Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Show changes
Showing
with 59318 additions and 1840 deletions
This diff is collapsed.
<?xml version="1.0" encoding="UTF-8"?>
<lccdd>
<define>
<comment>
Far Forward B0 Tracker Parameters
</comment>
<constant name="B0Tracker_zpos" value="B0PF_CenterPosition + B0PF_Length/2.0 + 20.0*cm"/>
</define>
<detectors>
<detector
id="B0Tracker_ID"
name="B0Tracker"
readout="B0TrackerHits"
type="ref_RectangularTracker"
insideTrackingVolume="true"
reflect="false"
vis="AnlRed">
<position x="0" y="0" z="B0Tracker_zpos"/>
<layer id="1"
vis="AnlBlue"
x="20.0*cm"
y="10.0*cm" >
<slice material="Air" thickness="1.0*cm" vis="AnlBlue" sensitive="true" />
</layer>
</detector>
</detectors>
<readouts>
<readout name="B0TrackerHits">
<segmentation type="CartesianGridXY" grid_size_x="1.0*mm" grid_size_y="1.0*mm" />
<id>system:8,barrel:3,layer:4,slice:4,x:32:-16,y:-16</id>
</readout>
</readouts>
</lccdd>
<lccdd>
<comment> Central Barrel Tracker Silicon </comment>
<define>
<constant name="cb_CTD_rmin" value="SiliconTrackerInnerRadius + 70.0 * mm"/>
<constant name="cb_CTD_rmax" value="SiliconTrackerOuterRadius"/>
<constant name="cb_CTD_zmax" value="SiliconTrackerOuterBarrel_zmax"/>
<constant name="cb_CTD_length" value="SiliconTrackerOuterBarrelLength"/>
<comment> Si layer opiton </comment>
<constant name="cb_CTD_Si_gap" value="5.0 * cm"/>
<constant name="cb_CTD_Si_layer" value="15"/>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
<detector id="cb_CTD_Si_ID" name="cb_CTD_Si" type="cb_CTD_Si" readout="cb_CTD_Si_Hits" vis="cb_CTDVis" insideTrackingVloume="true">
<dimensions rmin="cb_CTD_rmin" rmax="cb_CTD_rmax" length="cb_CTD_length" zmax="cb_CTD_zmax" gap="cb_CTD_Si_gap"/>
<layer repeat="cb_CTD_Si_layer" vis="cb_CTD_Si_layerVis">
<slice name="Silicon_slice" material="Si" sensitive="true"/>
</layer>
</detector>
</detectors>
<readouts>
<readout name="cb_CTD_Si_Hits">
<id>system:8,barrel:3,layer:4,x:32:-16,y:-16</id>
</readout>
</readouts>
<plugins>
</plugins>
<fields>
</fields>
</lccdd>
<lccdd>
<comment>Initial implementation of the Athena Detector
DIRC (ported from g4e). Currently constructed around
a fixed radius of 83.65cm (between the uRWEL layers).
TODO: this needs to be properly parameterized.
</comment>
<define>
<constant name="cb_DIRC_length" value="DIRCLength"/>
<constant name="cb_DIRC_rmin" value="82.00*cm"/>
<constant name="cb_DIRC_rmax" value="88.00*cm"/>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
<detector id="BarrelDIRC_ID" name="cb_DIRC" type="cb_DIRC" readout="DIRCHits" vis="AnlTeal">
<dimensions rmin="cb_DIRC_rmin" rmax="cb_DIRC_rmax" length="cb_DIRC_length"/>
<position x="0" y="0" z="DIRCOffset"/>
</detector>
</detectors>
<readouts>
<readout name="DIRCHits">
<segmentation type="CartesianGridXY" grid_size_x="3.0*mm" grid_size_y="3.0*mm" />
<id>system:8,barrel:3,module:12,x:32:-16,y:-16</id>
</readout>
</readouts>
<plugins>
</plugins>
<fields>
</fields>
</lccdd>
<lccdd>
<comment>Central Barrel Solenoid</comment>
<define>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<!-- Define detector -->
<detectors>
<comment>
Central Barrel Solenoid Magnet
</comment>
<detector id="Solenoid_ID" name="cb_Solenoid" type="cb_Solenoid" insideTrackingVolume="false" vis="cb_SolenoidVis">
<material name="Vacuum"/> <!-- G4_Galactic -->
<dimensions rmin="Solenoid_rmin" rmax="Solenoid_rmax" z="b_Solenoid_z" delta="cb_Solenoid_shift"/>
</detector>
</detectors>
<plugins>
</plugins>
<!-- TODO: Define field using field map-->
<fields>
</fields>
</lccdd>
<lccdd>
<comment> Central Barrel Vertex Detector </comment>
<define>
<constant name="cb_VTX_Barrel_rmin" value="VertexTrackerInnerRadius"/>
<constant name="cb_VTX_Barrel_rmax" value="VertexTrackerOuterRadius"/>
<constant name="cb_VTX_Barrel_length" value="VertexTrackerOuterBarrelLength"/>
<constant name="cb_VTX_Barrel_x_pos" value="0.0*mm"/>
<constant name="cb_VTX_Barrel_y_pos" value="0.0*mm"/>
<constant name="cb_VTX_Barrel_z_pos" value="0.0*mm"/>
<constant name="cb_VTX_Barrel_layer" value="6"/>
<comment> Need to cleanup and be more consistent with naming here </comment>
<constant name="VertexTrackerBarrelLength" value="400.0*mm"/>
<constant name="SiVertexEndcapP_rmin" value="VertexTrackerInnerRadius"/>
<constant name="SiVertexEndcapP_rmax" value="VertexTrackerOuterRadius"/>
<constant name="SiVertexEndcapP_zmin" value="VertexTrackerBarrelLength + 5*mm"/>
<constant name="SiVertexEndcapN_rmin" value="VertexTrackerInnerRadius"/>
<constant name="SiVertexEndcapN_rmax" value="VertexTrackerOuterRadius"/>
<constant name="SiVertexEndcapN_zmin" value="VertexTrackerBarrelLength + 5*mm"/>
<constant name="SiVertexEndcap_NLayers" value="5"/>
