Skip to content
Snippets Groups Projects
Commit b462d6af authored by Wouter Deconinck's avatar Wouter Deconinck
Browse files
Resolve "FileLoader should try harder"
parent 0efeac38
Branches
Tags
No related merge requests found
......@@ -189,8 +189,8 @@ static Ref_t create_field_map_brbz(Detector & /*lcdd*/, xml::Handle_t handle)
if( !fs::exists(fs::path(field_map_file)) ) {
auto ret = std::system(("mkdir -p fieldmaps && "
"wget " +
field_map_url + " -O " + field_map_file).c_str());
"curl --retry 5 -f " +
field_map_url + " -o " + field_map_file).c_str());
if (!fs::exists(fs::path(field_map_file))) {
std::cerr << "ERROR: file, " << field_map_file << ", does not exist\n";
......@@ -38,7 +38,7 @@ long load_file(
if (!fs::exists(fs::path(file))) {
std::string parent_path = fs::path(file).parent_path();
auto ret = std::system(("mkdir -p " + parent_path + " && "
"wget " + url + " -O " + file).c_str());
"curl --retry 5 -f " + url + " -o " + file).c_str());
std::cerr << "ERROR: file, " << file << ", does not exist\n";
std::quick_exit(1);
0% Loading or .
Please register or to comment
