Skip to content
Snippets Groups Projects
Commit 6247a933 authored by Yero1990's avatar Yero1990 Committed by Eric Pooser
Browse files
Hodo work (#128)
* -Added the fAdcTimeWindowMin/Max parameter values per plane for the hms/shms h(p)hodo.param file
* -added comments to SHMS/HMS hodo.param file
parent 2612a198
No related branches found
No related tags found
No related merge requests found
...@@ -10,6 +10,12 @@ hhodo_adc_mode=1 ...@@ -10,6 +10,12 @@ hhodo_adc_mode=1
; to move the tdc to between 0 and 4000 channels. ; to move the tdc to between 0 and 4000 channels.
hhodo_tdc_offset = 1120, 1120, 1120, 1120 hhodo_tdc_offset = 1120, 1120, 1120, 1120
; hhodo_tdc_offset = 1000, 1000, 1000, 1000 ; hhodo_tdc_offset = 1000, 1000, 1000, 1000
;hhodo set min and max fADC time window for all paddles in a plane in 'Channel' units
; the conversion is 0.0625 ns / channel for flash ADC 250
hhodo_AdcTimeWindowMin = 0., 0., 0., 0.
hhodo_AdcTimeWindowMax = 3200., 3200., 3200., 3200.
; hstart_time_center center of allowed time window (ns) ; hstart_time_center center of allowed time window (ns)
hstart_time_center = 32. hstart_time_center = 32.
; hstart_time_slop 1/2 width of time window ; hstart_time_slop 1/2 width of time window
...@@ -6,9 +6,15 @@ pcosmicflag=0 ...@@ -6,9 +6,15 @@ pcosmicflag=0
; if not set then defaults to use the raw pulse integral ; if not set then defaults to use the raw pulse integral
phodo_adc_mode=1 phodo_adc_mode=1
; hhodo_tdc_offset is array of time offsets for all paddles in a plane ; phodo_tdc_offset is array of time offsets for all paddles in a plane
phodo_tdc_offset = 1860, 2000, 2060, 2000 phodo_tdc_offset = 1860, 2000, 2060, 2000
;phodo set min and max fADC time window for all paddles in a plane in 'Channel' units
phodo_AdcTimeWindowMin = 0., 0., 0., 640.
phodo_AdcTimeWindowMax = 3200., 3200., 3200., 1760.
; pstart_time_center center of allowed time window ; pstart_time_center center of allowed time window
pstart_time_center = 32. pstart_time_center = 32.
0% Loading or .
Please register or to comment
