Skip to content
Snippets Groups Projects
Commit 7bd73541 authored by Massimiliano Culpo's avatar Massimiliano Culpo
Browse files
package.py : moved each specialized package to its own module file
parent e0f31889
No related branches found
No related tags found
No related merge requests found
...@@ -196,7 +196,9 @@ ...@@ -196,7 +196,9 @@
'alldeps', 'alldeps',
'nolink'] 'nolink']
from spack.package import Package, ExtensionConflictError from spack.package import Package, ExtensionConflictError
from spack.package import CMakePackage, AutotoolsPackage, EditableMakefile from spack.build_systems.editable_makefile import EditableMakefile
from spack.build_systems.autotools import AutotoolsPackage
from spack.build_systems.cmake import CMakePackage
from spack.version import Version, ver from spack.version import Version, ver
from spack.spec import DependencySpec, alldeps, nolink from spack.spec import DependencySpec, alldeps, nolink
from spack.multimethod import when from spack.multimethod import when
# Copyright (c) 2013-2016, Lawrence Livermore National Security, LLC.
# Produced at the Lawrence Livermore National Laboratory.
# This file is part of Spack.
# Created by Todd Gamblin, tgamblin@llnl.gov, All rights reserved.
# LLNL-CODE-647188
# For details, see https://github.com/llnl/spack
# Please also see the LICENSE file for our notice and the LGPL.
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License (as
# published by the Free Software Foundation) version 2.1, February 1999.
# This program is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the IMPLIED WARRANTY OF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the terms and
# conditions of the GNU Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
import inspect
import os.path
import llnl.util.tty as tty
from spack.package import PackageBase
class AutotoolsPackage(PackageBase):
"""Specialized class for packages that are built using GNU Autotools
This class provides four phases that can be overridden:
- autoreconf
- configure
- build
- install
They all have sensible defaults and for many packages the only thing
necessary will be to override `configure_args`
phases = ['autoreconf', 'configure', 'build', 'install']
# To be used in UI queries that require to know which
# build-system class we are using
build_system_class = 'AutotoolsPackage'
def autoreconf(self, spec, prefix):
"""Not needed usually, configure should be already there"""
pass
@PackageBase.sanity_check('autoreconf')
def is_configure_or_die(self):
"""Checks the presence of a `configure` file after the
autoreconf phase"""
if not os.path.exists('configure'):
raise RuntimeError(
'configure script not found in {0}'.format(os.getcwd()))
def configure_args(self):
"""Method to be overridden. Should return an iterable containing
all the arguments that must be passed to configure, except --prefix
return []
def configure(self, spec, prefix):
"""Runs configure with the arguments specified in `configure_args`
and an appropriately set prefix
options = ['--prefix={0}'.format(prefix)] + self.configure_args()
inspect.getmodule(self).configure(*options)
def build(self, spec, prefix):
"""The usual `make` after configure"""
inspect.getmodule(self).make()
def install(self, spec, prefix):
"""...and the final `make install` after configure"""
inspect.getmodule(self).make('install')
@PackageBase.sanity_check('build')
@PackageBase.on_package_attributes(run_tests=True)
def _run_default_function(self):
"""This function is run after build if self.run_tests == True
It will search for a method named `check` and run it. A sensible
default is provided in the base class.
try:
fn = getattr(self, 'check')
tty.msg('Trying default sanity checks [check]')
fn()
except AttributeError:
tty.msg('Skipping default sanity checks [method `check` not implemented]') # NOQA: ignore=E501
def check(self):
"""Default test : search the Makefile for targets `test` and `check`
and run them if found.
