
name=
"BackwardPID_rmax"
value=
"95.*cm"
<constant
name=
"BackwardPID_rmax"
value=
"95.*cm"
<constant
name=
"BackwardPID_length"
value=
"40.0*cm"
<constant
name=
value=
"40.0*cm"
<constant
name=
"BackwardTracking_length"
value=
5
.0*cm"
<constant
name=
value=
68
.0*cm"
<constant
name=
"BackwardTOF_length"
value=
"0.0*cm"
<constant
name=
value=
"0.0*cm"
<comment>
Note: PID has space for DIRC, ExtraSpace has room for other detectors past the PID
</comment>
<comment>
</comment>
@@ -393,19 +393,8 @@ Examples:
`TrackerBarrelForwardPadding` and `TrackerBarrelBackwardPadding` compensate for the asymmetry of the setup
</documentation>
</documentation>
<constant
name=
"TrackerBarrelForwardPadding"
value=
"25.0*cm"
<constant
name=
value=
"25.0*cm"
<constant
name=
"TrackerBarrelBackwardPadding"
value=
"7.
5
*cm"
<constant
name=
value=
"7.
0
*cm"
<comment>
Deprecated
constant name="SiliconTrackerInnerRadius" value="TrackerBarrel_rmin"
constant name="SiliconTrackerInnerBarrelLength" value="TrackerBarrelInner_length"
constant name="SiliconTrackerOuterRadius" value="TrackerBarrel_rmax"
constant name="SiliconTrackerOuterBarrelLength" value="TrackerBarrelOuter_length"
constant name="SiliconTrackerOuterBarrel_zmax" value="TrackerBarrelOuter_length/2.0"
TrackerBarrelOuter_length -> TrackerBarrel_length
TrackerBarrelInner_length -> TrackerBarrelInside_length
</comment>
<documentation>
<documentation>
## Central tracking and PID detector boundaries
@@ -562,17 +551,20 @@ The logic goes like this:
<!--constant name="EcalEndcapNThickness"
value="EcalEndcapNLayer1_NRepeat*EcalLayer1_thickness + EcalEndcapNLayer2_NRepeat*EcalLayer2_thickness + EcalEndcapNLayer3_NRepeat*EcalLayer3_thickness"/-->
<constant
name=
"EcalBarrel_length"
value=
"CentralTracking_length + BackwardInnerEndcap_length + EcalEndcapN_length"
<constant
name=
"EcalBarrelForward_length"
value=
"4*cm"
<constant
name=
"EcalBarrel_offset"
value=
"(CentralTracking_length - EcalBarrel_length)/2.0"
<constant
name=
"EcalBarrelForward_zmax"
value=
"CentralTrackingHalfP_length + EcalBarrelForward_length"
<constant
name=
"EcalBarrelBackward_zmax"
value=
"CentralTrackingHalfN_length + BackwardInnerEndcap_length + EcalEndcapN_length"
<constant
name=
"EcalBarrel_length"
value=
"EcalBarrelForward_zmax + EcalBarrelBackward_zmax"
<constant
name=
"EcalBarrel_offset"
value=
"(EcalBarrelForward_zmax - EcalBarrelBackward_zmax)/2.0"
<comment>
Special DIRC parameters (depend on the ECAL setup)
</comment>
<comment>
</comment>
<constant
name=
"DIRCReadout_length"
value=
"30*cm"
<constant
name=
value=