<constant name="SiVertexEndcapP_zmax" value="VertexTrackingRegion_length/2 - SiVertexEndcapN_zmin"/>
<constant name="SiVertexEndcap_delta" value="(SiVertexEndcapP_zmax - SiVertexEndcapP_zmin)/SiVertexEndcap_NLayers"/>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
<detector id="SiVertexSubAssembly_ID"
name="SiVertexSubAssembly"
type="DD4hep_SubdetectorAssembly"
vis="SiTrackerSubAssemblyVis">
<composite name="SiVertexEndcapN"/>
<composite name="SiVertexEndcapP"/>
<composite name="cb_VTX_Barrel"/>
</detector>
<detector id="cb_VTX_Barrel_ID" name="cb_VTX_Barrel" type="cb_VTX_Barrel" readout="cb_VTX_Barrel_Hits" vis="cb_VTX_BarrelVis" insideTrackingVloume="true">
<dimensions rmin="cb_VTX_Barrel_rmin" rmax="cb_VTX_Barrel_rmax" length="cb_VTX_Barrel_length"/>
<position x="cb_VTX_Barrel_x_pos" y="cb_VTX_Barrel_y_pos" z="cb_VTX_Barrel_z_pos"/>
<layer repeat="cb_VTX_Barrel_layer" vis="cb_VTX_Barrel_layerVis">
</layer>
</detector>
<detector id="SiVertexEndcapP_ID" name="SiVertexEndcapP" type="ref_DiskTracker"
insideTrackingVolume="true" reflect="false" vis="AnlRed">
<position x="0" y="0" z="0"/>
<layer id="1" vis="AnlOrange"
inner_z="SiVertexEndcapP_zmin + 0*SiVertexEndcap_delta"
inner_r="SiVertexEndcapP_rmin"
outer_r="SiVertexEndcapP_rmax">
<slice material="Air" thickness="1.0*mm" vis="AnlOrange" />
</layer>
<layer id="2" vis="AnlOrange"
inner_z="SiVertexEndcapP_zmin + 1*SiVertexEndcap_delta"
</layer>
<layer id="3" vis="AnlOrange"
inner_z="SiVertexEndcapP_zmin + 2*SiVertexEndcap_delta"
</layer>
<layer id="4" vis="AnlOrange"
inner_z="SiVertexEndcapP_zmin + 3*SiVertexEndcap_delta"
</layer>
<layer id="5" vis="AnlOrange"
inner_z="SiVertexEndcapP_zmin + 4*SiVertexEndcap_delta"
</layer>
</detector>
<detector id="SiVertexEndcapN_ID" name="SiVertexEndcapN" type="ref_DiskTracker"
insideTrackingVolume="true" reflect="true" vis="AnlRed">
inner_z="SiVertexEndcapN_zmin + 0*SiVertexEndcap_delta"
inner_r="SiVertexEndcapN_rmin"
outer_r="SiVertexEndcapN_rmax">
</layer>
inner_z="SiVertexEndcapN_zmin + 1*SiVertexEndcap_delta"
</layer>
inner_z="SiVertexEndcapN_zmin + 2*SiVertexEndcap_delta"
</layer>
inner_z="SiVertexEndcapN_zmin + 3*SiVertexEndcap_delta"
</layer>
inner_z="SiVertexEndcapN_zmin + 4*SiVertexEndcap_delta"
</layer>
</detector>
</detectors>
<readouts>
<readout name="cb_VTX_Barrel_Hits">
<id>system:8,barrel:3,layer:4,module:8,x:32:-16,y:-16</id>
</readout>
</readouts>
<plugins>
</plugins>
<fields>
</fields>
</lccdd>
<lccdd>
<comment> Electron endcap GEM tracking </comment>
<define>
<comment>
ce_GEM Parameters
</comment>
<constant name="ce_GEM_rmin" value="10.0 * cm"/> <comment> temporary number. Need beampipe radius </comment>
<!--<constant name="ce_GEM_rmin" value="0.0 * cm"/>-->
<constant name="ce_GEM_rmax" value="HcalEndcapN_rmin + 0.0 * cm"/> <comment> temporary number to avoid overlaps </comment>
<!--<constant name="ce_GEM_rmax" value="45.0 * cm + 50.0 * cm"/>-->
<constant name="ce_GEM_length" value="30.0 * cm"/>
<constant name="ce_GEM_x_pos" value="0.0 * cm"/>
<constant name="ce_GEM_y_pos" value="0.0 * cm"/>
<!--<constant name="ce_GEM_z_pos" value="-Solenoid_length/2.0 + ce_GEM_length/2.0"/>-->
<constant name="ce_GEM_z_pos" value="-EcalEndcapN_zmin - CrystalBox_z_length - ce_GEM_length/2.0"/>
<constant name="ce_GEM_layer" value="8"/>
<constant name="ce_GEM_layer_thickness" value="1.0 * cm"/>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
<detector id="ce_GEM_ID" name="ce_GEM" type="ce_GEM" readout="ce_GEM_Hits" vis="ce_GEMVis" insideTrackingVloume="true">
<dimensions rmin="ce_GEM_rmin" rmax="ce_GEM_rmax" length="ce_GEM_length"/>
<position x="ce_GEM_x_pos" y="ce_GEM_y_pos" z="ce_GEM_z_pos"/>
<layer repeat="ce_GEM_layer" vis="ce_GEM_layerVis">
<slice name="Ar10CO2_slice" material="Ar10CO2" thickness="ce_GEM_layer_thickness" sensitive="true"/>
</layer>
</detector>
</detectors>
<readouts>
<readout name="ce_GEM_Hits">
<id>system:8,layer:8,x:32:-16,y:-16</id>
</readout>
</readouts>
<plugins>
</plugins>
<fields>
</fields>
</lccdd>
<lccdd>
<define>
<constant name="ce_MRICHRMin" value="15*cm"/>
<constant name="ce_MRICHRMax" value="BarrelTracking_rmax"/>
<constant name="ce_MRICHLength" value="BackwardCherenkov_length"/>
<constant name="ce_MRICHZMin" value="-BarrelTracking_length/2.0 - BackwardTracking_length"/>
</define>
<detectors>
<detector id="ce_MRICH_ID" name="ce_MRICH" type="refdet_ce_MRICH" readout="MRICHHits" vis="BlueVis" material="Air">
<dimensions rmin="ce_MRICHRMin" rmax="ce_MRICHRMax" length="ce_MRICHLength" z="ce_MRICHZMin"/>
<modules material="Quartz" thickness="10*cm" width="10*cm" gap="1*cm" />
</detector>
</detectors>
<readouts>
<readout name="MRICHHits">
