Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Select Git revision
  • 18-make-ecal-blue
  • 24-optimize-barrel-em-calo-geometry
  • acts_v4
  • beampipe_overlap
  • bigger_solenoid
  • dawnfix
  • ecal_radius
  • geo_test
  • master
  • move_rich
  • new_runner
  • no_rich_hcal
  • rich_optimize
  • rich_test
  • rp_overlap
  • tracker2
  • vertex_tracker_radius
  • view_test
  • v0.0.1
  • v0.0.2
20 results
Target
  • cpeng/topside
1 result
Select Git revision
  • dawnfix
  • ecal_radius
  • master
  • no_rich_hcal
4 results
Show changes
Commits on Source 51
Showing
with 1861 additions and 500 deletions
image: eicweb.phy.anl.gov:4567/eic/juggler/juggler:latest
workflow:
rules:
- if: '$CI_PIPELINE_SOURCE == "merge_request_event"'
- if: '$CI_PIPELINE_SOURCE == "web"'
- if: '$CI_PIPELINE_SOURCE == "webide"'
- if: '$CI_COMMIT_BRANCH == "master"'
- if: '$CI_COMMIT_TAG'
default:
before_script:
- mkdir -p images && mkdir -p doc/
- git clone https://eicweb.phy.anl.gov/EIC/detectors/accelerator.git && ln -s accelerator/eic
- mkdir build && cd build && cmake ../. -DCMAKE_INSTALL_PREFIX=/usr/local && make -j20 && make install && cd ..
- source .local/bin/env.sh
artifacts:
expire_in: 72 hours
paths:
- images/
- doc/
- .local/detector
- .local/lib
- .local/bin
- .local/include
- .local/share
- results
- config
- images
- doc
- juggler.env
reports:
dotenv: juggler.env
stages:
- config
- initialize
- build
- docs
- test
- collect
- finalize
- deploy
compile:
stage: build
tags:
- silicon
script:
- echo "Build successful."
common:setup:
stage: config
rules:
- if: '$CI_SERVER_HOST == "eicweb.phy.anl.gov"'
before_script:
- git clone https://eicweb.phy.anl.gov/EIC/benchmarks/common_bench.git setup
script:
- export JUGGLER_DETECTOR="topside"
if [[ "x${CI_PIPELINE_SOURCE}" == "xmerge_request_event" || "$CI_COMMIT_BRANCH" == "master" ]]; then
export JUGGLER_DETECTOR_VERSION="${CI_COMMIT_REF_NAME}"
echo "JUGGLER_DETECTOR = ${JUGGLER_DETECTOR}"
echo "JUGGLER_DETECTOR_VERSION = ${CI_COMMIT_REF_NAME}"
echo "JUGGLER_DETECTOR_VERSION=$CI_COMMIT_REF_NAME" >> juggler.env
echo "JUGGLER_DETECTOR=$JUGGLER_DETECTOR" >> juggler.env
fi
- source setup/bin/env.sh && ./setup/bin/install_common.sh
common:detector:
stage: initialize
needs: ["common:setup"]
script:
- source .local/bin/env.sh && build_detector.sh
- mkdir_local_data_link sim_output
- mkdir -p results
- mkdir -p config
- print_env.sh
.views:
stage: docs
rules:
needs:
- ["compile"]
tags:
- silicon
artifacts:
paths:
- images/
- doc/
- ["common:detector"]
dawn_view1:detector:
extends: .views
script:
- ./bin/make_dawn_views -t view1 -d scripts/view1 -D
dawn_view1:ev1:
extends: .views
script:
- ./bin/make_dawn_views -t view1_ev1 -d scripts/view1 -s 2
dawn_view2:detector:
extends: .views
script:
- ./bin/make_dawn_views -t view2 -d scripts/view2 -D
dawn_view2:ev1:
extends: .views
script:
- ./bin/make_dawn_views -t view2_ev1 -d scripts/view2 -s 2
dawn_view3:detector:
extends: .views
script:
- ./bin/make_dawn_views -t view3 -d scripts/view3 -D
dawn_view3:ev1:
extends: .views
script:
- ./bin/make_dawn_views -t view3_ev1 -d scripts/view3 -s 2
dawn_view3:ev3:
extends: .views
script:
- ./bin/make_dawn_views -t view3_ev1 -d scripts/view3 -s 3
dawn_view3:ev4:
extends: .views
script:
- ./bin/make_dawn_views -t view3_ev1 -d scripts/view3 -s 4
dawn_view11:detector:
extends: .views
script:
- ./bin/make_dawn_views -t view11 -d scripts/view11 -D
dawn_view12:detector:
extends: .views
script:
- ./bin/make_dawn_views -t view12 -d scripts/view12 -D
dawn_view13:detector:
extends: .views
include:
- local: 'views/view1.yml'
- local: 'views/view2.yml'
- local: 'views/view3.yml'
- local: 'views/view6.yml'
- local: 'views/view7.yml'
- local: 'views/view11.yml'
- local: 'views/view12.yml'
- local: 'views/view13.yml'
- local: 'views/view14.yml'
- local: 'views/view15.yml'
# - local: 'views/config.yml'
dump_constants:
stage: test
needs:
script:
- ./bin/make_dawn_views -t view13 -d scripts/view13 -D
dawn_view14:detector:
extends: .views
- npdet_info dump ${DETECTOR_PATH}/topside.xml | tee doc/constants.out
dump_geometry:
stage: test
needs:
script:
- ./bin/make_dawn_views -t view14 -d scripts/view14 -D
- echo "dumping geometry to images"
- mkdir -p images
- dd_web_display --output images/detector_geo.root ${DETECTOR_PATH}/topside.xml
report:
stage: test
stage: finalize
rules:
needs:
- "dawn_view1:detector"
- "dawn_view2:detector"
- "dawn_view3:detector"
- "dawn_view1:ev1"
- "dawn_view2:ev1"
- "dawn_view3:ev1"
- "dawn_view11:detector"
- "dawn_view12:detector"
- "dawn_view13:detector"
- "dawn_view14:detector"
tags:
- silicon
- view_01
- view_02
- view_03
- view_06
- view_07
- view_11
- view_12
- view_13
- view_14
- view_15
- dump_constants
- dump_geometry
artifacts:
paths:
- images/
- doc/
script:
- pip3 install jinja2 && ls -lrth
- ./bin/make_images > doc/dawn_views.md
- ./bin/make_images
overlap_check:
stage: test
tags:
- silicon
rules:
needs:
- ["compile"]
script:
#- $(exit $(checkOverlaps -c topside.xml | tee doc/overlap_check.out | wc -l ))
- checkOverlaps -c topside.xml | tee doc/overlap_check.out | wc -l
- cat doc/overlap_check.out
allow_failure: true
- checkOverlaps -c ${DETECTOR_PATH}/topside.xml | tee doc/overlap_check.out
- echo "$(cat doc/overlap_check.out | grep ovlp | wc -l) overlaps..."
- if [[ "$(cat doc/overlap_check.out | grep ovlp | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi
topside:config_testing:
stage: test
tags:
- silicon
rules:
needs:
- ["compile"]
script:
- checkOverlaps -c ${DETECTOR_PATH}/topside.xml | tee doc/overlap_check.out | wc -l
allow_failure: true
benchmarks:reconstruction:
benchmarks:detector:
stage: deploy
trigger:
project: EIC/benchmarks/reconstruction_benchmarks
needs: ["overlap_check","report"]
rules:
when: never
- if: '$CI_COMMIT_BRANCH != "master"'
when: never
- when: on_success
variables:
JUGGLER_DETECTOR: "$JUGGLER_DETECTOR"
JUGGLER_DETECTOR_VERSION: "$JUGGLER_DETECTOR_VERSION"
trigger:
project: EIC/benchmarks/detector_benchmarks
strategy: depend
needs: ["common:detector","overlap_check","report"]
benchmarks:physics:
stage: deploy
trigger:
project: EIC/benchmarks/physics_benchmarks
rules:
when: never
when: never
- when: on_success
# http://docs.gitlab.com/ce/ci/yaml/README.html#cache
pages:
image: eicweb.phy.anl.gov:4567/containers/eic_container/node:15.12
rules:
- if: '$CI_SERVER_HOST != "eicweb.phy.anl.gov"'
cache:
paths:
- node_modules/
before_script:
- ls -lrth
script:
- mkdir public && cp doc/main.html public/index.html && cp doc/*.html public/.