"30*cm"
<constant
name=
"DIRC_length"
value=
"max(CentralTracking_length + BackwardInnerEndcap_length + EcalEndcapN_length, EcalBarrel_length) + DIRCReadout_length
<constant
name=
"DIRC
Forward
_length"
value=
"0*cm
<constant
name=
"DIRC
Extra_offset
value=
-5*cm
<constant
name=
"DIRC
Forward_zmax
value=
CentralTrackingHalfP_length + DIRCForward_length
<constant
name=
"DIRC
_offset"
value=
- DIRC_length) / 2 - DIRCExtra_offset
<constant
name=
"DIRC
Backward_zmax"
value=
"CentralTracking
HalfN
_length
+ BackwardInnerEndcap_length + EcalEndcapN_length + DIRCReadout_length
<constant
name=
"DIRC
Forward_zmax"
value=
"DIRC
_length/2. + DIRC_offset
<constant
name=
"DIRC
_length"
value=
"DIRC
Forward_zmax + DIRCBackward_zmax
<constant
name=
"DIRC
Backward_zmax"
value=
"DIRC
_length/2. - DIRC_offset
<constant
name=
"DIRC
_offset"
value=
DIRC
Forward_zmax - DIRCBackward_zmax)/2
<constant
name=
"DIRC_rmin"
value=
"BarrelTracking_rmax"
<constant
name=
"DIRC_rmin"
value=
<constant
name=
"DIRC_rmax"
value=
"DIRC_rmin + BarrelPIDThickness"
<constant
name=
"DIRC_rmax"
value=
manifest.txt
deleted
100644 → 0
0
169
View file @
6f3b4039
B0Tracker_zmin = 540.000 = B0TrackerCenter_zpos - B0Tracker_length/2.0
BackwardPID_rmax = 95.000 = 95.*cm
BarrelTrackingAndPID_rmax = 105.000 = BarrelTracking_rmax + BarrelPIDThickness
BarrelTracking_rmax = 95.000 = TrackerBarrel_rmax
BarrelTracking_zmax = 130.000 = BarrelTracking_length/2.0
Barrel_rmax = 159.000 = Solenoid_rmin - 1.0 *cm
Beampipe_rmax = 3.176 = IPBeampipe_rmax
CentralTracking_rmax = 95.000 = TrackerBarrel_rmax
DIRCBackward_zmax = 276.250 = DIRC_length/2. - DIRC_offset
DIRCForward_zmax = 151.250 = DIRC_length/2. + DIRC_offset
DIRCFrame_rmax = 99.000 = DIRC_rmin + DIRCFrame_thickness
DIRCModule_rmax = 97.200 = DIRC_rmin + DIRCBar_thickness + DIRCSkinFront_thickness + DIRCSkinBack_thickness
DIRCModule_rmin = 96.000 = DIRC_rmin + 1*cm
DIRC_rmax = 105.000 = DIRC_rmin + BarrelPIDThickness
DIRC_rmin = 95.000 = BarrelTracking_rmax
DRICH_rmax0 = 110.000 = 110.0*cm
DRICH_rmax1 = 125.000 = 125.0*cm
DRICH_rmax2 = 200.000 = 200*cm
DRICH_rmin0 = 11.176 = ForwardPID_rmin1
DRICH_rmin1 = 19.000 = 19.0*cm
DRICH_zmin = 155.000 = CentralTrackingHalfP_length
EcalBarrel_rmax = 151.272 = EcalBarrel_rmin + EcalBarrelThickness
EcalBarrel_rmin = 112.000 = BarrelTrackingAndPID_rmax + BarrelExtraSpaceThickness
EcalEndcapNCrystal_rmax = 40.000 = 40*cm
EcalEndcapN_rmax = 95.000 = BarrelTracking_rmax
EcalEndcapN_rmin = 7.526 = max((EcalEndcapN_zmin + EcalEndcapN_length) * tan(abs(CrossingAngle)) + 12.5 * mm, 5*cm)