<segmentation type="CartesianGridXY" grid_size_x="3*mm" grid_size_y="3*mm" />
<id>system:8,sector:8,module:14,x:32:-16,y:-16</id>
</readout>
</readouts>
</lccdd>
<display>
<comment>
Colors tweaked to be displayable by geoViewer
</comment>
<vis name="AnlGreen" alpha="1" r="100/256" g="200/256" b="0/256"/>
<vis name="AnlViolet" alpha="1" r="100/256" g="0/256" b="150/256"/>
<vis name="AnlProcess_Blue" alpha="1" r="0/256" g="100/256" b="202/256"/>
<vis name="AnlOrange" alpha="1" r="255/256" g="121/256" b="0"/>
<vis name="AnlRed" alpha="1" r="205/256" g="45/256 " b="45/256"/>
<vis name="AnlGold" alpha="1" r="248/256" g="188/256" b="0/256"/>
<vis name="AnlBlue" alpha="1" r="0/256" g="96/256" b="156/256"/>
<vis name="AnlTeal" alpha="1" r="0/256" g="161/256" b="156/256"/>
<vis name="AnlGray" alpha="1" r="102/256" g="102/256" b="102/256"/>
<vis name="AnlLight_Gray" alpha="1" r="209/256" g="209/256" b="209/256"/>
<vis name="AnlLightGray" ref="AnlLight_Gray" />
<!-- off-white (or white) don't work! -->
<!--vis name="AnlOff_White" alpha="1" r="242/256" g="242/256" b="242/256"/-->
<vis name="AnlDarkRed" alpha="1" r="161/256" g="45/256" b="45/256"/>
<vis name="AnlDarkGreen" alpha="1" r="0" g="110/256" b="50/256"/>
<vis name="AnlDarkBlue" alpha="1" r="45/256" g="45/256" b="110/256"/>
<vis name="AnlDelta_Red" ref="AnlDarkRed"/>
<vis name="AnlDelta_Green" ref="AnlDarkGreen"/>
<vis name="AnlDelta_Blue" ref="AnlDarkBlue"/>
</display>
<lccdd>
<comment> Simplified All Silicon Tracker based on:
https://github.com/reynier0611/g4lblvtx/blob/master/macros/auxiliary_studies/simplified_geometry/Fun4All_G4_simplified_v2.C
With some added info on ITS3 chip from
https://indico.bnl.gov/event/10677/contributions/45591/attachments/33204/53254/20210318-IR2%40EIC-SVT.pdf
To be used as standin until we get more detailed specs from the working group on the tracker.
Note that most details are replaced with
Note: initial implementation with hard-coded values,
TODO: add parametrization
</comment>
<define>
<constant name="VtxRadius1" value="3.3*cm"/>
<constant name="VtxRadius2" value="5.7*cm"/>
<constant name="VtxLength" value="30*cm"/>
<constant name="VtxThickness" value="0.05/100*9.37*cm"/>
<constant name="VtxServiceThickness" value="VtxThickness-ITS3Thickness"/>
<constant name="TrkBarrelThickness" value="0.55/100*9.37*cm"/>
<constant name="TrkBarrelServiceThickness" value="TrkBarrelThickness-ITS3Thickness"/>
<constant name="TrkBarrel1Radius1" value="21.0*cm"/>
<constant name="TrkBarrel1Radius2" value="22.68*cm"/>
<constant name="TrkBarrel1Length1" value="54.0*cm"/>
<constant name="TrkBarrel1Length2" value="60.0*cm"/>
<constant name="TrkBarrel2Radius1" value="39.3*cm"/>
<constant name="TrkBarrel2Radius2" value="43.23*cm"/>
<constant name="TrkBarrel2Length1" value="105.0*cm"/>
<constant name="TrkBarrel2Length2" value="114.0*cm"/>
<constant name="TrkDiskThickness" value="0.25/100*9.37*cm"/>
<constant name="TrkDiskServiceThickness" value="TrkDiskThickness-ITS3Thickness"/>
<constant name="TrkNumOuterDisks" value="3"/>
<constant name="TrkInnerDisk1_z" value="25.0*cm"/>
<constant name="TrkInnerDisk2_z" value="49.0*cm"/>
<constant name="TrkOuterDisk_zmin" value="73.0*cm"/>
<constant name="TrkOuterDisk_zmax" value="121.0*cm"/>
<constant name="TrkOuterDisk_deltaz" value="(TrkOuterDisk_zmax-TrkOuterDisk_zmin)/(TrkNumOuterDisks-1)" />
<constant name="TrkInnerDisk1_rmin" value="0.05025461*TrkInnerDisk1_z-0.180808*cm"/>
<constant name="TrkInnerDisk2_rmin" value="0.05025461*TrkInnerDisk2_z-0.180808*cm"/>
<constant name="TrkOuterDisk_rmin" value="3.18*cm"/>
<constant name="TrkInnerDisk1_rmax" value="18.5*TrkInnerDisk1_z/TrkInnerDisk1_z*cm"/>
<constant name="TrkInnerDisk2_rmax" value="18.5*TrkInnerDisk2_z/TrkInnerDisk1_z*cm"/>
<constant name="TrkOuterDisk_rmax" value="43.23*cm"/>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
<detector id="AllSiliconVtx_ID" name="AllSiliconVtx" type="refdet_CylinderTrackerBarrel" readout="ITS3Hits">
<module name="Module1" vis="AnlGreen">
<module_envelope rmin="VtxRadius1" thickness="VtxThickness" length="VtxLength" phi="360*degree" />
<module_component rmin="VtxRadius1" thickness="ITS3Thickness" material="Silicon" name="ITS3" sensitive="true" />
<module_component rmin="VtxRadius1 + ITS3Thickness" thickness="VtxServiceThickness" material="Silicon" name="VtxServices" />
</module>
<module name="Module2" vis="AnlGreen">
<module_envelope rmin="VtxRadius2" thickness="VtxThickness" length="VtxLength" phi="360*degree" />
<module_component rmin="VtxRadius2" thickness="ITS3Thickness" material="Silicon" name="ITS3" sensitive="true" />
<module_component rmin="VtxRadius2 + ITS3Thickness" thickness="VtxServiceThickness" material="Silicon" name="VtxServices" />
