Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Select Git revision
  • 101-north-ecal-add-modules-around-beampipe
  • 104-add-realistic-cooling-for-gridpix
  • 116-fix-the-detector-views
  • 12-job-failed-106994
  • 126-improved-gem-rings
  • 131-update-tof-for-canyonlands
  • 134-make-new-3d-views-of-ff-region-and-detectors
  • 144-irt-geometry
  • 147-fix-dirc-overlaps-and-make-it-great-again
  • 148-hcal-geometry-development
  • 149-dump-geometry-ci-job-should-also-produce-ff-geometry-separately
  • 21-electron-endcap-ecal-glass-outer-ring-implementation-needed-2
  • 23-add-barrel-tof
  • 24-tweak-zdc-longitudinal-size
  • 37-place-sifi-fibers-in-the-assembly-in-ecal-barrel
  • 38-mm-tracker-implementation
  • 40-quick-viz
  • 42-grid-pix-pid-detector
  • 53-acts-geometry-bug-outer-tracker-barrel
  • 54-dirc-better-parametrization
  • 56-astropix-sampling-fraction-test-2
  • 59-detailed-forward-gem-trd
  • 59-detailed-forward-gem-trd-2
  • 7-central-tracker-endcap-detail
  • 81-add-barrel-ecal-projection-at-positive-eta
  • 9-detector-plugin-for-w-scfi-calorimeter-layers
  • 98-update-barrel-and-endcap-tof
  • AllieWeary-master-patch-33350
  • acadia
  • acts_surface_binning
  • acts_vertex_barrel
  • add_segmentation
  • b0_acts
  • backward_ecal_cleanup
  • barrel-tracker-simplified
  • baseline-dimensions-rich-thickness
  • calibrations-ecal-hcal
  • calo-digitization-json
  • canyonlands
  • cherry-pick-85aaf29d
  • cherry-pick-ee231e50
  • deathvalley
  • deathvalley-1.5T
  • debug-vis
  • default_visibilities
  • documentation_tag
  • drich-optics-tests
  • drich-space-update
  • drich-two-mirrors
  • ecal-hcal-endcap-bore-and-length
  • hcal
  • hcal-klm
  • irt-erich
  • irt-init-v01
  • lengthen_ecalbarrel
  • line_drawing
  • lkosarzew-master-patch-25029
  • master
  • mlavinsky-master-patch-10431
  • module_frame
  • mriganka-branch02
  • niveditharam-master-patch-05822
  • optional_full_overlap_check
  • outer_tracker_fix
  • overlap_child_pipeline
  • remove_comment
  • rich-photos
  • shyam.kumar-master-patch-48113
  • sly2j-master-patch-62318
  • sphere-issue
  • sphere_tests
  • swapneshkhade-master-patch-16755
  • test
  • test-drich-tracker
  • testBranchRobin
  • test_tof_zy
  • tmp_view
  • tmp_viz
  • update_becal_nlayers
  • vanekjan-master-patch-74522
  • vdesai-master-patch-09582
  • vis_check
  • vis_dirc
  • vis_ref
  • wdconinc-master-patch-02076
  • weibin-master-patch-37475
  • zdc_prim_fix
  • zdemirog-master-patch-64142
  • zji-ScFiCal
  • acadia-v1.0
  • acadia-v1.0-alpha
  • acadia-v1.1
  • acadia-v2.0
  • acadia-v2.1
  • canyonlands-v1.0
  • canyonlands-v1.1
  • canyonlands-v1.2
  • canyonlands-v2.0
  • canyonlands-v2.1
  • canyonlands-v2.2
  • deathvalley-v1.0
  • deathvalley-v1.0-1.5T
  • deathvalley-v1.1
  • v0.1.0
  • v0.2.0
105 results
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Select Git revision
  • 144-irt-geometry
  • 144-test-small-sensor-overlap
  • 148-hcal-geometry-development-wdconinc-suggestion
  • 23-add-barrel-tof
  • 40-quick-viz
  • WorkingGemTrd_MLmodel_andAnalysis
  • acadia
  • add_segmentation
  • adjust-barrel-emcalo-geometry
  • b0_acts
  • canyonlands
  • canyonlands-acts-dd4hep-plugin
  • deathvalley
  • deathvalley-1.5T
  • deathvalley-acts-dd4hep-plugin
  • debug-vis
  • documentation_tag
  • drich-two-mirrors
  • hcal
  • hcal-klm
  • irt-erich
  • irt-init-v01
  • line_drawing
  • master
  • module_frame
  • mriganka-branch02
  • outer_tracker_fix
  • remove_comment
  • rich-photos
  • sphere-issue
  • sphere_tests
  • test
  • testBranchRobin
  • test_tof_zy
  • tmp_view
  • tmp_viz
  • vis_check
  • vis_dirc
  • vis_ref
  • zdc_prim_fix
  • zji-ScFiCal
  • acadia-v1.0
  • acadia-v1.0-alpha
  • acadia-v1.1
  • acadia-v2.0
  • acadia-v2.1
  • canyonlands-v1.0
  • canyonlands-v1.1
  • canyonlands-v1.2
  • canyonlands-v2.0
  • canyonlands-v2.1
  • canyonlands-v2.2
  • deathvalley-v1.0
  • deathvalley-v1.1
  • v0.1.0
  • v0.2.0
111 results
Show changes
Commits on Source (5)
...@@ -16,6 +16,7 @@ ...@@ -16,6 +16,7 @@
<vis name="AnlDelta_Blue" alpha="1" r="11/256" g="31/256" b="143/256"/> <vis name="AnlDelta_Blue" alpha="1" r="11/256" g="31/256" b="143/256"/>