EcalEndcapN_zmin = 191.000 = max(CentralTrackingHalfN_length+ BackwardInnerEndcap_length, SolenoidYokeEndcapN_zmin)
EcalEndcapP_rmax = 224.000 = Solenoid_rmax
EcalEndcapP_rmin = 20.000 = 200.0*mm
EcalEndcapP_zmin = 350.000 = CentralTrackingHalfP_length + ForwardInnerEndcap_length + ForwardServiceGap_length
ForwardPID_rmin1 = 11.176 = Beampipe_rmax + 80*mm
ForwardPID_rmin2 = 19.000 = 19.0*cm
GEMTrackerEndcapN_rmax = 94.500 = TrackerBarrel_rmax - 0.5*cm
GEMTrackerEndcapN_rmin = 15.000 = 15*cm
GEMTrackerEndcapN_zmin = 177.500 = CentralTrackingHalfN_length + BackwardPID_length
GEMTrackerEndcapP_rmax = 223.500 = Solenoid_rmax - 0.5*cm
GEMTrackerEndcapP_rmin = 19.000 = 19*cm
GEMTrackerEndcapP_zmin = 335.000 = CentralTrackingHalfP_length + ForwardPID_length
HcalBarrel_rmax = 324.000 = HcalBarrel_rmin + HcalBarrel_thickness
HcalBarrel_rmin = 224.000 = Solenoid_rmax
HcalEndcapN_rmin = 12.008 = max((HcalEndcapN_zmin + HcalEndcapN_length) * tan(abs(CrossingAngle)) + 22.25 * mm, 11 * cm)
HcalEndcapN_zmin = 286.250 = DIRCBackward_zmax + BackwardServiceGap_length
HcalEndcapP_rmin = 28.698 = max((HcalEndcapP_zmin + HcalEndcapP_length) * tan(2.0 * abs(CrossingAngle)) + BeampipeOD / 2.0, 15 * cm)
HcalEndcapP_zmin = 390.000 = max(EcalEndcapP_zmin + EcalEndcapP_length, Solenoid_length / 2.0 + Solenoid_offset)
IPBeampipe_rmax = 3.176 = 2.501*25.4*mm/2.0
MRICH_rmax = 95.000 = BackwardPID_rmax
MRICH_rmin = 10.000 = 10*cm
MRICH_zmin = 137.500 = CentralTrackingHalfN_length
SolenoidBarrelCoilFormer_rmax = 174.500 = SolenoidBarrelCoilFormer_rmin + SolenoidBarrelCoilFormerThickness
SolenoidBarrelCoilFormer_rmin = 169.500 = SolenoidBarrelInnerHelium_rmax
SolenoidBarrelCoilFormer_zmax = 180.000 = 1800.0 * mm
SolenoidBarrelCoilOverbind_rmax = 214.500 = SolenoidBarrelCoilOverbind_rmin + SolenoidBarrelCoilOverbindThickness
SolenoidBarrelCoilOverbind_rmin = 194.500 = SolenoidBarrelCoil_rmax
SolenoidBarrelCoilOverbind_zmax = 180.000 = 1800.0 * mm
SolenoidBarrelCoil_rmax = 194.500 = SolenoidBarrelCoil_rmin + SolenoidBarrelCoilThickness
SolenoidBarrelCoil_rmin = 174.500 = SolenoidBarrelCoilFormer_rmax
SolenoidBarrelCoil_zmax = 180.000 = 1800.0 * mm
SolenoidBarrelInnerFirstMLILayer_rmax = 166.500 = SolenoidBarrelInnerFirstMLILayer_rmin + SolenoidBarrelInnerFirstMLILayerThickness
SolenoidBarrelInnerFirstMLILayer_rmin = 165.000 = SolenoidBarrelInnerThermalShield_rmax
SolenoidBarrelInnerFirstMLILayer_zmax = 185.500 = 1855.0 * mm
SolenoidBarrelInnerHeliumVessel_rmax = 168.500 = SolenoidBarrelInnerHeliumVessel_rmin + SolenoidBarrelInnerHeliumVesselThickness
