Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Show changes
Commits on Source (37)
Showing
with 500 additions and 259 deletions
...@@ -115,19 +115,17 @@ dump_geometry: ...@@ -115,19 +115,17 @@ dump_geometry:
- print_env.sh - print_env.sh
## DEBUG ## DEBUG
- mkdir -p geo - mkdir -p geo
## disable fibers in SciFi endcap ECAL for better performance
## not needed, as we have no fibers in the current setup
#- sed -i '/<fiber/,+4d' ${DETECTOR_PATH}/compact/ci_ecal_scfi.xml
## finally: remove tracking subassemblies as they lower the display priority
## of some tracking detectors
sed -i -e '/<detectors>/,/<\/detectors>/d' ${DETECTOR_PATH}/compact/tracking_config*.xml sed -i -e '/<detectors>/,/<\/detectors>/d' ${DETECTOR_PATH}/compact/tracking_config*.xml
mv ${DETECTOR_PATH}/compact/display_geoviewer.xml ${DETECTOR_PATH}/compact/display.xml mv ${DETECTOR_PATH}/compact/display_geoviewer.xml ${DETECTOR_PATH}/compact/display.xml
for xml in ${DETECTOR_PATH}/compact/subsystem_views/*.xml; do for xml in ${DETECTOR_PATH}/compact/subsystem_views/*.xml; do
echo $xml
geo_name=`basename $xml .xml`_geo.root geo_name=`basename $xml .xml`_geo.root
cp $xml ${DETECTOR_PATH}/geo.xml cp $xml ${DETECTOR_PATH}/geo.xml
dd_web_display --output geo/${geo_name} ${DETECTOR_PATH}/geo.xml dd_web_display --output geo/${geo_name} ${DETECTOR_PATH}/geo.xml
done done
## Lower-resolution display of the pfRICH sensors for global views
- sed -i 's/_default"\/>/_lores"\/>/' ${DETECTOR_PATH}/compact/pfrich.xml
## full geo with downstream beamline ## full geo with downstream beamline
- dd_web_display --output geo/detector_geo_full.root ${DETECTOR_PATH}/athena.xml - dd_web_display --output geo/detector_geo_full.root ${DETECTOR_PATH}/athena.xml
## only central detector geo ## only central detector geo
...@@ -142,11 +140,13 @@ dump_geometry: ...@@ -142,11 +140,13 @@ dump_geometry:
## print some useful output ## print some useful output
echo "Geometry viewer at:" echo "Geometry viewer at:"
echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all&" echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all"
echo " - Central detector view at: "
echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all"
echo " - Subsystem view for `basename $xml .xml` at:" echo " - Subsystem view for `basename $xml .xml` at:"
echo " https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/${geo_name}?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all&" echo " https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/${geo_name}?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all"
done done
detector_documentation: detector_documentation:
...@@ -158,7 +158,7 @@ detector_documentation: ...@@ -158,7 +158,7 @@ detector_documentation:
- bash bin/build_documentation | tee doc/detector.md - bash bin/build_documentation | tee doc/detector.md
# xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/athena.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee doc/detector.md # xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/athena.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee doc/detector.md
# xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/ip6/ip6_defs.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true # xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/ip6/definitions.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
# for afile in ${DETECTOR_PATH}/compact/*.xml ; do # for afile in ${DETECTOR_PATH}/compact/*.xml ; do
# xmllint --format --xpath '//comment/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true # xmllint --format --xpath '//comment/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
# done # done
...@@ -179,7 +179,7 @@ report: ...@@ -179,7 +179,7 @@ report:
- view_20 - view_20
- dump_constants - dump_constants
- dump_geometry - dump_geometry
- convert_to_gdml - dump_gdml
script: script:
- pip3 install jinja2 && ls -lrth - pip3 install jinja2 && ls -lrth
- ./bin/make_images > doc/dawn_views.md - ./bin/make_images > doc/dawn_views.md
...@@ -199,6 +199,7 @@ overlap_check_tgeo: ...@@ -199,6 +199,7 @@ overlap_check_tgeo:
script: script:
## disable fibers in ECAL for normal overlap check ## disable fibers in ECAL for normal overlap check
- sed -i '/<fiber/,+6d' ${DETECTOR_PATH}/compact/ecal_barrel_interlayers.xml - sed -i '/<fiber/,+6d' ${DETECTOR_PATH}/compact/ecal_barrel_interlayers.xml
- sed -i '/<fiber/,+4d' ${DETECTOR_PATH}/ip6/far_forward/ZDC_Ecal_WSciFi.xml
- checkOverlaps -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_tgeo.out - checkOverlaps -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_tgeo.out
- echo "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l) overlaps..." - echo "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l) overlaps..."
- if [[ "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi - if [[ "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi
...@@ -210,6 +211,7 @@ overlap_check_geant4:full_fast: ...@@ -210,6 +211,7 @@ overlap_check_geant4:full_fast:
script: script:
## reduce the number of fibers in Hadron EMCal for overlap check ## reduce the number of fibers in Hadron EMCal for overlap check
## not needed, as we are running with a different setup now ## not needed, as we are running with a different setup now
#- sed -i 's/radius="EcalEndcapP_FiberRadius"/radius="EcalEndcapP_FiberRadius*10"/' ${DETECTOR_PATH}/compact/ci_ecal_scfi.xml #- sed -i 's/radius="EcalEndcapP_FiberRadius"/radius="EcalEndcapP_FiberRadius*10"/' ${DETECTOR_PATH}/compact/ci_ecal_scfi.xml
...@@ -229,13 +231,19 @@ overlap_check_geant4:inner_detector: ...@@ -229,13 +231,19 @@ overlap_check_geant4:inner_detector:
- echo "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l) overlaps..." - echo "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l) overlaps..."
- if [[ "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi - if [[ "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi
convert_to_gdml: dump_gdml:
stage: test stage: test
needs: needs:
- ["common:detector"] - ["common:detector"]
script: script:
- python scripts/convert_to_gdml.py --compact ${DETECTOR_PATH}/athena.xml --output geo/athena.gdml - |
gdml_name=`basename $xml .xml`.gdml
python scripts/convert_to_gdml.py --compact ${DETECTOR_PATH}/geo.xml --output geo/${gdml_name}
done
tracking_geometry_debug: tracking_geometry_debug:
...@@ -10,13 +10,18 @@ PROJECT(athena ...@@ -10,13 +10,18 @@ PROJECT(athena
set(CMAKE_CXX_STANDARD 17) set(CMAKE_CXX_STANDARD 17)
find_package( DD4hep REQUIRED COMPONENTS DDCore DDG4) set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Werror")
find_package(Acts REQUIRED COMPONENTS Core PluginIdentification PluginTGeo PluginDD4hep )
find_package(fmt)
#find_library(FMT_LIBRARY fmt)
find_package(DD4hep REQUIRED COMPONENTS DDCore DDG4)
find_package(ActsDD4hep)
if(ActsDD4hep_FOUND)
add_compile_definitions(USE_ACTSDD4HEP)
set(ActsDD4hep ActsDD4hep::ActsDD4hep)
else()
find_package(Acts REQUIRED COMPONENTS Core PluginIdentification PluginTGeo PluginDD4hep)
set(ActsDD4hep ActsCore ActsPluginDD4hep)
endif()
find_package(fmt REQUIRED)
set(a_lib_name athena) set(a_lib_name athena)
...@@ -24,17 +29,15 @@ set(a_lib_name athena) ...@@ -24,17 +29,15 @@ set(a_lib_name athena)
dd4hep_configure_output() dd4hep_configure_output()
dd4hep_add_plugin(${a_lib_name} SOURCES dd4hep_add_plugin(${a_lib_name} SOURCES
src/BackwardGEMTracker_geo.cpp
src/BarrelBarDetectorWithSideFrame_geo.cpp src/BarrelBarDetectorWithSideFrame_geo.cpp
src/BarrelCalorimeter_geo.cpp src/BarrelCalorimeter_geo.cpp
src/BarrelCalorimeterHybrid_geo.cpp
src/BarrelCalorimeterInterlayers_geo.cpp src/BarrelCalorimeterInterlayers_geo.cpp
src/BarrelTrackerWithFrame_geo.cpp src/BarrelTrackerWithFrame_geo.cpp
src/CompositeTracker_geo.cpp src/CompositeTracker_geo.cpp
src/CylinderTrackerBarrel_geo.cpp src/CylinderTrackerBarrel_geo.cpp
src/DIRC_geo.cpp src/DIRC_geo.cpp
src/DRich_geo.cpp src/DRICH_geo.cpp
src/ERich_geo.cpp src/PFRICH_geo.cpp
src/FileLoader.cpp src/FileLoader.cpp
src/FieldMapBrBz.cpp src/FieldMapBrBz.cpp
src/GaseousRICH_geo.cpp src/GaseousRICH_geo.cpp
...@@ -48,10 +51,10 @@ dd4hep_add_plugin(${a_lib_name} SOURCES ...@@ -48,10 +51,10 @@ dd4hep_add_plugin(${a_lib_name} SOURCES
src/SimpleDiskDetector_geo.cpp src/SimpleDiskDetector_geo.cpp
src/SolenoidCoil_geo.cpp src/SolenoidCoil_geo.cpp
src/TrapEndcapTracker_geo.cpp src/TrapEndcapTracker_geo.cpp
USES ActsCore ActsPluginDD4hep USES ${ActsDD4hep}
target_link_libraries(${a_lib_name} target_link_libraries(${a_lib_name}
PUBLIC DD4hep::DDCore DD4hep::DDRec fmt::fmt PUBLIC DD4hep::DDCore DD4hep::DDRec fmt::fmt
...@@ -3,22 +3,34 @@ Overview ...@@ -3,22 +3,34 @@ Overview
The Athena Detector at IP6 for Electron-Ion Collider experiment. The Athena Detector at IP6 for Electron-Ion Collider experiment.
**Detector geometry viewer:** **Detector geometry viewer:**
- [Central detector geometry](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/geo/detector_geo.root?job=report&item=default;1&opt=clipxyz;transp30;zoom100;ROTY0;ROTZ0;trz100;trr0;ctrl;all&) - [Central detector](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Full Detector geometry (including beamline)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/geo/detector_geo_full.root?job=report&item=default;1&opt=clipxyz;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all&) - [Full Detector (including beamline)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
- [Inner detector (without calorimetry)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/inner_detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
<a href="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01.pdf?job=report"> - Subsystem views:
<img src="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01.png?job=report" width="400px" /> - [Calorimetry](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/calorimeters_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [PID](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/pid_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [dRICH](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/drich_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
- [pfRICH](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/pfrich_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom55;ROTY49;ROTZ350;trz0;trr0;ctrl;all&)
- [DIRC](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/dirc_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [ToF](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/tof_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom55;ROTY49;ROTZ350;trz0;trr0;ctrl;all&)
- [Tracking](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/tracking_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Vertex detector](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/vertex_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Far-forward](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/ip6_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom40;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
<a href="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01.png?job=report" width="400px" />
</a> </a>
<br /> <br />
<a href="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01_top.pdf?job=report"> <a href="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01_top.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01_top.png?job=report" width="400px" /> <img src="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01_top.png?job=report" width="400px" />
</a> </a>
[Browse latest](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/browse/images?job=report) [Browse latest](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/browse/images?job=report)
[Detector views](views/detector_views.md) [Detector views](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/doc/dawn_views.md?job=report)
[Constants listing](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/doc/constants.out?job=report)
Getting Started Getting Started
...@@ -33,8 +33,8 @@ ...@@ -33,8 +33,8 @@
The ip6 (or other ip) defines should be included first. The ip6 (or other ip) defines should be included first.
