Skip to content
Snippets Groups Projects
Commit 080a82eb authored by Shujie Li's avatar Shujie Li Committed by Whitney Armstrong
Browse files
updated endcap thickness
parent 995111fd
No related branches found
No related tags found
No related merge requests found
......@@ -16,13 +16,17 @@
Aug 04, 2021, Shujie Li
udpated stave material budget for the baseline design.
udpated stave and disck material budget for the baseline design.
see https://eicweb.phy.anl.gov/EIC/detectors/athena/-/issues/63
ITS3 sensor thickness: 40um, pixel size: 10um (segmentation)
total X0 0.55% per layer:
0.4 mm aluminum ~ 0.44% X0.
2 x carbonfiber (RL ~ 25) 0.1 mm to match Si (RL~9) of 0.04mm
total X0 0.55% per barrel layer:
0.35 mm aluminum ~ 0.4% X0.
2 x carbonfiber (RL ~ 28) 0.12 mm (!!! material scan shows ~0.17mm, need to check later) to match Si (RL~9) of 0.04mm ~ 0.04%
total X0 0.24% per disk layer (4 sectors per disk):
0.15 mm aluminum ~ 0.16% X0.
1 x carbonfiber (RL ~ 28) 0.12 mm to match Si (RL~9) of 0.04mm ~ 0.04%
</comment>
......@@ -34,8 +38,8 @@
<constant name="TrackerBarrelLayer_rOffset" value="0.5*cm"/>
<constant name="TrackerBarrelSpaceFrame_width" value="4.0*cm"/>
<constant name="TrackerBarrelSpaceFrame_height" value="1.0835*cm"/>
<constant name="TrackerSensor_thickness" value="0.04*mm"/>
<constant name="TrackerBarrelSpaceFrame_height" value="1.0*cm"/>
<constant name="TrackerSensor_thickness" value="ITS3Thickness"/>
<constant name="TrackerBarrelInner_rmin1" value="21.0*cm"/>
<constant name="TrackerBarrelInner_rmin2" value="22.68*cm"/>
......@@ -57,47 +61,59 @@
<comment>
Here we are assuming the two endcaps (P and N) are symmetric.
</comment>
<!-- <constant name="TrackerEndcap_thickness" value="0.24/100*9.37*cm"/> -->
<!-- <constant name="TrackerEndcapService_thickness" value="TrackerEndcap_thickness-TrackerSensor_thickness"/> -->
<constant name="TrackerEndcapInner_nLayers" value="1"/>
<constant name="TrackerEndcapOuter_nLayers" value="3"/>
<constant name="TrackerEndcapInner_zmin" value="TrackerBarrelInner_length2/2.0 + 1.0*cm"/>
<constant name="TrackerEndcapInner_zmax" value="TrackerBarrelOuter_length1/2.0 - 1.0*cm"/>
<constant name="TrackerEndcapInner_length" value="TrackerEndcapInner_zmax- TrackerEndcapInner_zmin"/>
<constant name="TrackerEndcapInnerLayer_dz" value="TrackerEndcapInner_length/TrackerEndcapInner_nLayers"/>
<constant name="TrackerEndcapInnerLayer_thickness" value="min(5.0*cm,TrackerEndcapInnerLayer_dz - 0.5*cm)"/>
<constant name="TrackerEndcapLayer_dz" value="2*cm"/>
<constant name="TrackerEndcapLayerModule_dz" value="2.5*mm"/>
<constant name="TrackerEndcapInner_zmin" value="49*cm"/>
<!-- <constant name="TrackerEndcapInnerLayer_dz" value="TrackerEndcapLayer_dz"/> -->
<constant name="TrackerEndcapInner_zmax" value="TrackerEndcapInner_zmin+TrackerEndcapLayer_dz"/>
<constant name="TrackerEndcapInner_length" value="TrackerEndcapLayer_dz"/>
<constant name="TrackerEndcapInnerLayer_thickness" value="min(5.0*cm,TrackerEndcapLayer_dz - 0.5*cm)"/>
<comment> Note, the -1.0*cm is so the layers do not touch surfaces.