SolenoidBarrelInnerHeliumVessel_rmin = 166.500 = SolenoidBarrelInnerFirstMLILayer_rmax
SolenoidBarrelInnerHeliumVessel_zmax = 184.000 = 1840.0 * mm
SolenoidBarrelInnerHelium_rmax = 169.500 = SolenoidBarrelInnerHelium_rmin + SolenoidBarrelInnerHeliumThickness
SolenoidBarrelInnerHelium_rmin = 168.500 = SolenoidBarrelInnerHeliumVessel_rmax
SolenoidBarrelInnerHelium_zmax = 182.000 = 1820.0 * mm
SolenoidBarrelInnerSecondMLILayer_rmax = 164.000 = SolenoidBarrelInnerSecondMLILayer_rmin + SolenoidBarrelInnerSecondMLILayerThickness
SolenoidBarrelInnerSecondMLILayer_rmin = 162.000 = SolenoidBarrelInnerVacuumVessel_rmax
SolenoidBarrelInnerSecondMLILayer_zmax = 189.500 = 1895.0 * mm
SolenoidBarrelInnerThermalShield_rmax = 165.000 = SolenoidBarrelInnerThermalShield_rmin + SolenoidBarrelInnerThermalShieldThickness
SolenoidBarrelInnerThermalShield_rmin = 164.000 = SolenoidBarrelInnerSecondMLILayer_rmax
SolenoidBarrelInnerThermalShield_zmax = 187.500 = 1875.0 * mm
SolenoidBarrelInnerVacuumVessel_rmax = 162.000 = SolenoidBarrelInnerVacuumVessel_rmin + SolenoidBarrelInnerVacuumVesselThickness
SolenoidBarrelInnerVacuumVessel_rmin = 160.000 = SolenoidBarrel_rmin
SolenoidBarrelInnerVacuumVessel_zmax = 192.000 = 1920.0 * mm
SolenoidBarrelOuterFirstMLILayer_rmax = 218.500 = SolenoidBarrelOuterFirstMLILayer_rmin + SolenoidBarrelOuterFirstMLILayerThickness
SolenoidBarrelOuterFirstMLILayer_rmin = 217.000 = SolenoidBarrelOuterHeliumVessel_rmax
SolenoidBarrelOuterFirstMLILayer_zmax = 185.500 = 1855.0 * mm
SolenoidBarrelOuterHeliumVessel_rmax = 217.000 = SolenoidBarrelOuterHeliumVessel_rmin + SolenoidBarrelOuterHeliumVesselThickness
SolenoidBarrelOuterHeliumVessel_rmin = 216.000 = SolenoidBarrelOuterHelium_rmax
SolenoidBarrelOuterHeliumVessel_zmax = 184.000 = 1840.0 * mm
SolenoidBarrelOuterHelium_rmax = 216.000 = SolenoidBarrelOuterHelium_rmin + SolenoidBarrelOuterHeliumThickness
SolenoidBarrelOuterHelium_rmin = 214.500 = SolenoidBarrelCoilOverbind_rmax
SolenoidBarrelOuterHelium_zmax = 182.000 = 1820.0 * mm
SolenoidBarrelOuterSecondMLILayer_rmax = 221.500 = SolenoidBarrelOuterSecondMLILayer_rmin + SolenoidBarrelOuterSecondMLILayerThickness
SolenoidBarrelOuterSecondMLILayer_rmin = 219.500 = SolenoidBarrelOuterThermalShield_rmax
SolenoidBarrelOuterSecondMLILayer_zmax = 189.500 = 1895.0 * mm
SolenoidBarrelOuterThermalShield_rmax = 219.500 = SolenoidBarrelOuterThermalShield_rmin + SolenoidBarrelOuterThermalShieldThickness
SolenoidBarrelOuterThermalShield_rmin = 218.500 = SolenoidBarrelOuterFirstMLILayer_rmax
SolenoidBarrelOuterThermalShield_zmax = 187.500 = 1875.0 * mm
