Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
A
athena
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
Subhadip Pal
athena
Commits
4b5aa240
Commit
4b5aa240
authored
4 years ago
by
Jihee Kim
Browse files
Options
Downloads
Patches
Plain Diff
Added compact detector description and constructor files
parent
dc8c015d
No related branches found
No related tags found
No related merge requests found
Changes
3
Hide whitespace changes
Inline
Side-by-side
Showing
3 changed files
cb_Solenoid.xml
+69
-0
69 additions, 0 deletions
cb_Solenoid.xml
materials.xml
+0
-1
0 additions, 1 deletion
materials.xml
src/cb_Solenoid.cpp
+37
-0
37 additions, 0 deletions
src/cb_Solenoid.cpp
with
106 additions
and
1 deletion
cb_Solenoid.xml
0 → 100644
69
0
View file @
4b5aa240
<lccdd
xmlns:compact=
"http://www.lcsim.org/schemas/compact/1.0"
xmlns:xs=
"http://www.w3.org/2001/XMLSchema"
xs:noNamespaceSchemaLocation=
"http://www.lcsim.org/schemas/compact/1.0/compact.xsd"
<!-- Some information about detector -->
<info
name=
"Central Barrel Solenoid"
title=
author=
"Jihee Kim"
url=
"https://eicweb.phy.anl.gov/EIC/detectors/reference_detector.git"
status=
"development"
version=
"v1 2021-03-15"
<comment>
</comment>
</info>
<!-- Use DD4hep elements and materials definitions -->
<includes>
<gdmlFile
ref=
"elements.xml"
<gdmlFile
ref=
"materials.xml"
</includes>
<!-- Define the dimensions of the world volume -->
<define>
<constant
name=
"world_side"
value=
"50*m"
<constant
name=
"world_x"
value=
"world_side"
<constant
name=
"world_y"
value=
"world_side"
<constant
name=
"world_z"
value=
"world_side"
<constant
name=
"tracker_region_zmax"
value=
"6 * m"
<constant
name=
"tracker_region_rmax"
value=
"6 * m"
<constant
name=
"cb_Solenoid_ID"
value=
"1"
<constant
name=
"cb_Solenoid_rmin"
value=
"0.0 * cm"
<constant
name=
"cb_Solenoid_rmax"
value=
"137.0 * cm"
<constant
name=
"cb_Solenoid_z"
value=
"400.0 * cm"
<constant
name=
"cb_Solenoid_shift"
value=
"0.0 * cm"
</define>
<limits>
</limits>
<regions>
</regions>
<!-- Common Generic visualization attributes -->
<comment>
</comment>
<display>
<vis
name=
"cb_SolenoidVis"
alpha=
"0.4"
r=
"0.1"
g=
"0.0"
b=
"0.1"
showDaughters=
"true"
visible=
"true"
</display>
<!-- Define detector -->
<detectors>
<comment>
Central Barrel Solenoid Magnet
</comment>
<!-- TODO: Add material -->
<detector
id=
"cb_Solenoid_ID"
name=
"cb_Solenoid"
type=
"cb_Solenoid"
insideTrackingVolume=
"false"
vis=
"cb_SolenoidVis"
<material
name=
"Steel235"
<dimensions
rmin=
"cb_Solenoid_rmin"
rmax=
"cb_Solenoid_rmax"
z=
"cb_Solenoid_z"
delta=
"cb_Solenoid_shift"
</detector>
</detectors>
<plugins>
</plugins>
<!-- TODO: Define field -->
<fields>
<field
type=
"solenoid"
name=
"GlobalSolenoid"
inner_field=
"1.5 * tesla"
outer_field=
"0.5*tesla"
zmin=
"100.0 * cm"
zmax=
"100.0 * cm"
inner_radius=
"100.0 * cm"
outer_radius=
"100.0 * cm"
</fields>
</lccdd>
This diff is collapsed.
materials.xml
0
1
View file @
4b5aa240
@@ -2,7 +2,6 @@
@@ -2,7 +2,6 @@
<materials>
<materials>
Air by weight from
Air by weight from
http://www.engineeringtoolbox.com/air-composition-24_212.html
<material
name=
"Air"
<material
name=
"Air"
src/cb_Solenoid.cpp
0 → 100644
37
0
View file @
4b5aa240
#include
<XML/Helper.h>
// Central Barrel Solenoid
using
namespace
dd4hep
static
Ref_t
createDetector
Detector
desc
xml_h
handle
SensitiveDetector
sens
xml
DetElement
detElem
handle
std
string
detName
detElem
nameStr
int
detID
detElem
id
xml
Component
dims
detElem
dimensions
double
SizeZ
dims
z
// Size in Z direction
double
ROut
dims
rmax
// Outer diameter
double
RIn
dims
rmin
// Inner diameter
double
ShiftZ
dims
delta
// TODO: Material
//Material mat = desc.material("Steel235");
Material
mat
desc
material
detElem
materialStr
Tube
cb_Solenoid_GVol_Solid
RIn
ROut
SizeZ
2.
0.
360
deg
Volume
detVol
"cb_Solenoid_GVol_Logic"
mat
detVol
setVisAttributes
desc
visAttributes
detElem
visStr
DetElement
det
detName
detID
Volume
motherVol
desc
pickMotherVolume
det
Transform3D
tr
RotationZYX
0.
0.
0.
Position
0.
0.
ShiftZ
PlacedVolume
detPV
motherVol
placeVolume
detVol
tr
det
setPlacement
detPV
return
det
// clang-format off
DECLARE_DETELEMENT
cb_Solenoid
createDetector
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
