Skip to content
Snippets Groups Projects
Commit a7143771 authored by Barry Smith's avatar Barry Smith Committed by Todd Gamblin
Browse files
python: PYTHONHOME may not be the same as the prefix of the python executable (#2173)
On MacOS, brew installs /usr/local/bin/python but the Python prefix is not /usr/local/bin
Use the python command sys.exec to get the correct directory, instead of the ad hoc self.prefix
previously used
This was a bear to debug; been driving me nuts since I started using spack.
Since spack passes PYTHONHOME down to package builds in the environment
it was passing PYTHONHOME of /usr/local/bin to the PETSc build that uses Python so
the PETSc Python ./configure errored immediately with
ImportError: No module named site
since python could find no python modules. Todd Gamblin pointed out that my first try to fix
this was wrong since it assumed the spack python was the same python used to run spack. Elizabeth Fischer
suggested how to get it to work also with python3
Funded-by: IDEAS
Project: IDEAS/xSDK
Time:  7 hours
Thanks-to: Todd Gamblin, Elizabeth Fischer
parent 9989f8e2
Branches
Tags
No related merge requests found
...@@ -202,8 +202,27 @@ def site_packages_dir(self): ...@@ -202,8 +202,27 @@ def site_packages_dir(self):
def setup_dependent_environment(self, spack_env, run_env, extension_spec): def setup_dependent_environment(self, spack_env, run_env, extension_spec):
"""Set PYTHONPATH to include site-packages dir for the """Set PYTHONPATH to include site-packages dir for the
extension and any other python extensions it depends on.""" extension and any other python extensions it depends on."""
pythonhome = self.prefix # The python executable for version 3 may be python3 or python
spack_env.set('PYTHONHOME', pythonhome) # See https://github.com/LLNL/spack/pull/2173#issuecomment-257170199
pythonex = 'python{0}'.format('3' if self.spec.satisfies('@3') else '')
if os.path.isdir(self.prefix.bin):
base = self.prefix.bin
else:
base = self.prefix
if not os.path.isfile(os.path.join(base, pythonex)):
if self.spec.satisfies('@3'):
python = Executable(os.path.join(base, 'python'))
version = python('-c', 'import sys; print(sys.version)',
output=str)
if version.startswith('3'):
pythonex = 'python'
else:
raise RuntimeError('Cannot locate python executable')
else:
python = Executable(os.path.join(base, pythonex))
prefix = python('-c', 'import sys; print(sys.prefix)', output=str)
spack_env.set('PYTHONHOME', prefix.strip('\n'))
python_paths = [] python_paths = []
for d in extension_spec.traverse(deptype=nolink, deptype_query='run'): for d in extension_spec.traverse(deptype=nolink, deptype_query='run'):
0% Loading or .
Please register or to comment
