Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
A
athena
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
Subhadip Pal
athena
Commits
963e18d1
Commit
963e18d1
authored
3 years ago
by
Whitney Armstrong
Browse files
Options
Downloads
Patches
Plain Diff
View20 update
parent
4a1e0237
No related branches found
No related tags found
No related merge requests found
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
scripts/view20/generate_eps
+18
-7
18 additions, 7 deletions
with
18 additions
and
7 deletions
18
7
View file @
963e18d1
@@ -44,12 +44,24 @@ done
set
POSITIONAL
# restore positional parameters
set
POSITIONAL
#npdet_info print EcalEndcapN_z0 --value-only athena.xml
#180.5 cm
# Top view
# Top view with a thin slice down the middle
#dawncut 0 -1 0 1 ${INPUT_FILE} ${FILE_TAG}.prim
dawncut 0 0 1
-1800
INPUT_FILE
FILE_TAG
_endcapN_temp0.prim
dawncut 0 1 0 1
INPUT_FILE
FILE_TAG
_top_temp0.prim
dawncut 0 0
-1
1805
FILE_TAG
_endcapN_temp0.prim
FILE_TAG
_endcapN.prim
../../bin/dawn_tweak
--mag
5
--draw
1
--theta
180
--phi
0
--draw
3
dawn
-d
FILE_TAG
_endcapN.prim
ps2pdf
FILE_TAG
_endcapN.eps
FILE_TAG
_endcapN_full.pdf
gs
-o
FILE_TAG
_endcapN.pdf
-sDEVICE
pdfwrite
-c
"[/CropBox [51 250 550 590] /PAGES pdfmark"
-f
FILE_TAG
_endcapN_full.pdf
pdftoppm
FILE_TAG
_endcapN.pdf
FILE_TAG
_endcapN
-png
-singlefile
-cropbox
-thinlinemode
solid
-aaVector
yes
dawncut 0 1 0 1
INPUT_FILE
FILE_TAG
_top_temp0.prim
dawncut 0
-1
0 1
FILE_TAG
_top_temp0.prim
FILE_TAG
_top.prim
dawncut 0
-1
0 1
FILE_TAG
_top_temp0.prim
FILE_TAG
_top.prim
--mag
1
--draw
1
--theta
270
--phi
90
--mag
2
--draw
1
--theta
270
--phi
90
dawn
-d
FILE_TAG
_top.prim
dawn
-d
FILE_TAG
_top.prim
ps2pdf
FILE_TAG
_top.eps
FILE_TAG
_top_full.pdf
ps2pdf
FILE_TAG
_top.eps
FILE_TAG
_top_full.pdf
gs
-o
FILE_TAG
_top.pdf
-sDEVICE
pdfwrite
gs
-o
FILE_TAG
_top.pdf
-sDEVICE
pdfwrite
@@ -58,9 +70,8 @@ gs -o ${FILE_TAG}_top.pdf -sDEVICE=pdfwrite \
pdftoppm
FILE_TAG
_top.pdf
FILE_TAG
_top
-png
-singlefile
-cropbox
-thinlinemode
solid
-aaVector
yes
pdftoppm
FILE_TAG
_top.pdf
FILE_TAG
_top
-png
-singlefile
-cropbox
-thinlinemode
solid
-aaVector
yes
# Side view (lines)
# Side view (lines)
dawncut
-1
0 0 1
INPUT_FILE
FILE_TAG
.prim
dawncut 1 0 0 1
INPUT_FILE
FILE_TAG
_temp0.prim
#@dawncut 1 0 0 1 ${INPUT_FILE} ${FILE_TAG}_temp0.prim
dawncut
-1
0 0 1
FILE_TAG
_temp0.prim
FILE_TAG
.prim
#@dawncut -1 0 0 1 ${FILE_TAG}_temp0.prim ${FILE_TAG}.prim
--mag
1
--draw
1
--theta
180
--phi
90
--mag
1
--draw
1
--theta
180
--phi
90
dawn
-d
FILE_TAG
.prim
dawn
-d
FILE_TAG
.prim
ps2pdf
FILE_TAG
.eps
FILE_TAG
_full.pdf
ps2pdf
FILE_TAG
.eps
FILE_TAG
_full.pdf
This diff is collapsed.
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