</module>
<layer module="Module1" id="1" vis="AnlGreen">
<barrel_envelope inner_r="VtxRadius1" outer_r="VtxRadius1 + VtxThickness" z_length="VtxLength" />
<rphi_layout phi_tilt="0.0" nphi="1" phi0="0.0" rc="VtxRadius1" dr="0.0*mm" />
<z_layout dr="0.0*mm" z0="0" nz="1" />
</layer>
<layer module="Module2" id="2" vis="AnlGreen">
<barrel_envelope inner_r="VtxRadius2" outer_r="VtxRadius2 + VtxThickness" z_length="VtxLength" />
<rphi_layout phi_tilt="0.0" nphi="1" phi0="0.0" rc="VtxRadius2" dr="0.0*mm" />
</layer>
</detector>
<detector id="AllSiliconTrk1Assembly_ID" name="AllSiliconTrkAssembly1" type="DD4hep_SubdetectorAssembly" vis="AnlGreen">
<composite name="AllSiliconTrkDisk1N" />
<composite name="AllSiliconTrkDisk1P" />
<composite name="AllSiliconBarrel1" />
</detector>
<detector id="AllSiliconTrkBarrel1_ID" name="AllSiliconTrkBarrel1" type="refdet_CylinderTrackerBarrel" readout="ITS3Hits">
<module name="Module1" id="1" vis="AnlGreen">
<module_envelope rmin="TrkBarrel1Radius1" thickness="TrkBarrelThickness" length="TrkBarrel1Length1" phi="360*degree" />
<module_component rmin="TrkBarrel1Radius1" thickness="ITS3Thickness" material="Silicon" name="ITS3" sensitive="true" />
<module_component rmin="TrkBarrel1Radius1 + ITS3Thickness" thickness="TrkBarrelServiceThickness" material="Silicon" name="TrkBarrel1Services" />
</module>
<module name="Module2" id="2" vis="AnlGreen">
<module_envelope rmin="TrkBarrel1Radius2" thickness="TrkBarrelThickness" length="TrkBarrel1Length2" phi="360*degree" />
<module_component rmin="TrkBarrel1Radius2" thickness="ITS3Thickness" material="Silicon" name="ITS3" sensitive="true" />
<module_component rmin="TrkBarrel1Radius2 + ITS3Thickness" thickness="TrkBarrelServiceThickness" material="Silicon" name="TrkBarrel1Services" />
</module>
<barrel_envelope inner_r="TrkBarrel1Radius1" outer_r="TrkBarrel1Radius1 + TrkBarrelThickness" z_length="TrkBarrel1Length1" />
<rphi_layout phi_tilt="0.0" nphi="1" phi0="0.0" rc="TrkBarrel1Radius1" dr="0.0*mm" />
</layer>
<barrel_envelope inner_r="TrkBarrel1Radius2" outer_r="TrkBarrel1Radius2 + TrkBarrelThickness" z_length="TrkBarrel1Length2" />
<rphi_layout phi_tilt="0.0" nphi="1" phi0="0.0" rc="TrkBarrel1Radius2" dr="0.0*mm" />
</layer>
</detector>
<detector id="AllSiliconTrkDisk1N_ID" name="AllSiliconTrkDisk1N" type="ref_DiskTracker" insideTrackingVolume="true" reflect="true" vis="kAnlGreen">
<layer id="1" vis="AnlGreen"
inner_z="TrkInnerDisk1_z"
inner_r="TrkInnerDisk1_rmin"
outer_r="TrkInnerDisk1_rmax">
<slice material="Silicon" thickness="TrkDiskThickness" vis="AnlGreen" />
</layer>
</detector>
<detector id="AllSiliconTrkDisk1P_ID" name="AllSiliconTrkDisk1P" type="ref_DiskTracker" insideTrackingVolume="true" reflect="false" vis="kAnlGreen">
</layer>
</detector>
<detector id="AllSiliconTrk2Assembly_ID" name="AllSiliconTrkAssembly2" type="DD4hep_SubdetectorAssembly" vis="AnlGreen">
<composite name="AllSiliconTrkDisk2N" />
<composite name="AllSiliconTrkDisk2P" />
<composite name="AllSiliconBarrel2" />
</detector>
<detector id="AllSiliconTrkBarrel2_ID" name="AllSiliconTrkBarrel2" type="refdet_CylinderTrackerBarrel" readout="ITS3Hits">
<module_envelope rmin="TrkBarrel2Radius1" thickness="TrkBarrelThickness" length="TrkBarrel2Length1" phi="360*degree" />
<module_component rmin="TrkBarrel2Radius1" thickness="ITS3Thickness" material="Silicon" name="ITS3" sensitive="true" />
<module_component rmin="TrkBarrel2Radius1 + ITS3Thickness" thickness="TrkBarrelServiceThickness" material="Silicon" name="TrkBarrel2Services" />
</module>
<module_envelope rmin="TrkBarrel2Radius2" thickness="TrkBarrelThickness" length="TrkBarrel2Length2" phi="360*degree" />
<module_component rmin="TrkBarrel2Radius2" thickness="ITS3Thickness" material="Silicon" name="ITS3" sensitive="true" />
<module_component rmin="TrkBarrel2Radius2 + ITS3Thickness" thickness="TrkBarrelServiceThickness" material="Silicon" name="TrkBarrel2Services" />
</module>
<barrel_envelope inner_r="TrkBarrel2Radius1" outer_r="TrkBarrel2Radius1 + TrkBarrelThickness" z_length="TrkBarrel2Length1" />
<rphi_layout phi_tilt="0.0" nphi="1" phi0="0.0" rc="TrkBarrel2Radius1" dr="0.0*mm" />
</layer>
<barrel_envelope inner_r="TrkBarrel2Radius2" outer_r="TrkBarrel2Radius2 + TrkBarrelThickness" z_length="TrkBarrel2Length2" />
<rphi_layout phi_tilt="0.0" nphi="1" phi0="0.0" rc="TrkBarrel2Radius2" dr="0.0*mm" />
</layer>
</detector>
<detector id="AllSiliconTrkDisk2N_ID" name="AllSiliconTrkDisk2N" type="ref_DiskTracker" insideTrackingVolume="true" reflect="true" vis="kAnlGreen">
inner_z="TrkInnerDisk2_z"
inner_r="TrkInnerDisk2_rmin"
outer_r="TrkInnerDisk2_rmax">
<!--slice material="Silicon" thickness="ITS3Thickness" vis="AnlGreen" sensitive="true"/-->