These files have only a define tags. These files have only a define tags.
</documentation> </documentation>
<include ref="ip6/ip6_defs.xml" /> <include ref="ip6/definitions.xml" />
<include ref="ip6/far_forward_fields_275.xml" /> <include ref="ip6/far_forward/fields_275.xml" />
<include ref="compact/definitions.xml" /> <include ref="compact/definitions.xml" />
</define> </define>
...@@ -84,17 +84,6 @@ ...@@ -84,17 +84,6 @@
- and more... - and more...
<comment>
Beamline elements
</comment>
<include ref="ip6/forward_ion_beamline.xml"/>
<include ref="ip6/beampipe_hadron_B0.xml" />
<include ref="ip6/beampipe.xml" />
<include ref="ip6/inner_vacuum_FF_magnets.xml"/>
<documentation level="5"> <documentation level="5">
## Main magnet ## Main magnet
...@@ -107,13 +96,15 @@ ...@@ -107,13 +96,15 @@
<!--include ref="compact/tracking_config_acadia.xml"/--> <!--include ref="compact/tracking_config_acadia.xml"/-->
<include ref="compact/tracking_config_canyonlands.xml"/> <!--include ref="compact/tracking_config_canyonlands.xml"/-->
<include ref="compact/tracking_config_deathvalley.xml"/>
<documentation level="10"> <documentation level="10">
### PID detectors ### PID detectors
<!--include ref="compact/pid_config_acadia.xml" /--> <!--include ref="compact/pid_config_acadia.xml" /-->
<include ref="compact/pid_config_canyonlands.xml" /> <!--include ref="compact/pid_config_canyonlands.xml" /-->
<include ref="compact/pid_config_deathvalley.xml" />
## Central calorimetry ## Central calorimetry
...@@ -124,70 +115,17 @@ ...@@ -124,70 +115,17 @@
<documentation level="11"> <documentation level="11">
## Far foward detectors ## Far foward detectors
<include ref="ip6/B0_tracker.xml"/> <include ref="ip6/central_beampipe.xml"/>
<include ref="ip6/B0_preshower.xml"/>
<include ref="ip6/far_forward_offM_tracker.xml"/> <documentation level="11">
<include ref="ip6/far_forward_detectors.xml"/> ## Far foward detectors
<include ref="ip6/roman_pots_eRD24_design.xml"/> </documentation>
<include ref="ip6/far_forward.xml"/>
<fields>
<field name="B0PF_Magnet" type="MultipoleMagnet"> <documentation level="11">
<position x="B0PF_XPosition" y="0" z="B0PF_CenterPosition"/> ## Far backward detectors
<rotation x="0" y="B0PF_RotationAngle" z="0"/> </documentation>
<shape type="Tube" rmin="0.0" rmax="B0PF_InnerRadius" dz="B0PF_Length*0.5"/> <include ref="ip6/far_backward.xml"/>
<coefficient coefficient="B0PF_Bmax" skew="0.0*tesla"/>
<!--<coefficient coefficient="2.0*tesla/cm" skew="0.2*tesla/cm"/> -->
</field>
<field name="B0APF_Magnet" type="MultipoleMagnet">
<position x="B0APF_XPosition" y="0" z="B0APF_CenterPosition"/>
<rotation x="0" y="B0APF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B0APF_InnerRadius" dz="B0APF_Length*0.5"/>
<coefficient coefficient="B0APF_Bmax" skew="0.0*tesla"/>
</field>
<field name="Q1APF_Magnet" type="MultipoleMagnet">
<position x="Q1APF_XPosition" y="0" z="Q1APF_CenterPosition"/>
<rotation x="0" y="Q1APF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="Q1APF_InnerRadius" dz="Q1APF_Length*0.5"/>
<coefficient coefficient="Q1APF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="Q1APF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="Q1BPF_Magnet" type="MultipoleMagnet">
<position x="Q1BPF_XPosition" y="0" z="Q1BPF_CenterPosition"/>
<rotation x="0" y="Q1BPF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="Q1BPF_InnerRadius" dz="Q1BPF_Length*0.5"/>
<coefficient coefficient="Q1BPF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="Q1BPF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="Q2PF_Magnet" type="MultipoleMagnet">
<position x="Q2PF_XPosition" y="0" z="Q2PF_CenterPosition"/>
<rotation x="0" y="Q2PF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="Q2PF_InnerRadius" dz="Q2PF_Length*0.5"/>
<coefficient coefficient="Q2PF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="Q2PF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="B1PF_Magnet" type="MultipoleMagnet">
<position x="B1PF_XPosition" y="0" z="B1PF_CenterPosition"/>
<rotation x="0" y="B1PF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B1PF_InnerRadius" dz="B1PF_Length*0.5"/>
<coefficient coefficient="B1PF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="B1PF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="B1APF_Magnet" type="MultipoleMagnet">
<position x="B1APF_XPosition" y="0" z="B1APF_CenterPosition"/>
<rotation x="0" y="B1APF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B1APF_InnerRadius" dz="B1APF_Length*0.5"/>
<coefficient coefficient="B1APF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="B1APF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="B2PF_Magnet" type="MultipoleMagnet">
<position x="B2PF_XPosition" y="0" z="B2PF_CenterPosition"/>
<rotation x="0" y="B2PF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B2PF_InnerRadius" dz="B2PF_Length*0.5"/>
<coefficient coefficient="B2PF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="B2PF_GradientMax" skew="0.0*tesla/cm"/>
</field>
</fields>
<comment> <comment>
FB elements FB elements
...@@ -52,7 +52,7 @@ parser.add_argument('-t', '--tag', type=str,dest='file_tag', ...@@ -52,7 +52,7 @@ parser.add_argument('-t', '--tag', type=str,dest='file_tag',
help='Output file tag') help='Output file tag')
parser.add_argument('--timeout', type=int, parser.add_argument('--timeout', type=int,
default=60, default=3600,
help='Timeout in seconds') help='Timeout in seconds')
parser.add_argument('passthrough', nargs='*') parser.add_argument('passthrough', nargs='*')
...@@ -7,9 +7,15 @@ env = Environment( ...@@ -7,9 +7,15 @@ env = Environment(
autoescape=select_autoescape(['html', 'xml']) autoescape=select_autoescape(['html', 'xml'])
import os
import glob import glob
base_url = "https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw" if "CI_PROJECT_ID" in os.environ:
CI_PROJECT_ID = str(os.environ["CI_PROJECT_ID"])
else:
CI_PROJECT_ID = "473"
base_url = f"https://eicweb.phy.anl.gov/api/v4/projects/{CI_PROJECT_ID}/jobs/artifacts/master/raw"
#images = ["images/view2a.png","images/view2b.png", "images/view1.png"] #images = ["images/view2a.png","images/view2b.png", "images/view1.png"]
images = glob.glob("images/*.png") images = glob.glob("images/*.png")
"ecal_neg_endcap": {
"readout": "module",
"dynamicRange": "20*GeV",
"capacityBitsADC": 14,
"pedestalMean": 100,
"pedestalSigma": 1,
"thresholdValue": 3
"hcal_neg_endcap": {
"readout": "tile",
"dynamicRange": "20*MeV",
"capacityBitsADC": 8,
"pedestalMean": 20,
"pedestalSigma": 0.3,
"thresholdValue": 1
"ecal_pos_endcap": {
"dynamicRange": "3*GeV",
"pedestalSigma": 0.7,
"thresholdValue": 2
"hcal_pos_endcap": {
"readout": "tile",
"dynamicRange": "3.6*GeV",
"capacityBitsADC": 10,
"pedestalMean": 20,
"pedestalSigma": 0.8,
"thresholdValue": 3
"ecal_barrel_imaging": {
"readout": "pixel",
"dynamicRange": "3*MeV",
"capacityBitsADC": 13,
"pedestalSigma": 14,
"thresholdValue": 50
"ecal_barrel_scfi": {
"readout": "light_guide",
"dynamicRange": "750*MeV",
"pedestalMean": 20,
"thresholdValue": 1
"hcal_barrel": {
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 1
calo_digi_canyonlands.json
\ No newline at end of file
"electron": { "electron": {
"particle_name": "electron", "particle_name": "electron",
"sampling_fraction": 0.10856976476514045, "sampling_fraction": 0.1053739677993623,
"sampling_fraction_img": 0.00595078393326404, "sampling_fraction_error": 0.00014385360879111712,
"sampling_fraction_scfi": 0.10262666247845109, "sampling_fraction_error_img": 7.262477989358573e-05,
"thrown_energy": 4.975791477972636 "sampling_fraction_error_scfi": 0.0001238835428684493,
"sampling_fraction_img": 0.006008855583640059,
"sampling_fraction_scfi": 0.09940809338992981,
"thrown_energy": 5.000000028019361
"ffi_zdc_ecal": {
"sampling_fraction": 1.0,
"minClusterCenterEdep": "3.*MeV",
"minClusterHitEdep": "0.1*MeV",
"localDistXY": ["50*mm", "50*mm"],
"splitCluster": true
"ffi_zdc_hcal": {
"minClusterCenterEdep": "1.*MeV",
"localDistXY": ["200*mm", "200*mm"],
"splitCluster": false
...@@ -19,9 +19,6 @@ ...@@ -19,9 +19,6 @@
</comment> </comment>
<define> <define>
<comment> Main diagonal direction for barrel/endcap transitions </comment>
<constant name="TrackerMainDiagonal_tan" value="Eta1_1_tan"/>
<comment> Inner tracker setup </comment> <comment> Inner tracker setup </comment>
<constant name="InnerTrackerBarrel_rmin" value="13.38*cm"/> <constant name="InnerTrackerBarrel_rmin" value="13.38*cm"/>
<constant name="InnerTrackerBarrel_offset" value="4.62*cm"/> <constant name="InnerTrackerBarrel_offset" value="4.62*cm"/>
...@@ -147,11 +144,11 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -147,11 +144,11 @@ total X0 0.24% per disk layer (4 sectors per disk):
<constant name="InnerTrackerBarrelCone_z" value="(InnerTrackerBarrelCone_zmax + InnerTrackerBarrelCone_zmin)/2" /> <constant name="InnerTrackerBarrelCone_z" value="(InnerTrackerBarrelCone_zmax + InnerTrackerBarrelCone_zmin)/2" />
<constant name="InnerTrackerBarrelCone_thickness" value="SiTrackerSupportConeCF_thickness + SiTrackerServiceConeAl_thickness" /> <constant name="InnerTrackerBarrelCone_thickness" value="SiTrackerSupportConeCF_thickness + SiTrackerServiceConeAl_thickness" />
<comment> Shorten Module (with non-zero thickness!) to avoid overlaps with support cone</comment> <comment> Shorten Module (with non-zero thickness!) to avoid overlaps with support cone</comment>
<constant name="InnerTrackerBarrelMod1_length" value="2 * InnerTrackerBarrelMod1_rmin / TrackerMainDiagonal_tan - 0.5*cm - 2. * InnerTrackerBarrelCone_thickness" /> <constant name="InnerTrackerBarrelMod1_length" value="2 * InnerTrackerBarrelMod1_rmin / CentralTrackingBarrel_tan - 0.5*cm - 2. * InnerTrackerBarrelCone_thickness" />