This is a limitation of ACTS geometry which will likely go away in the future.</comment>
<constant name="TrackerEndcapOuter_zmin" value="TrackerBarrelOuter_length/2.0"/>
<constant name="TrackerEndcapOuter_zmax" value="TrackerEndcapOuter_zmin + 70"/>
<constant name="TrackerEndcapOuter_length" value="TrackerEndcapOuter_zmax- TrackerEndcapOuter_zmin"/>
<constant name="TrackerEndcapOuterLayer_dz" value="TrackerEndcapOuter_length/TrackerEndcapOuter_nLayers"/>
<constant name="TrackerEndcapOuterLayer_thickness" value="min(5.0*cm,TrackerEndcapOuterLayer_dz - 1.0*cm)"/>
<constant name="TrackerEndcapOuter_zmin1" value="73*cm"/>
<constant name="TrackerEndcapOuter_zmin2" value="97*cm"/>
<constant name="TrackerEndcapOuter_zmin3" value="121*cm"/>
<constant name="TrackerEndcapOuter_zmin" value="TrackerEndcapOuter_zmin1"/>
<constant name="TrackerEndcapOuter_zmax" value="TrackerEndcapOuter_zmin3 + TrackerEndcapLayer_dz"/>
<constant name="TrackerEndcapOuterLayer_thickness" value="min(5.0*cm,TrackerEndcapLayer_dz - 1.0*cm)"/>
<constant name="TrackerEndcapInner_rmin1" value="Beampipe_rmax+1.0*cm"/>
<!-- <constant name="TrackerEndcapInner_rmin2" value="Beampipe_rmax+1.0*cm"/> -->
<comment> this can be parametrized as a function of z. From acts check: rmin must > 3.57627cm which is beampipe_max+0.4cm</comment>
<constant name="TrackerEndcapOuter_rmin1" value="3.6*cm"/>
<constant name="TrackerEndcapOuter_rmin2" value="4.7*cm"/>
<constant name="TrackerEndcapOuter_rmin3" value="5.91*cm"/>
<constant name="TrackerEndcapOuter_rmin1" value="3.18*cm + 1.2*cm * 1"/>
<constant name="TrackerEndcapOuter_rmin2" value="3.18*cm + 1.2*cm * 1"/>
<constant name="TrackerEndcapOuter_rmin3" value="3.18*cm + 1.2*cm * 2"/>
<constant name="TrackerEndcapInner_rmax1" value="TrackerBarrelOuter_rmin1-5.0*mm"/>
<!-- <constant name="TrackerEndcapInner_rmax2" value="TrackerBarrelOuter_rmin1-5.0*mm"/> -->
<constant name="TrackerEndcapInner_rmax1" value="36.26*cm-5.0*mm"/>
<constant name="TrackerEndcapOuter_rmax1" value="43.23*cm"/>
<constant name="TrackerEndcapOuter_rmax2" value="43.23*cm"/>
<constant name="TrackerEndcapOuter_rmax3" value="43.23*cm"/>
<comment> TODO: These should be computed </comment>
<constant name="TrackerBarrelInner_NModules" value="30"/>
<constant name="TrackerBarrelOuter_NModules" value="56"/>
<comment> The carbonfiber shell covers the outer 3 disks and intercepts with the diagonal cone at
TrackerEndcapOuter_rmax1 * TrackerEndcapInner_zmin/TrackerEndcapInner_rmax1 ~ 60cm </comment>
<constant name="TrackerEndcapOuterShell_zmin" value="TrackerEndcapOuter_rmax1 * TrackerEndcapInner_zmin/TrackerEndcapInner_rmax1+1*cm"/>
<constant name="TrackerEndcapOuterShell_length" value="TrackerEndcapOuter_zmax- TrackerEndcapOuterShell_zmin"/>
<constant name="TrackerEndcapInnerModOpeningAngle" value="30.0*degree"/>
<constant name="TrackerEndcap_NModules" value="12"/>
<comment> nmodules = np.pi/np.arcsin(frame_width*np.cos(tilt_angle)/2.0/R) </comment>
<constant name="TrackerBarrel_StaveTiltAngle" value="5.0*degree"/>
<constant name="TrackerBarrelInner_NModules1" value="33"/>
<constant name="TrackerBarrelInner_NModules2" value="36"/>
