Skip to content
Snippets Groups Projects
Commit a5f88d6e authored by Jerome Soumagne's avatar Jerome Soumagne Committed by Adam J. Stewart
Browse files
Clean up mercury package and add boostsys, shared variants (#11368)
Use tarballs instead of git tags
Fix openpa dependency on gcc < 4.9
Fix boost dependency
Change sm variant default to true
parent d284ea39
No related branches found
No related tags found
No related merge requests found
......@@ -9,21 +9,28 @@ class Mercury(CMakePackage):
"""Mercury is a C library for implementing RPC, optimized for HPC"""
homepage = 'https://mercury-hpc.github.io/'
url = 'https://github.com/mercury-hpc/mercury/archive/0.9.0.tar.gz'
url = 'https://github.com/mercury-hpc/mercury/releases/download/v1.0.1/mercury-1.0.1.tar.bz2'
git = 'https://github.com/mercury-hpc/mercury.git'
version('develop', branch='master', submodules=True)
version('1.0.1', tag='v1.0.1', submodules=True)
version('1.0.0', tag='v1.0.0', submodules=True)
version('0.9.0', tag='v0.9.0', submodules=True)
variant('bmi', default=False, description='Use BMI for network transport')
variant('cci', default=False, description='Use CCI for network transport')
variant('mpi', default=False, description='Use MPI for network transport')
variant('ofi', default=True, description='Use libfabric plugin')
variant('sm', default=False, description='Use shared-memory plugin')
variant('opa', default=False, description='Use OpenPA for atomics')
variant('boost', default=True, description='Use BOOST preprocessor macros')
maintainers = ['soumagne']
version('master', branch='master', submodules=True)
version('1.0.1', sha256='02febd56c401ef7afa250caf28d012b37dee842bfde7ee16fcd2f741b9cf25b3')
version('1.0.0', sha256='fb0e44d13f4652f53e21040435f91d452bc2b629b6e98dcf5292cd0bece899d4')
version('0.9.0', sha256='40868e141cac035213fe79400f8926823fb1f5a0651fd7027cbe162b063843ef')
variant('bmi', default=False, description='Use BMI plugin')
variant('cci', default=False, description='Use CCI plugin')
variant('mpi', default=False, description='Use MPI plugin')
variant('ofi', default=True, description='Use OFI libfabric plugin')
# NOTE: the sm plugin does not require any package dependency.
variant('sm', default=True, description='Use shared-memory plugin')
# NOTE: if boostsys is False, mercury will install its own copy
# of the preprocessor headers.
variant('boostsys', default=True,
description='Use preprocessor headers from boost dependency')
variant('shared', default=True,
description='Build with shared libraries')
variant('selfforward', default=True,
description='Mercury will short-circuit operations' +
' by forwarding to itself when possible')
......@@ -38,78 +45,55 @@ class Mercury(CMakePackage):
depends_on('bmi', when='+bmi')
depends_on('mpi', when='+mpi')
depends_on('libfabric@1.5:', when='+ofi')
depends_on('openpa@1.0.3:', when='+opa')
depends_on('boost@1.48:', when='+boost')
depends_on('openpa@1.0.3:', when='%gcc@:4.8')
depends_on('boost@1.48:', when='+boostsys')
depends_on('boost', when='@:0.9') # internal boost headers were added in 1.0.0
conflicts('+ofi', when='@:0.9') # libfabric support was added in 1.0.0
conflicts('~ofi', when='+udreg') # udreg option is specific to OFI
def cmake_args(self):
"""Populate cmake arguments for Mercury."""
