Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
A
athena
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package Registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
Subhadip Pal
athena
Commits
f2821b0b
Commit
f2821b0b
authored
3 years ago
by
Sylvester Joosten
Browse files
Options
Downloads
Patches
Plain Diff
Resolve "Negative endcap (HCAL) geometry"
parent
8e8feb61
No related branches found
No related tags found
No related merge requests found
Changes
4
Hide whitespace changes
Inline
Side-by-side
Showing
4 changed files
compact/definitions.xml
+10
-6
10 additions, 6 deletions
compact/display.xml
+5
-0
5 additions, 0 deletions
compact/display.xml
compact/display_geoviewer.xml
+5
-0
compact/hcal.xml
+21
-2
21 additions, 2 deletions
compact/hcal.xml
with
41 additions
and
8 deletions
10
6
View file @
f2821b0b
@@ -190,6 +190,7 @@ The unused IDs below are saved for future use.
<constant
name=
"HCalBarrel_ID"
value=
"111"
<constant
name=
"HCalBarrel_ID"
value=
"111"
<constant
name=
"HCalEndcapP_ID"
value=
"112"
<constant
name=
"HCalEndcapP_ID"
value=
"112"
<constant
name=
"HCalEndcapN_ID"
value=
"113"
<constant
name=
"HCalEndcapN_ID"
value=
"113"
<constant
name=
"PassiveSteelRingEndcapP_ID"
value=
"114"
<documentation>
<documentation>
#### (120-129) (near) Forward reserved
@@ -423,9 +424,10 @@ Service gaps in FW direction (before endcapP ECAL) and BW direction (before endc
<constant
name=
"EcalEndcapP_zmin"
value=
"ForwardPIDRegion_zmin + ForwardInnerEndcapRegion_length + ForwardServiceGap_length"
<constant
name=
"EcalEndcapP_zmin"
value=
<constant
name=
"EcalEndcapP_length"
value=
"30*cm"
<constant
name=
value=
"30*cm"
<constant
name=
"EcalEndcapP_rmin"
value=
"200.0*mm"
<constant
name=
"EcalEndcapP_rmin"
value=
"200.0*mm"
<constant
name=
"EcalEndcapP_rmax"
value=
"Solenoid_rmax "
<comment>
extra 50cm rmax that "protrudes" into the HCAL
</comment>
<constant
name=
"EcalEndcapP_rmax"
value=
"Solenoid_rmax + 50*cm"
<constant
name=
"EcalEndcapN_zmin"
value=
max(
BackwardPIDRegion_zmin + BackwardInnerEndcapRegion_length
, SolenoidBackward_zmax)
<constant
name=
"EcalEndcapN_zmin"
value=
"BackwardPIDRegion_zmin + BackwardInnerEndcapRegion_length"
<constant
name=
"EcalEndcapN_length"
value=
"60*cm"
<constant
name=
value=
"60*cm"
<constant
name=
"EcalEndcapN_rmin"
value=
"max((EcalEndcapN_zmin + EcalEndcapN_length) * tan(abs(CrossingAngle)) + 15.5 * mm, 5*cm)"
<constant
name=
"EcalEndcapN_rmin"
value=
<constant
name=
"EcalEndcapN_rmax"
value=
"CentralTrackingRegion_rmax"
<constant
name=
"EcalEndcapN_rmax"
value=
@@ -436,6 +438,7 @@ Service gaps in FW direction (before endcapP ECAL) and BW direction (before endc
<constant
name=
"EcalBarrelBackward_zmax"
value=
"EcalEndcapN_zmin + 30*cm"
<constant
name=
value=
<constant
name=
"EcalBarrel_length"
value=
"EcalBarrelForward_zmax + EcalBarrelBackward_zmax"
<constant
name=
"EcalBarrel_length"
value=
<constant
name=
"EcalBarrel_offset"
value=
"(EcalBarrelForward_zmax - EcalBarrelBackward_zmax)/2.0"
<constant
name=
"EcalBarrel_offset"
value=
<constant
name=
"EcalBarrelReadout_length"
value=
"20*cm"
<documentation
level=
"3"
<documentation
level=
"3"
@@ -443,8 +446,8 @@ Service gaps in FW direction (before endcapP ECAL) and BW direction (before endc
</documentation>
</documentation>
<constant
name=
"DIRCReadout_length"
value=
"30*cm"
<constant
name=
value=
"30*cm"
<constant
name=
"DIRCForward_length"
value=
"0*cm"
<constant
name=
value=
"0*cm"
<constant
name=
"DIRCForward_zmax"
value=
ForwardPIDRegion_zmin + DIRCForward_length
<constant
name=
"DIRCForward_zmax"
value=
<constant
name=
"DIRCBackward_zmax"
value=
BackwardPIDRegion
_zm
in
BackwardInnerEndcapRegion_length + EcalEndcapN
_length +
DIRCReadout_length"
<constant
name=
"DIRCBackward_zmax"
value=
EcalBarrelBackward
_zm
ax
EcalBarrelReadout
_length +DIRCReadout_length
<constant
name=
"DIRC_length"
value=
"DIRCForward_zmax + DIRCBackward_zmax"
<constant
name=
"DIRC_length"
value=
<constant
name=
"DIRC_offset"
value=
"(DIRCForward_zmax - DIRCBackward_zmax)/2"
<constant
name=
"DIRC_offset"
value=
<constant
name=
"DIRC_rmin"
value=
<constant
name=
"DIRC_rmin"
value=