<constant name="InnerTrackerBarrelMod2_length" value="2 * InnerTrackerBarrelMod2_rmin / TrackerMainDiagonal_tan - 0.5*cm - 2. * InnerTrackerBarrelCone_thickness" /> <constant name="InnerTrackerBarrelMod2_length" value="2 * InnerTrackerBarrelMod2_rmin / CentralTrackingBarrel_tan - 0.5*cm - 2. * InnerTrackerBarrelCone_thickness" />
<constant name="InnerTrackerBarrelServiceCone_rmin1" value="InnerTrackerBarrelCone_zmin * TrackerMainDiagonal_tan" /> <constant name="InnerTrackerBarrelServiceCone_rmin1" value="InnerTrackerBarrelCone_zmin * CentralTrackingBarrel_tan" />
<constant name="InnerTrackerBarrelServiceCone_rmax1" value="InnerTrackerBarrelServiceCone_rmin1 + SiTrackerServiceConeAl_thickness" /> <constant name="InnerTrackerBarrelServiceCone_rmax1" value="InnerTrackerBarrelServiceCone_rmin1 + SiTrackerServiceConeAl_thickness" />
<constant name="InnerTrackerBarrelServiceCone_rmin2" value="InnerTrackerBarrelCone_zmax * TrackerMainDiagonal_tan" /> <constant name="InnerTrackerBarrelServiceCone_rmin2" value="InnerTrackerBarrelCone_zmax * CentralTrackingBarrel_tan" />
<constant name="InnerTrackerBarrelServiceCone_rmax2" value="InnerTrackerBarrelServiceCone_rmin2 + SiTrackerServiceConeAl_thickness" /> <constant name="InnerTrackerBarrelServiceCone_rmax2" value="InnerTrackerBarrelServiceCone_rmin2 + SiTrackerServiceConeAl_thickness" />
<constant name="InnerTrackerBarrelSupportCone_rmin1" value="InnerTrackerBarrelServiceCone_rmax1" /> <constant name="InnerTrackerBarrelSupportCone_rmin1" value="InnerTrackerBarrelServiceCone_rmax1" />
<constant name="InnerTrackerBarrelSupportCone_rmax1" value="InnerTrackerBarrelSupportCone_rmin1 + SiTrackerSupportConeCF_thickness" /> <constant name="InnerTrackerBarrelSupportCone_rmax1" value="InnerTrackerBarrelSupportCone_rmin1 + SiTrackerSupportConeCF_thickness" />
...@@ -284,14 +281,14 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -284,14 +281,14 @@ total X0 0.24% per disk layer (4 sectors per disk):
<comment> Inner Si endcap setup </comment> <comment> Inner Si endcap setup </comment>
<constant name="InnerTrackerEndcapMod1_zmin" value="InnerTrackerEndcap_zmin" /> <constant name="InnerTrackerEndcapMod1_zmin" value="InnerTrackerEndcap_zmin" />
<constant name="InnerTrackerEndcapMod1_rmin" value="InnerTrackerEndcap_rmin" /> <constant name="InnerTrackerEndcapMod1_rmin" value="InnerTrackerEndcap_rmin" />
<constant name="InnerTrackerEndcapMod1_rmax" value="min(InnerTrackerEndcapMod1_zmin * TrackerMainDiagonal_tan * 0.995, SiTrackerCyl_rmin)" /> <constant name="InnerTrackerEndcapMod1_rmax" value="min(InnerTrackerEndcapMod1_zmin * CentralTrackingBarrel_tan * 0.995, SiTrackerCyl_rmin)" />
<constant name="InnerTrackerEndcapMod1_x1" value="2 * InnerTrackerEndcapMod1_rmin * tan(SiTrackerEndcapMod_angle/2)" /> <constant name="InnerTrackerEndcapMod1_x1" value="2 * InnerTrackerEndcapMod1_rmin * tan(SiTrackerEndcapMod_angle/2)" />
<constant name="InnerTrackerEndcapMod1_x2" value="2 * InnerTrackerEndcapMod1_rmax * sin(SiTrackerEndcapMod_angle/2)" /> <constant name="InnerTrackerEndcapMod1_x2" value="2 * InnerTrackerEndcapMod1_rmax * sin(SiTrackerEndcapMod_angle/2)" />
<constant name="InnerTrackerEndcapMod1_y" value="InnerTrackerEndcapMod1_rmax * cos(SiTrackerEndcapMod_angle/2) - InnerTrackerEndcapMod1_rmin" /> <constant name="InnerTrackerEndcapMod1_y" value="InnerTrackerEndcapMod1_rmax * cos(SiTrackerEndcapMod_angle/2) - InnerTrackerEndcapMod1_rmin" />
<constant name="InnerTrackerEndcapMod2_zmin" value="InnerTrackerEndcapMod1_zmin + 1 * InnerTrackerEndcap_offset" /> <constant name="InnerTrackerEndcapMod2_zmin" value="InnerTrackerEndcapMod1_zmin + 1 * InnerTrackerEndcap_offset" />
<constant name="InnerTrackerEndcapMod2_rmin" value="InnerTrackerEndcap_rmin" /> <constant name="InnerTrackerEndcapMod2_rmin" value="InnerTrackerEndcap_rmin" />
<constant name="InnerTrackerEndcapMod2_rmax" value="min(InnerTrackerEndcapMod2_zmin * TrackerMainDiagonal_tan * 0.995, SiTrackerCyl_rmin)" /> <constant name="InnerTrackerEndcapMod2_rmax" value="min(InnerTrackerEndcapMod2_zmin * CentralTrackingBarrel_tan * 0.995, SiTrackerCyl_rmin)" />
<constant name="InnerTrackerEndcapMod2_x1" value="2 * InnerTrackerEndcapMod2_rmin * tan(SiTrackerEndcapMod_angle/2)" /> <constant name="InnerTrackerEndcapMod2_x1" value="2 * InnerTrackerEndcapMod2_rmin * tan(SiTrackerEndcapMod_angle/2)" />
<constant name="InnerTrackerEndcapMod2_x2" value="2 * InnerTrackerEndcapMod2_rmax * sin(SiTrackerEndcapMod_angle/2)" /> <constant name="InnerTrackerEndcapMod2_x2" value="2 * InnerTrackerEndcapMod2_rmax * sin(SiTrackerEndcapMod_angle/2)" />
<constant name="InnerTrackerEndcapMod2_y" value="InnerTrackerEndcapMod2_rmax * cos(SiTrackerEndcapMod_angle/2) - InnerTrackerEndcapMod2_rmin" /> <constant name="InnerTrackerEndcapMod2_y" value="InnerTrackerEndcapMod2_rmax * cos(SiTrackerEndcapMod_angle/2) - InnerTrackerEndcapMod2_rmin" />
...@@ -304,11 +301,11 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -304,11 +301,11 @@ total X0 0.24% per disk layer (4 sectors per disk):
<constant name="InnerTrackerEndcapLayer2_zmin" value="InnerTrackerEndcapMod2_zmin - SiTrackerEndcapLayer_thickness/2" /> <constant name="InnerTrackerEndcapLayer2_zmin" value="InnerTrackerEndcapMod2_zmin - SiTrackerEndcapLayer_thickness/2" />
<constant name="InnerTrackerEndcapCone_zmin" value="InnerTrackerBarrelCone_zmax" /> <constant name="InnerTrackerEndcapCone_zmin" value="InnerTrackerBarrelCone_zmax" />
<constant name="InnerTrackerEndcapServiceCone_rmin1" value="InnerTrackerEndcapCone_zmin * TrackerMainDiagonal_tan" /> <constant name="InnerTrackerEndcapServiceCone_rmin1" value="InnerTrackerEndcapCone_zmin * CentralTrackingBarrel_tan" />
<constant name="InnerTrackerEndcapServiceCone_rmax1" value="InnerTrackerEndcapServiceCone_rmin1 + SiTrackerServiceConeAl_thickness" /> <constant name="InnerTrackerEndcapServiceCone_rmax1" value="InnerTrackerEndcapServiceCone_rmin1 + SiTrackerServiceConeAl_thickness" />
<constant name="InnerTrackerEndcapServiceCone_rmin2" value="SiTrackerServiceCyl_rmin" /> <constant name="InnerTrackerEndcapServiceCone_rmin2" value="SiTrackerServiceCyl_rmin" />
<constant name="InnerTrackerEndcapServiceCone_rmax2" value="SiTrackerServiceCyl_rmax" /> <constant name="InnerTrackerEndcapServiceCone_rmax2" value="SiTrackerServiceCyl_rmax" />
<constant name="InnerTrackerEndcapCone_zmax" value="InnerTrackerEndcapServiceCone_rmin2 / TrackerMainDiagonal_tan" /> <constant name="InnerTrackerEndcapCone_zmax" value="InnerTrackerEndcapServiceCone_rmin2 / CentralTrackingBarrel_tan" />
<constant name="InnerTrackerEndcapCone_z" value="(InnerTrackerEndcapCone_zmax + InnerTrackerEndcapCone_zmin)/2" /> <constant name="InnerTrackerEndcapCone_z" value="(InnerTrackerEndcapCone_zmax + InnerTrackerEndcapCone_zmin)/2" />
<constant name="InnerTrackerEndcapCone_length" value="InnerTrackerEndcapCone_zmax - InnerTrackerEndcapCone_zmin" /> <constant name="InnerTrackerEndcapCone_length" value="InnerTrackerEndcapCone_zmax - InnerTrackerEndcapCone_zmin" />
<constant name="InnerTrackerEndcapSupportCone_rmin1" value="InnerTrackerEndcapServiceCone_rmax1" /> <constant name="InnerTrackerEndcapSupportCone_rmin1" value="InnerTrackerEndcapServiceCone_rmax1" />
...@@ -317,7 +314,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -317,7 +314,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
<constant name="InnerTrackerEndcapSupportCone_rmax2" value="SiTrackerSupportCyl_rmax" /> <constant name="InnerTrackerEndcapSupportCone_rmax2" value="SiTrackerSupportCyl_rmax" />
<comment> The tracker endcap ends at the same place as the medial tracker barrel that sits around it </comment> <comment> The tracker endcap ends at the same place as the medial tracker barrel that sits around it </comment>
<constant name="InnerTrackerEndcap_zmax" value="MedialTrackerBarrel_rmin / TrackerMainDiagonal_tan" /> <constant name="InnerTrackerEndcap_zmax" value="MedialTrackerBarrel_rmin / CentralTrackingBarrel_tan" />
<constant name="InnerTrackerEndcapCyl_zmin" value="InnerTrackerEndcapCone_zmax" /> <constant name="InnerTrackerEndcapCyl_zmin" value="InnerTrackerEndcapCone_zmax" />
<constant name="InnerTrackerEndcapCyl_zmax" value="InnerTrackerEndcap_zmax" /> <constant name="InnerTrackerEndcapCyl_zmax" value="InnerTrackerEndcap_zmax" />
<constant name="InnerTrackerEndcapCyl_z" value="(InnerTrackerEndcapCyl_zmin + InnerTrackerEndcapCyl_zmax)/2" /> <constant name="InnerTrackerEndcapCyl_z" value="(InnerTrackerEndcapCyl_zmin + InnerTrackerEndcapCyl_zmax)/2" />
...@@ -329,7 +326,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -329,7 +326,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapP_0_ID" id="TrackerEndcapP_0_ID"
name="InnerTrackerEndcapP" name="InnerTrackerEndcapP"
type="athena_TrapEndcapTracker" type="athena_TrapEndcapTracker"
readout="TrackerEndcapHits" readout="TrackerEndcapHits1"
vis="TrackerVis" vis="TrackerVis"
reflect="false"> reflect="false">
<support material="Aluminum" name="serv_cone_pos" vis="TrackerServiceVis"> <support material="Aluminum" name="serv_cone_pos" vis="TrackerServiceVis">
...@@ -405,7 +402,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -405,7 +402,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapN_0_ID" id="TrackerEndcapN_0_ID"
name="InnerTrackerEndcapN" name="InnerTrackerEndcapN"
readout="TrackerEndcapHits" readout="TrackerEndcapHits2"
reflect="true"> reflect="true">
<support material="Aluminum" name="serv_cone_neg" vis="TrackerServiceVis"> <support material="Aluminum" name="serv_cone_neg" vis="TrackerServiceVis">
...@@ -516,7 +513,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -516,7 +513,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerBarrel_1_ID" id="TrackerBarrel_1_ID"
name="MedialTrackerBarrel" name="MedialTrackerBarrel"
type="athena_TrackerBarrel" type="athena_TrackerBarrel"
readout="MPGDTrackerBarrelHits" readout="MPGDTrackerBarrelHits1"