self._if_make_target_execute('test')
self._if_make_target_execute('check')
# Check that self.prefix is there after installation
PackageBase.sanity_check('install')(PackageBase.sanity_check_prefix)
# LLNL-CODE-647188
import inspect
import os
import platform
import spack.build_environment
from llnl.util.filesystem import working_dir, join_path
class CMakePackage(PackageBase):
"""Specialized class for packages that are built using cmake
This class provides three phases that can be overridden:
- cmake
- build
- install
necessary will be to override `cmake_args`
phases = ['cmake', 'build', 'install']
build_system_class = 'CMakePackage'
def build_type(self):
"""Override to provide the correct build_type in case a complex
logic is needed
return 'RelWithDebInfo'
def root_cmakelists_dir(self):
"""Directory where to find the root CMakeLists.txt"""
return self.stage.source_path
@property
def std_cmake_args(self):
"""Standard cmake arguments provided as a property for
convenience of package writers
# standard CMake arguments
return CMakePackage._std_args(self)
@staticmethod
def _std_args(pkg):
"""Computes the standard cmake arguments for a generic package"""
try:
build_type = pkg.build_type()
build_type = 'RelWithDebInfo'
args = ['-DCMAKE_INSTALL_PREFIX:PATH={0}'.format(pkg.prefix),
'-DCMAKE_BUILD_TYPE:STRING={0}'.format(build_type),
'-DCMAKE_VERBOSE_MAKEFILE:BOOL=ON']
if platform.mac_ver()[0]:
args.append('-DCMAKE_FIND_FRAMEWORK:STRING=LAST')
# Set up CMake rpath
args.append('-DCMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=FALSE')
rpaths = ':'.join(spack.build_environment.get_rpaths(pkg))
args.append('-DCMAKE_INSTALL_RPATH:STRING={0}'.format(rpaths))
return args
def build_directory(self):
"""Override to provide another place to build the package"""
return join_path(self.stage.source_path, 'spack-build')
def cmake_args(self):
all the arguments that must be passed to configure, except:
- CMAKE_INSTALL_PREFIX
- CMAKE_BUILD_TYPE
return []
def cmake(self, spec, prefix):
"""Run cmake in the build directory"""
options = [self.root_cmakelists_dir()] + self.std_cmake_args + \
self.cmake_args()
create = not os.path.exists(self.build_directory())
with working_dir(self.build_directory(), create=create):
inspect.getmodule(self).cmake(*options)
"""The usual `make` after cmake"""
with working_dir(self.build_directory()):
"""...and the final `make install` after cmake"""
try:
tty.msg('Trying default build sanity checks [check]')
fn()
tty.msg('Skipping default build sanity checks [method `check` not implemented]') # NOQA: ignore=E501
def check(self):
"""Default test : search the Makefile for the target `test`
# LLNL-CODE-647188
import inspect
class EditableMakefile(PackageBase):
"""Specialized class for packages that are built using editable Makefiles
- edit
- build
- install
It is necessary to override the 'edit' phase, while 'build' and 'install'
have sensible defaults.
phases = ['edit', 'build', 'install']
build_system_class = 'EditableMakefile'
"""Directory where the main Makefile is located"""
def build_args(self):
"""List of arguments that should be passed to make at build time"""
return []
def install_args(self):
"""List of arguments that should be passed to make at install time"""
return []
def edit(self, spec, prefix):
"""This phase cannot be defaulted for obvious reasons..."""
raise NotImplementedError('\'edit\' function not implemented')
"""Default build phase : call make passing build_args"""
args = self.build_args()
inspect.getmodule(self).make(*args)
"""Default install phase : call make passing install_args"""
args = self.install_args() + ['install']
...@@ -38,7 +38,6 @@ ...@@ -38,7 +38,6 @@
import functools import functools
import inspect import inspect
import os import os
import platform
import re import re
import sys import sys
import textwrap import textwrap
...@@ -48,7 +47,6 @@ ...@@ -48,7 +47,6 @@
import llnl.util.lock import llnl.util.lock
import llnl.util.tty as tty import llnl.util.tty as tty
import spack import spack
import spack.compilers import spack.compilers
import spack.directives import spack.directives
import spack.error import spack.error
...@@ -1698,159 +1696,6 @@ class Package(PackageBase): ...@@ -1698,159 +1696,6 @@ class Package(PackageBase):
PackageBase.sanity_check('install')(PackageBase.sanity_check_prefix) PackageBase.sanity_check('install')(PackageBase.sanity_check_prefix)
def wdir(self):
return []
return []
with working_dir(self.wdir()):
pass
raise RuntimeError(
return []
try:
fn()
def check(self):
# This will be used as a registration decorator in user
# packages, if need be
@property
@staticmethod
def _std_args(pkg):
try:
return args
return []
self.cmake_args()
try:
fn()
def check(self):
def install_dependency_symlinks(pkg, spec, prefix): def install_dependency_symlinks(pkg, spec, prefix):
"""Execute a dummy install and flatten dependencies""" """Execute a dummy install and flatten dependencies"""
flatten_dependencies(spec, prefix) flatten_dependencies(spec, prefix)
...@@ -37,11 +37,11 @@ class Astyle(EditableMakefile): ...@@ -37,11 +37,11 @@ class Astyle(EditableMakefile):
parallel = False parallel = False
def wdir(self): def build_directory(self):
return join_path(self.stage.source_path, 'build', self.compiler.name) return join_path(self.stage.source_path, 'build', self.compiler.name)
def edit(self, spec, prefix): def edit(self, spec, prefix):
makefile = join_path(self.wdir(), 'Makefile') makefile = join_path(self.build_directory(), 'Makefile')
filter_file(r'^CXX\s*=.*', 'CXX=%s' % spack_cxx, makefile) filter_file(r'^CXX\s*=.*', 'CXX=%s' % spack_cxx, makefile)
def install_args(self): def install_args(self):
0% Loading or .
Please register or to comment
