Skip to content
Snippets Groups Projects
Commit 2608ed0d authored by Sylvester Joosten's avatar Sylvester Joosten
Browse files
Resolve "Update silicon tracker stave material budget"
parent 3718bd9f
Branches
Tags
No related merge requests found
...@@ -12,27 +12,39 @@ ...@@ -12,27 +12,39 @@
Note: initial implementation with hard-coded values, Note: initial implementation with hard-coded values,
TODO: add parametrization TODO: add parametrization
</comment>
<define> ----
Aug 04, 2021, Shujie Li
udpated stave material budget for the baseline design.
see https://eicweb.phy.anl.gov/EIC/detectors/athena/-/issues/63
ITS3 sensor thickness: 40um, pixel size: 10um (segmentation)
total X0 0.55% per layer:
0.4 mm aluminum ~ 0.44% X0.
2 x carbonfiber (RL ~ 25) 0.1 mm to match Si (RL~9) of 0.04mm
<constant name="TrackerBarrelSpaceFrame_width" value="4.0*cm"/> </comment>
<constant name="TrackerBarrelSpaceFrame_height" value="2.5*cm"/>
<constant name="TrackerSensor_thickness" value="0.03*mm"/>
<constant name="TrackerBarrel_thickness" value="0.55/100*9.37*cm"/>
<constant name="TrackerBarrelService_thickness" value="TrackerBarrel_thickness-TrackerSensor_thickness"/>
<define>
<comment> <comment>
Layer_rOffset is used to add inside space so the _rmin value is the nominal sensor radius. Layer_rOffset is used to add inside space so the _rmin value is the nominal sensor radius.
TrackerBarrelSpaceFrame_height must be smaller than {_rmin2 - _rmin1 - Layer_rOffset - 1mm - stave_thickness}
</comment> </comment>
<constant name="TrackerBarrelLayer_rOffset" value="0.5*cm"/> <constant name="TrackerBarrelLayer_rOffset" value="0.5*cm"/>
<constant name="TrackerBarrelInner_rmin1" value="21.0*cm"/> <constant name="TrackerBarrelSpaceFrame_width" value="4.0*cm"/>
<constant name="TrackerBarrelInner_rmin2" value="TrackerBarrelInner_rmin1 + TrackerBarrelSpaceFrame_width"/> <constant name="TrackerBarrelSpaceFrame_height" value="1.0835*cm"/>
<constant name="TrackerSensor_thickness" value="0.04*mm"/>
<constant name="TrackerBarrelInner_rmin2" value="22.68*cm"/>
<constant name="TrackerBarrelInner_length1" value="54.0*cm"/> <constant name="TrackerBarrelInner_length1" value="54.0*cm"/>
<constant name="TrackerBarrelInner_length2" value="60.0*cm"/> <constant name="TrackerBarrelInner_length2" value="60.0*cm"/>
<constant name="TrackerBarrelOuter_rmin1" value="39.3*cm"/> <constant name="TrackerBarrelOuter_rmin1" value="39.3*cm"/>
<constant name="TrackerBarrelOuter_rmin2" value="TrackerBarrelOuter_rmin1 + TrackerBarrelSpaceFrame_width"/> <constant name="TrackerBarrelOuter_rmin2" value="43.23*cm"/>
<constant name="TrackerBarrelOuter_length1" value="105.0*cm"/> <constant name="TrackerBarrelOuter_length1" value="105.0*cm"/>
<constant name="TrackerBarrelOuter_length2" value="114.0*cm"/> <constant name="TrackerBarrelOuter_length2" value="114.0*cm"/>
...@@ -46,8 +58,8 @@ ...@@ -46,8 +58,8 @@
<comment> <comment>
Here we are assuming the two endcaps (P and N) are symmetric. Here we are assuming the two endcaps (P and N) are symmetric.
