Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Show changes
Commits on Source (5)
...@@ -176,8 +176,9 @@ ...@@ -176,8 +176,9 @@
<include ref="compact/vertex_tracker.xml"/> <include ref="compact/vertex_tracker.xml"/>
<include ref="compact/central_tracker.xml"/> <include ref="compact/central_tracker.xml"/>
<!--include ref="compact/tof_barrel.xml"/>
<!--include ref="compact/rwell_tracker_barrel.xml"/--> <!--include ref="compact/rwell_tracker_barrel.xml"/-->
<include ref="compact/cb_DIRC.xml"/> <include ref="compact/cb_DIRC.xml"/>
<?xml version="1.0" encoding="UTF-8"?>
<lccdd>
<define>
<constant name="BarrelTOFSpaceFrame_width" value="40.0*mm"/>
<constant name="BarrelTOFSpaceFrame_height" value="sqrt(3.0)*32.0*mm/2.0"/>
<constant name="BarrelTOFSensor_thickness" value="0.03*mm"/>
<constant name="BarrelTOF_thickness" value="0.55/100*9.37*cm"/>
<constant name="BarrelTOFService_thickness" value="BarrelTOF_thickness-BarrelTOFSensor_thickness"/>
<comment>
Layer_rOffset is used to add inside space so the _rmin value is the nominal sensor radius.
</comment>
<constant name="BarrelTOFLayer_rOffset" value="0.5*cm"/>
<constant name="BarrelTOF_rmin1" value="50.0*cm"/>
<constant name="BarrelTOF_rmin2" value="BarrelTOF_rmin1 + BarrelTOFSpaceFrame_width"/>
<constant name="BarrelTOF_length1" value="105.0*cm"/>
<constant name="BarrelTOF_length2" value="114.0*cm"/>
<constant name="BarrelTOF_thickness" value="BarrelTOF_rmin2 - BarrelTOF_rmin1"/>
<constant name="BarrelTOF_length" value="BarrelTOF_length2"/>
<comment> TODO: These should be computed </comment>
<constant name="BarrelTOF_NModules" value="56"/>
</define>
<display>
</display>
<detectors>
<detector
id="BarrelTOF_ID"
name="BarrelTOF"
type="athena_TrackerBarrel"
readout="BarrelTOFHits"
insideTrackingVolume="true">
<dimensions
rmin="BarrelTOF_rmin1-BarrelTOFLayer_rOffset"
rmax="BarrelTOF_rmin2-BarrelTOFLayer_rOffset + BarrelTOF_thickness"
length="BarrelTOF_length"/>
<comment>
Tracker Barrel Modules
</comment>
<module name="BarrelTOF_Module1" vis="PurpleVis">
<frame material="CarbonFiber_25percent" vis="BlueGreenVis"
width="BarrelTOFSpaceFrame_width"
height="BarrelTOFSpaceFrame_height"
length="BarrelTOF_length1"
thickness="0.1*mm" />
<module_component name="peek1" material="PEEK" sensitive="false"
width="BarrelTOFSpaceFrame_width" length="BarrelTOF_length1-0.1*mm" thickness="2.0*mm" />
<module_component name="silicon"
thickness="0.05*mm" material="Silicon" sensitive="true">
</module_component>
<module_component name="peek2" material="PEEK" sensitive="false"
</module>
<module name="BarrelTOF_Module2" vis="PurpleVis">
length="BarrelTOF_length2"
width="BarrelTOFSpaceFrame_width" length="BarrelTOF_length2-0.1*mm" thickness="2.0*mm" />
</module_component>
</module>
<comment>
Tracker Barrel Inner Layers
</comment>
<layer module="BarrelTOF_Module1" id="1" vis="VertexVis">
<barrel_envelope
inner_r="BarrelTOF_rmin1-BarrelTOFLayer_rOffset"
outer_r="BarrelTOF_rmin1-BarrelTOFLayer_rOffset + BarrelTOF_thickness-1.0*mm"
z_length="BarrelTOF_length"/>
<rphi_layout phi_tilt="10.0*degree" nphi="BarrelTOF_NModules" phi0="0.0" rc="BarrelTOF_rmin1" dr="0.0 * mm"/>
<z_layout dr="0.0 * mm" z0="0.0 * mm" nz="1"/>
</layer>
<layer module="BarrelTOF_Module2" id="2" vis="VertexVis">
<barrel_envelope
inner_r="BarrelTOF_rmin2-BarrelTOFLayer_rOffset"
outer_r="BarrelTOF_rmin2-BarrelTOFLayer_rOffset + BarrelTOF_thickness"
<rphi_layout phi_tilt="10.0*degree" nphi="BarrelTOF_NModules" phi0="0.0" rc="BarrelTOF_rmin2" dr="0.0 * mm"/>
</layer>
</detector>
</detectors>
<readouts>
<readout name="BarrelTOFHits">
<segmentation type="CartesianGridXY" grid_size_x="0.150*mm" grid_size_y="0.150*mm" />
<id>system:8,barrel:2,layer:4,module:12,sensor:2,x:32:-16,y:-16</id>
</readout>
</readouts>
</lccdd>