insideTrackingVolume="true"> insideTrackingVolume="true">
<dimensions <dimensions
rmin="MedialTrackerBarrelEnvelope_rmin" rmin="MedialTrackerBarrelEnvelope_rmin"
...@@ -579,7 +576,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -579,7 +576,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
<comment> Medial Si endcap setup </comment> <comment> Medial Si endcap setup </comment>
<constant name="MedialTrackerEndcapPMod1_zmin" value="MedialTrackerEndcap_zmin" /> <constant name="MedialTrackerEndcapPMod1_zmin" value="MedialTrackerEndcap_zmin" />
<constant name="MedialTrackerEndcapPMod1_rmin" value="MedialTrackerEndcapP_rmin" /> <constant name="MedialTrackerEndcapPMod1_rmin" value="MedialTrackerEndcapP_rmin" />
<constant name="MedialTrackerEndcapPMod1_rmax" value="min(MedialTrackerEndcapPMod1_zmin * TrackerMainDiagonal_tan * 0.995, SiTrackerCyl_rmin)" /> <constant name="MedialTrackerEndcapPMod1_rmax" value="min(MedialTrackerEndcapPMod1_zmin * CentralTrackingBarrel_tan * 0.995, SiTrackerCyl_rmin)" />
<constant name="MedialTrackerEndcapPMod1_x1" value="2 * MedialTrackerEndcapPMod1_rmin * tan(SiTrackerEndcapMod_angle/2)" /> <constant name="MedialTrackerEndcapPMod1_x1" value="2 * MedialTrackerEndcapPMod1_rmin * tan(SiTrackerEndcapMod_angle/2)" />
<constant name="MedialTrackerEndcapPMod1_x2" value="2 * MedialTrackerEndcapPMod1_rmax * sin(SiTrackerEndcapMod_angle/2)" /> <constant name="MedialTrackerEndcapPMod1_x2" value="2 * MedialTrackerEndcapPMod1_rmax * sin(SiTrackerEndcapMod_angle/2)" />
<constant name="MedialTrackerEndcapPMod1_y" value="MedialTrackerEndcapPMod1_rmax * cos(SiTrackerEndcapMod_angle/2) - MedialTrackerEndcapPMod1_rmin" /> <constant name="MedialTrackerEndcapPMod1_y" value="MedialTrackerEndcapPMod1_rmax * cos(SiTrackerEndcapMod_angle/2) - MedialTrackerEndcapPMod1_rmin" />
...@@ -590,7 +587,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -590,7 +587,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
<constant name="MedialTrackerEndcapNMod1_zmin" value="MedialTrackerEndcap_zmin" /> <constant name="MedialTrackerEndcapNMod1_zmin" value="MedialTrackerEndcap_zmin" />
<constant name="MedialTrackerEndcapNMod1_rmin" value="MedialTrackerEndcapN_rmin" /> <constant name="MedialTrackerEndcapNMod1_rmin" value="MedialTrackerEndcapN_rmin" />
<constant name="MedialTrackerEndcapNMod1_rmax" value="min(MedialTrackerEndcapNMod1_zmin * TrackerMainDiagonal_tan * 0.995, SiTrackerCyl_rmin)" /> <constant name="MedialTrackerEndcapNMod1_rmax" value="min(MedialTrackerEndcapNMod1_zmin * CentralTrackingBarrel_tan * 0.995, SiTrackerCyl_rmin)" />
<constant name="MedialTrackerEndcapNMod1_x1" value="2 * MedialTrackerEndcapNMod1_rmin * tan(SiTrackerEndcapMod_angle/2)" /> <constant name="MedialTrackerEndcapNMod1_x1" value="2 * MedialTrackerEndcapNMod1_rmin * tan(SiTrackerEndcapMod_angle/2)" />
<constant name="MedialTrackerEndcapNMod1_x2" value="2 * MedialTrackerEndcapNMod1_rmax * sin(SiTrackerEndcapMod_angle/2)" /> <constant name="MedialTrackerEndcapNMod1_x2" value="2 * MedialTrackerEndcapNMod1_rmax * sin(SiTrackerEndcapMod_angle/2)" />
<constant name="MedialTrackerEndcapNMod1_y" value="MedialTrackerEndcapNMod1_rmax * cos(SiTrackerEndcapMod_angle/2) - MedialTrackerEndcapNMod1_rmin" /> <constant name="MedialTrackerEndcapNMod1_y" value="MedialTrackerEndcapNMod1_rmax * cos(SiTrackerEndcapMod_angle/2) - MedialTrackerEndcapNMod1_rmin" />
...@@ -600,7 +597,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -600,7 +597,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
<constant name="MedialTrackerEndcapNLayer1_zmin" value="MedialTrackerEndcapNMod1_zmin - SiTrackerEndcapLayer_thickness/2" /> <constant name="MedialTrackerEndcapNLayer1_zmin" value="MedialTrackerEndcapNMod1_zmin - SiTrackerEndcapLayer_thickness/2" />
<comment> The tracker endcap ends at the same place as the outer tracker barrel that sits around it </comment> <comment> The tracker endcap ends at the same place as the outer tracker barrel that sits around it </comment>
<constant name="MedialTrackerEndcap_zmax" value="OuterTrackerBarrel_rmin / TrackerMainDiagonal_tan" /> <constant name="MedialTrackerEndcap_zmax" value="OuterTrackerBarrel_rmin / CentralTrackingBarrel_tan" />
<constant name="MedialTrackerEndcapCyl_zmin" value="InnerTrackerEndcap_zmax" /> <constant name="MedialTrackerEndcapCyl_zmin" value="InnerTrackerEndcap_zmax" />
<constant name="MedialTrackerEndcapCyl_zmax" value="MedialTrackerEndcap_zmax" /> <constant name="MedialTrackerEndcapCyl_zmax" value="MedialTrackerEndcap_zmax" />
<constant name="MedialTrackerEndcapCyl_z" value="(MedialTrackerEndcapCyl_zmin + MedialTrackerEndcapCyl_zmax)/2" /> <constant name="MedialTrackerEndcapCyl_z" value="(MedialTrackerEndcapCyl_zmin + MedialTrackerEndcapCyl_zmax)/2" />
...@@ -612,7 +609,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -612,7 +609,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapP_1_ID" id="TrackerEndcapP_1_ID"
name="MedialTrackerEndcapP" name="MedialTrackerEndcapP"
readout="TrackerEndcapHits" readout="TrackerEndcapHits3"
<support material="Aluminum" name="serv_cyl_pos" vis="TrackerServiceVis" <support material="Aluminum" name="serv_cyl_pos" vis="TrackerServiceVis"
...@@ -650,7 +647,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -650,7 +647,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapN_1_ID" id="TrackerEndcapN_1_ID"
name="MedialTrackerEndcapN" name="MedialTrackerEndcapN"
readout="TrackerEndcapHits" readout="TrackerEndcapHits4"
<support material="Aluminum" name="serv_cyl_neg" vis="TrackerServiceVis" <support material="Aluminum" name="serv_cyl_neg" vis="TrackerServiceVis"
...@@ -714,7 +711,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -714,7 +711,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerBarrel_2_ID" id="TrackerBarrel_2_ID"
name="OuterTrackerBarrel" name="OuterTrackerBarrel"
readout="MPGDTrackerBarrelHits" readout="MPGDTrackerBarrelHits2"
rmin="OuterTrackerBarrelEnvelope_rmin" rmin="OuterTrackerBarrelEnvelope_rmin"
...@@ -846,7 +843,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -846,7 +843,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapP_2_ID" id="TrackerEndcapP_2_ID"
name="OuterTrackerEndcapP" name="OuterTrackerEndcapP"
readout="TrackerEndcapHits" readout="TrackerEndcapHits5"
...@@ -924,7 +921,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -924,7 +921,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapN_2_ID" id="TrackerEndcapN_2_ID"
name="OuterTrackerEndcapN" name="OuterTrackerEndcapN"
readout="TrackerEndcapHits" readout="TrackerEndcapHits6"
...@@ -996,7 +993,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -996,7 +993,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
<comment> Parameters for the "ring" GEMS around the silicon tracker, which are all identical </comment> <comment> Parameters for the "ring" GEMS around the silicon tracker, which are all identical </comment>
<constant name="GEMEndcapRingMod_rmin" value="SiTrackerSupportCyl_rmax + GEMFrameBotEdge_width" /> <constant name="GEMEndcapRingMod_rmin" value="SiTrackerSupportCyl_rmax + GEMFrameBotEdge_width" />
<constant name="GEMEndcapRingMod_rmax" value="min(min(GEMEndcapPDisk1_zmin, GEMEndcapN_zmin) * TrackerMainDiagonal_tan * 0.995, CentralTrackingRegion_rmax) - GEMFrameTopEdge_width" /> <constant name="GEMEndcapRingMod_rmax" value="min(min(GEMEndcapPDisk1_zmin, GEMEndcapN_zmin) * CentralTrackingBarrel_tan * 0.995, CentralTrackingRegion_rmax) - GEMFrameTopEdge_width" />
<constant name="GEMEndcapRingMod_x1" value="2 * GEMEndcapRingMod_rmin * tan(GEMEndcapMod_angle/2)" /> <constant name="GEMEndcapRingMod_x1" value="2 * GEMEndcapRingMod_rmin * tan(GEMEndcapMod_angle/2)" />
<constant name="GEMEndcapRingMod_x2" value="2 * GEMEndcapRingMod_rmax * sin(GEMEndcapMod_angle/2)" /> <constant name="GEMEndcapRingMod_x2" value="2 * GEMEndcapRingMod_rmax * sin(GEMEndcapMod_angle/2)" />
<constant name="GEMEndcapRingMod_y" value="GEMEndcapRingMod_rmax * cos(GEMEndcapMod_angle/2) - GEMEndcapRingMod_rmin" /> <constant name="GEMEndcapRingMod_y" value="GEMEndcapRingMod_rmax * cos(GEMEndcapMod_angle/2) - GEMEndcapRingMod_rmin" />
...@@ -1039,7 +1036,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -1039,7 +1036,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
<constant name="GEMEndcapLargeModBotFrame_x2" value="2 * GEMEndcapLargeModBotFrame_rmax * sin(GEMEndcapMod_angle/2)" /> <constant name="GEMEndcapLargeModBotFrame_x2" value="2 * GEMEndcapLargeModBotFrame_rmax * sin(GEMEndcapMod_angle/2)" />
<constant name="GEMEndcapLargeMod_rmin" value="GEMEndcapPMod3_zmin * ForwardTrackingRegion_tan + GEMFrameBotEdge_width" /> <constant name="GEMEndcapLargeMod_rmin" value="GEMEndcapPMod3_zmin * ForwardTrackingRegion_tan + GEMFrameBotEdge_width" />
<comment> Ensure there's always the length of the service gap in space available above the large GEM (top frame can extend into this at the corners). </comment> <comment> Ensure there's always the length of the service gap in space available above the large GEM (top frame can extend into this at the corners). </comment>
<constant name="GEMEndcapLargeMod_rmax" value="min(GEMEndcapPMod3_zmin * TrackerMainDiagonal_tan, Solenoid_rmax-ForwardServiceGap_length)" /> <constant name="GEMEndcapLargeMod_rmax" value="min(GEMEndcapPMod3_zmin * CentralTrackingBarrel_tan, Solenoid_rmax-ForwardServiceGap_length)" />
<constant name="GEMEndcapLargeMod_x1" value="2 * GEMEndcapLargeMod_rmin * sin(GEMEndcapMod_angle/2)" /> <constant name="GEMEndcapLargeMod_x1" value="2 * GEMEndcapLargeMod_rmin * sin(GEMEndcapMod_angle/2)" />
<constant name="GEMEndcapLargeMod_x2" value="2 * GEMEndcapLargeMod_rmax * sin(GEMEndcapMod_angle/2)" /> <constant name="GEMEndcapLargeMod_x2" value="2 * GEMEndcapLargeMod_rmax * sin(GEMEndcapMod_angle/2)" />
