Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • jlab/hallc/analyzer_software/hcana
  • whit/hcana
2 results
Show changes
Showing
with 2303 additions and 515 deletions
// A exception class for PRad Event Viewer //
// Chao Peng //
// 02/27/2016 //
#include "PRadException.h"
using namespace std;
PRadException::PRadException(const string &typ, const string &txt, const string &aux)
: title(typ), text(txt), auxText(aux)
PRadException::PRadException(PRadExceptionType typ, const string &txt, const string &aux)
: type(typ), text(txt), auxText(aux)
PRadException::PRadException(PRadExceptionType typ, const string &txt, const string &file, const string &func, int line)
ostringstream oss;
oss << " evioException occured in file " << file << ", function " << func << ", line " << line;
auxText=oss.str();
string PRadException::FailureDesc(void) const
ostringstream oss;
oss << text << endl
<< auxText;
return(oss.str());
string PRadException::FailureType(void) const
if(!title.empty())
return title;
string oss;
switch(type)
case ET_CONNECT_ERROR:
oss = "ET CONNECT ERROR";
break;
case ET_CONFIG_ERROR:
oss = "ET CONFIG ERROR";
break;
case ET_STATION_CONFIG_ERROR:
oss = "ET STATION CONFIG ERROR";
break;
case ET_STATION_CREATE_ERROR:
oss = "ET STATION CREATE ERROR";
break;
case ET_STATION_ATTACH_ERROR:
oss = "ET ATTACH ERROR";
break;
case ET_READ_ERROR:
oss = "ET READ ERROR";
break;
case ET_PUT_ERROR:
oss = "ET PUT ERROR";
break;
case HIGH_VOLTAGE_ERROR:
oss = "HIGH VOLTAGE SYSTEM ERROR";
break;
default:
oss = "UNKNOWN ERROR";
break;
return(oss);
const char* PRadException::what() const noexcept
string failure = FailureType() + ": " + FailureDesc();
return failure.c_str();
#ifndef PRAD_EXCEPTION_H
#define PRAD_EXCEPTION_H
#include <stdlib.h>
#include <string.h>
#include <exception>
#include <string>
#include <sstream>
class PRadException : public std::exception
public:
enum PRadExceptionType
UNKNOWN_ERROR,
ET_CONNECT_ERROR,
ET_CONFIG_ERROR,
ET_STATION_CONFIG_ERROR,
ET_STATION_CREATE_ERROR,
ET_STATION_ATTACH_ERROR,
ET_READ_ERROR,
ET_PUT_ERROR,
HIGH_VOLTAGE_ERROR,
PRadException(const std::string &typ, const std::string &txt = "", const std::string &aux = "");
PRadException(PRadExceptionType typ = UNKNOWN_ERROR, const std::string &txt = "", const std::string &aux = "");
PRadException(PRadExceptionType typ, const std::string &txt, const std::string &file, const std::string &func, int line);
virtual ~PRadException(void) {}
virtual std::string FailureDesc(void) const;
virtual std::string FailureType(void) const;
const char *what() const noexcept;
public:
PRadExceptionType type; // exception type
std::string title;
std::string text; // primary text
std::string auxText; // auxiliary text
#endif
...@@ -39,7 +39,8 @@ THcAerogel::THcAerogel( const char* name, const char* description, ...@@ -39,7 +39,8 @@ THcAerogel::THcAerogel( const char* name, const char* description,
THaNonTrackingDetector(name,description,apparatus), THaNonTrackingDetector(name,description,apparatus),
fPresentP(0), fPresentP(0),
fAdcPosTimeWindowMin(0), fAdcPosTimeWindowMax(0), fAdcNegTimeWindowMin(0), fAdcPosTimeWindowMin(0), fAdcPosTimeWindowMax(0), fAdcNegTimeWindowMin(0),
fAdcNegTimeWindowMax(0), fRegionValue(0), fPosGain(0), fNegGain(0), fAdcNegTimeWindowMax(0),fPedNegDefault(0),fPedPosDefault(0),