spec = self.spec
args = [
'-DBUILD_SHARED_LIBS=ON',
'-DMERCURY_USE_CHECKSUMS=ON',
'-DMERCURY_USE_EAGER_BULK=ON',
'-DMERCURY_USE_SYSTEM_MCHECKSUM=OFF',
'-DMERCURY_USE_XDR=OFF'
variant_bool = lambda feature: str(feature in spec)
parallel_tests = '+mpi' in spec and self.run_tests
cmake_args = [
'-DBUILD_SHARED_LIBS:BOOL=%s' % variant_bool('+shared'),
'-DBUILD_TESTING:BOOL=%s' % str(self.run_tests),
'-DMERCURY_ENABLE_PARALLEL_TESTING:BOOL=%s' % str(parallel_tests),
'-DMERCURY_USE_BOOST_PP:BOOL=ON',
'-DMERCURY_USE_CHECKSUMS:BOOL=ON',
'-DMERCURY_USE_EAGER_BULK:BOOL=ON',
'-DMERCURY_USE_SELF_FORWARD:BOOL=%s'
% variant_bool('+selfforward'),
'-DMERCURY_USE_SYSTEM_MCHECKSUM:BOOL=OFF',
'-DMERCURY_USE_XDR:BOOL=OFF',
'-DNA_USE_BMI:BOOL=%s' % variant_bool('+bmi'),
'-DNA_USE_CCI:BOOL=%s' % variant_bool('+cci'),
'-DNA_USE_MPI:BOOL=%s' % variant_bool('+mpi'),
'-DNA_USE_SM:BOOL=%s' % variant_bool('+sm'),
if '+boost' in spec:
args.append('-DMERCURY_USE_BOOST_PP=ON')
else:
args.append('-DMERCURY_USE_BOOST_PP=OFF')
if '+bmi' in spec:
args.append('-DNA_USE_BMI=ON')
else:
args.append('-DNA_USE_BMI=OFF')
if '+cci' in spec:
args.append('-DNA_USE_CCI=ON')
else:
args.append('-DNA_USE_CCI=OFF')
if '+mpi' in spec:
args.append('-DNA_USE_MPI=ON')
else:
args.append('-DNA_USE_MPI=OFF')
if '@1.0.0:' in spec:
cmake_args.extend([
'-DMERCURY_USE_SYSTEM_BOOST:BOOL=%s'
% variant_bool('+boostsys'),
'-DNA_USE_OFI:BOOL=%s' % variant_bool('+ofi'),
if '+ofi' in spec:
args.append('-DNA_USE_OFI=ON')
cmake_args.append(
'-DNA_OFI_GNI_USE_UDREG:BOOL=%s' % variant_bool('+udreg')
if self.run_tests:
args.append('-DNA_OFI_TESTING_PROTOCOL={0}'.format(';'.join(
spec['libfabric'].variants['fabrics'].value)))
else:
args.append('-DNA_USE_OFI=OFF')
if '+sm' in spec:
args.append('-DNA_USE_SM=ON')
else:
args.append('-DNA_USE_SM=OFF')
if '+opa' in spec:
args.append('-DMERCURY_USE_OPA=ON')
else:
args.append('-DMERCURY_USE_OPA=OFF')
if '+selfforward' in spec:
args.append('-DMERCURY_USE_SELF_FORWARD=ON')
else:
args.append('-DMERCURY_USE_SELF_FORWARD=OFF')
if '+udreg' in spec:
args.append('-DNA_OFI_GNI_USE_UDREG=ON')
else:
args.append('-DNA_OFI_GNI_USE_UDREG=OFF')
if self.run_tests:
args.append('-DBUILD_TESTING=ON')
else:
args.append('-DBUILD_TESTING=OFF')
if '+mpi' in spec and self.run_tests:
args.append('-DMERCURY_ENABLE_PARALLEL_TESTING=ON')
else:
args.append('-DMERCURY_ENABLE_PARALLEL_TESTING=OFF')
cmake_args.append(
'-DNA_OFI_TESTING_PROTOCOL:STRING={0}'.format(
';'.join(spec['libfabric'].variants['fabrics'].value)
return args
return cmake_args
def check(self):
"""Unit tests fail when run in parallel."""
0% Loading or .
Please register or to comment