<constant name="GEMEndcapLargeMod_y" value="GEMEndcapLargeMod_rmax * cos(GEMEndcapMod_angle/2) - GEMEndcapLargeMod_rmin" /> <constant name="GEMEndcapLargeMod_y" value="GEMEndcapLargeMod_rmax * cos(GEMEndcapMod_angle/2) - GEMEndcapLargeMod_rmin" />
...@@ -1059,7 +1056,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -1059,7 +1056,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapP_3_ID" id="TrackerEndcapP_3_ID"
name="GEMEndcapP" name="GEMEndcapP"
readout="GEMTrackerEndcapHits" readout="GEMTrackerEndcapHits1"
<module name="RingModule" vis="TrackerGEMModuleVis"> <module name="RingModule" vis="TrackerGEMModuleVis">
...@@ -1173,7 +1170,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -1173,7 +1170,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapN_3_ID" id="TrackerEndcapN_3_ID"
name="GEMEndcapN" name="GEMEndcapN"
readout="GEMTrackerEndcapHits" readout="GEMTrackerEndcapHits2"
...@@ -1321,7 +1318,7 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -1321,7 +1318,7 @@ total X0 0.24% per disk layer (4 sectors per disk):
id="TrackerEndcapP_4_ID" id="TrackerEndcapP_4_ID"
name="ForwardGEM" name="ForwardGEM"
readout="GEMTrackerEndcapHits" readout="GEMTrackerEndcapHits3"
<module name="LargeModule" vis="TrackerGEMModuleVis"> <module name="LargeModule" vis="TrackerGEMModuleVis">
...@@ -1400,15 +1397,47 @@ total X0 0.24% per disk layer (4 sectors per disk): ...@@ -1400,15 +1397,47 @@ total X0 0.24% per disk layer (4 sectors per disk):
<segmentation type="CartesianGridXY" grid_size_x="0.010*mm" grid_size_y="0.010*mm" /> <segmentation type="CartesianGridXY" grid_size_x="0.010*mm" grid_size_y="0.010*mm" />
<id>system:8,layer:4,module:12,sensor:2,x:32:-14,y:-18</id> <id>system:8,layer:4,module:12,sensor:2,x:32:-14,y:-18</id>
</readout> </readout>
<readout name="TrackerEndcapHits"> <readout name="TrackerEndcapHits1">
<segmentation type="CartesianGridXZ" grid_size_x="0.010*mm" grid_size_z="0.010*mm" />
<id>system:8,layer:4,module:12,sensor:2,x:32:-16,z:-16</id>
</readout>
<readout name="TrackerEndcapHits2">
</readout>
<readout name="TrackerEndcapHits3">
</readout>
<readout name="TrackerEndcapHits4">
</readout>
<readout name="TrackerEndcapHits5">
<segmentation type="CartesianGridXZ" grid_size_x="0.010*mm" grid_size_z="0.010*mm" /> <segmentation type="CartesianGridXZ" grid_size_x="0.010*mm" grid_size_z="0.010*mm" />
<id>system:8,layer:4,module:12,sensor:2,x:32:-16,z:-16</id> <id>system:8,layer:4,module:12,sensor:2,x:32:-16,z:-16</id>
<readout name="MPGDTrackerBarrelHits"> <readout name="TrackerEndcapHits6">
</readout>
<readout name="MPGDTrackerBarrelHits1">
<segmentation type="CartesianGridXY" grid_size_x="0.150*mm*sqrt(12)" grid_size_y="0.150*mm*sqrt(12)" />
</readout>
<readout name="MPGDTrackerBarrelHits2">
<segmentation type="CartesianGridXY" grid_size_x="0.150*mm*sqrt(12)" grid_size_y="0.150*mm*sqrt(12)" /> <segmentation type="CartesianGridXY" grid_size_x="0.150*mm*sqrt(12)" grid_size_y="0.150*mm*sqrt(12)" />
<readout name="GEMTrackerEndcapHits"> <readout name="GEMTrackerEndcapHits1">
<segmentation type="CartesianGridXZ" grid_size_x="0.050*mm*sqrt(12)" grid_size_z="0.250*mm*sqrt(12)" />
</readout>
<readout name="GEMTrackerEndcapHits2">
</readout>
<readout name="GEMTrackerEndcapHits3">
<segmentation type="CartesianGridXZ" grid_size_x="0.050*mm*sqrt(12)" grid_size_z="0.250*mm*sqrt(12)" /> <segmentation type="CartesianGridXZ" grid_size_x="0.050*mm*sqrt(12)" grid_size_z="0.250*mm*sqrt(12)" />
...@@ -231,38 +231,78 @@ The unused IDs below are saved for future use. ...@@ -231,38 +231,78 @@ The unused IDs below are saved for future use.
<constant name="SolenoidYoke_ID" value="142"/> <constant name="SolenoidYoke_ID" value="142"/>
<documentation> <documentation>
#### (150-169) Far Forward Detectors #### (150-169) Far Forward Detectors
- Forward Roman Pot ID: 150 - Forward Roman Pot ID: 150
- Forward B0 Tracker ID: 151 - Forward B0 Tracker ID: 151
- Zero Degree Cal. Ecal ID: 160 - Zero Degree Cal. Ecal ID: 160
- Zero Degree Cal. Hcal ID: 161 - Zero Degree Cal. Hcal ID: 161
TODO: A lot of the repeated ID's below should be pushed into a single detector TODO: A lot of the repeated ID's below should be pushed into a single detector
<constant name="B0Tracker_Station_1_ID" value="150"/> <constant name="B0Tracker_Station_1_ID" value="150"/>
<constant name="B0Tracker_Station_2_ID" value="151"/> <constant name="B0Tracker_Station_2_ID" value="151"/>
<constant name="B0Tracker_Station_3_ID" value="152"/> <constant name="B0Tracker_Station_3_ID" value="152"/>
<constant name="B0Tracker_Station_4_ID" value="153"/> <constant name="B0Tracker_Station_4_ID" value="153"/>
<constant name="B0Preshower_Station_1_ID" value="154"/> <constant name="B0Preshower_Station_1_ID" value="154"/>
<constant name="ForwardRomanPot_Station_1_ID" value="155"/> <constant name="ForwardRomanPot_Station_1_ID" value="155"/>
<constant name="ForwardRomanPot_Station_2_ID" value="156"/> <constant name="ForwardRomanPot_Station_2_ID" value="156"/>
<constant name="ForwardOffMTracker_station_1_ID" value="159"/> <constant name="ForwardOffMTracker_station_1_ID" value="159"/>
<constant name="ForwardOffMTracker_station_2_ID" value="160"/> <constant name="ForwardOffMTracker_station_2_ID" value="160"/>
<constant name="ForwardOffMTracker_station_3_ID" value="161"/> <constant name="ForwardOffMTracker_station_3_ID" value="161"/>
<constant name="ForwardOffMTracker_station_4_ID" value="162"/> <constant name="ForwardOffMTracker_station_4_ID" value="162"/>
<comment> TODO naming consistency </comment> <constant name="ZDCEcal_ID" value="163"/>
<constant name="ffi_ZDC_ECAL_ID" value="163"/> <constant name="ZDCHcal_ID" value="164"/>
<constant name="ffi_ZDC_HCAL_ID" value="164"/>
<constant name="VacuumMagnetElement_1_ID" value="165"/> <constant name="VacuumMagnetElement_1_ID" value="165"/>
#### (170-189) Forward Beamline Magnets #### (170-189) Far Forward Beamline Magnets
<constant name="B0PF_ID" value="170"/>
<constant name="B0APF_ID" value="171"/>
<constant name="Q1APF_ID" value="172"/>
<constant name="Q1BPF_ID" value="173"/>
<constant name="Q2PF_ID" value="174"/>
<constant name="B1PF_ID" value="175"/>
<constant name="B1APF_ID" value="176"/>
<constant name="B2PF_ID" value="177"/>
<constant name="Q0EF_ID" value="180"/>
<constant name="Q1EF_ID" value="181"/>
#### (190-199) Backward Beamline Magnets #### (190-199) Far Backward Beamline Magnets
- Low-Q2 Tagger 1 Tracker ID: 195
- Low-Q2 Tagger 1 Calorimeter ID: 196
- Low-Q2 Tagger 2 Tracker ID: 198
- Low-Q2 Tagger 2 Calorimeter ID: 199
</documentation>
<constant name="LumiCollimator_ID" value="190"/>
<constant name="LumiDipole_ID" value="191"/>
<constant name="TaggerTracker_1_ID" value="195"/>
<constant name="TaggerCalorimeter_1_ID" value="196"/>
<constant name="TaggerTracker_2_ID" value="198"/>
<constant name="TaggerCalorimeter_2_ID" value="199"/>
<documentation>
#### (200-219) Far Backward Beamline Magnets
<constant name="Pipe_to_Q1eR_ID" value="200"/>
<constant name="Magnet_Q1eR_ID" value="201"/>
<constant name="Pipe_in_Q1eR_ID" value="202"/>
<constant name="Pipe_Q1eR_to_Q2eR_ID" value="203"/>
<constant name="Magnet_Q2eR_ID" value="204"/>
<constant name="Pipe_in_Q2eR_ID" value="205"/>
<constant name="Pipe_Q2eR_to_B2AeR_ID" value="206"/>
<constant name="Magnet_B2AeR_ID" value="207"/>
<constant name="Pipe_in_B2AeR_ID" value="208"/>
<constant name="Pipe_B2AeR_to_B2BeR_ID" value="209"/>
<constant name="Magnet_B2BeR_ID" value="210"/>
<constant name="Pipe_in_B2BeR_ID" value="211"/>
<constant name="Magnet_Q3eR_ID" value="212"/>
<constant name="Vacuum_in_Q3eR_ID" value="213"/>
## Detector Definition Parameters ## Detector Definition Parameters
...@@ -311,6 +351,13 @@ Examples: ...@@ -311,6 +351,13 @@ Examples:
<constant name="Eta3_9_tan" value="tan(2*atan(exp(-3.9)))" /> <constant name="Eta3_9_tan" value="tan(2*atan(exp(-3.9)))" />
<constant name="Eta4_0_tan" value="tan(2*atan(exp(-4.0)))" /> <constant name="Eta4_0_tan" value="tan(2*atan(exp(-4.0)))" />
<constant name="Eta4_1_tan" value="tan(2*atan(exp(-4.1)))" /> <constant name="Eta4_1_tan" value="tan(2*atan(exp(-4.1)))" />
<constant name="Eta4_2_tan" value="tan(2*atan(exp(-4.2)))" />
<constant name="Eta4_3_tan" value="tan(2*atan(exp(-4.3)))" />
<constant name="Eta4_4_tan" value="tan(2*atan(exp(-4.4)))" />
<constant name="Eta4_5_tan" value="tan(2*atan(exp(-4.5)))" />
<constant name="Eta4_6_tan" value="tan(2*atan(exp(-4.6)))" />
<constant name="Eta4_7_tan" value="tan(2*atan(exp(-4.7)))" />
<constant name="Eta4_8_tan" value="tan(2*atan(exp(-4.8)))" />
<comment>Solenoid option</comment> <comment>Solenoid option</comment>
...@@ -365,12 +412,13 @@ Examples: ...@@ -365,12 +412,13 @@ Examples:
<constant name="CentralTrackingRegion_rmax" value="950.0*mm" /> <constant name="CentralTrackingRegion_rmax" value="950.0*mm" />
<constant name="CentralTrackingRegionP_zmax" value="1900.0*mm" /> <constant name="CentralTrackingRegionP_zmax" value="1700.0*mm" />
<constant name="CentralTrackingRegionN_zmax" value="1500.0*mm" /> <constant name="CentralTrackingRegionN_zmax" value="1500.0*mm" />
<constant name="CentralTrackingRegion_length" value="CentralTrackingRegionP_zmax + CentralTrackingRegionN_zmax" /> <constant name="CentralTrackingRegion_length" value="CentralTrackingRegionP_zmax + CentralTrackingRegionN_zmax" />
<comment> <comment>
tan(theta) to determine rmin in the outer tracking region (due to tapered beampipe) tan(theta) to determine rmin in the outer tracking region (due to tapered beampipe)
<constant name="CentralTrackingBarrel_tan" value="Eta1_1_tan" />
<constant name="CentralTrackingRegionP_tan" value="Eta3_7_tan * 1.00" /> <constant name="CentralTrackingRegionP_tan" value="Eta3_7_tan * 1.00" />
<constant name="CentralTrackingRegionN_tan" value="Eta4_0_tan * 0.99" /> <constant name="CentralTrackingRegionN_tan" value="Eta4_0_tan * 0.99" />
