Skip to content
Snippets Groups Projects
Commit 80e4066d authored by Mark Jones's avatar Mark Jones
Browse files
Modify get_file_event and event
Add electron_arm variable to get_file_event call.
Modify get_file_event so it assumes that first 4 vector
is for the HMS and the 2nd 4-vector is SHMS.
THen if electron_arm= 1 then
electron 4-vector = HMS 4-vector
proton 4-vector = SHMS 4-vector
else
electron 4-vector = SHMS 4-vector
proton 4-vector = HMS 4-vector
parent bbbea151
Branches
Tags
No related merge requests found
...@@ -299,7 +299,7 @@ C modified 5/15/06 for poinct ...@@ -299,7 +299,7 @@ C modified 5/15/06 for poinct
endif !not (doing_hyd_elast) endif !not (doing_hyd_elast)
if ( doing_2pi) then if ( doing_2pi) then
ok_2pi = .true. ok_2pi = .true.
call get_file_event(spec%e%theta,spec%p%theta, call get_file_event(electron_arm,spec%e%theta,spec%p%theta,
> vertex%e%xptar,vertex%e%yptar,vertex%e%p,vertex%e%E, > vertex%e%xptar,vertex%e%yptar,vertex%e%p,vertex%e%E,
> vertex%p%xptar,vertex%p%yptar,vertex%p%p,vertex%p%E, > vertex%p%xptar,vertex%p%yptar,vertex%p%p,vertex%p%E,
> main%gen_weight) > main%gen_weight)
subroutine get_file_event(th_spec_e,th_spec_p, subroutine get_file_event(e_arm,th_spec_e,th_spec_p,
> dxdz,dydz,e_mom,e_E,dxdzp,dydzp,p_mom,p_E,weight) > dxdz,dydz,e_mom,e_E,dxdzp,dydzp,p_mom,p_E,weight)
c c
c input variables: c input variables:
c electron_arm : 1 means HMS is electron arm
c 5 means SHMS is the electron arm
c th_spec_e : central spec angle for electron (rad) c th_spec_e : central spec angle for electron (rad)
c th_spec_p : central spec angle for proton (rad) c th_spec_p : central spec angle for proton (rad)
c output variables: c output variables:
...@@ -20,12 +22,14 @@ c ...@@ -20,12 +22,14 @@ c
implicit none implicit none
include 'simulate.inc' include 'simulate.inc'
c c
real*8 e_4v(4), e_4vr(4) integer*4 e_arm,ii
real*8 p_4v(4), p_4vr(4) real*8 SHMS_4v(4), e_4vr(4), e_4v(4)
real*8 HMS_4v(4), p_4vr(4), p_4v(4)
real*8 cth_hms, sth_hms, cth_shms, sth_shms real*8 cth_hms, sth_hms, cth_shms, sth_shms
real*8 th_spec_e real*8 th_spec_e
real*8 th_spec_p real*8 th_spec_p
real*8 e_mom,e_E,dxdz,dydz,e_vz real*8 sth_elec,cth_elec,sth_prot,cth_prot
real*8 e_mom,e_E,dxdz,dydz,e_vz,SHMS_vz,HMS_vz
real*8 p_mom,p_E,dxdzp,dydzp,p_vz real*8 p_mom,p_E,dxdzp,dydzp,p_vz
real*8 w, weight real*8 w, weight
character*80 multpifile character*80 multpifile
...@@ -47,40 +51,69 @@ c ...@@ -47,40 +51,69 @@ c
c c
c c
end_of_2pi_file = .false. end_of_2pi_file = .false.
read(51,*,end=999,err=999) e_4v,e_vz,p_4v,p_vz,w 888 continue
read(51,*,end=999,err=999) HMS_4v,HMS_vz,SHMS_4v,SHMS_vz,w
count = count + 1 count = count + 1
c if (count .gt. 100) goto 999
c Rotate 4-vectors to their respective frames
c This is a rotation around the x-axis, which points downwards
c --> the HMS is at negative angles, and the SHMS at positive angles
if (e_arm .eq. 1) then
cth_elec = cos(th_spec_e)
sth_elec = sin(-th_spec_e)
cth_prot= cos(th_spec_p)
sth_prot = sin(th_spec_p)
e_vz = HMS_vz * 1.
p_vz = SHMS_vz * 1.
e_4v(1) = HMS_4v(1)
p_4v(1) = SHMS_4v(1)
e_4v(2) = HMS_4v(2)
p_4v(2) = SHMS_4v(2)
e_4v(3) = HMS_4v(3)
p_4v(3) = SHMS_4v(3)
e_4v(4) = HMS_4v(4)
p_4v(4) = SHMS_4v(4)
else
cth_prot = cos(th_spec_p)
sth_prot = sin(-th_spec_p)
sth_elec = sin(th_spec_e)
e_vz = SHMS_vz * 1.
p_vz = HMS_vz * 1.