artifacts:
paths:
- public
......@@ -16,15 +16,20 @@ Quick start
[Browse latest](https://eicweb.phy.anl.gov/EIC/detectors/topside/-/jobs/artifacts/master/browse/images?job=report)
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view1.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view1.png?job=report" width="600px" />
[Detector views](views/detector_views.md)
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view01.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view01.png?job=report" width="600px" />
</a>
<br \>
<br />
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2a.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2a.png?job=report" width="400px" />
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view02a.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view02a.png?job=report" width="400px" />
</a>
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2e.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2e.png?job=report" width="400px" />
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view02e.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view02e.png?job=report" width="400px" />
</a>
<br />
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view11.pdf?job=report">
......@@ -108,303 +113,8 @@ Done.
Looking at the detector
https://ma.ttias.be/socks-proxy-linux-ssh-bypass-content-filters/
### TOPSiDE views
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view11.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view11a.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0050.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0100.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0150.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0200.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0250.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0300.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0350.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0400.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0450.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0500.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0550.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0600.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0650.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0700.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0750.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0800.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0850.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0900.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a0950.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1000.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1050.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1100.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1150.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1200.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1250.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1300.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1350.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1400.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1450.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1500.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1550.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1600.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1650.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1700.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1750.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1800.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1850.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1900.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a1950.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a2000.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12b.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view13b.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0150.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0200.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0250.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0300.