Skip to content
Snippets Groups Projects
Unverified Commit b472c138 authored by Sergey Kosukhin's avatar Sergey Kosukhin Committed by GitHub
Browse files
Fix FCFLAGS handling for Autotools packages (#14788)
Spack's fflags are meant for both f77 and fc. Therefore, they must
be passed as FFLAGS and FCFLAGS to the configure scripts of
Autotools-based packages.
parent 370e7c21
Branches
Tags
No related merge requests found
...@@ -43,7 +43,7 @@ parameters=( ...@@ -43,7 +43,7 @@ parameters=(
# The compiler input variables are checked for sanity later: # The compiler input variables are checked for sanity later:
# SPACK_CC, SPACK_CXX, SPACK_F77, SPACK_FC # SPACK_CC, SPACK_CXX, SPACK_F77, SPACK_FC
# The default compiler flags are passed from these variables: # The default compiler flags are passed from these variables:
# SPACK_CFLAGS, SPACK_CXXFLAGS, SPACK_FCFLAGS, SPACK_FFLAGS, # SPACK_CFLAGS, SPACK_CXXFLAGS, SPACK_FFLAGS,
# SPACK_LDFLAGS, SPACK_LDLIBS # SPACK_LDFLAGS, SPACK_LDLIBS
# Debug env var is optional; set to "TRUE" for debug logging: # Debug env var is optional; set to "TRUE" for debug logging:
# SPACK_DEBUG # SPACK_DEBUG
...@@ -263,6 +263,12 @@ def flags_to_build_system_args(self, flags): ...@@ -263,6 +263,12 @@ def flags_to_build_system_args(self, flags):
if values: if values:
values_str = '{0}={1}'.format(flag.upper(), ' '.join(values)) values_str = '{0}={1}'.format(flag.upper(), ' '.join(values))
self.configure_flag_args.append(values_str) self.configure_flag_args.append(values_str)
# Spack's fflags are meant for both F77 and FC, therefore we
# additionaly set FCFLAGS if required.
values = flags.get('fflags', None)
if values:
values_str = 'FCFLAGS={0}'.format(' '.join(values))
def configure(self, spec, prefix): def configure(self, spec, prefix):
"""Runs configure with the arguments specified in """Runs configure with the arguments specified in
0% Loading or .
Please register or to comment