<constant name="TrackerBarrelOuter_NModules1" value="62"/>
<constant name="TrackerBarrelOuter_NModules2" value="68"/>
<constant name="TrackerEndcapInnerModOpeningAngle" value="360.0/TrackerEndcap_NModules*degree"/>
<constant name="TrackerEndcapInnerMod1_x1" value="2.0*TrackerEndcapInner_rmin1*sin(TrackerEndcapInnerModOpeningAngle/2.0)"/>
<constant name="TrackerEndcapInnerMod1_x2" value="2.0*TrackerEndcapInner_rmax1*sin(TrackerEndcapInnerModOpeningAngle/2.0)"/>
<constant name="TrackerEndcapInnerMod1_y" value="TrackerEndcapInner_rmax1*cos(TrackerEndcapInnerModOpeningAngle/2.0) - TrackerEndcapInner_rmin1"/>
......@@ -141,11 +157,11 @@
Tracker Barrel Modules
</comment>
<module name="TrackerBarrelInner_Module1" vis="TrackerModuleVis">
<frame material="CarbonFiber_25percent" vis="TrackerSupportVis"
<frame material="CarbonFiber" vis="TrackerSupportVis"
width="TrackerBarrelSpaceFrame_width"
height="TrackerBarrelSpaceFrame_height"
length="TrackerBarrelInner_length1"
thickness="0.1*mm" />
thickness="TrackerCarbon_thickness" />
<module_component name="aluminum1" material="Aluminum" sensitive="false"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length1-4*mm" thickness="0.4*mm" />
<module_component name="silicon"
......@@ -155,11 +171,11 @@
</module_component>
</module>
<module name="TrackerBarrelInner_Module2" vis="TrackerModuleVis">
length="TrackerBarrelInner_length2"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length2-4*mm" thickness="0.4*mm" />
......@@ -176,7 +192,7 @@
inner_r="TrackerBarrelInner_rmin1-TrackerBarrelLayer_rOffset"
outer_r="TrackerBarrelInner_rmin1-TrackerBarrelLayer_rOffset + TrackerBarrelInner_thickness-1.0*mm"
z_length="TrackerBarrelInner_length1"/>
<rphi_layout phi_tilt="10.0*degree" nphi="TrackerBarrelInner_NModules" phi0="0.0" rc="TrackerBarrelInner_rmin1" dr="0.0 * mm"/>
<rphi_layout phi_tilt="TrackerBarrel_StaveTiltAngle" nphi="TrackerBarrelInner_NModules1" phi0="0.0" rc="TrackerBarrelInner_rmin1" dr="0.0 * mm"/>
<z_layout dr="0.0 * mm" z0="0.0 * mm" nz="1"/>
</layer>
<layer module="TrackerBarrelInner_Module2" id="2" vis="TrackerLayerVis">
......@@ -184,7 +200,7 @@
inner_r="TrackerBarrelInner_rmin2-TrackerBarrelLayer_rOffset"
outer_r="TrackerBarrelInner_rmin2-TrackerBarrelLayer_rOffset + TrackerBarrelInner_thickness"
z_length="TrackerBarrelInner_length2"/>
<rphi_layout phi_tilt="10.0*degree" nphi="TrackerBarrelInner_NModules" phi0="0.0" rc="TrackerBarrelInner_rmin2" dr="0.0 * mm"/>
<rphi_layout phi_tilt="TrackerBarrel_StaveTiltAngle" nphi="TrackerBarrelInner_NModules2" phi0="0.0" rc="TrackerBarrelInner_rmin2" dr="0.0 * mm"/>
</layer>
</detector>
......@@ -199,18 +215,19 @@
<module name="Module1" vis="AnlProcess_Blue">
<trd x1="TrackerEndcapInnerMod1_x1/2.0" x2="TrackerEndcapInnerMod1_x2/2.0" z="TrackerEndcapInnerMod1_y/2"/>
<module_component thickness="ITS3Thickness" material="Silicon" sensitive="true"/>
<module_component thickness="0.25/100*9.37*cm-ITS3Thickness" material="Silicon"/>
<module_component thickness="TrackerEndcapAluminum_thickness" material="Aluminum"/>
<module_component thickness="TrackerCarbon_thickness" material="CarbonFiber"/>
</module>
<layer id="1">
<envelope vis="AnlRed"