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0350.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0400.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0450.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0500.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0550.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0600.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0650.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0700.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0750.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0800.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0850.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0900.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a0950.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1000.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1050.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1100.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1150.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1200.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1250.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1300.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1350.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1400.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1450.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1500.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1550.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1600.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1650.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1700.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1750.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1800.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1850.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1900.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a1950.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14a2000.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view14b.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view1.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view1_ev1.png?job=report" width="400px" />
<br \>
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2b.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2c.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2d.png?job=report" width="400px" />
<br \>
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2_ev1a.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2_ev1b.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2_ev1c.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2_ev1d.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view2_ev1e.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view3.png?job=report" width="400px" />
<br \>
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view3_ev1.png?job=report" width="400px" />
<br \>
......@@ -6,7 +6,7 @@ export DAWN_PS_PREVIEWER="ls"
OUT_FILE=".DAWN_1.history"
function print_the_help {
echo "USAGE: ${0} [-s <skip_events>] -d <dawn_run_dir> "
echo "USAGE: ${0} -d <dawn_run_dir> "
echo " OPTIONS: "
echo " -x targeted x coordinate position"
echo " -y targeted x coordinate position"
......@@ -14,6 +14,7 @@ function print_the_help {
echo " --theta viewing angle"
echo " --phi viewing angle"
echo " -m,--mag magnification"
echo " --draw draw style "
echo " -d,--dawn-dir <dawn_run_dir> Directory with the .DAWN files and a generate script "
exit
......@@ -91,6 +92,13 @@ do
shift # past argument
shift # past value
--draw)
echo "updating drawing to ${2}"
sed -i '9d' ${DAWN_RUN_DIR}/${OUT_FILE}
sed -i '9i'${2} ${DAWN_RUN_DIR}/${OUT_FILE}
shift # past value
-i|--input)
OUT_FILE="$2"
......@@ -92,7 +92,9 @@ rm -f *.prim
if [ "${DETECTOR_ONLY}" -eq "1" ] ; then
./scripts/run_topside.py -i scripts/input_data/few_events.hepmc \
./scripts/run_topside.py \
--compact ${DETECTOR_PATH}/topside.xml \
-o derp.root -n 1 \
--ui csh --vis -b -m macro/dawn_picture.mac &
......@@ -108,7 +110,9 @@ kill %1
else
echo " Running simulation for tracks"
-o derp.root -s ${SKIP_EVENTS} -n 1 \
--ui csh --vis -b -m macro/dawn_picture2.mac &