frPosAdcPedRaw(0), frPosAdcPulseIntRaw(0), frPosAdcPulseAmpRaw(0), frPosAdcPedRaw(0), frPosAdcPulseIntRaw(0), frPosAdcPulseAmpRaw(0),
frPosAdcPulseTimeRaw(0), frPosAdcPed(0), frPosAdcPulseInt(0), frPosAdcPulseTimeRaw(0), frPosAdcPed(0), frPosAdcPulseInt(0),
frPosAdcPulseAmp(0), frPosAdcPulseTime(0), frNegAdcPedRaw(0), frPosAdcPulseAmp(0), frPosAdcPulseTime(0), frNegAdcPedRaw(0),
...@@ -59,7 +60,8 @@ THcAerogel::THcAerogel( const char* name, const char* description, ...@@ -59,7 +60,8 @@ THcAerogel::THcAerogel( const char* name, const char* description,
THcAerogel::THcAerogel( ) : THcAerogel::THcAerogel( ) :
THaNonTrackingDetector(), THaNonTrackingDetector(),
fPedNegDefault(0),fPedPosDefault(0),fRegionValue(0), fPosGain(0), fNegGain(0),
...@@ -111,6 +113,8 @@ void THcAerogel::DeleteArrays() ...@@ -111,6 +113,8 @@ void THcAerogel::DeleteArrays()
delete [] fAdcPosTimeWindowMax; fAdcPosTimeWindowMax = 0; delete [] fAdcPosTimeWindowMax; fAdcPosTimeWindowMax = 0;
delete [] fAdcNegTimeWindowMin; fAdcNegTimeWindowMin = 0; delete [] fAdcNegTimeWindowMin; fAdcNegTimeWindowMin = 0;
delete [] fAdcNegTimeWindowMax; fAdcNegTimeWindowMax = 0; delete [] fAdcNegTimeWindowMax; fAdcNegTimeWindowMax = 0;
delete [] fPedNegDefault; fPedNegDefault = 0;
delete [] fPedPosDefault; fPedPosDefault = 0;
// 6 GeV variables // 6 GeV variables
delete fPosTDCHits; fPosTDCHits = NULL; delete fPosTDCHits; fPosTDCHits = NULL;
...@@ -296,6 +300,8 @@ Int_t THcAerogel::ReadDatabase( const TDatime& date ) ...@@ -296,6 +300,8 @@ Int_t THcAerogel::ReadDatabase( const TDatime& date )
fAdcPosTimeWindowMax = new Double_t [fNelem]; fAdcPosTimeWindowMax = new Double_t [fNelem];
fAdcNegTimeWindowMin = new Double_t [fNelem]; fAdcNegTimeWindowMin = new Double_t [fNelem];
fAdcNegTimeWindowMax = new Double_t [fNelem]; fAdcNegTimeWindowMax = new Double_t [fNelem];
fPedNegDefault = new Int_t [fNelem];
fPedPosDefault = new Int_t [fNelem];
DBRequest list[]={ DBRequest list[]={
{"aero_num_regions", &fNRegions, kInt}, {"aero_num_regions", &fNRegions, kInt},
...@@ -315,6 +321,8 @@ Int_t THcAerogel::ReadDatabase( const TDatime& date ) ...@@ -315,6 +321,8 @@ Int_t THcAerogel::ReadDatabase( const TDatime& date )
{"aero_adcPosTimeWindowMax", fAdcPosTimeWindowMax, kDouble, static_cast<UInt_t>(fNelem), 1}, {"aero_adcPosTimeWindowMax", fAdcPosTimeWindowMax, kDouble, static_cast<UInt_t>(fNelem), 1},
{"aero_adcNegTimeWindowMin", fAdcNegTimeWindowMin, kDouble, static_cast<UInt_t>(fNelem), 1}, {"aero_adcNegTimeWindowMin", fAdcNegTimeWindowMin, kDouble, static_cast<UInt_t>(fNelem), 1},
{"aero_adcNegTimeWindowMax", fAdcNegTimeWindowMax, kDouble, static_cast<UInt_t>(fNelem), 1}, {"aero_adcNegTimeWindowMax", fAdcNegTimeWindowMax, kDouble, static_cast<UInt_t>(fNelem), 1},
{"aero_PedNegDefault", fPedNegDefault, kInt, static_cast<UInt_t>(fNelem), 1},
{"aero_PedPosDefault", fPedPosDefault, kInt, static_cast<UInt_t>(fNelem), 1},
{"aero_adc_tdc_offset", &fAdcTdcOffset, kDouble, 0, 1}, {"aero_adc_tdc_offset", &fAdcTdcOffset, kDouble, 0, 1},
{"aero_debug_adc", &fDebugAdc, kInt, 0, 1}, {"aero_debug_adc", &fDebugAdc, kInt, 0, 1},
{"aero_six_gev_data", &fSixGevData, kInt, 0, 1}, {"aero_six_gev_data", &fSixGevData, kInt, 0, 1},