<!--slice material="Silicon" thickness="TrkDiskServiceThickness" vis="AnlGreen" /-->
</layer>
</detector>
<detector id="AllSiliconTrkDisk2P_ID" name="AllSiliconTrkDisk2P" type="ref_DiskTracker" insideTrackingVolume="true" reflect="false" vis="kAnlGreen">
</layer>
</detector>
<detector id="AllSiliconTrkOuterN_ID" name="AllSiliconTrkOuterN" type="ref_DiskTracker" insideTrackingVolume="true" reflect="true" vis="kAnlGreen">
inner_z="TrkOuterDisk_zmin"
inner_r="TrkOuterDisk_rmin"
outer_r="TrkOuterDisk_rmax">
</layer>
<layer id="2" vis="AnlGreen"
inner_z="TrkOuterDisk_zmin + 1 * TrkOuterDisk_deltaz"
</layer>
<layer id="3" vis="AnlGreen"
inner_z="TrkOuterDisk_zmin + 2 * TrkOuterDisk_deltaz"
</layer>
</detector>
<detector id="AllSiliconTrkOuterP_ID" name="AllSiliconTrkOuterP" type="ref_DiskTracker" insideTrackingVolume="true" reflect="false" vis="kAnlGreen">
</layer>
</layer>
</layer>
</detector>
</detectors>
<readouts>
<readout name="ITS3Hits">
<segmentation type="CartesianGridXY" grid_size_x="0.010*mm" grid_size_y="0.010*mm" />
<id>system:8,barrel:2,layer:4,module:7,sensor:2,x:30:-17,y:-17</id>
</readout>
</readouts>
<plugins>
</plugins>
<fields>
</fields>
</lccdd>
<lccdd>
<comment>
DIRC consists of 16 (default) identical modules making a barrel.
Each DIRC module consists of:
_______
[FD|Prizm|Lens|--------bars+glue-----|mirror]
Main constants to control DIRC global geometry:
- DIRC_length
- DIRC_offset
- DIRC_rmin
- DIRCBox_count (16 full dirc, 1 - a single module)
- DIRC_rotation (allows to flip the DIRC)
When DIRC_length is set, it affects bars length (all other lengths are fixed)
The width of each DIRC module is derived from DIRCPrism_width
</comment>
<define>
<constant name="DIRCFake_rmin" value="BarrelTracking_rmax-11*cm"/>
<constant name="DIRC_rotation" value="pi" comment="Allows DIRC flip"/>
<!-- <constant name="cb_DIRC_length" value="DIRCLength"/> -->
<!-- CLEANUP THIS if not sure. This is from the initial implementation
<constant name="DIRC_length" value="285.500*cm"/>
<constant name="DIRCFake_rmin" value="82.00*cm"/>-->
<!-- Prism -->
<constant name="DIRCPrism_width" value="360*mm"/>
<constant name="DIRCPrism_length" value="300*mm"/>
<constant name="DIRCPrism_short_edge" value="50*mm"/>
<constant name="DIRCPrism_angle" value="32*deg"/>
<constant name="DIRCPrism_long_edge" value="DIRCPrism_short_edge + DIRCPrism_length * tan(DIRCPrism_angle)"/>
<constant name="DIRCPrism_height" value="DIRCPrism_long_edge"/>
<!-- DIRC length -->
<constant name="DIRCMain_length" value="DIRC_length"/>
<constant name="DIRCFake_offset" value="DIRC_offset+15*cm"/>
<!-- Box - main DIRC modules -->
<constant name="DIRCBox_count" value="16" comment="Number of DIRC boxes per... DIRC. 16 - default"/>
<constant name="DIRCBox_width" value="DIRCPrism_width"/>
<!-- Mirror -->
<constant name="DIRCMirror_height" value="20 * mm"/>
<constant name="DIRCMirror_width" value="DIRCPrism_width"/>
<constant name="DIRCMirror_thickness" value="1 * mm"/>
<!-- Lens -->
<constant name="DIRCLens_height" value="DIRCPrism_long_edge"/>
<constant name="DIRCLens_width" value="DIRCPrism_width"/>
<constant name="DIRCLens_thickness" value="12 * mm"/>
<constant name="DIRCLens_r1" value="33 * mm"/>
<constant name="DIRCLens_r2" value="24 * mm"/>
<constant name="DIRCLens_shight" value="25 * mm" comment="Is 'shight' from UK urban dictionary???"/>
<!-- FD (Foto detectors?) -->
<constant name="DIRCFd_height" value="DIRCPrism_height"/>
<constant name="DIRCFd_width" value="DIRCPrism_width"/>
<constant name="DIRCFd_thickness" value="1*mm"/>
<!-- Bar - Each DIRC box consists of N "bars" -->
<!-- BarAssembly - Bars + Glue -->
<constant name="DIRCBarAssm_length" value="DIRCMain_length - DIRCPrism_length - DIRCMirror_thickness - DIRCLens_thickness - DIRCFd_thickness" comment="Length of bars+glue assembly"/>
<constant name="DIRCBar_count" value="11" comment="Number of bars per box"/>
<constant name="DIRCBar_gap" value="0.15 * mm"/>
<constant name="DIRCBar_height" value="17 * mm"/>
<constant name="DIRCBar_width" value="(DIRCPrism_width - (DIRCBar_count - 1) * DIRCBar_gap) / DIRCBar_count"/>
<constant name="DIRCGlue_thickness" value="0.05 * mm"/>
<constant name="DIRCBar_length" value="(DIRCBarAssm_length-4*DIRCGlue_thickness)/4"/>
<!-- dirc outer volume -->
<comment>
RMax is calculated according to "rectangle inside ring" problem solution
https://math.stackexchange.com/questions/4222684/calculate-rectangle-inside-ring-parameters/4222691#4222691
</comment>
<constant name="DIRCFake_rmax" value="sqrt( (DIRCFake_rmin+DIRCPrism_height)^2 + 0.25*(DIRCPrism_height)^2 )"/>
</define>
<materials>
<comment>
Only non optical material variants are here.
