Skip to content
Snippets Groups Projects
Commit d50a18d9 authored by Peter Scheibel's avatar Peter Scheibel
Browse files
XML output for unit tests is now enabled with an option (disabled by default)
parent 60f77566
No related branches found
No related tags found
No related merge requests found
...@@ -39,9 +39,12 @@ def setup_parser(subparser): ...@@ -39,9 +39,12 @@ def setup_parser(subparser):
'names', nargs='*', help="Names of tests to run.") 'names', nargs='*', help="Names of tests to run.")
subparser.add_argument( subparser.add_argument(
'-l', '--list', action='store_true', dest='list', help="Show available tests") '-l', '--list', action='store_true', dest='list', help="Show available tests")
# TODO: make XML output optional
'-d', '--outputDir', dest='outputDir', help="Nose creates XML files in this directory") '--createXmlOutput', action='store_true', dest='createXmlOutput',
help="Create JUnit XML from test results")
'--xmlOutputDir', dest='xmlOutputDir',
'-v', '--verbose', action='store_true', dest='verbose', '-v', '--verbose', action='store_true', dest='verbose',
help="verbose output") help="verbose output")
...@@ -53,10 +56,14 @@ def test(parser, args): ...@@ -53,10 +56,14 @@ def test(parser, args):
colify(spack.test.list_tests(), indent=2) colify(spack.test.list_tests(), indent=2)
else: else:
if not args.outputDir: if not args.createXmlOutput:
outputDir = join_path(os.getcwd(), "test-output") outputDir = None
else: else:
outputDir = args.outputDir if not args.xmlOutputDir:
if not os.path.exists(outputDir): outputDir = join_path(os.getcwd(), "test-output")
mkdirp(outputDir) else:
outputDir = os.path.abspath(args.xmlOutputDir)
mkdirp(outputDir)
spack.test.run(args.names, outputDir, args.verbose) spack.test.run(args.names, outputDir, args.verbose)
...@@ -92,11 +92,13 @@ def run(names, outputDir, verbose=False): ...@@ -92,11 +92,13 @@ def run(names, outputDir, verbose=False):
tty.msg("Running test: %s" % test) tty.msg("Running test: %s" % test)
xmlOutputFname = "unittests-{0}.xml".format(test) runOpts = ["--with-%s" % spack.test.tally_plugin.Tally.name]
xmlOutputPath = join_path(outputDir, xmlOutputFname)
runOpts = ["--with-%s" % spack.test.tally_plugin.Tally.name, if outputDir:
"--with-xunit", xmlOutputFname = "unittests-{0}.xml".format(test)
"--xunit-file={0}".format(xmlOutputPath)] xmlOutputPath = join_path(outputDir, xmlOutputFname)
runOpts += ["--with-xunit",
argv = [""] + runOpts + [module] argv = [""] + runOpts + [module]
result = nose.run(argv=argv, addplugins=[tally]) result = nose.run(argv=argv, addplugins=[tally])
...@@ -35,6 +35,7 @@ def __init__(self): ...@@ -35,6 +35,7 @@ def __init__(self):
self.failCount = 0 self.failCount = 0
self.errorCount = 0 self.errorCount = 0
# TODO: this doesn't account for the possibility of skipped tests
@property @property
def numberOfTests(self): def numberOfTests(self):
return self.errorCount + self.failCount + self.successCount return self.errorCount + self.failCount + self.successCount
0% Loading or .
Please register or to comment