...@@ -331,6 +339,8 @@ Int_t THcAerogel::ReadDatabase( const TDatime& date ) ...@@ -331,6 +339,8 @@ Int_t THcAerogel::ReadDatabase( const TDatime& date )
fAdcNegTimeWindowMin[ip] = -1000.; fAdcNegTimeWindowMin[ip] = -1000.;
fAdcPosTimeWindowMax[ip] = 1000.; fAdcPosTimeWindowMax[ip] = 1000.;
fAdcNegTimeWindowMax[ip] = 1000.; fAdcNegTimeWindowMax[ip] = 1000.;
fPedNegDefault[ip] = 0.;
fPedPosDefault[ip] = 0.;
fSixGevData = 0; // Set 6 GeV data parameter to false unless set in parameter file fSixGevData = 0; // Set 6 GeV data parameter to false unless set in parameter file
...@@ -646,6 +656,21 @@ Int_t THcAerogel::Decode( const THaEvData& evdata ) ...@@ -646,6 +656,21 @@ Int_t THcAerogel::Decode( const THaEvData& evdata )
if (rawPosAdcHit.GetPulseAmpRaw(thit) > 0) ((THcSignalHit*) fPosAdcErrorFlag->ConstructedAt(nrPosAdcHits))->Set(npmt, 0); if (rawPosAdcHit.GetPulseAmpRaw(thit) > 0) ((THcSignalHit*) fPosAdcErrorFlag->ConstructedAt(nrPosAdcHits))->Set(npmt, 0);
if (rawPosAdcHit.GetPulseAmpRaw(thit) <= 0) ((THcSignalHit*) fPosAdcErrorFlag->ConstructedAt(nrPosAdcHits))->Set(npmt, 1); if (rawPosAdcHit.GetPulseAmpRaw(thit) <= 0) ((THcSignalHit*) fPosAdcErrorFlag->ConstructedAt(nrPosAdcHits))->Set(npmt, 1);
if (rawPosAdcHit.GetPulseAmpRaw(thit) <= 0) {
Double_t PeakPedRatio= rawPosAdcHit.GetF250_PeakPedestalRatio();
Int_t NPedSamples= rawPosAdcHit.GetF250_NPedestalSamples();
Double_t AdcToC = rawPosAdcHit.GetAdcTopC();
Double_t AdcToV = rawPosAdcHit.GetAdcTomV();
if (fPedPosDefault[npmt-1] !=0) {
Double_t tPulseInt = AdcToC*(rawPosAdcHit.GetPulseIntRaw(thit) - fPedPosDefault[npmt-1]*PeakPedRatio);
((THcSignalHit*) frPosAdcPulseInt->ConstructedAt(nrPosAdcHits))->Set(npmt, tPulseInt);
((THcSignalHit*) frPosAdcPedRaw->ConstructedAt(nrPosAdcHits))->Set(npmt, fPedPosDefault[npmt-1]);
((THcSignalHit*) frPosAdcPed->ConstructedAt(nrPosAdcHits))->Set(npmt, float(fPedPosDefault[npmt-1])/float(NPedSamples)*AdcToV);
((THcSignalHit*) frPosAdcPulseAmp->ConstructedAt(nrPosAdcHits))->Set(npmt, 0.);
++nrPosAdcHits; ++nrPosAdcHits;
fTotNumAdcHits++; fTotNumAdcHits++;
...@@ -669,6 +694,21 @@ Int_t THcAerogel::Decode( const THaEvData& evdata ) ...@@ -669,6 +694,21 @@ Int_t THcAerogel::Decode( const THaEvData& evdata )
if (rawNegAdcHit.GetPulseAmpRaw(thit) > 0) ((THcSignalHit*) fNegAdcErrorFlag->ConstructedAt(nrNegAdcHits))->Set(npmt, 0); if (rawNegAdcHit.GetPulseAmpRaw(thit) > 0) ((THcSignalHit*) fNegAdcErrorFlag->ConstructedAt(nrNegAdcHits))->Set(npmt, 0);
if (rawNegAdcHit.GetPulseAmpRaw(thit) <= 0) ((THcSignalHit*) fNegAdcErrorFlag->ConstructedAt(nrNegAdcHits))->Set(npmt, 1); if (rawNegAdcHit.GetPulseAmpRaw(thit) <= 0) ((THcSignalHit*) fNegAdcErrorFlag->ConstructedAt(nrNegAdcHits))->Set(npmt, 1);
if (rawNegAdcHit.GetPulseAmpRaw(thit) <= 0) {
Double_t PeakPedRatio= rawNegAdcHit.GetF250_PeakPedestalRatio();
Int_t NPedSamples= rawNegAdcHit.GetF250_NPedestalSamples();
Double_t AdcToC = rawNegAdcHit.GetAdcTopC();
Double_t AdcToV = rawNegAdcHit.GetAdcTomV();
if (fPedNegDefault[npmt-1] !=0) {
Double_t tPulseInt = AdcToC*(rawNegAdcHit.GetPulseIntRaw(thit) - fPedNegDefault[npmt-1]*PeakPedRatio);
((THcSignalHit*) frNegAdcPulseInt->ConstructedAt(nrNegAdcHits))->Set(npmt, tPulseInt);
((THcSignalHit*) frNegAdcPedRaw->ConstructedAt(nrNegAdcHits))->Set(npmt, fPedNegDefault[npmt-1]);