See optical_materials.xml for optical ones
</comment>
<material name="Epotek">
<D type="density" value="1.2" unit="g/cm3"/>
<composite n="5" ref="H"/>
<composite n="3" ref="C"/>
<composite n="2" ref="O"/>
</material>
<material name="Nlak33a">
<D type="density" value="4.220" unit="g/cm3"/>
<composite n="1" ref="Si"/>
</material>
</materials>
<limits>
</limits>
<regions>
</regions>
<display>
<vis name="DIRCTube" ref="AnlTeal" alpha="0.1" visible="true" showDaughters="true" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCBox" ref="AnlLight_Gray" alpha="0.1" visible="true" showDaughters="true" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCLens1" ref="AnlProcess_Blue" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCLens2" ref="AnlProcess_Blue" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCLens3" ref="AnlTeal" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCBar" ref="AnlTeal" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCGlue" ref="AnlViolet" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCMirror" ref="AnlGray" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCPrism" ref="AnlTeal" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCFd" ref="AnlRed" visible="true" showDaughters="false" />
</display>
<detectors>
<detector id="BarrelDIRC_ID" name="cb_DIRC" type="cb_DIRC" readout="DIRCBarHits" vis="DIRCTube">
<dimensions rmin="DIRCFake_rmin" rmax="DIRCFake_rmax" length="DIRCMain_length" radius="DIRCRadius" dx="DIRCBars_DX" dy="DIRCBars_DY" number="DIRCNum" deltaphi="DIRCDPhi"/>
<position x="0" y="0" z="DIRCFake_offset"/>
<rotation theta="DIRC_rotation"/>
<module name="DircBox" R="DIRCRadius" repeat="DIRCBox_count" width="DIRCPrism_width + 1*mm" height="DIRCPrism_height*2" length="DIRCBarAssm_length + 550*mm" vis="DIRCBox">
<!-- Mirror (at the end of the module) -->
<mirror
height="DIRCMirror_height"
width="DIRCMirror_width"
thickness="DIRCMirror_thickness"
material="Aluminum"
vis="DIRCMirror"
<!-- DIRC Bar -->
<!-- TODO parametrize as bar+glue assembly with layers -->
<bar
height="DIRCBar_height"
width="DIRCBar_width"
length="DIRCBar_length"
repeat="DIRCBar_count"
gap="DIRCBar_gap"
material="Quartz"
vis="DIRCBar"
<glue thickness="DIRCGlue_thickness" material="Epotek" vis="DIRCGlue"/>
<!-- lens -->
<lens
height="DIRCLens_height"
width="DIRCLens_width"
thickness="DIRCLens_thickness"
r1="DIRCLens_r1"
r2="DIRCLens_r2"
<prism/> <!-- TODO parametrize here -->
<fd
height="DIRCFd_height"
width="DIRCFd_width"
thickness="DIRCFd_thickness"
vis="DIRCFd"
material="Quartz"
</module>
</detector>
</detectors>
<readouts>
<readout name="DIRCBarHits">
<id>system:8,module:8,section:8,bar:8,x:32:-16,y:-16</id>
</readout>
</readouts>
<plugins>
</plugins>
<fields>
</fields>
</lccdd>
<display> <display>
<vis name="AnlGreen" alpha="1" r="119/255" g="179/255" b="0"/> <comment>
<vis name="AnlViolet" alpha="1" r="91/256" g="0" b="145/256"/> See compact/colors.xml for list of colors.
<vis name="AnlProcess_Blue" alpha="1" r="0/256" g="130/256" b="202/256"/> </comment>
<vis name="AnlRed" alpha="1" r="205/256" g="32/256" b="44/256"/>
<vis name="AnlGold" alpha="1" r="248/256" g="178/256" b="0/256"/>
<vis name="AnlOff_White" alpha="1" r="242/256" g="242/256" b="242/256"/>
<vis name="AnlDelta_Red" alpha="1" r="161/256" g="43/256" b="47/256"/>
<vis name="AnlDelta_Green" alpha="1" r="0" g="120/256" b="54/256"/>
<vis name="AnlDelta_Blue" alpha="1" r="11/256" g="31/256" b="143/256"/>
<vis name="AnlRed_1" alpha="0.5" r="205/256" g="32/256" b="44/256"/>
<comment>Tracker_Layer_Vis is AnlGold</comment>
<vis name="Tracker_Layer_Vis" alpha="0.5" r="248/256" g="178/256" b="0/256" showDaughters="true" />
<vis name="InvisibleNoDaughters" showDaughters="false" visible="false"/> <vis name="InvisibleNoDaughters" showDaughters="false" visible="false"/>
<vis name="InvisibleWithDaughters" showDaughters="true" visible="false"/> <vis name="InvisibleWithDaughters" showDaughters="true" visible="false"/>
<vis name="SiVertexVis" alpha="0.9" r="1" g="0" b="1" showDaughters="true" /> <comment>
<vis name="SiTrackerBarrelVis" alpha="0.5" r="0.0" g="0.0" b="1.0" showDaughters="true" visible="true"/> Tracking Visualizations
<vis name="SiTrackerVis" alpha="0.9" r="1.0" g="0.0" b="0.0" showDaughters="true" lineStyle="solid" drawingStyle="solid" /> </comment>
<vis name="TrackerVis" ref="AnlRed" />
<vis name="TrackerSupportVis" alpha="1.0" r="1.0" g="0.0" b="0.0" visible="true" showDaughters="false" /> <vis name="TrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="true" />
<vis name="TrackerLayerVis" alpha="0.9" r="0.0" g="1.0" b="0.0" visible="true" showDaughters="true" /> <vis name="TrackerServiceVis" ref="AnlGold" showDaughters="false" />
<vis name="TrackerLayerVis" ref="AnlGray" visible="true" showDaughters="true" />
<vis name="SiTrackerBarrelVis1" alpha="0.8" r="0.0" g="0.9" b="0.9" showDaughters="true" /> <vis name="TrackerModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" />
<vis name="SiTrackerBarrelVis2" alpha="0.8" r="0.1" g="0.9" b="0.0" showDaughters="true" visible="true"/> <vis name="TrackerMPGDVis" ref="AnlRed" visible="true" showDaughters="false" />
<vis name="SiTrackerEndcapVis1" alpha="0.8" r="1.0" g="0.0" b="1.0" showDaughters="true" visible="true"/> <comment> Visualization for Barrel MMGAS (apply to layers) and GEM endcap (apply to modules) </comment>
<vis name="SiTrackerEndcapVis2" alpha="0.8" r="1.0" g="0.45" b="0.0" showDaughters="false" visible="true"/> <vis name="TrackerGEMModuleVis" ref="TrackerMPGDVis" visible="true" showDaughters="false" />
<vis name="SiTrackerSubAssemblyVis" alpha="1" r="0.0" g="0.99" b="0.0" showDaughters="true" visible="true"/> <vis name="TrackerMMGASLayerVis" ref="TrackerMPGDVis" visible="true" showDaughters="false" />