rmin="TrackerEndcapInner_rmin1"
rmax="TrackerEndcapInner_rmax1"
length="TrackerEndcapInnerLayer_thickness"
zstart="TrackerEndcapInner_zmin + TrackerEndcapInner_length/2.0" />
zstart="TrackerEndcapInner_zmin" />
<ring vis="AnlRed"
r="TrackerEndcapInner_rmin1+TrackerEndcapInnerMod1_y/2.0"
zstart="0.0"
nmodules="12" dz="2.5 * mm" module="Module1" />
nmodules="TrackerEndcap_NModules" dz="TrackerEndcapLayerModule_dz" module="Module1" />
</layer>
</detector>
......@@ -224,18 +241,19 @@
</module>
<layer id="1">
<ring vis="AnlRed"
zstart="0"
</layer>
</detector>
......@@ -258,11 +276,11 @@
</comment>
<module name="TrackerBarrelOuter_Module1" vis="PurpleVis">
<frame material="CarbonFiber_25percent" vis="BlueGreenVis"
<frame material="CarbonFiber" vis="BlueGreenVis"
length="TrackerBarrelOuter_length1"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelOuter_length1-0.1*mm" thickness="0.40*mm" />
......@@ -272,11 +290,11 @@
</module_component>
</module>
<module name="TrackerBarrelOuter_Module2" vis="PurpleVis">
length="TrackerBarrelOuter_length2"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelOuter_length2-0.1*mm" thickness="0.40*mm" />
......@@ -293,7 +311,7 @@
inner_r="TrackerBarrelOuter_rmin1-TrackerBarrelLayer_rOffset"
outer_r="TrackerBarrelOuter_rmin1-TrackerBarrelLayer_rOffset + TrackerBarrelOuter_thickness-1.0*mm"
z_length="TrackerBarrelOuter_length1"/>
<rphi_layout phi_tilt="10.0*degree" nphi="TrackerBarrelOuter_NModules" phi0="0.0" rc="TrackerBarrelOuter_rmin1" dr="0.0 * mm"/>
<rphi_layout phi_tilt="TrackerBarrel_StaveTiltAngle" nphi="TrackerBarrelOuter_NModules1" phi0="0.0" rc="TrackerBarrelOuter_rmin1" dr="0.0 * mm"/>
</layer>
<layer module="TrackerBarrelOuter_Module2" id="2" vis="VertexVis">
......@@ -301,7 +319,7 @@
inner_r="TrackerBarrelOuter_rmin2-TrackerBarrelLayer_rOffset"
outer_r="TrackerBarrelOuter_rmin2-TrackerBarrelLayer_rOffset + TrackerBarrelOuter_thickness"
z_length="TrackerBarrelOuter_length2"/>
<rphi_layout phi_tilt="10.0*degree" nphi="TrackerBarrelOuter_NModules" phi0="0.0" rc="TrackerBarrelOuter_rmin2" dr="0.0 * mm"/>
<rphi_layout phi_tilt="TrackerBarrel_StaveTiltAngle" nphi="TrackerBarrelOuter_NModules2" phi0="0.0" rc="TrackerBarrelOuter_rmin2" dr="0.0 * mm"/>
</layer>
</detector>
......@@ -313,56 +331,59 @@
readout="TrackerEndcapHits"
vis="TrackerVis"
reflect="false">
<support vis="TrackerSupportVis" material="CarbonFiber_25percent"
<support vis="TrackerSupportVis" material="CarbonFiber"
rmin="TrackerEndcapOuter_rmax3+1.0*mm"
thickness="2.0*mm" length="TrackerEndcapOuter_length" zstart="TrackerEndcapOuter_zmin" />
thickness="2.0*mm" length="TrackerEndcapOuterShell_length" zstart="TrackerEndcapOuterShell_zmin" />
<trd x1="TrackerEndcapOuterMod1_x1/2.0" x2="TrackerEndcapOuterMod1_x2/2.0" z="TrackerEndcapOuterMod1_y/2"/>
</module>
<module name="Module2" vis="AnlProcess_Blue">
<trd x1="TrackerEndcapOuterMod2_x1/2.0" x2="TrackerEndcapOuterMod2_x2/2.0" z="TrackerEndcapOuterMod2_y/2"/>
</module>
<module name="Module3" vis="AnlProcess_Blue">
<trd x1="TrackerEndcapOuterMod3_x1/2.0" x2="TrackerEndcapOuterMod3_x2/2.0" z="TrackerEndcapOuterMod3_y/2"/>
</module>
<layer id="1">