((THcSignalHit*) frNegAdcPed->ConstructedAt(nrNegAdcHits))->Set(npmt, float(fPedNegDefault[npmt-1])/float(NPedSamples)*AdcToV);
((THcSignalHit*) frNegAdcPulseAmp->ConstructedAt(nrNegAdcHits))->Set(npmt, 0.);
++nrNegAdcHits; ++nrNegAdcHits;
fTotNumNegAdcHits++; fTotNumNegAdcHits++;
...@@ -690,6 +730,8 @@ Int_t THcAerogel::CoarseProcess( TClonesArray& ) //tracks ...@@ -690,6 +730,8 @@ Int_t THcAerogel::CoarseProcess( TClonesArray& ) //tracks
Double_t StartTime = 0.0; Double_t StartTime = 0.0;
if( fglHod ) StartTime = fglHod->GetStartTime(); if( fglHod ) StartTime = fglHod->GetStartTime();
Double_t OffsetTime = 0.0;
if( fglHod ) OffsetTime = fglHod->GetOffsetTime();
//cout << " starttime = " << StartTime << endl; //cout << " starttime = " << StartTime << endl;
// Loop over the elements in the TClonesArray // Loop over the elements in the TClonesArray
for(Int_t ielem = 0; ielem < frPosAdcPulseInt->GetEntries(); ielem++) { for(Int_t ielem = 0; ielem < frPosAdcPulseInt->GetEntries(); ielem++) {
...@@ -700,18 +742,13 @@ Int_t THcAerogel::CoarseProcess( TClonesArray& ) //tracks ...@@ -700,18 +742,13 @@ Int_t THcAerogel::CoarseProcess( TClonesArray& ) //tracks
Double_t pulseIntRaw = ((THcSignalHit*) frPosAdcPulseIntRaw->ConstructedAt(ielem))->GetData(); Double_t pulseIntRaw = ((THcSignalHit*) frPosAdcPulseIntRaw->ConstructedAt(ielem))->GetData();
Double_t pulseAmp = ((THcSignalHit*) frPosAdcPulseAmp->ConstructedAt(ielem))->GetData(); Double_t pulseAmp = ((THcSignalHit*) frPosAdcPulseAmp->ConstructedAt(ielem))->GetData();
Double_t pulseTime = ((THcSignalHit*) frPosAdcPulseTime->ConstructedAt(ielem))->GetData(); Double_t pulseTime = ((THcSignalHit*) frPosAdcPulseTime->ConstructedAt(ielem))->GetData();
Double_t adctdcdiffTime = StartTime-pulseTime; Double_t adctdcdiffTime = StartTime-pulseTime+OffsetTime;
Bool_t errorFlag = ((THcSignalHit*) fPosAdcErrorFlag->ConstructedAt(ielem))->GetData();
//// Bool_t pulseTimeCut = adctdcdiffTime > fAdcTimeWindowMin && adctdcdiffTime < fAdcTimeWindowMax; //// Bool_t pulseTimeCut = adctdcdiffTime > fAdcTimeWindowMin && adctdcdiffTime < fAdcTimeWindowMax;
Bool_t pulseTimeCut = adctdcdiffTime > fAdcPosTimeWindowMin[npmt] && adctdcdiffTime < fAdcPosTimeWindowMax[npmt]; Bool_t pulseTimeCut = adctdcdiffTime > fAdcPosTimeWindowMin[npmt] && adctdcdiffTime < fAdcPosTimeWindowMax[npmt];
// By default, the last hit within the timing cut will be considered "good" // By default, the last hit within the timing cut will be considered "good"
if (!errorFlag)
fGoodPosAdcMult.at(npmt) += 1; fGoodPosAdcMult.at(npmt) += 1;
} if (pulseTimeCut) {
if (!errorFlag && pulseTimeCut) {
fGoodPosAdcPed.at(npmt) = pulsePed; fGoodPosAdcPed.at(npmt) = pulsePed;
// cout << " out = " << npmt << " " << frPosAdcPulseInt->GetEntries() << " " <<fGoodPosAdcMult.at(npmt); // cout << " out = " << npmt << " " << frPosAdcPulseInt->GetEntries() << " " <<fGoodPosAdcMult.at(npmt);
fGoodPosAdcPulseInt.at(npmt) = pulseInt; fGoodPosAdcPulseInt.at(npmt) = pulseInt;
...@@ -738,17 +775,13 @@ Int_t THcAerogel::CoarseProcess( TClonesArray& ) //tracks ...@@ -738,17 +775,13 @@ Int_t THcAerogel::CoarseProcess( TClonesArray& ) //tracks