......@@ -15,5 +15,14 @@ base_url = "https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master
images = glob.glob("images/*.png")
template = env.get_template('detector_views.md')
print(template.render(base_url=base_url, images=images))
res = template.render(base_url=base_url, images=images)
#print(template.render(base_url=base_url, images=images))
with open('doc/dawn_views.md','w') as out:
out.write(res + '\n')
views_template = env.get_template('views.html')
res2 = views_template.render(base_url=base_url, images=images)
with open('doc/views.html','w') as out:
out.write(res2 + '\n')
<!DOCTYPE html>
<html>
<head>
<title>TOPSiDE</title>
</head>
<body>
<h1>TOPSiDE</h1>
</a>
<br />
</a>
</a>
<br />
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view11.png?job=report" width="600px" />
</a>
<br />
<a href="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw/images/view12a.png?job=report" width="600px" />
</a>
<h2>TOPSiDE Reference</h2>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
<br \>
</body>
</html>
This diff is collapsed.
#/vis/open DAWNFILE 1000x1000+600+400
#/vis/scene/create
#/vis/scene/add/volume
#/vis/sceneHandler/attach
#/vis/viewer/flush
#/vis/scene/add/trajectories
#/vis/scene/add/hits
#/tracking/storeTrajectory 1
#/vis/drawVolume
#/vis/geometry/set/forceSolid all -1 true
#/vis/geometry/set/visibility world_volume 0 0
#/run/beamOn 1
#/vis/viewer/flush
/vis/open DAWNFILE
/vis/viewer/set/lineSegmentsPerCircle 24
/vis/scene/create
#/vis/scene/add/scale 1 m x 1 0 0 manual -0.5 -2 0 m
/vis/scene/add/scale 1 m y 1 0 0 manual 2 -0.75 -3 m
#/vis/scene/add/scale 1 m y 1 0 0 manual 2 -0.75 -3 m
#/vis/scene/add/scale 2 m z 1 0 0 manual 0 -2 0 m
#/vis/scene/add/magneticField 6 lightArrow
/vis/viewer/flush
/vis/scene/add/trajectories rich smooth
/vis/scene/add/hits
# Create an attribute filter named attributeFilter-0
/vis/filtering/trajectories/create/attributeFilter
# Select attribute "IMag"
/vis/filtering/trajectories/attributeFilter-0/setAttribute IMag
# Select trajectories with 100 MeV <= IMag< 500 GeV
/vis/filtering/trajectories/attributeFilter-0/addInterval 500 MeV 500 GeV
# List available attributes
/vis/list
# List filters
/vis/filtering/trajectories/list
/run/beamOn 5
exit
#/vis/scene/create
#/vis/viewer/flush
#/vis/drawVolume
#/run/beamOn 1
#/vis/viewer/flush
/vis/open DAWNFILE
/vis/scene/create
#/vis/viewer/flush
/vis/scene/add/hits
/vis/list
# List filters
/run/beamOn 1
exit
......@@ -112,7 +112,7 @@
<include ref="topside/hcal.xml"/>
<include ref="topside/solenoid.xml"/>
<include ref="topside/topside_rich.xml"/>
<include ref="topside/forward_rich.xml"/>
<include ref="topside/roman_pots.xml"/>
<include ref="../accelerator/eic/forward_ion_beamline.xml"/>
......@@ -58,7 +58,7 @@ def run_sim(args):
outputfile = args.output
if outputfile is None:
outputfile = 'data/topside_rich_' + time.strftime('%Y-%m-%d_%H-%M')
outputfile = 'data/forward_rich_' + time.strftime('%Y-%m-%d_%H-%M')
podio = DDG4.EventAction(kernel, 'Geant4Output2Podio/RootOutput', True)
podio.HandleMCTruth = False
<!DOCTYPE html>
<html>
<head>
<title>Topside Detector</title>
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<link href="http://netdna.bootstrapcdn.com/bootstrap/3.0.0/css/bootstrap.min.css" rel="stylesheet" media="screen">
<style type="text/css">
.container {
max-width: 500px;
padding-top: 100px;
h2 {color: red;}
</style>
</head>
<body>
<h1>TOPSiDE</h1>
<div class="container">
{% block content %}{% endblock %}
<br>
<h2>Details</h2>
</div>
<script src="http://code.jquery.com/jquery-1.10.2.min.js"></script>
<script src="http://netdna.bootstrapcdn.com/bootstrap/3.0.0/js/bootstrap.min.js"></script>
</body>
</html>
{% extends "layout.html" %}
{% block content %}
<h2>Detector Views</h2>
<br>
<table>
{%- for row in images|batch(3, '&nbsp;') %}
<tr>
{%- for column in row %}
<td>
<img src="{{base_url}}/{{column}}?job=report" width="300px" />
<br \>
</td>
{%- endfor %}
</tr>
{%- endfor %}
</table>
{% endblock %}
......@@ -214,9 +214,21 @@ def run():
#seq, act = geant4.setupDetector('HeavyGasCherenkov','PhotoMultiplierSDAction')
#act.adopt(f3)