SolenoidBarrelOuterVacuumVessel_rmax = 224.000 = SolenoidBarrelOuterVacuumVessel_rmin + SolenoidBarrelOuterVacuumVesselThickness
SolenoidBarrelOuterVacuumVessel_rmin = 221.500 = SolenoidBarrelOuterSecondMLILayer_rmax
SolenoidBarrelOuterVacuumVessel_zmax = 192.000 = 1920.0 * mm
SolenoidBarrel_rmin = 160.000 = Solenoid_rmin
SolenoidBarrel_zmax = 192.000 = Solenoid_length/2.0
SolenoidEndcapCoilEndSupport_rmax = 214.500 = SolenoidBarrelCoilOverbind_rmax
SolenoidEndcapCoilEndSupport_rmin = 169.500 = SolenoidBarrelCoilFormer_rmin
SolenoidEndcapCoilEndSupport_zmin = 180.000 = 1800.0 * mm
SolenoidEndcapFirstMLILayer_rmax = 218.500 = SolenoidBarrelOuterFirstMLILayer_rmax
SolenoidEndcapFirstMLILayer_rmin = 165.000 = SolenoidBarrelInnerFirstMLILayer_rmin
SolenoidEndcapFirstMLILayer_zmin = 185.500 = 1855.0 * mm
SolenoidEndcapHeliumVessel_rmax = 217.000 = SolenoidBarrelOuterHeliumVessel_rmax
SolenoidEndcapHeliumVessel_rmin = 166.500 = SolenoidBarrelInnerHeliumVessel_rmin
SolenoidEndcapHeliumVessel_zmin = 184.000 = 1840.0 * mm
SolenoidEndcapHelium_rmax = 216.000 = SolenoidBarrelOuterHelium_rmax
SolenoidEndcapHelium_rmin = 168.500 = SolenoidBarrelInnerHelium_rmin
SolenoidEndcapHelium_zmin = 182.000 = 1820.0 * mm
SolenoidEndcapSecondMLILayer_rmax = 219.500 = SolenoidBarrelOuterSecondMLILayer_rmin
SolenoidEndcapSecondMLILayer_rmin = 164.000 = SolenoidBarrelInnerSecondMLILayer_rmax
SolenoidEndcapSecondMLILayer_zmin = 187.500 = 1875.0 * mm
SolenoidEndcapThermalShield_rmax = 218.500 = SolenoidBarrelOuterThermalShield_rmin
SolenoidEndcapThermalShield_rmin = 165.000 = SolenoidBarrelInnerThermalShield_rmax
SolenoidEndcapThermalShield_zmin = 186.500 = 1865.0 * mm
SolenoidEndcapVacuumVessel_rmax = 221.500 = SolenoidBarrelOuterVacuumVessel_rmin
SolenoidEndcapVacuumVessel_rmin = 162.000 = SolenoidBarrelInnerVacuumVessel_rmax
SolenoidEndcapVacuumVessel_zmin = 189.500 = 1895.0 * mm
SolenoidYokeEndcapN_zmin = 191.000 = Solenoid_length/2.0 - Solenoid_offset + EndcapNExtra_length
SolenoidYokeEndcapP_zmin = 233.000 = Solenoid_length/2.0 + Solenoid_offset + EndcapPExtra_length
Solenoid_rmax = 224.000 = Solenoid_rmin + Solenoid_thickness
Solenoid_rmin = 160.000 = 1600.0*mm
TrackerBarrelInner_rmin1 = 21.000 = 21.0*cm
TrackerBarrelInner_rmin2 = 22.680 = 22.68*cm
TrackerBarrelInside_zmax = 30.000 = TrackerBarrelInside_length/2.0
TrackerBarrelOuter_rmin1 = 39.300 = 39.3*cm
TrackerBarrelOuter_rmin2 = 43.230 = 43.23*cm
TrackerBarrel_rmax = 95.000 = BackwardPID_rmax
TrackerBarrel_rmin = 20.000 = VertexTrackingRegion_rmax
TrackerBarrel_zmax = 130.000 = TrackerBarrel_length/2.0