...@@ -378,16 +426,35 @@ Examples: ...@@ -378,16 +426,35 @@ Examples:
### PID Detector Region Parameters ### PID Detector Region Parameters
<comment> Global PID regions with suballocations for TOF and RICH detectors </comment>
<constant name="ForwardPIDRegion_zmin" value="CentralTrackingRegionP_zmax" /> <constant name="ForwardPIDRegion_zmin" value="CentralTrackingRegionP_zmax" />
<constant name="ForwardPIDRegion_length" value="140.0*cm" /> <constant name="ForwardPIDRegion_length" value="160.0*cm" />
<comment> Forward TOF region currenlty empty for future upgrades </comment>
<constant name="ForwardTOFRegion_zmin" value="ForwardPIDRegion_zmin" />
<constant name="ForwardTOFRegion_length" value="20.0*cm" />
<constant name="ForwardTOFRegion_rmax" value="CentralTrackingRegion_rmax" />
<constant name="ForwardTOFRegion_tan" value="CentralTrackingRegionP_tan" />
<comment> Forward RICH region </comment>
<constant name="ForwardRICHRegion_zmin" value="ForwardTOFRegion_zmin + ForwardTOFRegion_length" />
<constant name="ForwardRICHRegion_length" value="ForwardPIDRegion_length - ForwardTOFRegion_length" />
<comment> tangent of the opening angle at the front and back of the RICH </comment> <comment> tangent of the opening angle at the front and back of the RICH </comment>
<constant name="ForwardPIDRegion_tan1" value="CentralTrackingRegionP_tan * 1.00" /> <constant name="ForwardRICHRegion_tan1" value="CentralTrackingRegionP_tan * 0.88" />
<constant name="ForwardPIDRegion_tan2" value="Eta3_6_tan * 1.01" /> <constant name="ForwardRICHRegion_tan2" value="Eta3_6_tan * 0.89" />
<constant name="BackwardPIDRegion_zmin" value="CentralTrackingRegionN_zmax" /> <constant name="BackwardPIDRegion_zmin" value="CentralTrackingRegionN_zmax" />
<constant name="BackwardPIDRegion_tan" value="CentralTrackingRegionN_tan" />
<constant name="BackwardPIDRegion_length" value="60.0*cm" /> <constant name="BackwardPIDRegion_length" value="60.0*cm" />
<constant name="BackwardPIDRegion_rmax" value="CentralTrackingRegion_rmax" /> <constant name="BackwardPIDRegion_rmax" value="CentralTrackingRegion_rmax" />
<constant name="BackwardPIDRegion_tan" value="CentralTrackingRegionN_tan * 0.92" />
<comment> Backward RICH region </comment>
<constant name="BackwardRICHRegion_zmin" value="BackwardPIDRegion_zmin" />
<constant name="BackwardRICHRegion_length" value="58.0*cm" />
<comment> Backward TOF region, currently empty for upgrades </comment>
<constant name="BackwardTOFRegion_zmin" value="BackwardRICHRegion_zmin + BackwardRICHRegion_length" />
<constant name="BackwardTOFRegion_length" value="BackwardPIDRegion_length - BackwardRICHRegion_length" />
<comment> Note: PID has space for DIRC, ExtraSpace sits past the PID</comment> <comment> Note: PID has space for DIRC, ExtraSpace sits past the PID</comment>
<constant name="BarrelPIDRegion_thickness" value="8.0 * cm" /> <constant name="BarrelPIDRegion_thickness" value="8.0 * cm" />
...@@ -399,7 +466,7 @@ Examples: ...@@ -399,7 +466,7 @@ Examples:
<constant name="BackwardTrackingRegion_tan" value="CentralTrackingRegionN_tan" /> <constant name="BackwardTrackingRegion_tan" value="CentralTrackingRegionN_tan" />
<constant name="BackwardTrackingRegion_zmin" value="BackwardPIDRegion_zmin + BackwardPIDRegion_length" /> <constant name="BackwardTrackingRegion_zmin" value="BackwardPIDRegion_zmin + BackwardPIDRegion_length" />
<constant name="ForwardTrackingRegion_tan" value="ForwardPIDRegion_tan2" /> <constant name="ForwardTrackingRegion_tan" value="ForwardRICHRegion_tan2" />
<constant name="ForwardTrackingRegion_zmin" value="ForwardPIDRegion_zmin + ForwardPIDRegion_length" /> <constant name="ForwardTrackingRegion_zmin" value="ForwardPIDRegion_zmin + ForwardPIDRegion_length" />
<constant name="ForwardTrackingRegion_length" value="10.0*cm" /> <constant name="ForwardTrackingRegion_length" value="10.0*cm" />
<constant name="BackwardTrackingRegion_length" value="0.0*cm" /> <constant name="BackwardTrackingRegion_length" value="0.0*cm" />
...@@ -429,7 +496,12 @@ Service gaps in FW direction (before endcapP ECAL) and BW direction (before endc ...@@ -429,7 +496,12 @@ Service gaps in FW direction (before endcapP ECAL) and BW direction (before endc
<constant name="EcalEndcapN_zmin" value="BackwardPIDRegion_zmin + BackwardInnerEndcapRegion_length"/> <constant name="EcalEndcapN_zmin" value="BackwardPIDRegion_zmin + BackwardInnerEndcapRegion_length"/>
<constant name="EcalEndcapN_length" value="60*cm" /> <constant name="EcalEndcapN_length" value="60*cm" />
<constant name="EcalEndcapN_rmin" value="max((EcalEndcapN_zmin + EcalEndcapN_length) * tan(abs(CrossingAngle)) + 15.5 * mm, 5*cm)" /> <comment>
rmin1: rmin round electron pipe (ignoring the hadron pipe)
rmin2: rmin around both beam pipes
</comment>
<constant name="EcalEndcapN_rmin1" value="Eta4_6_tan * EcalEndcapN_zmin" />
<constant name="EcalEndcapN_rmin2" value="Eta4_1_tan * EcalEndcapN_zmin" />
<constant name="EcalEndcapN_rmax" value="CentralTrackingRegion_rmax" /> <constant name="EcalEndcapN_rmax" value="CentralTrackingRegion_rmax" />
<constant name="EcalBarrelRegion_thickness" value="45.0*cm"/> <constant name="EcalBarrelRegion_thickness" value="45.0*cm"/>
...@@ -25,7 +25,21 @@ ...@@ -25,7 +25,21 @@
<vis name="VertexLayerVis" ref="AnlGray" visible="true" showDaughters="true" /> <vis name="VertexLayerVis" ref="AnlGray" visible="true" showDaughters="true" />
<vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" /> <vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" />
<vis name="TOFVis" ref="AnlGreen" showDaughters="true" /> <vis name="TOFVis" ref="AnlTeal" visible="true" showDaughters="true"/>
<vis name="TOFLayerVis" ref="TOFVis" visible="true" showdaughters="true"/>
<vis name="TOFModuleVis" ref="TOFVis" visible="true" showdaughters="true"/>
<vis name="TOFSupportVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="TOFSensorVis" ref="TOFVis" visible="true" showDaughters="true"/>
<comment> By default don't display the barrel module details </comment>
<vis name="TOFBarrelModuleVis" ref="TOFVis" visible="true" showdaughters="true"/>
<comment> extra detailed vizualizations for the barrel </comment>
<vis name="TOFHybridVis" ref="AnlGold" visible="true" showDaughters="true"/>
<vis name="TOFCoolingTube" ref="AnlRed" visible="true" showDaughters="true"/>
<vis name="TOFCoolant" ref="TrackerServiceVis" visible="true" showDaughters="true"/>
<vis name="TOFCSkinVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="TOFCFoamVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="TOFCHoneycombVis" ref="TrackerServiceVis" visible="true" showDaughters="true"/>
<vis name="FFTrackerVis" ref="AnlRed" /> <vis name="FFTrackerVis" ref="AnlRed" />
<vis name="FFTrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="false" /> <vis name="FFTrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="false" />
...@@ -105,19 +119,17 @@ ...@@ -105,19 +119,17 @@
<vis name="FFMagnetVis" ref="AnlGreen" showDaughters="true" visible="true"/> <vis name="FFMagnetVis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="FFMagnetCoilVis" ref="AnlRed" showDaughters="true" visible="true"/> <vis name="FFMagnetCoilVis" ref="AnlRed" showDaughters="true" visible="true"/>
<vis name="cb_SolenoidVis" alpha="0.4" r= "0.1" g="0.0" b="0.1" showDaughters="true" visible="true"/> <comment>
<vis name="ffi_ZDC_ECAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> ZDC visualization
<vis name="ffi_ZDC_ECAL_module_Vis" alpha="1.0" r= "0.1" g="1.0" b="0.9" showDaughters="true" visible="true"/> </comment>
<vis name="ffi_ZDC_HCAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="cb_CTDVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="ffi_ZDC_ECAL_Vis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="cb_CTD_Si_layerVis" alpha="1.0" r= "0.9" g="1.0" b="0.1" showDaughters="true" visible="true"/> <vis name="ffi_ZDC_ECAL_module_Vis" ref="AnlRed" showDaughters="false" visible="true"/>
<vis name="ce_GEMVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="ffi_ZDC_HCAL_Vis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="cb_GEM_layerVis" alpha="0.8" r= "0.8" g="0.4" b="0.3" showDaughters="true" visible="true"/>
<vis name="cb_VTX_BarrelVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="cb_VTX_Barrel_layerVis" alpha="2.0" r= "0.0" g="0.2" b="0.8" showDaughters="true" visible="true"/>
<vis name="ci_GEMVis" r= "0.8" g="0.4" b="0.3" alpha="0.8" showDaughters="true" visible="true"/> <comment>
<vis name="ci_HCALVis" r= "0.6" g="0" b="0.6" alpha="1.0" showDaughters="true" visible="true"/> PID visualization
</comment>
<vis name="DRICH_vessel_vis" ref="AnlGray" showDaughters="true" visible="true" /> <vis name="DRICH_vessel_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="DRICH_gas_vis" ref="AnlGreen" alpha="0.5" showDaughters="true" visible="true" /> <vis name="DRICH_gas_vis" ref="AnlGreen" alpha="0.5" showDaughters="true" visible="true" />
...@@ -125,6 +137,7 @@ ...@@ -125,6 +137,7 @@
<vis name="DRICH_filter_vis" alpha="1.0" r="1.0" g="1.0" b="0.0" showDaughters="true" visible="true" /> <vis name="DRICH_filter_vis" alpha="1.0" r="1.0" g="1.0" b="0.0" showDaughters="true" visible="true" />
<vis name="DRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" /> <vis name="DRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="DRICH_sensor_vis" ref="AnlBlue" showDaughters="true" visible="true" /> <vis name="DRICH_sensor_vis" ref="AnlBlue" showDaughters="true" visible="true" />
<vis name="PFRICH_sensor_vis" ref="AnlBlue" showDaughters="true" visible="true" />
<vis name="MRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" /> <vis name="MRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="MRICH_frame_vis" ref="AnlGold" showDaughters="true" visible="true" /> <vis name="MRICH_frame_vis" ref="AnlGold" showDaughters="true" visible="true" />