e_4v(1) = SHMS_4v(1)
p_4v(1) = HMS_4v(1)
e_4v(2) = SHMS_4v(2)
p_4v(2) = HMS_4v(2)
e_4v(3) = SHMS_4v(3)
p_4v(3) = HMS_4v(3)
e_4v(4) = SHMS_4v(4)
p_4v(4) = HMS_4v(4)
endif
if(debug(5)) then if(debug(5)) then
write(*,*) ' ' write(*,*) ' '
write(*,*) ' NEW EVENT: ',count, weight write(*,*) ' NEW EVENT: ',count, weight
write(*,*) ' HMS: ',e_4v(1),e_4v(2),e_4v(3),e_4v(4) write(*,*) ' e: ',e_4v(1),e_4v(2),e_4v(3),e_4v(4)
write(*,*) ' SHMS: ',p_4v(1),p_4v(2),p_4v(3),p_4v(4) write(*,*) ' p: ',p_4v(1),p_4v(2),p_4v(3),p_4v(4)
write(*,*) ' vertex: ',e_vz,p_vz write(*,*) ' vertex: ',e_vz,p_vz
endif !debug endif !debug
c cc Rotatation about the x-axis --> only y, and z change
cth_hms = cos(th_spec_e)
sth_hms = sin(-th_spec_e)
cth_shms = cos(th_spec_p)
sth_shms = sin(th_spec_p)
e_4vr(1) = e_4v(1) e_4vr(1) = e_4v(1)
e_4vr(2) = cth_hms * e_4v(2) - sth_hms * e_4v(3) e_4vr(2) = cth_elec * e_4v(2) - sth_elec * e_4v(3)
e_4vr(3) = sth_hms * e_4v(2) + cth_hms * e_4v(3) e_4vr(3) = sth_elec * e_4v(2) + cth_elec * e_4v(3)
e_4vr(4) = e_4v(4) e_4vr(4) = e_4v(4)
p_4vr(1) = p_4v(1) p_4vr(1) = p_4v(1)
p_4vr(2) = cth_shms * p_4v(2) - sth_shms * p_4v(3) p_4vr(2) = cth_prot * p_4v(2) - sth_prot * p_4v(3)
p_4vr(3) = sth_shms * p_4v(2) + cth_shms * p_4v(3) p_4vr(3) = sth_prot * p_4v(2) + cth_prot * p_4v(3)
p_4vr(4) = p_4v(4) p_4vr(4) = p_4v(4)
write(*,*) ' SPEC:' write(*,*) ' SPEC:'
write(*,*) ' HMS: ',-th_spec_e/pi*180 write(*,*) ' e: ',th_spec_e/pi*180
write(*,*) ' SHMS: ',th_spec_p/pi*180 write(*,*) ' p: ',th_spec_p/pi*180
write(*,*) ' ROTATED: ' write(*,*) ' ROTATED: '
write(*,*) ' HMS: ',e_4vr(1),e_4vr(2),e_4vr(3),e_4vr(4) write(*,*) ' e: ',e_4vr(1),e_4vr(2),e_4vr(3),e_4vr(4)
write(*,*) ' SHMS: ',p_4vr(1),p_4vr(2),p_4vr(3),p_4vr(4) write(*,*) ' p: ',p_4vr(1),p_4vr(2),p_4vr(3),p_4vr(4)
c Calculate dxdz and dydz c Calculate dxdz and dydz
e_mom = sqrt(e_4vr(1)**2 + e_4vr(2)**2 + e_4vr(3)**2) e_mom = sqrt(e_4vr(1)**2 + e_4vr(2)**2 + e_4vr(3)**2)
...@@ -96,16 +129,18 @@ c Convert momenta and energies into MeV ...@@ -96,16 +129,18 @@ c Convert momenta and energies into MeV
p_E = p_4vr(4) * 1000. p_E = p_4vr(4) * 1000.
c Weight and vertex positions are read in correctly. c Weight and vertex positions are read in correctly.
c Vertez z is read in cm c Vertez z is read in cm
e_vz = e_vz * 1.
p_vz = p_vz * 1.
weight = w weight = w
write(*,*) 'SIMC INPUT: ' write(*,*) 'SIMC INPUT: '
write(*,*) ' HMS: ',dxdz,dydz,e_mom,e_E,e_vz write(*,*) ' e: ',dxdz,dydz,e_mom,e_E,e_vz
write(*,*) ' SHMS: ',dxdzp,dydzp,p_mom,p_E,p_vz write(*,*) ' p: ',dxdzp,dydzp,p_mom,p_E,p_vz
c c
if ( abs(atan(e_4v(1)/e_4v(3))*57.3-th_spec_e)<3.
c .and. abs(atan(p_4v(1)/p_4v(3))*57.3-th_spec_p)<3. ) then
count_miss = count_miss+1
endif
return return
c c
999 write(*,*) ' reached end of file' 999 write(*,*) ' reached end of file'
0% Loading or .
Please register or to comment