<constant name="TrackerEndcap_thickness" value="0.25/100*9.37*cm"/> <!-- <constant name="TrackerEndcap_thickness" value="0.24/100*9.37*cm"/> -->
<constant name="TrackerEndcapService_thickness" value="TrackerEndcap_thickness-TrackerSensor_thickness"/> <!-- <constant name="TrackerEndcapService_thickness" value="TrackerEndcap_thickness-TrackerSensor_thickness"/> -->
<constant name="TrackerEndcapInner_nLayers" value="1"/> <constant name="TrackerEndcapInner_nLayers" value="1"/>
<constant name="TrackerEndcapOuter_nLayers" value="3"/> <constant name="TrackerEndcapOuter_nLayers" value="3"/>
...@@ -69,14 +81,14 @@ ...@@ -69,14 +81,14 @@
This is a limitation of ACTS geometry which will likely go away in the future.</comment> This is a limitation of ACTS geometry which will likely go away in the future.</comment>
<constant name="TrackerEndcapInner_rmin1" value="Beampipe_rmax+1.0*cm"/> <constant name="TrackerEndcapInner_rmin1" value="Beampipe_rmax+1.0*cm"/>
<constant name="TrackerEndcapInner_rmin2" value="Beampipe_rmax+1.0*cm"/> <!-- <constant name="TrackerEndcapInner_rmin2" value="Beampipe_rmax+1.0*cm"/> -->
<constant name="TrackerEndcapOuter_rmin1" value="3.18*cm + 1.2*cm * 1"/> <constant name="TrackerEndcapOuter_rmin1" value="3.18*cm + 1.2*cm * 1"/>
<constant name="TrackerEndcapOuter_rmin2" value="3.18*cm + 1.2*cm * 1"/> <constant name="TrackerEndcapOuter_rmin2" value="3.18*cm + 1.2*cm * 1"/>
<constant name="TrackerEndcapOuter_rmin3" value="3.18*cm + 1.2*cm * 2"/> <constant name="TrackerEndcapOuter_rmin3" value="3.18*cm + 1.2*cm * 2"/>
<constant name="TrackerEndcapInner_rmax1" value="TrackerBarrelOuter_rmin1-5.0*mm"/> <constant name="TrackerEndcapInner_rmax1" value="TrackerBarrelOuter_rmin1-5.0*mm"/>
<constant name="TrackerEndcapInner_rmax2" value="TrackerBarrelOuter_rmin1-5.0*mm"/> <!-- <constant name="TrackerEndcapInner_rmax2" value="TrackerBarrelOuter_rmin1-5.0*mm"/> -->
<constant name="TrackerEndcapOuter_rmax1" value="43.23*cm"/> <constant name="TrackerEndcapOuter_rmax1" value="43.23*cm"/>
<constant name="TrackerEndcapOuter_rmax2" value="43.23*cm"/> <constant name="TrackerEndcapOuter_rmax2" value="43.23*cm"/>
...@@ -124,7 +136,7 @@ ...@@ -124,7 +136,7 @@
insideTrackingVolume="true"> insideTrackingVolume="true">
<dimensions <dimensions
rmin="TrackerBarrelInner_rmin1-TrackerBarrelLayer_rOffset" rmin="TrackerBarrelInner_rmin1-TrackerBarrelLayer_rOffset"
rmax="TrackerBarrelInner_rmin2-TrackerBarrelLayer_rOffset + TrackerBarrelInner_thickness" rmax="TrackerBarrelInner_rmin2-TrackerBarrelLayer_rOffset + TrackerBarrelInner_thickness"
length="TrackerBarrelInner_length"/> length="TrackerBarrelInner_length"/>
<comment> <comment>
Tracker Barrel Modules Tracker Barrel Modules
...@@ -135,15 +147,13 @@ ...@@ -135,15 +147,13 @@
height="TrackerBarrelSpaceFrame_height" height="TrackerBarrelSpaceFrame_height"
length="TrackerBarrelInner_length1" length="TrackerBarrelInner_length1"
thickness="0.1*mm" /> thickness="0.1*mm" />
<module_component name="peek1" material="PEEK" sensitive="false" <module_component name="aluminum1" material="Aluminum" sensitive="false"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length1-4*mm" thickness="2.0*mm" /> width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length1-4*mm" thickness="0.4*mm" />
<module_component name="silicon" <module_component name="silicon"
width="TrackerBarrelSpaceFrame_width" width="TrackerBarrelSpaceFrame_width"
length="TrackerBarrelInner_length1-5*mm" thickness="0.05*mm" material="Silicon" sensitive="true"> length="TrackerBarrelInner_length1-5*mm" thickness="TrackerSensor_thickness" material="Silicon" sensitive="true">
<!--position z="-0.025*mm" y="0*mm"/--> <!--position z="-0.025*mm" y="0*mm"/-->
</module_component> </module_component>