<vis name="SiTrackerLayerVis" alpha="1" r="0.0" g="1" b="0.0" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="VertexSupportLayerVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="EcalVis" alpha="0.1" r="0.0" g="0.75" b="0.1" showDaughters="false"/> <vis name="VertexSupportVis" ref="VertexSupportLayerVis" visible="true" showDaughters="true" />
<vis name="EcalEndcapVis" alpha="1.0" r="0.0" g="0.99" b="0.0" showDaughters="false" visible="true" /> <vis name="VertexLayerVis" ref="AnlGray" visible="true" showDaughters="true" />
<vis name="EcalBarrelVis" alpha="1.0" r="0.0" g="0.99" b="0.0" showDaughters="false" visible="true" /> <vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" />
<vis name="TOFVis" ref="AnlTeal" visible="true" showDaughters="true"/>
<vis name="TOFLayerVis" ref="TOFVis" visible="true" showdaughters="true"/>
<vis name="TOFModuleVis" ref="TOFVis" visible="true" showdaughters="true"/>
<vis name="SolenoidCoilVis" alpha="1.0" r="0.55" g="0.55" b="0.7" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" /> <vis name="TOFSupportVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="SolenoidCryostatVis" alpha="0.4" r="0.55" g="0.55" b="0.7" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" /> <vis name="TOFSensorVis" ref="TOFVis" visible="true" showDaughters="true"/>
<vis name="SolenoidYokeVis" alpha="0.2" r="0.8" g="0.1" b="0.1" showDaughters="false" visible="true" lineStyle="solid" drawingStyle="solid" /> <comment> By default don't display the barrel module details </comment>
<vis name="RICHVis" alpha="0.5" r="1" g="0" b="1" showDaughters="true"/> <vis name="TOFBarrelModuleVis" ref="TOFVis" visible="true" showdaughters="true"/>
<vis name="BeamPipeVis" alpha="1" r= "0.75" g="0.75" b="0.75" showDaughters="true" visible="true"/> <comment> extra detailed vizualizations for the barrel </comment>
<vis name="TOFHybridVis" ref="AnlGold" visible="true" showDaughters="true"/>
<vis name="cb_SolenoidVis" alpha="0.4" r= "0.1" g="0.0" b="0.1" showDaughters="true" visible="true"/> <vis name="TOFCoolingTube" ref="AnlRed" visible="true" showDaughters="true"/>
<vis name="ffi_ZDCVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="TOFCoolant" ref="TrackerServiceVis" visible="true" showDaughters="true"/>
<vis name="ffi_ZDCmoduleVis" alpha="1.0" r= "0.1" g="1.0" b="0.9" showDaughters="true" visible="true"/> <vis name="TOFCSkinVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="cb_CTDVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="TOFCFoamVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="cb_CTD_Si_layerVis" alpha="1.0" r= "0.9" g="1.0" b="0.1" showDaughters="true" visible="true"/> <vis name="TOFCHoneycombVis" ref="TrackerServiceVis" visible="true" showDaughters="true"/>
<vis name="ce_GEMVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="cb_GEM_layerVis" alpha="0.8" r= "0.8" g="0.4" b="0.3" showDaughters="true" visible="true"/>
<vis name="cb_VTX_BarrelVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="FFTrackerVis" ref="AnlRed" />
<vis name="cb_VTX_Barrel_layerVis" alpha="2.0" r= "0.0" g="0.2" b="0.8" showDaughters="true" visible="true"/> <vis name="FFTrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="FFTrackerShieldingVis" ref="AnlGray" visible="true" showDaughters="false" />
<vis name="ci_GEMVis" r= "0.8" g="0.4" b="0.3" alpha="0.8" showDaughters="true" visible="true"/> <vis name="FFTrackerServiceVis" ref="AnlGold" visible="true" showDaughters="false" />
<vis name="ci_HCALVis" r= "0.6" g="0" b="0.6" alpha="1.0" showDaughters="true" visible="true"/> <vis name="FFTrackerLayerVis" ref="TrackerVis" visible="true" showDaughters="true" />
<vis name="FFTrackerModuleVis" ref="FFTrackerLayerVis" visible="true" showDaughters="true" />
<vis name="FFTrackerSurfaceVis" ref="FFTrackerLayerVis" visible="true" showDaughters="true" />
<comment> For shielded modules by default just display to module instead of 6 layers </comment>
<vis name="FFTrackerShieldedModuleVis" ref="FFTrackerModuleVis" visible="true" showDaughters="false" />
<comment>
ECal Vis
</comment>
<vis name="EcalVis" ref="AnlGold" showDaughters="true" visible="true"/>
<vis name="EcalBarrelVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalBarrelStaveVis" ref="AnlOrange" showDaughters="false" visible="true" />
<vis name="EcalBarrelEnvelopeVis" ref="AnlGold" showDaughters="false" visible="true" />
<vis name="EcalBarrelSupportVis" ref="AnlOrange" showDaughters="false" visible="true"/>
<vis name="EcalBarrelLayerVis" ref="AnlGold" showDaughters="true" visible="true"/>
<vis name="EcalBarrelSliceVis" ref="AnlGray" showDaughters="false" visible="true"/>
<vis name="EcalBarrelFiberLayerVis" ref="AnlGold" showDaughters="false" visible="true" />
<vis name="EcalEndcapVis" ref="AnlGold" showDaughters="true" visible="false"/>
<vis name="EcalEndcapLayerVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapBlockVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapNModuleVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="FFPreVis" ref="AnlGold" showDaughters="true" visible="true"/>
<vis name="FFPreLayerVis" ref="FFPreVis" showDaughters="true" visible="true"/>
<vis name="FFPreModuleVis" ref="FFPreLayerVis" showDaughters="true" visible="true"/>
<vis name="FFPreRadiatorVis" ref="FFPreModuleVis" showDaughters="true" visible="true"/>
<vis name="FFPreReadoutVis" ref="FFTrackerSurfaceVis" showDaughters="true" visible="true"/>
<comment>
HCal Vis
</comment>