Double_t pulseIntRaw = ((THcSignalHit*) frNegAdcPulseIntRaw->ConstructedAt(ielem))->GetData(); Double_t pulseIntRaw = ((THcSignalHit*) frNegAdcPulseIntRaw->ConstructedAt(ielem))->GetData();
Double_t pulseAmp = ((THcSignalHit*) frNegAdcPulseAmp->ConstructedAt(ielem))->GetData(); Double_t pulseAmp = ((THcSignalHit*) frNegAdcPulseAmp->ConstructedAt(ielem))->GetData();
Double_t pulseTime = ((THcSignalHit*) frNegAdcPulseTime->ConstructedAt(ielem))->GetData(); Double_t pulseTime = ((THcSignalHit*) frNegAdcPulseTime->ConstructedAt(ielem))->GetData();
Bool_t errorFlag = ((THcSignalHit*) fNegAdcErrorFlag->ConstructedAt(ielem))->GetData();
Bool_t pulseTimeCut = adctdcdiffTime > fAdcNegTimeWindowMin[npmt] && adctdcdiffTime < fAdcNegTimeWindowMax[npmt]; Bool_t pulseTimeCut = adctdcdiffTime > fAdcNegTimeWindowMin[npmt] && adctdcdiffTime < fAdcNegTimeWindowMax[npmt];
if (!errorFlag)
fGoodNegAdcMult.at(npmt) += 1; fGoodNegAdcMult.at(npmt) += 1;
if (!errorFlag && pulseTimeCut) { if (pulseTimeCut) {
fGoodNegAdcPed.at(npmt) = pulsePed; fGoodNegAdcPed.at(npmt) = pulsePed;
fGoodNegAdcPulseIntRaw.at(npmt) = pulseIntRaw; fGoodNegAdcPulseIntRaw.at(npmt) = pulseIntRaw;
fGoodNegAdcPulseAmp.at(npmt) = pulseAmp; fGoodNegAdcPulseAmp.at(npmt) = pulseAmp;
...@@ -73,6 +73,8 @@ class THcAerogel : public THaNonTrackingDetector, public THcHitList { ...@@ -73,6 +73,8 @@ class THcAerogel : public THaNonTrackingDetector, public THcHitList {
Double_t *fAdcPosTimeWindowMax; Double_t *fAdcPosTimeWindowMax;
Double_t *fAdcNegTimeWindowMin; Double_t *fAdcNegTimeWindowMin;
Double_t *fAdcNegTimeWindowMax; Double_t *fAdcNegTimeWindowMax;
Int_t* fPedNegDefault;
Int_t* fPedPosDefault;
Double_t fAdcTdcOffset; Double_t fAdcTdcOffset;
Double_t *fRegionValue; Double_t *fRegionValue;
This diff is collapsed.
...@@ -69,6 +69,7 @@ public: ...@@ -69,6 +69,7 @@ public:
Int_t fTotNumGoodAdcHits; Int_t fTotNumGoodAdcHits;
Int_t fTotNumTracksMatched; Int_t fTotNumTracksMatched;
Int_t fTotNumTracksFired; Int_t fTotNumTracksFired;
Double_t fRefTime;
Double_t fNpeSum; Double_t fNpeSum;
Double_t* fGain; Double_t* fGain;
...@@ -102,6 +103,7 @@ public: ...@@ -102,6 +103,7 @@ public:
Double_t fNpeThresh; Double_t fNpeThresh;
Double_t* fAdcTimeWindowMin; Double_t* fAdcTimeWindowMin;
Double_t* fAdcTimeWindowMax; Double_t* fAdcTimeWindowMax;
Int_t* fPedDefault;
Double_t* fRegionValue; Double_t* fRegionValue;
...@@ -65,6 +65,14 @@ void THcCoinTime::Clear( Option_t* opt ) ...@@ -65,6 +65,14 @@ void THcCoinTime::Clear( Option_t* opt )
fROC2_ePosCoinTime=kBig; fROC2_ePosCoinTime=kBig;
fROC1_RAW_CoinTime=kBig; fROC1_RAW_CoinTime=kBig;
fROC2_RAW_CoinTime=kBig; fROC2_RAW_CoinTime=kBig;
fTRIG1_ePosCoinTime=kBig;
fTRIG4_ePosCoinTime=kBig;
fTRIG1_ePiCoinTime=kBig;
fTRIG4_ePiCoinTime=kBig;
fTRIG1_eKCoinTime=kBig;
fTRIG4_eKCoinTime=kBig;
fTRIG1_epCoinTime=kBig;
fTRIG4_epCoinTime=kBig;
//_____________________________________________________________________________ //_____________________________________________________________________________
...@@ -263,6 +271,9 @@ Int_t THcCoinTime::Process( const THaEvData& evdata ) ...@@ -263,6 +271,9 @@ Int_t THcCoinTime::Process( const THaEvData& evdata )
Double_t hms_ypfp = theHMSTrack->GetPhi(); Double_t hms_ypfp = theHMSTrack->GetPhi();
Double_t HMS_FPtime = theHMSTrack->GetFPTime(); Double_t HMS_FPtime = theHMSTrack->GetFPTime();