@@ -459,7 +462,7 @@ Service gaps in FW direction (before endcapP ECAL) and BW direction (before endc
<comment>
HcalEndcapP needs to clear the expanding beampipe with 2 * crossing angle + its radius of BeampipeOD / 2
</comment>
<comment>
</comment>
<constant
name=
"HcalEndcapP_rmin"
value=
"max((HcalEndcapP_zmin + HcalEndcapP_length) * tan(2.0 * abs(CrossingAngle)) + BeampipeOD / 2.0, 15 * cm)"
<constant
name=
"HcalEndcapP_rmin"
value=
<constant
name=
"HcalEndcapN_zmin"
value=
"DIRCBackward_zmax + BackwardServiceGap_length"
<constant
name=
"HcalEndcapN_zmin"
value=
max(
, 335*cm)
<constant
name=
"HcalEndcapN_length"
value=
"105.0*cm"
<constant
name=
value=
"105.0*cm"
<comment>
HcalEndcapN needs to clear the straight beampipe with 1 * crossing angle + its radius of 22.25 mm
</comment>
<comment>
</comment>
<constant
name=
"HcalEndcapN_rmin"
value=
"max((HcalEndcapN_zmin + HcalEndcapN_length) * tan(abs(CrossingAngle)) + 22.25 * mm, 11 * cm)"
<constant
name=
"HcalEndcapN_rmin"
value=
@@ -467,7 +470,8 @@ Service gaps in FW direction (before endcapP ECAL) and BW direction (before endc
<constant
name=
"HcalBarrel_thickness"
value=
"100.0*cm "
<constant
name=
value=
"100.0*cm "
<constant
name=
"HcalBarrel_rmin"
value=
"Solenoid_rmax"
<constant
name=
"HcalBarrel_rmin"
value=
"Solenoid_rmax"
<constant
name=
"HcalBarrel_rmax"
value=
"HcalBarrel_rmin + HcalBarrel_thickness"
<constant
name=
"HcalBarrel_rmax"
value=
<constant
name=
"HcalBarrel_length"
value=
"HcalEndcapP_zmin + HcalEndcapN_zmin "
<constant
name=
"HcalBarrelForward_zmax"
value=
"HcalEndcapP_zmin - ForwardServiceGap_length - EcalEndcapP_length"
<constant
name=
"HcalBarrelBackward_zmax"
value=
"HcalEndcapN_zmin - BackwardServiceGap_length"
<comment>
<comment>
These are used by ddsim, the region where we store all secondaries
This diff is collapsed.
compact/display.xml
5
0
View file @
f2821b0b
@@ -57,6 +57,11 @@
@@ -57,6 +57,11 @@
<vis
name=
"HcalSensorVis"
ref=
"AnlBlue"
showDaughters=
"false"
visible=
"false"
<vis
name=
"HcalSensorVis"
ref=
"AnlBlue"
showDaughters=
"false"
visible=
"false"
<vis
name=
"HcalAbsorberVis"
ref=
"AnlGray"
showDaughters=
"false"
visible=
"false"
<vis
name=
"HcalAbsorberVis"
ref=
"AnlGray"
showDaughters=
"false"
visible=
"false"
<comment>
Passive steel for flux return
</comment>
<vis
name=
"PassiveSteelVis"
ref=
"AnlViolet"
showDaughters=
"false"
visible=
"true"
<comment>
<comment>
Solenoid
Solenoid
</comment>
</comment>
5
0
View file @
f2821b0b
@@ -56,6 +56,11 @@
@@ -56,6 +56,11 @@
<vis
name=
"HcalSensorVis"
ref=
"AnlBlue"
showDaughters=
"true"
visible=
"true"
<vis
name=
"HcalSensorVis"
ref=
"AnlBlue"
showDaughters=
"true"
visible=
"true"
<vis
name=
"HcalAbsorberVis"
ref=
"AnlGray"
showDaughters=
"true"
visible=
"true"
<vis
name=
"HcalAbsorberVis"
ref=
"AnlGray"
showDaughters=
"true"
visible=
"true"
<comment>
</comment>
<vis
name=
"PassiveSteelVis"
ref=
"AnlViolet"
showDaughters=
"false"
visible=
"true"
<comment>
<comment>
Solenoid
Solenoid
</comment>
</comment>
compact/hcal.xml
21
2
View file @
f2821b0b
<lccdd>
<lccdd>
<define>
<define>
<constant
name=
"HcalBarrel_
offset"
value=
Hcal
EndcapP_zmin-HcalEndcapN_zmin)/2.0"
<constant
name=
"HcalBarrel_
length"
value=
"Hcal
BarrelForward_zmax + HcalBarrelBackward_zmax"
<constant
name=
"HcalBarrel_offset"
value=
"(HcalBarrelForward_zmax - HcalBarrelBackward_zmax)/2"
<constant
name=
"HcalBarrelAvailThickness"
value=
<constant
name=
value=
<documentation>
<documentation>
#### Material Thickness
</documentation>
</documentation>
@@ -93,6 +94,24 @@
@@ -93,6 +94,24 @@
</layer>
</layer>
</detector>
</detector>
<detector
id=
name=
"PassiveSteelRingEndcapP"
type=
"athena_PolyhedraEndcapCalorimeter2"
vis=
"PassiveSteelVis"
calorimeterType=
"HAD_ENDCAP"
reflect=
"false"
<position
x=
"0"
y=
"0"
z=
"0"
<dimensions
numsides=
"CaloSides"
zmin=
"EcalEndcapP_zmin"
rmin=
"EcalEndcapP_rmax"
rmax=
"HcalBarrel_rmax"
<layer
repeat=
"1"
<slice
material=
"Steel235"
thickness=
vis=
"HcalAbsorberVis"
</layer>
</detector>
<detector
<detector
id=
"HCalEndcapN_ID"
id=
"HCalEndcapN_ID"
name=
"HcalEndcapN"
name=
"HcalEndcapN"
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
