Skip to content
GitLab
Explore
Sign in
Primary navigation
Search or go to…
Project
E
ecce
Manage
Activity
Members
Labels
Plan
Issues
Issue boards
Milestones
Wiki
Code
Merge requests
Repository
Branches
Commits
Tags
Repository graph
Compare revisions
Snippets
Build
Pipelines
Jobs
Pipeline schedules
Artifacts
Deploy
Releases
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Help
Help
Support
GitLab documentation
Compare GitLab plans
Community forum
Contribute to GitLab
Provide feedback
Keyboard shortcuts
Snippets
Groups
Projects
Show more breadcrumbs
EIC
detectors
ecce
Compare revisions
main to 12-drich-sensor-material-should-not-be-airoptical
Compare revisions
Changes are shown as if the
source
revision was being merged into the
target
revision.
Learn more about comparing revisions.
Source
EIC/detectors/ecce
Select target project
No results found
Select Git revision
Branches
2-reparametrize-cleanup-implement-inner-central-detector
9-put-rings-of-barrel-ecal-sciglass-blocks-in-polycones
github-actions-workflow-dispatch
main
parse-modified-drich-xml-files
6 results
Swap
Target
EIC/detectors/ecce
EIC/detectors/ecce
1 result
main
Select Git revision
Branches
main
6 results
Show changes
Only incoming changes from source
Include changes to target since source was created
Compare
View open merge request
Commits on Source (1)
your commit message
· 610f4237
Ajit Kumar
authored
2 years ago
610f4237
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
compact/drich.xml
+1
-1
1 addition, 1 deletion
compact/drich.xml
compact/optical_materials.xml
+150
-4
150 additions, 4 deletions
with
151 additions
and
5 deletions
compact/drich.xml
Edit
View file @
610f4237
@@ -180,7 +180,7 @@
@@ -180,7 +180,7 @@
spherical patch below
</documentation>
</documentation>
<module
<module
material=
AirOptical
material=
SiPM
surface=
"SensorSurface_DRICH"
surface=
vis=
"DRICH_sensor_vis"
vis=
"DRICH_sensor_vis"
side=
"DRICH_sensor_size"
side=
"DRICH_sensor_size"
This diff is collapsed.
Edit
View file @
610f4237
@@ -8,6 +8,127 @@
@@ -8,6 +8,127 @@
1.0*eV 1.00029
1.0*eV 1.00029
5.1*eV 1.00029
5.1*eV 1.00029
<matrix
name=
"RINDEX__SiPM"
coldim=
"2"
values=
3.86052*eV 6.00137
3.8402*eV 5.99268
3.82009*eV 5.98609
3.80018*eV 5.98158
3.78049*eV 5.97863
3.76099*eV 5.97858
3.74057*eV 5.98263
3.72037*eV 5.9865
3.70039*eV 5.99464
3.68062*eV 6.00479
3.65998*eV 6.01731
3.64063*eV 6.03369
3.62044*eV 6.05377
3.60046*eV 6.08028
3.58071*eV 6.1132
3.56015*eV 6.15475
3.54083*eV 6.20882
3.52073*eV 6.27768
3.50085*eV 6.36838
3.48021*eV 6.48259
3.46079*eV 6.62403
3.44062*eV 6.77999
3.42069*eV 6.93477
3.40005*eV 7.0607
3.38059*eV 7.13127
3.36043*eV 7.13374
3.34052*eV 7.08041
3.32084*eV 6.97814
3.30051*eV 6.83782
3.28042*eV 6.6779
3.26058*eV 6.52084
3.24014*eV 6.36837
3.22078*eV 6.22608
3.2*eV 6.09465
3.1803*eV 5.9744
3.16004*eV 5.86379
3.14004*eV 5.76207
3.12028*eV 5.66928
3.1*eV 5.58343
3.08075*eV 5.50446
3.06022*eV 5.42998
3.04071*eV 5.35815
3.02071*eV 5.29201
3.00024*eV 5.22892
