Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
A
athena
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
Subhadip Pal
athena
Commits
d4ebdbc6
Commit
d4ebdbc6
authored
3 years ago
by
Jihee Kim
Browse files
Options
Downloads
Patches
Plain Diff
Resolve "Backward Electron Endcap Crystal"
parent
a5f70c02
No related branches found
No related tags found
No related merge requests found
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
compact/ce_GEM.xml
+2
-1
2 additions, 1 deletion
compact/ce_GEM.xml
compact/ecal.xml
+17
-1
17 additions, 1 deletion
compact/ecal.xml
with
19 additions
and
2 deletions
compact/ce_GEM.xml
2
1
View file @
d4ebdbc6
@@ -15,7 +15,8 @@
<constant
name=
"ce_GEM_length"
value=
"30.0 * cm"
<constant
name=
"ce_GEM_x_pos"
value=
"0.0 * cm"
<constant
name=
"ce_GEM_y_pos"
value=
"0.0 * cm"
<constant
name=
"ce_GEM_z_pos"
value=
"-Solenoid_length/2.0 + ce_GEM_length/2.0"
<!--<constant name="ce_GEM_z_pos" value="-Solenoid_length/2.0 + ce_GEM_length/2.0"/>-->
<constant
name=
"ce_GEM_z_pos"
value=
"-EcalEndcapN_zmin - CrystalBox_z_length - ce_GEM_length/2.0"
<constant
name=
"ce_GEM_layer"
value=
"8"
<constant
name=
"ce_GEM_layer_thickness"
value=
"1.0 * cm"
</define>
This diff is collapsed.
compact/ecal.xml
17
1
View file @
d4ebdbc6
@@ -159,6 +159,22 @@
<slice
material=
"Air"
thickness=
"EcalAir1Thickness"
</layer>
</detector>
<comment>
Crystal Calorimeter
Backward (negative pseudorapidity) angle electron detector
</comment>
<detector
id=
"CrystalEndcap_ID"
name=
"ElectronECAL"
type=
"CrystalCalorimeterEndcap"
readout=
"CrystalEcalHits"
vis=
"GreenVis"
<position
x=
"CrystalEndcap_x_pos"
y=
"CrystalEndcap_y_pos"
z=
"CrystalEndcap_z_pos"
<dimensions
rmin=
"CrystalEndcap_rmin"
rmax=
"CrystalEndcap_rmax"
x=
"CrystalBox_x_length"
y=
"CrystalBox_y_length"
z=
"CrystalBox_z_length"
delta=
"CrystalBox_offset"
</detector>
</detectors>
<!-- Definition of the readout segmentation/definition -->
@@ -168,11 +184,11 @@
<segmentation type="CartesianGridXY" grid_size_x="20.0*mm" grid_size_y="20.0*mm" />
<id>system:5,module:4,x:32:-16,y:-16</id>
</readout>
<readout
name=
"CrystalEcalHits"
<segmentation
type=
"CartesianGridXY"
grid_size_x=
grid_size_y=
<id>
system:8,sector:4,module:20,x:48:-8,y:-8
</id>
</readout>
<readout
name=
"EcalBarrelHits"
<segmentation
type=
"CartesianGridXY"
grid_size_x=
"3.5 * mm"
grid_size_y=
"3.5 * mm"
<id>
system:8,barrel:3,module:4,layer:6,slice:5,x:32:-16,y:-16
</id>
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
