Skip to content
Snippets Groups Projects
Commit 3e9daa1a authored by Whitney Armstrong's avatar Whitney Armstrong
Browse files
Removing acts ext so we can debug them
parent 9fb0ea9f
Branches
Tags
No related merge requests found
......@@ -25,9 +25,9 @@ static Ref_t create_detector(Detector& description, xml_h e, SensitiveDetector s
string det_name = x_det.nameStr();
DetElement sdet(det_name, det_id);
Acts::ActsExtension* barrelExtension = new Acts::ActsExtension();
barrelExtension->addType("barrel", "detector");
sdet.addExtension<Acts::ActsExtension>(barrelExtension);
//Acts::ActsExtension* barrelExtension = new Acts::ActsExtension();
//barrelExtension->addType("barrel", "detector");
//sdet.addExtension<Acts::ActsExtension>(barrelExtension);
Assembly assembly(det_name);
map<string, Volume> mod_volumes;
......@@ -118,10 +118,10 @@ static Ref_t create_detector(Detector& description, xml_h e, SensitiveDetector s
Volume m_env = mod_volumes[m_nam];
DetElement lay_elt(sdet, _toString(x_layer.id(), "layer%d"), lay_id);
Acts::ActsExtension* layerExtension = new Acts::ActsExtension();
layerExtension->addType("sensitive cylinder", "layer");
// layerExtension->addValue(10. * Acts::UnitConstants::mm, "r", "envelope");
lay_elt.addExtension<Acts::ActsExtension>(layerExtension);
//Acts::ActsExtension* layerExtension = new Acts::ActsExtension();
//layerExtension->addType("sensitive cylinder", "layer");
//// layerExtension->addValue(10. * Acts::UnitConstants::mm, "r", "envelope");
//lay_elt.addExtension<Acts::ActsExtension>(layerExtension);
Placements& sensVols = sensitives[m_nam];
......@@ -158,8 +158,8 @@ static Ref_t create_detector(Detector& description, xml_h e, SensitiveDetector s
PlacedVolume sens_pv = sensVols[ic];
DetElement comp_elt(mod_elt, sens_pv.volume().name(), module);
comp_elt.setPlacement(sens_pv);
Acts::ActsExtension* moduleExtension = new Acts::ActsExtension("YZX");
comp_elt.addExtension<Acts::ActsExtension>(moduleExtension);
//Acts::ActsExtension* moduleExtension = new Acts::ActsExtension("YZX");
//comp_elt.addExtension<Acts::ActsExtension>(moduleExtension);
/// Increase counters etc.
0% Loading or .
Please register or to comment
