Skip to content
Snippets Groups Projects
Unverified Commit 7357b702 authored by Massimiliano Culpo's avatar Massimiliano Culpo Committed by GitHub
Browse files
Update link for codecov's browser extensions (#15779)
parent 77e13849
No related branches found
No related tags found
No related merge requests found
...@@ -385,8 +385,8 @@ coverage. This helps us tell what percentage of lines of code in Spack are ...@@ -385,8 +385,8 @@ coverage. This helps us tell what percentage of lines of code in Spack are
covered by unit tests. Although code covered by unit tests can still contain covered by unit tests. Although code covered by unit tests can still contain
bugs, it is much less error prone than code that is not covered by unit tests. bugs, it is much less error prone than code that is not covered by unit tests.
Codecov provides `browser extensions <https://github.com/codecov/browser-extension>`_ Codecov provides `browser extensions <https://github.com/codecov/sourcegraph-codecov>`_
for Google Chrome, Firefox, and Opera. These extensions integrate with GitHub for Google Chrome and Firefox. These extensions integrate with GitHub
and allow you to see coverage line-by-line when viewing the Spack repository. and allow you to see coverage line-by-line when viewing the Spack repository.
If you are new to Spack, a great way to get started is to write unit tests to If you are new to Spack, a great way to get started is to write unit tests to
increase coverage! increase coverage!
0% Loading or .
Please register or to comment
