- Downloads
New package Jali - unstructured mesh infrastructure for multiphysics applications (#14498)
* add variant for enabling testing * add variant for enabling testing * enable tests and clean up other options * enable tests and clean up other options * add numbered versions * add numbered versions * updates to avoid enable_tests variant; correct versioning * updates to avoid enable_tests variant; correct versioning * fixes for style * appropriate partitioners are enabled if 'all' is specified - so no need to check in spec * revert accidental change to copyright * remove erroneously re-introduced line about tests * new spack recipe for build Jali - unstructured mesh infrastructure for multiphysics applications * remove the +parallel condition for mstk, update 1.1.1 sha256sum and whitespace cleanup * reformat description * cut down description
Please register or sign in to comment
