Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
S
Spack
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
GitLab community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
eic_tools
Spack
Commits
6355ee20
Commit
6355ee20
authored
Nov 7, 2018
by
Zack Galbreath
Committed by
Todd Gamblin
Dec 20, 2018
Browse files
Options
Downloads
Patches
Plain Diff
Include accurate build time in CDash report
parent
8d087208
No related branches found
No related tags found
No related merge requests found
Changes
1
Show whitespace changes
Inline
Side-by-side
Showing
1 changed file
lib/spack/spack/reporters/cdash.py
+10
-6
10 additions, 6 deletions
with
10 additions
and
6 deletions
10
6
View file @
6355ee20
@@ -63,10 +63,10 @@ def __init__(self, args):
self
buildname
args
cdash_build
or
self
install_command
self
buildname
args
cdash_build
or
self
install_command
self
site
args
cdash_site
or
socket
gethostname
self
site
args
cdash_site
or
socket
gethostname
self
osname
platform
system
self
osname
platform
system
self
start
time
int
time
time
self
end
time
int
time
time
buildstamp_format
%Y%m%d-%H%M-{0}
format
args
cdash_track
buildstamp_format
%Y%m%d-%H%M-{0}
format
args
cdash_track
self
buildstamp
time
strftime
buildstamp_format
self
buildstamp
time
strftime
buildstamp_format
time
localtime
self
start
time
time
localtime
self
end
time
self
buildId
None
self
buildId
None
self
revision
self
revision
git
which
git
git
which
git
@@ -80,16 +80,18 @@ def build_report(self, filename, report_data):
report_data
phase
report_data
phase
report_data
phase
log
report_data
phase
log
report_data
phase
status
0
report_data
phase
status
0
report_data
phase
starttime
self
starttime
report_data
phase
endtime
self
endtime
report_data
phase
endtime
self
starttime
# Track the phases we perform so we know what reports to create.
phases_encountered
phases_encountered
total_duration
0
# Parse output phase-by-phase.
phase_regexp
re
compile
r
Executing phase:
phase_regexp
re
compile
r
Executing phase:
cdash_phase
cdash_phase
for
spec
in
report_data
specs
for
spec
in
report_data
specs
if
time
in
spec
total_duration
int
spec
time
for
package
in
spec
packages
for
package
in
spec
packages
if
stdout
in
package
if
stdout
in
package
current_phase
current_phase
@@ -121,7 +123,9 @@ def build_report(self, filename, report_data):
build_pos
phases_encountered
index
build
build_pos
phases_encountered
index
build
phases_encountered
insert
0
phases_encountered
pop
build_pos
phases_encountered
insert
0
phases_encountered
pop
build_pos
self
starttime
self
endtime
total_duration
for
phase
in
phases_encountered
for
phase
in
phases_encountered
report_data
phase
starttime
self
starttime
errors
warnings
parse_log_events
errors
warnings
parse_log_events
report_data
phase
log
splitlines
report_data
phase
log
splitlines
nerrors
len
errors
nerrors
len
errors
@@ -182,8 +186,8 @@ def concretization_report(self, filename, msg):
report_data
report_data
self
initialize_report
filename
report_data
self
initialize_report
filename
report_data
report_data
update
report_data
update
report_data
update
starttime
self
start
time
report_data
update
starttime
self
end
time
report_data
update
endtime
self
start
time
report_data
update
endtime
self
end
time
report_data
update
revision
self
revision
report_data
update
revision
self
revision
report_data
update
log
msg
report_data
update
log
msg
This diff is collapsed.
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