2.98005*eV 5.17029
2.96013*eV 5.11482
2.94048*eV 5.06314
2.9204*eV 5.01344
2.90058*eV 4.96515
2.88037*eV 4.91983
2.86044*eV 4.87551
2.84013*eV 4.83454
2.8201*eV 4.79402
2.80036*eV 4.75579
2.78027*eV 4.72035
2.76046*eV 4.68437
2.74033*eV 4.6499
2.72049*eV 4.61686
2.70035*eV 4.58484
2.6805*eV 4.55488
2.66037*eV 4.52398
2.64055*eV 4.4966
2.62046*eV 4.46761
2.60013*eV 4.44291
2.58011*eV 4.417
2.5604*eV 4.39178
2.54046*eV 4.36771
2.52033*eV 4.34368
2.5005*eV 4.32062
2.4805*eV 4.29862
2.46032*eV 4.27751
2.44046*eV 4.25561
2.42046*eV 4.23543
2.40031*eV 4.21543
2.3805*eV 4.19637
2.36011*eV 4.17734
2.34006*eV 4.15922
2.32036*eV 4.14024
2.30013*eV 4.12328
2.28025*eV 4.10624
2.2603*eV 4.08924
2.24029*eV 4.07313
2.22023*eV 4.05718
2.20014*eV 4.04213
2.18041*eV 4.02614
2.16028*eV 4.01211
2.14014*eV 3.99709
2.12038*eV 3.98311
2.10027*eV 3.96911
2.08019*eV 3.95609
2.06014*eV 3.94308
2.04014*eV 3.93108
2.0202*eV 3.91807
2.00032*eV 3.90606
1.9802*eV 3.89306
1.96016*eV 3.88205
1.94023*eV 3.87004
1.9201*eV 3.85804
1.90009*eV 3.84703
1.88021*eV 3.83703
1.86019*eV 3.82603
1.84031*eV 3.81503
1.82032*eV 3.80502
1.80023*eV 3.79602
1.78033*eV 3.78702
1.76011*eV 3.77802
1.74011*eV 3.76802
1.72031*eV 3.76102
1.70026*eV 3.75201
1.68022*eV 3.74501
1.6602*eV 3.73601
1.64021*eV 3.72801
1.62028*eV 3.72101
1.60021*eV 3.71401
1.58022*eV 3.70501
1.56014*eV 3.69701
1.54018*eV 3.688
1.52017*eV 3.681
1.50012*eV 3.673
<matrix
name=
"RINDEX__Quartz"
coldim=
"2"
values=
<matrix
name=
"RINDEX__Quartz"
coldim=
"2"
values=
1.0*eV 1.46
1.0*eV 1.46
5.1*eV 1.46
5.1*eV 1.46
@@ -700,6 +821,12 @@
<property
name=
"RINDEX"
ref=
"RINDEX__Air"
<property
name=
"RINDEX"
ref=
"RINDEX__Air"
<property
name=
"ABSLENGTH"
coldim=
"2"
values=
"1*eV 200*m 5*eV 200*m"
<property
name=
"ABSLENGTH"
coldim=
"2"
values=
</material>
</material>
<material
name=
"SiPM"
<D
type=
"density"
unit=
"g/cm3"
value=
"2.33"
<fraction
n=
"1.000"
ref=
"Si"
<property
name=
"RINDEX"
ref=
"RINDEX__SiPM"
<property
name=
"ABSLENGTH"
coldim=
"2"
values=
</material>
<material
name=
"VacuumOptical"
<material
name=
"VacuumOptical"
<D
type=
"density"
unit=
"g/cm3"
value=
"0.0000000001"
<D
type=
"density"
unit=
"g/cm3"
value=
"0.0000000001"
<fraction
n=
"0.754"
ref=
"N"
<fraction
n=
"0.754"
ref=
"N"
@@ -857,10 +984,29 @@
</opticalsurface>
</opticalsurface>
<opticalsurface
name=
model=
"glisur"
finish=
"polished"
type=
"dielectric_dielectric"
<opticalsurface
name=
model=
"glisur"
finish=
"polished"
type=
<property
name=
"EFFICIENCY"
coldim=
"2"
values=
<property
name=
"EFFICIENCY"
coldim=
"2"
values=
1*eV 1
3.8*eV 0.02
4*eV 1
3.7*eV 0.07
7*eV 1
3.7*eV 0.1
3.6*eV 0.16
3.5*eV 0.2
3.4*eV 0.26
3.3*eV 0.3
3.1*eV 0.35
2.9*eV 0.38
2.7*eV 0.4
2.5*eV 0.39
2.3*eV 0.34
2*eV 0.23
1.9*eV 0.21
1.9*eV 0.2
1.8*eV 0.17
1.8*eV 0.15
1.7*eV 0.12
1.6*eV 0.1
1.5*eV 0.08
1.5*eV 0.05
1.4*eV 0.03
<property
name=
"IMAGINARYRINDEX"
coldim=
"2"
values=
<property
name=
"IMAGINARYRINDEX"
coldim=
"2"
values=
1*eV 1.69
1*eV 1.69
4*eV 1.69
4*eV 1.69