...@@ -11,42 +11,83 @@ ...@@ -11,42 +11,83 @@
<comment> <comment>
Tracking Visualizations Tracking Visualizations
<vis name="TrackerSupportVis" ref="AnlBlue" showDaughters="false" /> <vis name="TrackerVis" ref="AnlRed" />
<vis name="TrackerLayerVis" ref="AnlTeal" visible="true" showDaughters="true" /> <vis name="TrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="TrackerModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" /> <vis name="TrackerServiceVis" ref="AnlGold" showDaughters="false" />
<vis name="TrackerLayerVis" ref="AnlGray" visible="true" showDaughters="true" />
<vis name="VertexSupportVis" ref="AnlBlue" showDaughters="false" /> <vis name="TrackerModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="true" />
<vis name="VertexLayerVis" ref="AnlTeal" visible="true" showDaughters="true" /> <vis name="TrackerMPGDVis" ref="AnlRed" visible="true" showDaughters="true" />
<vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" /> <comment> Layer-based visualization for MPGD detectors as it looks better </comment>
<vis name="TrackerGEMModuleVis" ref="TrackerMPGDVis" visible="true" showDaughters="false" />
<vis name="TOFVis" ref="AnlGreen" showDaughters="true" /> <vis name="TrackerMMGASLayerVis" ref="TrackerMPGDVis" visible="true" showDaughters="false" />
<vis name="VertexLayerVis" ref="AnlGray" visible="true" showDaughters="false" />
<vis name="VertexSupportLayerVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="VertexSupportVis" ref="VertexSupportLayerVis" visible="true" showDaughters="true" />
<vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="true" />
<vis name="FFTrackerShieldingVis" ref="AnlGray" visible="true" showDaughters="false" />
<vis name="FFTrackerServiceVis" ref="AnlGold" visible="true" showDaughters="false" />
<vis name="FFTrackerLayerVis" ref="TrackerVis" visible="true" showDaughters="true" />
<vis name="FFTrackerModuleVis" ref="FFTrackerLayerVis" visible="true" showDaughters="true" />
<vis name="FFTrackerSurfaceVis" ref="FFTrackerLayerVis" visible="true" showDaughters="true" />
<comment> Display shielded modules in all their glory </comment>
<vis name="FFTrackerShieldedModuleVis" ref="FFTrackerModuleVis" visible="true" showDaughters="true" />
<comment> <comment>
ECal Vis ECal Vis
<vis name="EcalVis" ref="AnlGold" showDaughters="true" visible="true"/> <vis name="EcalBarrelLayerVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapVis" ref="AnlGold" showDaughters="false" visible="true"/> <vis name="EcalBarrelEnvelopeVis" ref="AnlGold" showDaughters="true" visible="false" />
<vis name="EcalBarrelVis" ref="AnlGold" showDaughters="false" visible="true"/> <vis name="EcalBarrelStaveVis" ref="AnlGold" showDaughters="true" visible="true" />
<vis name="EcalBarrelStaveVis" ref="AnlViolet" showDaughters="false" visible="true" />
<vis name="EcalBarrelEnvelopeVis" ref="AnlViolet" showDaughters="false" visible="true" />
<vis name="EcalBarrelSupportVis" ref="AnlOrange" showDaughters="false" visible="true"/>
<vis name="EcalBarrelLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="EcalBarrelSliceVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="EcalBarrelFiberLayerVis" ref="AnlGold" showDaughters="false" visible="true" /> <vis name="EcalBarrelFiberLayerVis" ref="AnlGold" showDaughters="false" visible="true" />
<vis name="EcalBarrelSliceVis" ref="AnlGray"/>
<vis name="EcalBarrelSupportVis" ref="AnlOrange"/>
<vis name="EcalVis" ref="AnlGold" showDaughters="true" visible="false"/>
<vis name="EcalEndcapLayerVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapBlockVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapNModuleVis" ref="AnlTeal" showDaughters="false" visible="true"/> <vis name="EcalEndcapNModuleVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="FFPreVis" ref="AnlGold" showDaughters="true" visible="true"/>
<vis name="FFPreLayerVis" ref="FFPreVis" showDaughters="true" visible="true"/>
<vis name="FFPreModuleVis" ref="FFPreLayerVis" showDaughters="true" visible="true"/>
<vis name="FFPreRadiatorVis" ref="FFPreModuleVis" showDaughters="true" visible="true"/>
<vis name="FFPreReadoutVis" ref="FFTrackerSurfaceVis" showDaughters="true" visible="true"/>
<comment> <comment>
HCal Vis HCal Vis
<vis name="HcalVis" ref="AnlViolet" showDaughters="true" visible="true"/> <vis name="HcalVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalBarrelVis" ref="AnlViolet" showDaughters="true" visible="true"/> <vis name="HcalBarrelVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalBarrelStaveVis" ref="AnlViolet" showDaughters="true" visible="true"/> <vis name="HcalBarrelStaveVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalBarrelLayerVis" ref="AnlViolet" showDaughters="false" visible="true"/> <vis name="HcalBarrelLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalEndcapVis" ref="AnlViolet" showDaughters="true" visible="true"/> <vis name="HcalEndcapVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalEndcapLayerVis" ref="AnlViolet" showDaughters="false" visible="true"/> <vis name="HcalEndcapLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalSensorVis" ref="AnlBlue" showDaughters="false" visible="false"/> <vis name="HcalSensorVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalAbsorberVis" ref="AnlViolet" showDaughters="false" visible="false"/> <vis name="HcalAbsorberVis" ref="AnlGray" showDaughters="true" visible="true"/>
<comment>
Passive steel for flux return
</comment>
<vis name="PassiveSteelVis" ref="AnlViolet" showDaughters="false" visible="true"/>
<comment> <comment>
Solenoid Solenoid
...@@ -59,43 +100,65 @@ ...@@ -59,43 +100,65 @@
<comment> <comment>
PID Detectors PID Detectors
<vis name="RICHVis" ref="AnlViolet" showDaughters="true"/> <vis name="RICHVis" ref="AnlTeal" showDaughters="true"/>
<vis name="DIRCVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<vis name="DIRCLayerVis" ref="AnlTeal" showDaughters="false" visible="true"/>
<vis name="DIRCModuleVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<vis name="DIRCSupportVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<vis name="DIRCFrameVis" ref="AnlOrange" showDaughters="true" visible="true"/>
<vis name="DIRCBarVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<comment>
Beam line with magnets
</comment>
<vis name="BeamPipeVis" ref="AnlLightGray" showDaughters="true" visible="true"/>
<comment>
ZDC visualization
</comment>
<comment> <comment>
Beam line PID visualization
<vis name="BeamPipeVis" ref="AnlLight_Gray" showDaughters="true" visible="true"/>
<vis name="cb_SolenoidVis" alpha="0.4" r= "0.1" g="0.0" b="0.1" showDaughters="true" visible="true"/> <vis name="DRICH_gas_vis" ref="AnlLightGray" alpha="0.2" showDaughters="true" visible="true" />
<vis name="ffi_ZDC_ECAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="DRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="ffi_ZDC_ECAL_module_Vis" alpha="1.0" r= "0.1" g="1.0" b="0.9" showDaughters="true" visible="true"/> <vis name="DRICH_filter_vis" alpha="1.0" r="1.0" g="1.0" b="0.0" showDaughters="true" visible="true" />
<vis name="ffi_ZDC_HCAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="DRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="cb_CTDVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="DRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" />
<vis name="cb_CTD_Si_layerVis" alpha="1.0" r= "0.9" g="1.0" b="0.1" showDaughters="true" visible="true"/> <vis name="PFRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" />
<vis name="cb_GEM_layerVis" alpha="0.8" r= "0.8" g="0.4" b="0.3" showDaughters="true" visible="true"/> <vis name="MRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="cb_VTX_BarrelVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="MRICH_frame_vis" ref="AnlGold" showDaughters="true" visible="true" />
<vis name="cb_VTX_Barrel_layerVis" alpha="2.0" r= "0.0" g="0.2" b="0.8" showDaughters="true" visible="true"/> <vis name="MRICH_lens_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="MRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="ci_HCALVis" r= "0.6" g="0" b="0.6" alpha="1.0" showDaughters="true" visible="true"/> <vis name="RICHServiceVis" ref="AnlGray" showDaughters="true" visible="true" />
<comment> <comment>
Deprecated colors. Deprecated values used for IP6 vis
vis name="GreenVis" alpha="1.0" r= "0.0" g="1.0" b="0.0" showDaughters="true" visible="true"/
vis name="RedVis" alpha="0.2" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/
vis name="RPVis" alpha="0.99" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/
vis name="RPLayerVis" alpha="0.99" r= "0.0" g="0.7" b="0.3" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" /
vis name="BlueVis" alpha="1.0" r= "0.0" g="0.0" b="1.0" showDaughters="true" visible="true"/
vis name="OrangeVis" alpha="1.0" r= "1.0" g="0.45" b="0.0" showDaughters="true" visible="true"/
vis name="RedGreenVis" alpha="0.5" r= "1.0" g="1.0" b="0.0" showDaughters="true" visible="true"/
vis name="BlueGreenVis" alpha="0.5" r= "0.0" g="1.0" b="1.0" showDaughters="true" visible="true"/
vis name="PurpleVis" alpha="1.0" r= "1.0" g="0.0" b="1.0" showDaughters="true" visible="true"/
vis name="DoubleRedG" alpha="0.5" r= "2.0" g=".10" b="0.0" showDaughters="true" visible="true"/
vis name="RBG015" alpha="0.5" r= "0.0" g=".2" b="1.0" showDaughters="true" visible="true"/
vis name="RBG510" alpha="0.5" r= "1.0" g=".2" b="0.0" showDaughters="true" visible="true"/
vis name="RBG" alpha="0.5" r= "1.0" g="1.0" b="1.0" showDaughters="true" visible="true"/
vis name="GrayVis" alpha="1.0" r= "0.75" g="0.75" b="0.75" showDaughters="true" visible="true"/
<vis name="GreenVis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="RedVis" ref="AnlRed" showDaughters="true" visible="true"/>
<vis name="RPVis" ref="AnlDelta_Red" showDaughters="true" visible="true"/>
