Skip to content
Snippets Groups Projects
Commit 7684b4f1 authored by Sylvester Joosten's avatar Sylvester Joosten
Browse files
Fix EcalEndcapN so the blocks are sensitive again
parent 67b88f09
No related branches found
No related tags found
No related merge requests found
...@@ -80,10 +80,12 @@ static Ref_t create_detector(Detector& desc, xml::Handle_t handle, SensitiveDete ...@@ -80,10 +80,12 @@ static Ref_t create_detector(Detector& desc, xml::Handle_t handle, SensitiveDete
Box glass_box("glass_box", Glass_Width * 0.5, Glass_Width * 0.5, Glass_Thickness * 0.5); Box glass_box("glass_box", Glass_Width * 0.5, Glass_Width * 0.5, Glass_Thickness * 0.5);
Volume glass_module("glass_module", glass_box, glass_material); Volume glass_module("glass_module", glass_box, glass_material);
glass_module.setVisAttributes(desc.visAttributes("EcalEndcapNModuleVis")); glass_module.setVisAttributes(desc.visAttributes("EcalEndcapNModuleVis"));
glass_module.setSensitiveDetector(sens);
Box crystal_box("crystal_box", Crystal_Width* 0.5, Crystal_Width * 0.5, Crystal_Thickness * 0.5); Box crystal_box("crystal_box", Crystal_Width* 0.5, Crystal_Width * 0.5, Crystal_Thickness * 0.5);
Volume crystal_module("crystal_module", crystal_box, crystal_material); Volume crystal_module("crystal_module", crystal_box, crystal_material);
crystal_module.setVisAttributes(desc.visAttributes("EcalEndcapNModuleVis")); crystal_module.setVisAttributes(desc.visAttributes("EcalEndcapNModuleVis"));
crystal_module.setSensitiveDetector(sens);
// GLASS // GLASS
double diameter = 2 * Glass_OuterR; double diameter = 2 * Glass_OuterR;
0% Loading or .
Please register or to comment
