Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
E
eic_container
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Container Registry
Model registry
Operate
Environments
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
containers
eic_container
Commits
5f8dcee5
Commit
5f8dcee5
authored
1 year ago
by
Wouter Deconinck
Browse files
Options
Downloads
Patches
Plain Diff
fix: new df and manual prune jobs
parent
3b9eb0d1
No related branches found
No related tags found
1 merge request
!795
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
.gitlab-ci.yml
+48
-11
48 additions, 11 deletions
.gitlab-ci.yml
containers/jug/dev.Dockerfile
+1
-0
1 addition, 0 deletions
with
49 additions
and
11 deletions
.gitlab-ci.yml
48
11
View file @
5f8dcee5
@@ -159,19 +159,19 @@ status:pending:
## base job settings for all docker interactions
.docker
.docker
${DOCKER_IMAGE}
${DOCKER_IMAGE}
services
services
docker:dind
docker:dind
before_script
before_script
# Login to registries
if [[ -n "${EXPORT_TAG}" ]] ; then
if [[ -n "${DH_REGISTRY}" ]] ; then
docker login -u ${DH_REGISTRY_USER} -
p ${DH_EICWEB_TOKEN}
${DH_REGISTRY} ;
echo ${DH_EICWEB_TOKEN} |
-password-stdin
${DH_REGISTRY} ;
fi ;
fi ;
if [[ -n "${GH_REGISTRY}" ]] ; then
docker login -u
${GITHUB_REGISTRY_
USER} -p ${GITHUB_REGISTRY_TOKEN}
${GH_REGISTRY} ;
echo
${GITHUB_REGISTRY_
TOKEN} | docker login -u ${GITHUB_REGISTRY_USER} --password-stdin
${GH_REGISTRY} ;
fi ;
fi ;
if [[ -n "${CI_REGISTRY}" ]] ; then
docker login -u ${CI_REGISTRY_USER} -p ${CI_REGISTRY_PASSWORD}
${CI_REGISTRY} ;
echo ${CI_REGISTRY_PASSWORD} | docker login -u ${CI_REGISTRY_USER} --password-stdin
${CI_REGISTRY} ;
fi ;
fi ;
fi
fi
after_script
after_script
@@ -527,7 +527,50 @@ benchmarks:detector:nightly:
project
EIC/benchmarks/detector_benchmarks
project
strategy
depend
strategy
depend
allow_failure
false
allow_failure
false
df
extends
.build
stage
config
tags
docker-new
needs
version
script
docker images
docker ps --size
docker stats --all --no-stream --no-trunc > docker-stats-all.txt
docker context ls
docker volume ls
docker volume ls --filter=name=buildx_buildkit_builder
docker buildx ls
docker buildx inspect
docker buildx du
docker buildx du --verbose > docker-buildx-du-verbose.txt
docker system df
docker system df --verbose > docker-system-df-verbose.txt
artifacts
paths
prune
extends
.build
stage
finalize
tags
docker-new
needs
clean_internal_tag
clean_unstable_mr
clean_pipeline
rules
when
manual
script
docker buildx prune --all --force --filter=until=24h --verbose
docker system prune --all --force --filter=until=24h
docker system prune --volumes --force
allow_failure
true
clean_internal_tag
clean_internal_tag
alpine/curl
alpine/curl
stage
finalize
stage
finalize
@@ -567,9 +610,6 @@ clean_unstable_mr:
if [ "$state" == "merged" ] ; then docker rmi $repository:$tag ; fi ;
if [ "$state" == "closed" ] ; then docker rmi $repository:$tag ; fi ;
done
done
docker system prune --filter until=24h --force
docker system df
docker images
clean_pipeline
clean_pipeline
extends
.docker
extends
.docker
@@ -600,9 +640,6 @@ clean_pipeline:
if [ "$status" == "failed" ] ; then docker rmi $repository:$tag ; fi ;
if [ "$status" == "canceled" ] ; then docker rmi $repository:$tag ; fi ;
done
done
docker system df
docker images
status:success
status:success
stage
status-report
stage
status-report
This diff is collapsed.
1
0
View file @
5f8dcee5
@@ -137,6 +137,7 @@ RUN --mount=type=cache,target=/ccache,id=${TARGETPLATFORM} \
EOF
EOF
set -e
set -e
export CCACHE_DIR=/ccache
mkdir -p /var/cache/spack/blobs/sha256/
find /var/cache/spack/blobs/sha256/ -atime +7 -delete
JUGGLER_VERSION=$(jq -r .sha /tmp/juggler.json)
EICRECON_VERSION=$(jq -r .sha /tmp/eicrecon.json)
Preview
0%
Loading
Try again
or
attach a new file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Save comment
Cancel
Please
register
or
sign in
to comment