<vis name="HcalVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalBarrelVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalBarrelStaveVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalBarrelLayerVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalEndcapVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalEndcapLayerVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalSensorVis" ref="AnlBlue" showDaughters="false" visible="false"/>
<vis name="HcalAbsorberVis" ref="AnlGray" showDaughters="false" visible="false"/>
<comment>
Passive steel for flux return
</comment>
<vis name="PassiveSteelVis" ref="AnlViolet" showDaughters="false" visible="true"/>
<comment>
Solenoid
</comment>
<vis name="SolenoidCoilVis" ref="AnlLightGray" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="SolenoidCryostatVis" ref="AnlGray" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="SolenoidYokeVis" ref="AnlLight_Gray" showDaughters="false" visible="true" lineStyle="solid" drawingStyle="solid" />
<comment>
PID Detectors
</comment>
<vis name="RICHVis" ref="AnlTeal" showDaughters="true"/>
<vis name="DIRCVis" ref="AnlTeal" showDaughters="true" visible="false"/>
<vis name="DIRCLayerVis" ref="AnlTeal" showDaughters="true" visible="false"/>
<vis name="DIRCModuleVis" ref="AnlTeal" showDaughters="true" visible="false"/>
<vis name="DIRCSupportVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<vis name="DIRCFrameVis" ref="AnlOrange" showDaughters="true" visible="true"/>
<vis name="DIRCBarVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<comment>
Beam line with magnets
</comment>
<vis name="BeamPipeVis" ref="AnlLightGray" showDaughters="true" visible="true"/>
<vis name="FFMagnetVis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="FFMagnetCoilVis" ref="AnlRed" showDaughters="true" visible="true"/>
<comment>
ZDC visualization
</comment>
<vis name="ffi_ZDC_ECAL_Vis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="ffi_ZDC_ECAL_module_Vis" ref="AnlRed" showDaughters="false" visible="true"/>
<vis name="ffi_ZDC_HCAL_Vis" ref="AnlBlue" showDaughters="true" visible="true"/>
<comment>
PID visualization
</comment>
<vis name="DRICH_vessel_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="DRICH_gas_vis" ref="AnlGreen" alpha="0.5" showDaughters="true" visible="true" />
<vis name="DRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="DRICH_filter_vis" alpha="1.0" r="1.0" g="1.0" b="0.0" showDaughters="true" visible="true" />
<vis name="DRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="DRICH_sensor_vis" ref="AnlBlue" showDaughters="true" visible="true" />
<vis name="PFRICH_sensor_vis" ref="AnlBlue" showDaughters="true" visible="true" />
<vis name="MRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="MRICH_frame_vis" ref="AnlGold" showDaughters="true" visible="true" />
<vis name="MRICH_lens_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="MRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="RICHServiceVis" ref="AnlGray" showDaughters="true" visible="true" />
</display>
<comment> <comment>
Deprecated colors. Deprecated colors.
vis name="GreenVis" alpha="1.0" r= "0.0" g="1.0" b="0.0" showDaughters="true" visible="true"/
vis name="RedVis" alpha="0.2" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/
vis name="RPVis" alpha="0.99" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/
vis name="RPLayerVis" alpha="0.99" r= "0.0" g="0.7" b="0.3" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" /
vis name="BlueVis" alpha="1.0" r= "0.0" g="0.0" b="1.0" showDaughters="true" visible="true"/
vis name="OrangeVis" alpha="1.0" r= "1.0" g="0.45" b="0.0" showDaughters="true" visible="true"/
vis name="RedGreenVis" alpha="0.5" r= "1.0" g="1.0" b="0.0" showDaughters="true" visible="true"/
vis name="BlueGreenVis" alpha="0.5" r= "0.0" g="1.0" b="1.0" showDaughters="true" visible="true"/
vis name="PurpleVis" alpha="1.0" r= "1.0" g="0.0" b="1.0" showDaughters="true" visible="true"/
vis name="DoubleRedG" alpha="0.5" r= "2.0" g=".10" b="0.0" showDaughters="true" visible="true"/
vis name="RBG015" alpha="0.5" r= "0.0" g=".2" b="1.0" showDaughters="true" visible="true"/
vis name="RBG510" alpha="0.5" r= "1.0" g=".2" b="0.0" showDaughters="true" visible="true"/
vis name="RBG" alpha="0.5" r= "1.0" g="1.0" b="1.0" showDaughters="true" visible="true"/
vis name="GrayVis" alpha="1.0" r= "0.75" g="0.75" b="0.75" showDaughters="true" visible="true"/
</comment> </comment>
<vis name="GreenVis" alpha="1.0" r= "0.0" g="1.0" b="0.0" showDaughters="true" visible="true"/>
<vis name="RedVis" alpha="0.2" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/>
<vis name="RPVis" alpha="0.99" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/>
<vis name="RPLayerVis" alpha="0.99" r= "0.0" g="0.7" b="0.3" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="BlueVis" alpha="1.0" r= "0.0" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="OrangeVis" alpha="1.0" r= "1.0" g="0.45" b="0.0" showDaughters="true" visible="true"/>
<vis name="RedGreenVis" alpha="0.5" r= "1.0" g="1.0" b="0.0" showDaughters="true" visible="true"/>
<vis name="BlueGreenVis" alpha="0.5" r= "0.0" g="1.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="PurpleVis" alpha="1.0" r= "1.0" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="DoubleRedG" alpha="0.5" r= "2.0" g=".10" b="0.0" showDaughters="true" visible="true"/>
<vis name="RBG015" alpha="0.5" r= "0.0" g=".2" b="1.0" showDaughters="true" visible="true"/>
<vis name="RBG510" alpha="0.5" r= "1.0" g=".2" b="0.0" showDaughters="true" visible="true"/>
<vis name="RBG" alpha="0.5" r= "1.0" g="1.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="GrayVis" alpha="1.0" r= "0.75" g="0.75" b="0.75" showDaughters="true" visible="true"/>
</display> </display>