seq, act = geant4.setupTracker('SiTrackerBarrel')
seq, act = geant4.setupTracker('SiTrackerEndcapP')
seq, act = geant4.setupTracker('SiTrackerEndcapN')
seq, act = geant4.setupTracker('SiTrackerBarrel_Layer1')
seq, act = geant4.setupTracker('SiTrackerEndcapP_Layer1')
seq, act = geant4.setupTracker('SiTrackerEndcapN_Layer1')
seq, act = geant4.setupTracker('SiTrackerBarrel_Layer2')
seq, act = geant4.setupTracker('SiTrackerEndcapP_Layer2')
seq, act = geant4.setupTracker('SiTrackerEndcapN_Layer2')
seq, act = geant4.setupTracker('SiTrackerBarrel_Layer3')
seq, act = geant4.setupTracker('SiTrackerEndcapP_Layer3')
seq, act = geant4.setupTracker('SiTrackerEndcapN_Layer3')
seq, act = geant4.setupTracker('SiTrackerBarrel_Layer4')
seq, act = geant4.setupTracker('SiTrackerEndcapP_Layer4')
seq, act = geant4.setupTracker('SiTrackerEndcapN_Layer4')
seq, act = geant4.setupTracker('SiTrackerBarrel_Layer5')
seq, act = geant4.setupTracker('SiTrackerEndcapP_Layer5')
seq, act = geant4.setupTracker('SiTrackerEndcapN_Layer5')
#seq, act = geant4.setupTracker('SiVertexBarrel')
#seq, act = geant4.setupTracker('SiTrackerForward')
#seq, act = geant4.setupCalorimeter('EcalBarrel')
......@@ -9,8 +9,8 @@ function print_the_help {
exit
FILE_TAG="view1"
INPUT_FILE="g4_0000.prim"
FILE_TAG="view01"
INPUT_FILE="../../g4_0000.prim"
POSITIONAL=()
......@@ -44,6 +44,7 @@ done
set -- "${POSITIONAL[@]}" # restore positional parameters
# Side view
dawncut 1 0 0 1 ${INPUT_FILE} ${FILE_TAG}_temp0.prim
dawncut -1 0 0 1 ${FILE_TAG}_temp0.prim ${FILE_TAG}.prim
dawn -d ${FILE_TAG}.prim
......@@ -55,3 +56,15 @@ gs -o ${FILE_TAG}.pdf -sDEVICE=pdfwrite \
pdftoppm ${FILE_TAG}.pdf ${FILE_TAG} -png -singlefile -cropbox
# Top view
dawncut 0 1 0 1 ${INPUT_FILE} ${FILE_TAG}_temp0.prim
dawncut 0 -1 0 1 ${FILE_TAG}_temp0.prim ${FILE_TAG}.prim
../../bin/dawn_tweak --theta 270
ps2pdf ${FILE_TAG}.eps ${FILE_TAG}_top_full.pdf
gs -o ${FILE_TAG}_top.pdf -sDEVICE=pdfwrite \
-c "[/CropBox [51 250 550 590] /PAGES pdfmark" \
-f ${FILE_TAG}_top_full.pdf
pdftoppm ${FILE_TAG}_top.pdf ${FILE_TAG}_top -png -singlefile -cropbox
......@@ -75,8 +75,9 @@ gs -o ${FILE_TAG}.pdf -sDEVICE=pdfwrite \
dawncut 1 0 -0.01666 200 ${INPUT_FILE} ${FILE_TAG}a_temp0.prim
dawncut -1 0 0.01666 200 ${FILE_TAG}a_temp0.prim ${FILE_TAG}a.prim
#dawncut 1 0 -0.01666 200 ${INPUT_FILE} ${FILE_TAG}a_temp0.prim
dawncut -1 0 0.01666 200 ${INPUT_FILE} ${FILE_TAG}a.prim
../../bin/dawn_tweak --draw 5
dawn -d ${FILE_TAG}a.prim
ps2pdf ${FILE_TAG}a.eps ${FILE_TAG}a_full.pdf
gs -o ${FILE_TAG}a.pdf -sDEVICE=pdfwrite \
1.34392e+07
0.0
180
90
0
0
0
0
29
40
1
0.001
0
#!/bin/bash
#trignometry
sin ()
echo "scale=5;s($1)" | bc -l
cos ()
echo "scale=5;c($1)" | bc -l
tan ()
echo "scale=5;s($1)/c($1)" | bc -l
#sin ()
# echo "scale=5;s($1)" | bc -l
#cos ()
# echo "scale=5;c($1)" | bc -l
#tan ()
# echo "scale=5;s($1)/c($1)" | bc -l
......@@ -62,16 +62,18 @@ set -- "${POSITIONAL[@]}" # restore positional parameters
echo "view12 produces a series of slightly rotated XY slices a different z locations. Along beamline"
../../bin/dawn_tweak --mag 40
# slice at z = 2m
# note the offset has to change with sign of the direction to cut in the opposite direction.
dawncut 0 0 1 2005 ${INPUT_FILE} ${FILE_TAG}b_temp0.prim
dawncut 0 0 -1 -2000 ${FILE_TAG}b_temp0.prim ${FILE_TAG}b.prim
dawn -d ${FILE_TAG}b.prim
ps2pdf ${FILE_TAG}b.eps ${FILE_TAG}b_full.pdf
gs -o ${FILE_TAG}b.pdf -sDEVICE=pdfwrite \
-c "[/CropBox [50 175 550 675] /PAGES pdfmark" \
-f ${FILE_TAG}b_full.pdf
pdftoppm ${FILE_TAG}b.pdf ${FILE_TAG}b -png -singlefile -cropbox
#dawncut 0 0 1 2005 ${INPUT_FILE} ${FILE_TAG}b_temp0.prim
#dawncut 0 0 -1 -2000 ${FILE_TAG}b_temp0.prim ${FILE_TAG}b.prim
#dawn -d ${FILE_TAG}b.prim
#ps2pdf ${FILE_TAG}b.eps ${FILE_TAG}b_full.pdf
#gs -o ${FILE_TAG}b.pdf -sDEVICE=pdfwrite \
# -c "[/CropBox [50 175 550 675] /PAGES pdfmark" \
# -f ${FILE_TAG}b_full.pdf
#pdftoppm ${FILE_TAG}b.pdf ${FILE_TAG}b -png -singlefile -cropbox
original_file_tag="${FILE_TAG}"
......@@ -90,7 +92,7 @@ make_slice(){
rm "${FILE_TAG}_temp0.prim"
rm "${FILE_TAG}.prim"
for zzz in $(seq 50 50 2000) ;
for zzz in $(seq 0 2 130) ;
do
make_slice ${zzz} &
done
1.34392e+07
0.0
-1
180
0