if (SHMS_FPtime==-2000 || HMS_FPtime==-2000) return 1;
if (SHMS_FPtime==-1000 || HMS_FPtime==-1000) return 1;
//Get raw TDC Times for HMS/SHMS (3/4 trigger) //Get raw TDC Times for HMS/SHMS (3/4 trigger)
pTRIG1_TdcTime_ROC1 = fCoinDet->Get_CT_Trigtime(0); //SHMS pTRIG1_TdcTime_ROC1 = fCoinDet->Get_CT_Trigtime(0); //SHMS
pTRIG4_TdcTime_ROC1 = fCoinDet->Get_CT_Trigtime(1); //HMS pTRIG4_TdcTime_ROC1 = fCoinDet->Get_CT_Trigtime(1); //HMS
...@@ -227,7 +227,7 @@ protected: ...@@ -227,7 +227,7 @@ protected:
public: public:
THcDriftChamberPlane* GetPlane(unsigned int i_plane) { THcDriftChamberPlane* GetPlane(unsigned int i_plane) {
if(i_plane < fNPlanes) { if(static_cast<int>(i_plane) < fNPlanes) {
return fPlanes[i_plane]; return fPlanes[i_plane];
return nullptr; return nullptr;
...@@ -298,6 +298,7 @@ Int_t THcDriftChamberPlane::DefineVariables( EMode mode ) ...@@ -298,6 +298,7 @@ Int_t THcDriftChamberPlane::DefineVariables( EMode mode )
{"dist","Drift distancess", {"dist","Drift distancess",
"fHits.THcDCHit.GetDist()"}, "fHits.THcDCHit.GetDist()"},
{"nhit", "Number of hits", "GetNHits()"}, {"nhit", "Number of hits", "GetNHits()"},
{"RefTime", "TDC reference time", "fTdcRefTime"},
{ 0 } { 0 }
...@@ -351,7 +352,7 @@ Int_t THcDriftChamberPlane::ProcessHits(TClonesArray* rawhits, Int_t nexthit) ...@@ -351,7 +352,7 @@ Int_t THcDriftChamberPlane::ProcessHits(TClonesArray* rawhits, Int_t nexthit)
fHits->Clear(); fHits->Clear();
fRawHits->Clear(); fRawHits->Clear();
fTdcRefTime = kBig;
Int_t nrawhits = rawhits->GetLast()+1; Int_t nrawhits = rawhits->GetLast()+1;
fNRawhits=0; fNRawhits=0;
Int_t ihit = nexthit; Int_t ihit = nexthit;
...@@ -365,6 +366,7 @@ Int_t THcDriftChamberPlane::ProcessHits(TClonesArray* rawhits, Int_t nexthit) ...@@ -365,6 +366,7 @@ Int_t THcDriftChamberPlane::ProcessHits(TClonesArray* rawhits, Int_t nexthit)
Int_t wireNum = hit->fCounter; Int_t wireNum = hit->fCounter;
THcDCWire* wire = GetWire(wireNum); THcDCWire* wire = GetWire(wireNum);
Bool_t First_Hit_In_Window = kTRUE; Bool_t First_Hit_In_Window = kTRUE;
if (hit->GetRawTdcHit().HasRefTime()) fTdcRefTime = hit->GetRawTdcHit().GetRefTime();
for(UInt_t mhit=0; mhit<hit->GetRawTdcHit().GetNHits(); mhit++) { for(UInt_t mhit=0; mhit<hit->GetRawTdcHit().GetNHits(); mhit++) {
fNRawhits++; fNRawhits++;
/* Sort into early, late and ontime */ /* Sort into early, late and ontime */
...@@ -391,6 +393,7 @@ Int_t THcDriftChamberPlane::SubtractStartTime() ...@@ -391,6 +393,7 @@ Int_t THcDriftChamberPlane::SubtractStartTime()
if (StartTime == -1000) StartTime = 0.0;
for(Int_t ihit=0;ihit<GetNHits();ihit++) { for(Int_t ihit=0;ihit<GetNHits();ihit++) {
THcDCHit *thishit = (THcDCHit*) fHits->At(ihit); THcDCHit *thishit = (THcDCHit*) fHits->At(ihit);
Double_t temptime= thishit->GetTime()-StartTime; Double_t temptime= thishit->GetTime()-StartTime;
...@@ -86,6 +86,8 @@ protected: ...@@ -86,6 +86,8 @@ protected:
TClonesArray* fHits; TClonesArray* fHits;
TClonesArray* fRawHits; TClonesArray* fRawHits;
TClonesArray* fWires; TClonesArray* fWires;
Double_t fTdcRefTime;
Int_t fVersion; Int_t fVersion;
Int_t fWireOrder; Int_t fWireOrder;
...@@ -142,6 +142,10 @@ Int_t THcHallCSpectrometer::DefineVariables( EMode mode ) ...@@ -142,6 +142,10 @@ Int_t THcHallCSpectrometer::DefineVariables( EMode mode )