<vis name="AnlRed_1" alpha="0.5" r="205/256" g="32/256" b="44/256"/> <vis name="AnlRed_1" alpha="0.5" r="205/256" g="32/256" b="44/256"/>
<vis name="AnlTeal_1" alpha="1" r="0/256" g="161/256" b="156/256" showDaughters="false"/>
<comment>Tracker_Layer_Vis is AnlGold</comment> <comment>Tracker_Layer_Vis is AnlGold</comment>
<vis name="Tracker_Layer_Vis" alpha="0.5" r="248/256" g="178/256" b="0/256" showDaughters="true" /> <vis name="Tracker_Layer_Vis" alpha="0.5" r="248/256" g="178/256" b="0/256" showDaughters="true" />
...@@ -5,8 +5,7 @@ ...@@ -5,8 +5,7 @@
<include ref="ecal_barrel_hybrid.xml"/> <include ref="ecal_barrel_hybrid.xml"/>
<comment>electron endcap ecal</comment> <comment>electron endcap ecal</comment>
<!--<include ref="ce_ecal.xml"/>--> <include ref="ecal_endcapn_crystal_glass.xml"/>
<include ref="ce_ecal_crystal_glass.xml"/>
<comment>hadron endcap ecal</comment> <comment>hadron endcap ecal</comment>
<include ref="ci_ecal.xml"/> <include ref="ci_ecal.xml"/>
<lccdd> <lccdd>
<display> <display>
<vis name="EcalBarrelEnvelope_vis" alpha="0.9" r="0.99" g="0.5" b="0" showDaughters="true" visible="false" /> <vis name="EcalBarrelEnvelope_vis" alpha="0.9" r="0.99" g="0.5" b="0" showDaughters="false" visible="true" />
<vis name="EcalBarrelStave_vis" alpha="0.9" r="0.99" g="0.5" b="0" showDaughters="true" visible="false" /> <vis name="EcalBarrelStave_vis" alpha="0.9" r="0.99" g="0.5" b="0" showDaughters="false" visible="true" />
<vis name="EcalBarrelFiberLayerVis" alpha="1.0" r="102/256" g="102/256" b="102/256" showDaughters="false" visible="true" /> <vis name="EcalBarrelFiberLayerVis" alpha="1.0" r="102/256" g="102/256" b="102/256" showDaughters="false" visible="false" />
<vis name="EcalBarrelFiberVis" alpha="1.0" r="0/256" g="130/256" b="202/256" showDaughters="false" visible="false" /> <vis name="EcalBarrelFiberVis" alpha="1.0" r="0/256" g="130/256" b="202/256" showDaughters="false" visible="false" />
</display> </display>
<define> <define>
...@@ -23,7 +23,7 @@ ...@@ -23,7 +23,7 @@
<rotation x="0" y="0" z="0"/> <rotation x="0" y="0" z="0"/>
<placements> <placements>
<lines sector="1" mirrorx="true" mirrory="true"> <lines sector="1" mirrorx="true" mirrory="true">
<module sizex="CrystalModule_sx" sizey="CrystalModule_sy" sizez="CrystalModule_sz" material="PbWO4" vis="AnlTeal"/> <module sizex="CrystalModule_sx" sizey="CrystalModule_sy" sizez="CrystalModule_sz" material="PbWO4" vis="InvisibleNoDaughters"/>
<wrapper thickness="CrystalModule_wrap" material="Epoxy" vis="WhiteVis"/> <wrapper thickness="CrystalModule_wrap" material="Epoxy" vis="WhiteVis"/>
<line axis="x" x="CrystalModule_dx/2." y="CrystalModule_dy*1/2." z="CrystalModule_z0" begin="7" nmods="17"/> <line axis="x" x="CrystalModule_dx/2." y="CrystalModule_dy*1/2." z="CrystalModule_z0" begin="7" nmods="17"/>
<line axis="x" x="CrystalModule_dx/2." y="CrystalModule_dy*3/2." z="CrystalModule_z0" begin="7" nmods="17"/> <line axis="x" x="CrystalModule_dx/2." y="CrystalModule_dy*3/2." z="CrystalModule_z0" begin="7" nmods="17"/>
...@@ -51,7 +51,7 @@ ...@@ -51,7 +51,7 @@
<line axis="x" x="CrystalModule_dx/2." y="CrystalModule_dy*47/2." z="CrystalModule_z0" begin="0" nmods="6"/> <line axis="x" x="CrystalModule_dx/2." y="CrystalModule_dy*47/2." z="CrystalModule_z0" begin="0" nmods="6"/>
</lines> </lines>
<lines sector="2" mirrorx="true" mirrory="true"> <lines sector="2" mirrorx="true" mirrory="true">
<module sizex="GlassModule_sx" sizey="GlassModule_sy" sizez="GlassModule_sz" material="PbGlass" vis="AnlBlue"/> <module sizex="GlassModule_sx" sizey="GlassModule_sy" sizez="GlassModule_sz" material="PbGlass" vis="InvisibleNoDaughters"/>
<wrapper thickness="GlassModule_wrap" material="Epoxy" vis="WhiteVis"/> <wrapper thickness="GlassModule_wrap" material="Epoxy" vis="WhiteVis"/>
<line axis="x" x="GlassModule_dx/2." y="GlassModule_dy*1/2." z="GlassModule_z0" begin="12" nmods="11"/> <line axis="x" x="GlassModule_dx/2." y="GlassModule_dy*1/2." z="GlassModule_z0" begin="12" nmods="11"/>
<line axis="x" x="GlassModule_dx/2." y="GlassModule_dy*3/2." z="GlassModule_z0" begin="12" nmods="11"/> <line axis="x" x="GlassModule_dx/2." y="GlassModule_dy*3/2." z="GlassModule_z0" begin="12" nmods="11"/>
