Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
S
Spack
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package Registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
eic_tools
Spack
Commits
b3ba45af
Commit
b3ba45af
authored
8 years ago
by
Adam J. Stewart
Committed by
Todd Gamblin
8 years ago
Browse files
Options
Downloads
Patches
Plain Diff
Various improvements to H5hut (#2636)
parent
c89de04f
No related branches found
Branches containing commit
No related tags found
Tags containing commit
No related merge requests found
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
var/spack/repos/builtin/packages/h5hut/package.py
+38
-33
38 additions, 33 deletions
with
38 additions
and
33 deletions
38
33
View file @
b3ba45af
@@ -26,45 +26,50 @@
@@ -26,45 +26,50 @@
from
spack
import
from
spack
import
class
H5hut
Package
class
H5hut
AutotoolsPackage
H5hut (HDF5 Utility Toolkit)
H5hut (HDF5 Utility Toolkit).
High-Performance I/O Library for Particle-based Simulations
High-Performance I/O Library for Particle-based Simulations.
homepage
https://amas.psi.ch/H5hut/
homepage
url
https://amas.psi.ch/H5hut/raw-attachment/wiki/DownloadSources/H5hut-1.99.13.tar.gz
url
version
1.99.13
2a07a449afe50534de006ac6954a421a
version
1.99.13
variant
fortran
default
True
description
Enable Fortran support
variant
fortran
default
True
description
variant
mpi
default
True
description
Enable MPI support
variant
mpi
default
True
description
Enable MPI support
depends_on
autoconf @2.60:
type
build
depends_on
mpi
when
+mpi
depends_on
automake
type
build
depends_on
hdf5 +mpi
when
+mpi
depends_on
hdf5 @1.8:
# h5hut +mpi uses the obsolete function H5Pset_fapl_mpiposix:
depends_on
hdf5 @:1.8.12
when
+mpi
depends_on
hdf5@1.8:1.8.12+mpi
when
+mpi
depends_on
libtool
type
build
depends_on
hdf5@1.8:
when
~mpi
depends_on
mpi
when
+mpi
def
install
self
spec
prefix
# If built in parallel, the following error message occurs:
autogen
Executable
./autogen.sh
# install: .libs/libH5hut.a: No such file or directory
autogen
parallel
False
configopts
--prefix={0}
format
prefix
if
+fortran
in
spec
if
not
self
compiler
fc
raise
RuntimeError
Cannot build Fortran variant without a Fortran compiler
configopts
append
--enable-fortran
if
+mpi
in
spec
configopts
extend
--enable-parallel
CC=%s
spec
mpi
mpicc
CXX=%s
spec
mpi
mpicxx
if
+fortran
in
spec
configopts
append
FC=%s
spec
mpi
mpifc
configure
configopts
make
@AutotoolsPackage.precondition
configure
make
install
def
validate
self
Checks if Fortran compiler is available.
if
+fortran
in
self
spec
and
not
self
compiler
fc
raise
RuntimeError
Cannot build Fortran variant without a Fortran compiler.
def
configure_args
self
spec
self
spec
config_args
--enable-shared
if
+fortran
in
spec
config_args
append
--enable-fortran
if
+mpi
in
spec
config_args
extend
--enable-parallel
CC={0}
format
spec
mpi
mpicc
CXX={0}
format
spec
mpi
mpicxx
if
+fortran
in
spec
config_args
append
FC={0}
format
spec
mpi
mpifc
return
config_args
This diff is collapsed.
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
