Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
S
Spack
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package Registry
Container Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
eic_tools
Spack
Commits
198ccfae
Commit
198ccfae
authored
4 years ago
by
Adam J. Stewart
Committed by
Peter Scheibel
4 years ago
Browse files
Options
Downloads
Patches
Plain Diff
Pandas: add v1.1.0
parent
c2cd728e
No related branches found
No related tags found
No related merge requests found
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
var/spack/repos/builtin/packages/py-pandas/package.py
+5
-1
5 additions, 1 deletion
with
5 additions
and
1 deletion
5
1
View file @
198ccfae
@@ -12,7 +12,7 @@ class PyPandas(PythonPackage):
programming language.
homepage
https://pandas.pydata.org/
homepage
url
https://pypi.io/packages/source/p/pandas/pandas-1.
0.5
.tar.gz
url
1.0
.tar.gz
maintainers
adamjstewart
maintainers
adamjstewart
import_modules
import_modules
@@ -29,6 +29,7 @@ class PyPandas(PythonPackage):
pandas.api.extensions
version
1.1.0
sha256
b39508562ad0bb3f384b0db24da7d68a2608b9ddc85b1d931ccaaa92d5e45273
version
1.0.5
sha256
69c5d920a0b2a9838e677f78f4dde506b95ea8e4d30da25859db6469ded84fa8
version
1.0.5
sha256
version
1.0.4
sha256
b35d625282baa7b51e82e52622c300a1ca9f786711b2af7cbe64f1e6831f4126
version
1.0.4
sha256
version
1.0.3
sha256
32f42e322fb903d0e189a4c10b75ba70d90958cc4f66a1781ed027f1a1d14586
version
1.0.3
sha256
@@ -56,11 +57,14 @@ class PyPandas(PythonPackage):
depends_on
python@3.5.3:
type
build
run
when
@0.25:
depends_on
python@3.5.3:
type
build
run
when
@0.25:
# https://pandas.pydata.org/docs/whatsnew/v1.0.0.html#build-changes
depends_on
py-cython@0.29.13:
type
build
when
@1:
depends_on
py-cython@0.29.13:
type
build
when
@1:
depends_on
py-cython@0.29.16:
type
build
when
@1.1:
depends_on
py-setuptools@24.2.0:
type
build
depends_on
type
build
depends_on
py-numpy
type
build
run
depends_on
py-numpy
type
build
run
depends_on
py-numpy@1.13.3:
type
build
run
when
@0.25:
depends_on
py-numpy@1.13.3:
type
build
run
when
@0.25:
depends_on
py-numpy@1.15.4:
type
build
run
when
@1.1:
depends_on
py-python-dateutil
type
build
run
depends_on
py-python-dateutil
type
build
run
depends_on
py-python-dateutil@2.6.1:
type
build
run
when
@0.25:
depends_on
type
build
run
when
@0.25:
depends_on
py-python-dateutil@2.7.3:
type
build
run
when
@1.1:
depends_on
py-pytz@2017.2:
type
build
run
depends_on
py-pytz@2017.2:
type
build
run
# Recommended dependencies
This diff is collapsed.
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
