Skip to content
Snippets Groups Projects
Commit df04daf4 authored by Wouter Deconinck's avatar Wouter Deconinck
Browse files
HcalEndcapP should use HcalEndcapPLayer_NRepeat
parent e577cf44
No related branches found
No related tags found
No related merge requests found
......@@ -50,7 +50,7 @@
zmin="HcalEndcapP_zmin"
rmin="HcalEndcapP_rmin"
rmax="HcalBarrel_rmax"/>
<layer repeat="51" vis="HcalEndcapVis" >
<layer repeat="HcalEndcapPLayer_NRepeat" vis="HcalEndcapVis" >
<slice material="Steel235" thickness="HcalEndcapPSteelThickness" vis="HcalAbsorberVis"/>
<slice material="Polystyrene" thickness="HcalEndcapPPolystyreneThickness" vis="HcalSensorVis" sensitive="yes" limits="cal_limits"/>
</layer>
0% Loading or .
Please register or to comment