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length1-6*mm" thickness="2.0*mm" />
</module> </module>
<module name="TrackerBarrelInner_Module2" vis="TrackerModuleVis"> <module name="TrackerBarrelInner_Module2" vis="TrackerModuleVis">
<frame material="CarbonFiber_25percent" vis="TrackerSupportVis" <frame material="CarbonFiber_25percent" vis="TrackerSupportVis"
...@@ -151,15 +161,13 @@ ...@@ -151,15 +161,13 @@
length="TrackerBarrelInner_length2" length="TrackerBarrelInner_length2"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length2-4*mm" thickness="2.0*mm" /> width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length2-4*mm" thickness="0.4*mm" />
length="TrackerBarrelInner_length2-5*mm" thickness="0.05*mm" material="Silicon" sensitive="true"> length="TrackerBarrelInner_length2-5*mm" thickness="TrackerSensor_thickness" material="Silicon" sensitive="true">
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelInner_length2-6*mm" thickness="2.0*mm" />
</module> </module>
<comment> <comment>
Tracker Barrel Inner Layers Tracker Barrel Inner Layers
...@@ -197,7 +205,7 @@ ...@@ -197,7 +205,7 @@
<layer id="1"> <layer id="1">
<envelope vis="AnlRed" <envelope vis="AnlRed"
rmin="TrackerEndcapInner_rmin1" rmin="TrackerEndcapInner_rmin1"
rmax="TrackerEndcapInner_rmax2" rmax="TrackerEndcapInner_rmax1"
length="TrackerEndcapInnerLayer_dz" length="TrackerEndcapInnerLayer_dz"
zstart="TrackerEndcapInner_zmin" /> zstart="TrackerEndcapInner_zmin" />
<ring vis="AnlRed" <ring vis="AnlRed"
...@@ -222,7 +230,7 @@ ...@@ -222,7 +230,7 @@
...@@ -256,15 +264,13 @@ ...@@ -256,15 +264,13 @@
length="TrackerBarrelOuter_length1" length="TrackerBarrelOuter_length1"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelOuter_length1-0.1*mm" thickness="2.0*mm" /> width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelOuter_length1-0.1*mm" thickness="0.40*mm" />
length="TrackerBarrelOuter_length1-0.1*mm" length="TrackerBarrelOuter_length1-0.1*mm"
thickness="0.05*mm" material="Silicon" sensitive="true"> thickness="TrackerSensor_thickness" material="Silicon" sensitive="true">
<module_component name="peek2" material="PEEK" sensitive="false"
</module> </module>
<module name="TrackerBarrelOuter_Module2" vis="PurpleVis"> <module name="TrackerBarrelOuter_Module2" vis="PurpleVis">
<frame material="CarbonFiber_25percent" vis="BlueGreenVis" <frame material="CarbonFiber_25percent" vis="BlueGreenVis"
...@@ -272,15 +278,13 @@ ...@@ -272,15 +278,13 @@
length="TrackerBarrelOuter_length2" length="TrackerBarrelOuter_length2"
width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelOuter_length2-0.1*mm" thickness="2.0*mm" /> width="TrackerBarrelSpaceFrame_width" length="TrackerBarrelOuter_length2-0.1*mm" thickness="0.40*mm" />
</module> </module>
<comment> <comment>
...@@ -421,12 +425,14 @@ ...@@ -421,12 +425,14 @@
<readouts> <readouts>
<readout name="TrackerBarrelHits"> <readout name="TrackerBarrelHits">
<segmentation type="CartesianGridXY" grid_size_x="0.150*mm" grid_size_y="0.150*mm" /> <segmentation type="CartesianGridXY" grid_size_x="0.010*mm" grid_size_y="0.010*mm" />
<id>system:8,barrel:2,layer:4,module:12,sensor:2,x:32:-16,y:-16</id> <id>system:8,barrel:2,layer:4,module:12,sensor:2,x:32:-16,y:-16</id>
</readout> </readout>
<readout name="TrackerEndcapHits"> <readout name="TrackerEndcapHits">
<segmentation type="CartesianGridXZ" grid_size_x="0.20*mm" grid_size_z="0.20*mm" /> <segmentation type="CartesianGridXZ" grid_size_x="0.010*mm" grid_size_z="0.010*mm" />
<id>system:8,barrel:2,layer:4,module:12,sensor:2,x:32:-16,z:-16</id> <id>system:8,barrel:2,layer:4,module:12,sensor:2,x:32:-16,z:-16</id>
</readouts> </readouts>
0% Loading or .
Please register or to comment
