Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Show changes
Commits on Source (1)
...@@ -45,7 +45,7 @@ ...@@ -45,7 +45,7 @@
id="HCalEndcapP_ID" id="HCalEndcapP_ID"
name="HcalEndcapP" name="HcalEndcapP"
type="refdet_PolyhedraEndcapCalorimeter2" type="refdet_PolyhedraEndcapCalorimeter2"
readout="HcalEndcapHits" readout="HcalHadronEndcapHits"
vis="HcalEndcapVis" vis="HcalEndcapVis"
calorimeterType="HAD_ENDCAP" calorimeterType="HAD_ENDCAP"
reflect="false"> reflect="false">
...@@ -65,7 +65,7 @@ ...@@ -65,7 +65,7 @@
id="HCalEndcapN_ID" id="HCalEndcapN_ID"
name="HcalEndcapN" name="HcalEndcapN"
readout="HcalEndcapHits" readout="HcalElectronEndcapHits"
calorimeterType="HAD_ENDCAP" reflect="true"> calorimeterType="HAD_ENDCAP" reflect="true">
<position x="0" y="0" z="0"/> <position x="0" y="0" z="0"/>
...@@ -87,10 +87,13 @@ ...@@ -87,10 +87,13 @@
<segmentation type="CartesianGridXY" grid_size_x="100* mm" grid_size_y="100 * mm"/> <segmentation type="CartesianGridXY" grid_size_x="100* mm" grid_size_y="100 * mm"/>
<id>system:8,barrel:3,module:4,layer:8,slice:5,x:32:-16,y:-16</id> <id>system:8,barrel:3,module:4,layer:8,slice:5,x:32:-16,y:-16</id>
</readout> </readout>
<readout name="HcalEndcapHits"> <readout name="HcalHadronEndcapHits">
<segmentation type="CartesianGridXY" grid_size_x="100 * mm" grid_size_y="100 * mm"/> <segmentation type="CartesianGridXY" grid_size_x="100 * mm" grid_size_y="100 * mm"/>
<readout name="HcalElectronEndcapHits">
<segmentation type="CartesianGridXY" grid_size_x="100 * mm" grid_size_x ="100 * mm"/>
</readouts> </readouts>
<plugins> <plugins>