rmin="TrackerEndcapOuter_rmin1"
rmax="TrackerEndcapOuter_rmax1"
length="TrackerEndcapOuterLayer_thickness"
zstart="TrackerEndcapOuter_zmin1" />
<ring vis="AnlRed"
r="TrackerEndcapOuter_rmin1+TrackerEndcapOuterMod1_y/2.0"
zstart="0.0*mm"
</layer>
<layer id="2">
rmin="TrackerEndcapOuter_rmin2"
rmax="TrackerEndcapOuter_rmax2"
zstart="TrackerEndcapOuter_zmin + TrackerEndcapOuterLayer_dz" />
zstart="TrackerEndcapOuter_zmin2" />
<ring vis="AnlRed"
r="TrackerEndcapOuter_rmin2+TrackerEndcapOuterMod2_y/2.0"
zstart="0.0*mm"
nmodules="12" dz="2.5 * mm" module="Module2" />
nmodules="TrackerEndcap_NModules" dz="TrackerEndcapLayerModule_dz" module="Module2" />
</layer>
<layer id="3">
rmin="TrackerEndcapOuter_rmin3"
rmax="TrackerEndcapOuter_rmax3"
zstart="TrackerEndcapOuter_zmin + 2 * TrackerEndcapOuterLayer_dz" />
zstart="TrackerEndcapOuter_zmin3" />
<ring vis="AnlRed"
r="TrackerEndcapOuter_rmin3+TrackerEndcapOuterMod3_y/2.0"
zstart="0.0*mm"
nmodules="12" dz="2.5 * mm" module="Module3" />
nmodules="TrackerEndcap_NModules" dz="TrackerEndcapLayerModule_dz" module="Module3" />
</layer>
</detector>
......@@ -373,56 +394,59 @@
vis="AnlRed"
reflect="true">
</module>
</module>
</module>
<layer id="1">
rmin="TrackerEndcapOuter_rmin1 + 0 * 1.2*cm"
<ring vis="AnlRed"
zstart="0.0*mm"
</layer>
<layer id="2">
<ring vis="AnlRed"
zstart="0.0*mm"
</layer>
<layer id="3">
<ring vis="AnlRed"
zstart="0.0*mm"
</layer>
</detector>
......@@ -442,4 +466,4 @@
</readouts>
</lccdd>
</lccdd>
\ No newline at end of file
......@@ -5,6 +5,8 @@
THis value probably can live in the file that includes this one.
</comment>
<constant name="ITS3Thickness" value="40*um"/>
<constant name="TrackerCarbon_thickness" value="0.12*mm"/>
<constant name="TrackerEndcapAluminum_thickness" value="0.15*mm"/>
<documentation>
#### Vertex Tracker Barrel Parameters
......@@ -41,7 +43,7 @@ Simple carbon fiber support shell.
<constant name="VertexBarrelLayer_rmax1" value="VertexBarrelLayer_rmin1 + VertexBarrelLayer_thickness"/>
<constant name="VertexBarrelLayer_rmax2" value="VertexBarrelLayer_rmin2 + VertexBarrelLayer_thickness"/>
<constant name="VertexBarrelShell_rmin" value="VertexBarrelLayer_rmin2+2*VertexBarrelLayer_offset"/>
<constant name="VertexBarrelShell_rmin" value="VertexBarrelLayer_rmin2+VertexBarrelLayer_offset"/>
<constant name="VertexBarrelShell_thickness" value="300*um"/>
<constant name="VertexBarrelShell_rmax" value="VertexBarrelShell_rmin + VertexBarrelShell_thickness"/>
<constant name="VertexBarrelShell_length" value="VertexBarrel_length"/>
......@@ -123,7 +125,7 @@ Simple carbon fiber support shell.
sensitive="true"
width="VertexBarrelShellStave_width"
length="VertexBarrelMod_length"
thickness="VertexBarrelSensor_thickness"
thickness="VertexBarrelShell_thickness"
vis="VertexLayerVis" />
</module>
<comment> Layers composed of many arrayed modules </comment>
......@@ -173,7 +175,8 @@ Simple carbon fiber support shell.
<trd x1="VertexEndcapMod1_x1/2.0" x2="VertexEndcapMod1_x2/2.0" z="VertexEndcapMod1_y/2"/>
</module>
<layer id="1">
......@@ -199,7 +202,8 @@ Simple carbon fiber support shell.
</module>
<layer id="1">
0% Loading or .
Please register or to comment