fIsSetup = ( mode == kDefine ); fIsSetup = ( mode == kDefine );
RVarDef vars[] = { RVarDef vars[] = {
{ "tr.betachisq", "Chi2 of beta", "fTracks.THaTrack.GetBetaChi2()"}, { "tr.betachisq", "Chi2 of beta", "fTracks.THaTrack.GetBetaChi2()"},
{ "tr.GoodPlane4", "Flag for track hitting hodo plane 4", "fTracks.THaTrack.GetGoodPlane4()"},
{ "tr.GoodPlane3", "Flag for track hitting hodo plane 3", "fTracks.THaTrack.GetGoodPlane3()"},
{ "tr.fptime", "Track hodo focal plane time", "fTracks.THaTrack.GetFPTime()"},
{ "tr.npmt", "Track number of hodo PMTs hit", "fTracks.THaTrack.GetNPMT()"},
{ "tr.PruneSelect", "Prune Select ID", "fPruneSelect"}, { "tr.PruneSelect", "Prune Select ID", "fPruneSelect"},
{ "present", "Trigger Type includes this spectrometer", "fPresent"}, { "present", "Trigger Type includes this spectrometer", "fPresent"},
{ 0 } { 0 }
...@@ -10,60 +10,59 @@ ...@@ -10,60 +10,59 @@
#include "Rtypes.h" #include "Rtypes.h"
#include "THaHelicityDet.h"
#include "hcana/Logger.h"
class THaEvData; class THaEvData;
class TDatime; class TDatime;
class TH1F; class TH1F;
class THcHelicityReader { class THcHelicityReader : public hcana::ConfigLogging<podd2::EmptyBase> {
public: public:
THcHelicityReader(); THcHelicityReader();
virtual ~THcHelicityReader(); virtual ~THcHelicityReader();
struct ROCinfo { struct ROCinfo {
Int_t roc; // ROC to read out Int_t roc; // ROC to read out
Int_t slot; // Headers to search for (0 = ignore) Int_t slot; // Headers to search for (0 = ignore)
Int_t index; // Index into buffer Int_t index; // Index into buffer
protected:
protected:
// Used by ReadDatabase // Used by ReadDatabase
enum EROC { kHel = 0, kHelm, kMPS, kQrt, kTime, kCount }; enum EROC { kHel = 0, kHelm, kMPS, kQrt, kTime, kCount };
Int_t SetROCinfo( EROC which, Int_t roc, Int_t slot, Int_t index ); Int_t SetROCinfo(EROC which, Int_t roc, Int_t slot, Int_t index);
virtual void Clear( Option_t* opt="" ); virtual void Clear(Option_t* opt = "");
virtual Int_t ReadData( const THaEvData& evdata ); virtual Int_t ReadData(const THaEvData& evdata);
Int_t ReadDatabase( const char* dbfilename, const char* prefix, Int_t ReadDatabase(const char* dbfilename, const char* prefix, const TDatime& date,
const TDatime& date, int debug_flag = 0 ); int debug_flag = 0);
void Begin(); void Begin();
void End(); void End();
ULong64_t fTITime; ULong64_t fTITime;
UInt_t fTITime_last; UInt_t fTITime_last;
UInt_t fTITime_rollovers; UInt_t fTITime_rollovers;
// Reported Helicity status for the event // Reported Helicity status for the event
Bool_t fIsMPS; Bool_t fIsMPS;
Bool_t fIsQrt; Bool_t fIsQrt;
Bool_t fIsHelp; Bool_t fIsHelp;
Bool_t fIsHelm; Bool_t fIsHelm;
Int_t fADCThreshold; // Threshold for On/Off of helicity signals Int_t fADCThreshold; // Threshold for On/Off of helicity signals
ROCinfo fROCinfo[kCount]; ROCinfo fROCinfo[kCount];
Int_t fQWEAKDebug; // Debug level Int_t fQWEAKDebug; // Debug level
Bool_t fHaveROCs; // Required ROCs are defined Bool_t fHaveROCs; // Required ROCs are defined
Bool_t fNegGate; // Invert polarity of gate, TO DO implement this functionality Bool_t fNegGate; // Invert polarity of gate, TO DO implement this functionality
static const Int_t NHISTR = 12; static const Int_t NHISTR = 12;
