Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
S
Spack
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
GitLab community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
eic_tools
Spack
Commits
a2b9a000
Commit
a2b9a000
authored
Apr 29, 2016
by
Brett Viren
Browse files
Options
Downloads
Patches
Plain Diff
Add add removal and status actions in addition to link and add various ways to filter what is done.
parent
49956faa
No related branches found
No related tags found
No related merge requests found
Changes
1
Show whitespace changes
Inline
Side-by-side
Showing
1 changed file
lib/spack/spack/cmd/view.py
+107
-23
107 additions, 23 deletions
with
107 additions
and
23 deletions
107
23
View file @
a2b9a000
Produce a file-system
view
of a Spack DAG.
Concept from Nix, implemented by brett.viren@gmail.com ca 2016.
# Copyright (c) 2013, Lawrence Livermore National Security, LLC.
# Produced at the Lawrence Livermore National Laboratory.
@@ -22,7 +27,9 @@
@@ -22,7 +27,9 @@
# along with this program; if not, write to the Free Software Foundation,
# Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
import
os
import
os
import
re
import
argparse
import
argparse
import
spack
import
spack
@@ -34,8 +41,15 @@
@@ -34,8 +41,15 @@
def
setup_parser
subparser
def
setup_parser
subparser
setup_parser
parser
subparser
setup_parser
parser
subparser
subparser
add_argument
prefix
nargs
1
subparser
add_argument
-e
--exclude
action
append
default
help
Path to top-level directory for the view.
help
exclude any packages which the given re pattern
subparser
add_argument
-a
--action
default
link
choices
link
remove
status
# names match action_*() functions below
help
what action to perform on the view
subparser
add_argument
--no-dependencies
action
store_true
default
False
help
just operate on named packages and do not follow dependencies
subparser
add_argument
-p
--prefix
required
True
help
Path to a top-level directory to receive the view.
subparser
add_argument
specs
nargs
argparse
REMAINDER
subparser
add_argument
specs
nargs
argparse
REMAINDER
help
specs of packages to expose in the view.
help
@@ -45,64 +59,134 @@ def assuredir(path):
os
makedirs
path
os
makedirs
path
def
relative_to
prefix
path
def
relative_to
prefix
path
Return end of `path` relative to `prefix`
assert
0
path
find
prefix
assert
0
path
find
prefix
reldir
path
len
prefix
reldir
path
len
prefix
if
reldir
startswith
if
reldir
startswith
reldir
reldir
1
reldir
reldir
1
return
reldir
return
reldir
def
view_one
prefix
spec
print
spec
name
spec
prefix
def
transform_path
spec
path
prefix
None
Return the a relative path corresponding to given path spec.prefix
if
os
path
isabs
path
path
relative_to
spec
prefix
path
subdirs
path
split
os
path
sep
if
subdirs
0
.spack
lst
.spack
spec
name
subdirs
1
path
os
path
join
lst
if
prefix
path
os
path
join
prefix
path
return
path
def
action_status
spec
prefix
Check status of view in prefix against spec
dotspack
os
path
join
prefix
.spack
spec
name
dotspack
os
path
join
prefix
.spack
spec
name
if
os
path
exists
os
path
join
dotspack
if
os
path
exists
os
path
join
dotspack
tty
warn
Skipping previously added package %s
spec
name
tty
info
Package added: %s
spec
name
return
tty
info
Package missing: %s
spec
name
return
def
action_remove
spec
prefix
Remove any files found in spec from prefix and purge empty directories.
if
not
os
path
exists
prefix
return
return
dotspack
transform_path
spec
.spack
prefix
if
not
os
path
exists
dotspack
tty
info
Skipping nonexistent package %s
spec
name
return
for
dirpath
dirnames
filenames
in
os
walk
spec
prefix
for
dirpath
dirnames
filenames
in
os
walk
spec
prefix
if
not
filenames
if
not
filenames
continue
# avoid explicitly making empty dirs
continue
targdir
transform_path
spec
dirpath
prefix
for
fname
in
filenames
src
os
path
join
dirpath
fname
dst
os
path
join
targdir
fname
if
not
os
path
exists
dst
#tty.warn("Skipping nonexistent file for view: %s" % dst)
continue
os
unlink
dst
reldir
relative_to
spec
prefix
dirpath
# fixme: assumes .spack has no subdirs
def
action_link
spec
prefix
if
dirpath
endswith
.spack
Symlink all files in `spec` into directory `prefix`.
targdir
dotspack
else
targdir
os
path
join
prefix
reldir
dotspack
transform_path
spec
.spack
prefix
if
os
path
exists
dotspack
tty
warn
spec
name
return
for
dirpath
dirnames
filenames
in
os
walk
spec
prefix
if
not
filenames
continue
targdir
transform_path
spec
dirpath
prefix
assuredir
targdir
assuredir
targdir
print
\t
%s...
reldir
nlinks
0
for
fname
in
filenames
for
fname
in
filenames
src
os
path
join
dirpath
fname
src
os
path
join
dirpath
fname
dst
os
path
join
targdir
fname
dst
os
path
join
targdir
fname
if
os
path
exists
dst
if
os
path
exists
dst
if
.spack
in
dst
split
os
path
sep
continue
# silence these
tty
warn
Skipping existing file for view: %s
dst
tty
warn
dst
continue
continue
os
symlink
src
dst
os
symlink
src
dst
nlinks
1
print
nlinks
def
purge_empty_directories
path
Ascend up from the leaves accessible from `path` and remove empty directories.
for
dirpath
subdirs
files
in
os
walk
path
topdown
False
for
sd
in
subdirs
sdp
os
path
join
dirpath
sd
try
os
rmdir
sdp
except
OSError
tty
warn
Not removing directory with contents: %s
sdp
def
view
parser
args
def
view
parser
args
# if not args.specs:
The view command.
# tty.die("view creation requires at least one spec argument")
to_exclude
re
compile
e
for
e
in
args
exclude
def
exclude
spec
for
e
in
to_exclude
if
e
match
spec
name
return
True
return
False
specs
spack
cmd
parse_specs
args
specs
normalize
True
concretize
True
specs
spack
cmd
parse_specs
args
specs
normalize
True
concretize
True
if
not
specs
if
not
specs
setup_parser
parser
print_help
setup_parser
parser
print_help
return
1
return
1
prefix
args
prefix
0
prefix
args
prefix
assuredir
prefix
assuredir
prefix
flat
set
flat
set
for
spec
in
specs
for
spec
in
specs
if
args
no_dependencies
flat
add
spec
continue
flat
update
spec
normalized
traverse
flat
update
spec
normalized
traverse
action
args
action
lower
method
eval
action_
action
for
spec
in
flat
for
spec
in
flat
view_one
prefix
spec
if
exclude
spec
tty
info
Skipping excluded package:
%s
spec
name
continue
if
not
os
path
exists
spec
prefix
tty
warn
Skipping unknown package: %s in %s
spec
name
spec
prefix
continue
tty
info
%s %s
action
spec
name
method
spec
prefix
if
action
in
remove
prefix
This diff is collapsed.
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