<vis name="RPLayerVis" ref="AnlTeal" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="BlueVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="OrangeVis" ref="AnlOrange" showDaughters="true" visible="true"/>
<vis name="BlueGreenVis" alpha="0.5" r= "0.0" g="1.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="PurpleVis" alpha="1.0" r= "1.0" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="DoubleRedG" alpha="0.5" r= "2.0" g=".10" b="0.0" showDaughters="true" visible="true"/>
<vis name="RBG015" alpha="0.5" r= "0.0" g=".2" b="1.0" showDaughters="true" visible="true"/>
<vis name="RBG510" alpha="0.5" r= "1.0" g=".2" b="0.0" showDaughters="true" visible="true"/>
<vis name="RBG" alpha="0.5" r= "1.0" g="1.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="GrayVis" alpha="1.0" r= "0.75" g="0.75" b="0.75" showDaughters="true" visible="true"/>
<vis name="AnlRed_1" alpha="0.5" r="205/256" g="32/256" b="44/256"/>
</display> </display>
...@@ -25,7 +25,18 @@ ...@@ -25,7 +25,18 @@
<vis name="VertexSupportVis" ref="VertexSupportLayerVis" visible="true" showDaughters="true" /> <vis name="VertexSupportVis" ref="VertexSupportLayerVis" visible="true" showDaughters="true" />
<vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="true" /> <vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="true" />
<vis name="TOFVis" ref="AnlTeal" showDaughters="true" visible="true"/> <vis name="TOFVis" ref="AnlTeal" visible="true" showDaughters="true"/>
...@@ -69,7 +80,7 @@ ...@@ -69,7 +80,7 @@
<vis name="HcalBarrelLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/> <vis name="HcalBarrelLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalEndcapVis" ref="AnlBlue" showDaughters="false" visible="true"/> <vis name="HcalEndcapVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalEndcapLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/> <vis name="HcalEndcapLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalSensorVis" ref="AnlBlue" showDaughters="true" visible="true"/> <vis name="HcalSensorVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalAbsorberVis" ref="AnlGray" showDaughters="true" visible="true"/> <vis name="HcalAbsorberVis" ref="AnlGray" showDaughters="true" visible="true"/>
<comment> <comment>
...@@ -104,16 +115,25 @@ ...@@ -104,16 +115,25 @@
<vis name="ffi_ZDC_ECAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <comment>
<vis name="ffi_ZDC_ECAL_module_Vis" alpha="1.0" r= "0.1" g="1.0" b="0.9" showDaughters="true" visible="true"/> ZDC visualization
<vis name="ffi_ZDC_HCAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> </comment>
<comment>
PID visualization
</comment>
<vis name="DRICH_gas_vis" ref="AnlGreen" alpha="0.5" showDaughters="true" visible="true" /> <vis name="DRICH_gas_vis" ref="AnlLightGray" alpha="0.2" showDaughters="true" visible="true" />
<vis name="DRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" /> <vis name="DRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="DRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" /> <vis name="DRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" />
<vis name="PFRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" /> <!-- invisible, to speedup graphics -->
...@@ -3,10 +3,10 @@ ...@@ -3,10 +3,10 @@
<define> <define>
<!-- vessel (=snout+tank) geometry --> <!-- vessel (=snout+tank) geometry -->
<constant name="DRICH_zmin" value="ForwardPIDRegion_zmin"/> <!-- vessel front --> <constant name="DRICH_zmin" value="ForwardRICHRegion_zmin"/> <!-- vessel front -->
<constant name="DRICH_Length" value="ForwardPIDRegion_length"/> <!-- overall vessel length (including snout) --> <constant name="DRICH_Length" value="ForwardRICHRegion_length"/> <!-- overall vessel length (including snout) -->
<constant name="DRICH_rmin0" value="ForwardPIDRegion_zmin * ForwardPIDRegion_tan1"/> <!-- bore radius at dRICh vessel frontplane --> <constant name="DRICH_rmin0" value="ForwardRICHRegion_zmin * ForwardRICHRegion_tan1"/> <!-- bore radius at dRICh vessel frontplane -->
<constant name="DRICH_rmin1" value="(ForwardPIDRegion_zmin + ForwardPIDRegion_length) * ForwardPIDRegion_tan2"/> <!-- bore radius at dRICh vessel backplane --> <constant name="DRICH_rmin1" value="(ForwardRICHRegion_zmin + ForwardRICHRegion_length) * ForwardRICHRegion_tan2"/> <!-- bore radius at dRICh vessel backplane -->
<constant name="DRICH_wall_thickness" value="0.5*cm"/> <!-- thickness of radial walls --> <constant name="DRICH_wall_thickness" value="0.5*cm"/> <!-- thickness of radial walls -->
<constant name="DRICH_window_thickness" value="0.1*cm"/> <!-- thickness of entrance and exit walls --> <constant name="DRICH_window_thickness" value="0.1*cm"/> <!-- thickness of entrance and exit walls -->
<!-- tank geometry: cylinder, holding the majority of detector components --> <!-- tank geometry: cylinder, holding the majority of detector components -->
...@@ -94,13 +94,14 @@ ...@@ -94,13 +94,14 @@
filter; the filter is applied to the back of the aerogel, so that it separates filter; the filter is applied to the back of the aerogel, so that it separates
the aerogel and gas radiators the aerogel and gas radiators
- dimensions: - dimensions:
- `frontplane`: front of the aerogel, w.r.t. front plane of the vessel envelope
- `rmin` and `rmax`: inner and outer radius (at the front plane; radial bounds are conical)
- `phiw`: azimuthal width of wedge - `phiw`: azimuthal width of wedge
- `thickness`: radiator thickness, defined separately for aerogel and filter - `thickness`: radiator thickness, defined separately for aerogel and filter
- `pitch`: controls the angle of the radiator (0=vertical) - `pitch`: controls the angle of the radiator (0=vertical)
</documentation> </documentation>
<radiator <radiator
rmin="DRICH_rmin0 + DRICH_wall_thickness + 2.0*cm" rmin="DRICH_rmin0 + DRICH_wall_thickness + 0.2*cm"
rmax="DRICH_rmax0 - DRICH_wall_thickness - 0.2*cm" rmax="DRICH_rmax0 - DRICH_wall_thickness - 0.2*cm"
phiw="60*degree" phiw="60*degree"
frontplane="DRICH_window_thickness + 0.5*DRICH_aerogel_thickness" frontplane="DRICH_window_thickness + 0.5*DRICH_aerogel_thickness"
...@@ -142,17 +143,16 @@ ...@@ -142,17 +143,16 @@
material="Acrylic_DRICH" material="Acrylic_DRICH"
surface="MirrorSurface_DRICH" surface="MirrorSurface_DRICH"
vis="DRICH_mirror_vis" vis="DRICH_mirror_vis"
backplane="DRICH_window_thickness + 5.0*cm" backplane="DRICH_window_thickness + 1.0*cm"
rmin="DRICH_rmin1 + DRICH_wall_thickness - 1.0*cm" rmin="DRICH_rmin1 + DRICH_wall_thickness - 1.0*cm"
rmax="DRICH_rmax2 - DRICH_wall_thickness - 5.0*cm" rmax="DRICH_rmax2 - DRICH_wall_thickness - 1.0*cm"
phiw="59.5*degree" phiw="59.5*degree"
thickness="0.2*cm" thickness="0.2*cm"
focus_tune_x="40.0*cm" focus_tune_x="30.0*cm"
focus_tune_z="-30.0*cm" focus_tune_z="-40.0*cm"
debug="DRICH_debug_mirror" debug="DRICH_debug_mirror"
<!-- /detectors/detector/sensors --> <!-- /detectors/detector/sensors -->
<documentation level="10"> <documentation level="10">
#### Sensors #### Sensors
...@@ -205,14 +205,14 @@ ...@@ -205,14 +205,14 @@
- `zmin`: z-plane cut - `zmin`: z-plane cut
<sphere <sphere
centerz="-80.0 * cm" centerz="-55.0 * cm"
centerx="DRICH_rmax2 - 35.0*cm" centerx="DRICH_rmax2 - 35.0*cm"
radius="100.0 * cm" radius="85.0 * cm"
debug="DRICH_debug_sensors" debug="DRICH_debug_sensors"
<sphericalpatch <sphericalpatch
phiw="18*degree" phiw="18*degree"
rmin="DRICH_rmax1 + 0.0*cm" rmin="DRICH_rmax1 + 5.0*cm"
rmax="DRICH_rmax2 - 5.0*cm" rmax="DRICH_rmax2 - 5.0*cm"
zmin="DRICH_SnoutLength + 5.0*cm" zmin="DRICH_SnoutLength + 5.0*cm"
...@@ -11,11 +11,8 @@ ...@@ -11,11 +11,8 @@
<!--include ref="ecal_forward_scfi.xml"/--> <!--include ref="ecal_forward_scfi.xml"/-->
<include ref="ecal_forward_homogenous.xml"/> <include ref="ecal_forward_homogenous.xml"/>
<!--<include ref="ecal_backward_crystal_glass.xml"/>-->
<include ref="ecal_backward_hybrid.xml"/> <include ref="ecal_backward_hybrid.xml"/>
<!-- <include ref="ecal_barrel.xml"/> -->
<!-- <include ref="ecal_barrel_hybrid.xml"/> -->
<include ref="ecal_barrel_interlayers.xml"/> <include ref="ecal_barrel_interlayers.xml"/>
</lccdd> </lccdd>
...@@ -34,6 +34,8 @@ ...@@ -34,6 +34,8 @@
<constant name="GlassModule_wrap" value="2*CrystalModule_wrap"/> <constant name="GlassModule_wrap" value="2*CrystalModule_wrap"/>
<constant name="GlassModule_z0" value="0.0*cm"/> <constant name="GlassModule_z0" value="0.0*cm"/>
<constant name="EcalEndcapNIonCutout_dphi" value="30*degree"/>
<constant name="EcalEndcapN_thickness" value="GlassModule_length"/> <constant name="EcalEndcapN_thickness" value="GlassModule_length"/>
<constant name="EcalEndcapN_z0" value="-EcalEndcapN_zmin - EcalEndcapN_thickness/2"/> <constant name="EcalEndcapN_z0" value="-EcalEndcapN_zmin - EcalEndcapN_thickness/2"/>
<constant name="EcalEndcapNCrystal_rmax" value="40*cm"/> <constant name="EcalEndcapNCrystal_rmax" value="40*cm"/>
...@@ -12,7 +12,7 @@ ...@@ -12,7 +12,7 @@
To change the number of imaging layers from, e.g., 9 to 6, To change the number of imaging layers from, e.g., 9 to 6,
change EcalBarrelImagingLayers_nMax variable change EcalBarrelImagingLayers_nMax variable
</comment> </comment>
<constant name="EcalBarrelImagingLayers_nMax" value="9"/> <constant name="EcalBarrelImagingLayers_nMax" value="6"/>
<constant name="EcalBarrel_Support_thickness" value="5*cm"/> <constant name="EcalBarrel_Support_thickness" value="5*cm"/>
<constant name="EcalBarrel_SiliconThickness" value="500*um"/> <constant name="EcalBarrel_SiliconThickness" value="500*um"/>
<lccdd> <lccdd>
<comment> Endcap Tracker </comment> <comment> Endcap Tracker for Acadia </comment>
<define> <define>
<constant name="GEMTrackerEndcapP_thickness" value="min(10.0*cm,ForwardTrackingRegion_length)" /> <constant name="GEMTrackerEndcapP_thickness" value="min(10.0*cm,ForwardTrackingRegion_length)" />
