Skip to content
Snippets Groups Projects
Commit 263d8a81 authored by Massimiliano Culpo's avatar Massimiliano Culpo Committed by Peter Scheibel
Browse files
Updated Sphinx configuration (#11165)
parent 177b7f11
No related branches found
No related tags found
No related merge requests found
version: 2
sphinx:
configuration: lib/spack/docs/conf.py
python:
version: 3.7
install:
- requirements: lib/spack/docs/requirements.txt
...@@ -73,7 +73,7 @@ jobs: ...@@ -73,7 +73,7 @@ jobs:
- r-base-core - r-base-core
- r-base-dev - r-base-dev
- python: '3.6' - python: '3.7'
sudo: required sudo: required
os: linux os: linux
language: python language: python
# These dependencies should be installed using pip in order # These dependencies should be installed using pip in order
# to build the documentation. # to build the documentation.
sphinx==1.7.0 sphinx==2.0.1
sphinxcontrib-programoutput sphinxcontrib-programoutput==0.14
sphinx-rtd-theme sphinx-rtd-theme==0.4.3
0% Loading or .
Please register or to comment