// TH1F* fHistoR[12]; // Histograms // TH1F* fHistoR[12]; // Histograms
private: private:
ClassDef(THcHelicityReader, 0) // Helper class for reading QWEAK helicity data
ClassDef(THcHelicityReader,0) // Helper class for reading QWEAK helicity data
#endif #endif
...@@ -73,6 +73,7 @@ protected: ...@@ -73,6 +73,7 @@ protected:
Int_t slot; Int_t slot;
Int_t channel; Int_t channel;
Int_t reftime; Int_t reftime;
Int_t refdifftime;
std::vector<RefIndexMap> fRefIndexMaps; std::vector<RefIndexMap> fRefIndexMaps;
// Should this be a sparse list instead in case user // Should this be a sparse list instead in case user
...@@ -34,6 +34,9 @@ public: ...@@ -34,6 +34,9 @@ public:
Double_t GetNegADCpeak() const { return fNegADC_Peak; } Double_t GetNegADCpeak() const { return fNegADC_Peak; }
Double_t GetPosADCtime() const { return fPosADC_Time; } Double_t GetPosADCtime() const { return fPosADC_Time; }
Double_t GetNegADCtime() const { return fNegADC_Time; } Double_t GetNegADCtime() const { return fNegADC_Time; }
Double_t GetPosADCCorrtime() const { return fPosADC_CorrTime; }
Double_t GetNegADCCorrtime() const { return fNegADC_CorrTime; }
Double_t GetCalcPosition() const { return fCalcPosition; }
Int_t GetPosTDC() const { return fPosTDC; } Int_t GetPosTDC() const { return fPosTDC; }
Int_t GetNegTDC() const { return fNegTDC; } Int_t GetNegTDC() const { return fNegTDC; }
Double_t GetPosCorrectedTime() const { return fPosCorrectedTime;} Double_t GetPosCorrectedTime() const { return fPosCorrectedTime;}
...@@ -46,8 +49,9 @@ public: ...@@ -46,8 +49,9 @@ public:
Int_t GetPaddleNumber() const { return fPaddleNumber; } Int_t GetPaddleNumber() const { return fPaddleNumber; }
Double_t GetPaddleCenter() const { return fPaddleCenter; } Double_t GetPaddleCenter() const { return fPaddleCenter; }
void SetCorrectedTimes(Double_t pos, Double_t neg, Double_t) { void SetCorrectedTimes(Double_t pos, Double_t neg) {
fPosCorrectedTime = pos; fNegCorrectedTime = neg; fPosCorrectedTime = pos; fNegCorrectedTime = neg;
fHasCorrectedTimes = kFALSE;
void SetCorrectedTimes(Double_t pos, Double_t neg, void SetCorrectedTimes(Double_t pos, Double_t neg,
Double_t postof, Double_t negtof, Double_t postof, Double_t negtof,
...@@ -75,6 +79,15 @@ public: ...@@ -75,6 +79,15 @@ public:
void SetNegADCtime( Double_t ptime) { void SetNegADCtime( Double_t ptime) {
fNegADC_Time =ptime; fNegADC_Time =ptime;
void SetPosADCCorrtime( Double_t ptime) {
fPosADC_CorrTime =ptime;
void SetNegADCCorrtime( Double_t ptime) {
fNegADC_CorrTime =ptime;
void SetCalcPosition( Double_t calcpos) {
fCalcPosition =calcpos;
protected: protected:
static const Double_t kBig; //! static const Double_t kBig; //!
...@@ -86,6 +99,9 @@ protected: ...@@ -86,6 +99,9 @@ protected:
Double_t fNegADC_Peak; // ADC peak amplitude Double_t fNegADC_Peak; // ADC peak amplitude
Double_t fPosADC_Time; // ADC time Double_t fPosADC_Time; // ADC time
Double_t fNegADC_Time; // ADC time Double_t fNegADC_Time; // ADC time
Double_t fPosADC_CorrTime; // ADC time
Double_t fNegADC_CorrTime; // ADC time
Double_t fCalcPosition; // Position along paddle calculated by time diff
Int_t fPaddleNumber; Int_t fPaddleNumber;
Double_t fPosCorrectedTime; // Pulse height corrected time Double_t fPosCorrectedTime; // Pulse height corrected time
