Skip to content
Snippets Groups Projects
Commit c1277892 authored by Eric Pooser's avatar Eric Pooser Committed by GitHub
Browse files
Pooser rename dirs work (#186)
* Fix naming scheme and histo names to be consistant with the rest of the repo
* Same fix as previous commit but for HMS
* Modify production replay scripts to keep naming convention consistant with previous commits
* Apparently THaVhist cannot handle LaTeX alphabets
* Turn off tzero per wire param causing replay to crash and burn
* Uncomment event/trigger types.  Needs to be cleaned up later
* Remove deprecated detector directories
* Remove deprecated map files
* Exclude trigger histo with no real variable
* Include raster into stack map
* Uncomment lines which were causing a bajillion errors
Needs to be cleaned up at some point
* Remove deprecated parameter files
* Remove deprecated replay scripts
* Remove deprecated template file
parent c633d481
No related branches found
No related tags found
No related merge requests found
Showing
with 50 additions and 1394 deletions
Loading
0% Loading or .
Please register or to comment
