Skip to content
Snippets Groups Projects
Unverified Commit d7454baa authored by darmac's avatar darmac Committed by GitHub
Browse files
util-linux: add libmount variant (#15631)
parent c3e41444
Branches
Tags
No related merge requests found
...@@ -24,15 +24,22 @@ class UtilLinux(AutotoolsPackage): ...@@ -24,15 +24,22 @@ class UtilLinux(AutotoolsPackage):
depends_on('python@2.7:') depends_on('python@2.7:')
depends_on('pkgconfig') depends_on('pkgconfig')
depends_on('gettext', when='+libmount')
# Make it possible to disable util-linux's libuuid so that you may # Make it possible to disable util-linux's libuuid so that you may
# reliably depend_on(`libuuid`). # reliably depend_on(`libuuid`).
variant('libuuid', default=True, description='Build libuuid') variant('libuuid', default=True, description='Build libuuid')
variant('libmount', default=False, description='Build libmount.so with gettext')
def url_for_version(self, version): def url_for_version(self, version):
url = "https://www.kernel.org/pub/linux/utils/util-linux/v{0}/util-linux-{1}.tar.gz" url = "https://www.kernel.org/pub/linux/utils/util-linux/v{0}/util-linux-{1}.tar.gz"
return url.format(version.up_to(2), version) return url.format(version.up_to(2), version)
def setup_build_environment(self, env):
if '+libmount' in self.spec:
env.append_flags('LDFLAGS', '-L{0} -lintl'.format(
self.spec['gettext'].prefix.lib))
def configure_args(self): def configure_args(self):
config_args = [ config_args = [
'--disable-use-tty-group', '--disable-use-tty-group',
0% Loading or .
Please register or to comment
