Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
S
Spack
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
eic_tools
Spack
Commits
87610a51
Commit
87610a51
authored
9 years ago
by
Todd Gamblin
Browse files
Options
Downloads
Plain Diff
Merge pull request #448 from epfl-scitas/packages/gromacs
Added package : gromacs
parents
93a74604
30c30474
No related branches found
No related tags found
No related merge requests found
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
var/spack/repos/builtin/packages/fftw/package.py
+2
-0
2 additions, 0 deletions
var/spack/repos/builtin/packages/gromacs/package.py
+56
-0
56 additions, 0 deletions
with
58 additions
and
0 deletions
2
0
View file @
87610a51
@@ -47,6 +47,8 @@ class Fftw(Package):
depends_on
mpi
when
+mpi
depends_on
mpi
when
+mpi
# TODO : add support for architecture specific optimizations as soon as targets are supported
def
install
self
spec
prefix
def
install
self
spec
prefix
options
--prefix=%s
prefix
options
--prefix=%s
prefix
--enable-shared
--enable-shared
This diff is collapsed.
0 → 100644
56
0
View file @
87610a51
from
spack
import
class
Gromacs
Package
GROMACS (GROningen MAchine for Chemical Simulations) is a molecular dynamics package primarily designed for
simulations of proteins, lipids and nucleic acids. It was originally developed in the Biophysical Chemistry
department of University of Groningen, and is now maintained by contributors in universities and research centers
across the world.
GROMACS is one of the fastest and most popular software packages available and can run on CPUs as well as GPUs.
It is free, open source released under the GNU General Public License. Starting from version 4.6, GROMACS is
released under the GNU Lesser General Public License.
homepage
http://www.gromacs.org
url
ftp://ftp.gromacs.org/pub/gromacs/gromacs-5.1.2.tar.gz
version
5.1.2
614d0be372f1a6f1f36382b7a6fcab98
variant
mpi
default
True
description
Activate MPI support
variant
shared
default
True
description
Enables the build of shared libraries
variant
debug
default
False
description
Enables debug mode
variant
double
default
False
description
Produces a double precision version of the executables
depends_on
mpi
when
+mpi
depends_on
fftw
# TODO : add GPU support
def
install
self
spec
prefix
options
if
+mpi
in
spec
options
append
-DGMX_MPI:BOOL=ON
if
+double
in
spec
options
append
-DGMX_DOUBLE:BOOL=ON
if
~shared
in
spec
options
append
-DBUILD_SHARED_LIBS:BOOL=OFF
if
+debug
in
spec
options
append
-DCMAKE_BUILD_TYPE:STRING=Debug
else
options
append
-DCMAKE_BUILD_TYPE:STRING=Release
options
extend
std_cmake_args
with
working_dir
spack-build
create
True
cmake
options
make
make
install
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