TrackerEndcapInner_rmax1 = 35.760 = 36.26*cm-5.0*mm
TrackerEndcapInner_rmin1 = 4.176 = Beampipe_rmax+1.0*cm
TrackerEndcapInner_zmax = 51.000 = TrackerEndcapInner_zmin+TrackerEndcapLayer_dz
TrackerEndcapInner_zmin = 49.000 = 49*cm
TrackerEndcapOuterShell_zmin = 60.236 = TrackerEndcapOuter_rmax1 * TrackerEndcapInner_zmin/TrackerEndcapInner_rmax1+1*cm
TrackerEndcapOuter_rmax1 = 43.230 = 43.23*cm
TrackerEndcapOuter_rmax2 = 43.230 = 43.23*cm
TrackerEndcapOuter_rmax3 = 43.230 = 43.23*cm
TrackerEndcapOuter_rmin1 = 3.600 = 3.6*cm
TrackerEndcapOuter_rmin2 = 4.700 = 4.7*cm
TrackerEndcapOuter_rmin3 = 5.910 = 5.91*cm
TrackerEndcapOuter_zmax = 123.000 = TrackerEndcapOuter_zmin3 + TrackerEndcapLayer_dz
TrackerEndcapOuter_zmin = 73.000 = TrackerEndcapOuter_zmin1
TrackerEndcapOuter_zmin1 = 73.000 = 73*cm
TrackerEndcapOuter_zmin2 = 97.000 = 97*cm
TrackerEndcapOuter_zmin3 = 121.000 = 121*cm
VertexBarrelLayer_rmax1 = 3.500 = VertexBarrelLayer_rmin1 + VertexBarrelLayer_thickness
VertexBarrelLayer_rmax2 = 5.800 = VertexBarrelLayer_rmin2 + VertexBarrelLayer_thickness
VertexBarrelLayer_rmin1 = 3.300 = VertexBarrelMod1_rmin - VertexBarrelLayer_thickness/2.0
VertexBarrelLayer_rmin2 = 5.600 = VertexBarrelMod2_rmin - VertexBarrelLayer_thickness/2.0
VertexBarrelMod1_rmin = 3.400 = 3.4*cm
VertexBarrelMod2_rmin = 5.700 = 5.7*cm
VertexBarrelShell_rmax = 10.030 = VertexBarrelShell_rmin + VertexBarrelShell_thickness
VertexBarrelShell_rmin = 10.000 = 10.0*cm
VertexBarrelSupport_rmax = 10.500 = VertexBarrelSupport_rmin + VertexBarrelSupport_thickness
VertexBarrelSupport_rmin = 9.500 = VertexBarrelShell_rmin-VertexBarrelSupport_thickness/2.0
VertexTrackerBarrel_rmax = 20.000 = 200.0*mm
VertexTrackerBarrel_rmin = 3.276 = Beampipe_rmax + 1.0*mm
VertexTrackerBarrel_zmax = 15.000 = VertexTrackerBarrel_length/2.0
VertexTrackerEndcapN_rmax = 20.000 = VertexTrackerBarrel_rmax
VertexTrackerEndcapN_rmin = 3.676 = Beampipe_rmax + 5.0*mm
VertexTrackerEndcapN_zmax = 30.000 = 300.0*mm
VertexTrackerEndcapN_zmin = 15.000 = VertexTrackerBarrel_zmax
VertexTrackerEndcapP_rmax = 20.000 = VertexTrackerBarrel_rmax
VertexTrackerEndcapP_rmin = 3.676 = Beampipe_rmax + 5.0*mm
VertexTrackerEndcapP_zmax = 30.000 = 300.0*mm
VertexTrackerEndcapP_zmin = 15.000 = VertexTrackerBarrel_zmax
VertexTrackingRegion_rmax = 20.000 = VertexTrackerBarrel_rmax
VertexTrackingRegion_zmax = 30.000 = VertexTrackerEndcapP_zmax
tracker_region_rmax = 95.000 = CentralTracking_rmax
tracker_region_zmax = 146.250 = CentralTracking_length/2.0
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
