Skip to content
Snippets Groups Projects
Commit bee5c055 authored by Todd Gamblin's avatar Todd Gamblin
Browse files
Update tests to reflect new in-memory hashing vs. coarser dag_hash.
- Spack currently not hashing build deps (to allow more reuse of packages
  and less frequent re-installing)
- Fast in-memory hash should still hash *all* deptypes, and installed
  specs will only reflect link and run deps.
- We'll revert this when we can concretize more liberally based on what
  is already installed.
parent 235a045d
No related branches found
No related tags found
No related merge requests found
...@@ -91,22 +91,33 @@ def test_read_and_write_spec(self): ...@@ -91,22 +91,33 @@ def test_read_and_write_spec(self):
# Make sure spec file can be read back in to get the original spec # Make sure spec file can be read back in to get the original spec
spec_from_file = self.layout.read_spec(spec_path) spec_from_file = self.layout.read_spec(spec_path)
self.assertEqual(spec, spec_from_file)
self.assertTrue(spec.eq_dag, spec_from_file) # currently we don't store build dependency information when
# we write out specs to the filesystem.
# TODO: fix this when we can concretize more loosely based on
# TODO: what is installed. We currently omit these to
# TODO: increase reuse of build dependencies.
stored_deptypes = ('link', 'run')
expected = spec.copy(deps=stored_deptypes)
self.assertEqual(expected, spec_from_file)
self.assertTrue(expected.eq_dag, spec_from_file)
self.assertTrue(spec_from_file.concrete) self.assertTrue(spec_from_file.concrete)
# Ensure that specs that come out "normal" are really normal. # Ensure that specs that come out "normal" are really normal.
with open(spec_path) as spec_file: with open(spec_path) as spec_file:
read_separately = Spec.from_yaml(spec_file.read()) read_separately = Spec.from_yaml(spec_file.read())
read_separately.normalize() # TODO: revise this when build deps are in dag_hash
self.assertEqual(read_separately, spec_from_file) norm = read_separately.normalized().copy(deps=stored_deptypes)
self.assertEqual(norm, spec_from_file)
read_separately.concretize() # TODO: revise this when build deps are in dag_hash
self.assertEqual(read_separately, spec_from_file) conc = read_separately.concretized().copy(deps=stored_deptypes)
self.assertEqual(conc, spec_from_file)
# Make sure the hash of the read-in spec is the same # Make sure the hash of the read-in spec is the same
self.assertEqual(spec.dag_hash(), spec_from_file.dag_hash()) self.assertEqual(expected.dag_hash(), spec_from_file.dag_hash())
# Ensure directories are properly removed # Ensure directories are properly removed
self.layout.remove_install_directory(spec) self.layout.remove_install_directory(spec)
0% Loading or .
Please register or to comment
