Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Show changes
Commits on Source (110)
Showing
with 58021 additions and 427 deletions
...@@ -23,3 +23,9 @@ ip6 ...@@ -23,3 +23,9 @@ ip6
*.swp *.swp
fieldmaps fieldmaps
manifest.txt
acts.txt
acts2.txt
materials-map.cbor
...@@ -47,7 +47,7 @@ common:setup: ...@@ -47,7 +47,7 @@ common:setup:
script: script:
- export JUGGLER_DETECTOR="athena" - export JUGGLER_DETECTOR="athena"
if [[ "x${CI_PIPELINE_SOURCE}" == "xmerge_request_event" || "$CI_COMMIT_BRANCH" == "master" ]]; then # if [[ "x${CI_PIPELINE_SOURCE}" == "xmerge_request_event" || "$CI_COMMIT_BRANCH" == "master" ]]; then
export JUGGLER_DETECTOR_VERSION="${CI_COMMIT_REF_NAME}" export JUGGLER_DETECTOR_VERSION="${CI_COMMIT_REF_NAME}"
echo "BEAMLINE_CONFIG = ${BEAMLINE_CONFIG}" echo "BEAMLINE_CONFIG = ${BEAMLINE_CONFIG}"
echo "BEAMLINE_CONFIG_VERSION = ${BEAMLINE_CONFIG_VERSION}" echo "BEAMLINE_CONFIG_VERSION = ${BEAMLINE_CONFIG_VERSION}"
...@@ -55,7 +55,7 @@ common:setup: ...@@ -55,7 +55,7 @@ common:setup:
echo "JUGGLER_DETECTOR_VERSION = ${CI_COMMIT_REF_NAME}" echo "JUGGLER_DETECTOR_VERSION = ${CI_COMMIT_REF_NAME}"
echo "JUGGLER_DETECTOR_VERSION=$CI_COMMIT_REF_NAME" >> juggler.env echo "JUGGLER_DETECTOR_VERSION=$CI_COMMIT_REF_NAME" >> juggler.env
echo "JUGGLER_DETECTOR=$JUGGLER_DETECTOR" >> juggler.env echo "JUGGLER_DETECTOR=$JUGGLER_DETECTOR" >> juggler.env
fi #fi
- source setup/bin/env.sh && ./setup/bin/install_common.sh - source setup/bin/env.sh && ./setup/bin/install_common.sh
common:detector: common:detector:
...@@ -63,8 +63,8 @@ common:detector: ...@@ -63,8 +63,8 @@ common:detector:
needs: needs:
- common:setup - common:setup
script: script:
- source .local/bin/env.sh && build_detector.sh #- source .local/bin/env.sh && build_detector.sh
- mkdir_local_data_link sim_output - build_detector.sh
- mkdir -p results - mkdir -p results
- mkdir -p config - mkdir -p config
- mkdir -p doc - mkdir -p doc
...@@ -80,6 +80,8 @@ build:simple: ...@@ -80,6 +80,8 @@ build:simple:
.views: .views:
stage: docs stage: docs
tags:
- phy-scratch
before_script: before_script:
- source .local/bin/env.sh - source .local/bin/env.sh
- env - env
...@@ -107,29 +109,44 @@ dump_geometry: ...@@ -107,29 +109,44 @@ dump_geometry:
- common:detector - common:detector
script: script:
- echo "dumping geometry" - echo "dumping geometry"
## DEBUG
- echo "LD_LIBRARY_PATH - $LD_LIBRARY_PATH"
- echo "PATH - $PATH"
- print_env.sh
## DEBUG
- mkdir -p geo - mkdir -p geo
## subsystem views
sed -i -e '/<detectors>/,/<\/detectors>/d' ${DETECTOR_PATH}/compact/tracking_config*.xml
mv ${DETECTOR_PATH}/compact/display_geoviewer.xml ${DETECTOR_PATH}/compact/display.xml mv ${DETECTOR_PATH}/compact/display_geoviewer.xml ${DETECTOR_PATH}/compact/display.xml
for xml in ${DETECTOR_PATH}/compact/subsystem_views/*.xml; do for xml in ${DETECTOR_PATH}/compact/subsystem_views/*.xml; do
echo $xml
geo_name=`basename $xml .xml`_geo.root geo_name=`basename $xml .xml`_geo.root
cp $xml ${DETECTOR_PATH}/geo.xml cp $xml ${DETECTOR_PATH}/geo.xml
dd_web_display --output geo/${geo_name} ${DETECTOR_PATH}/geo.xml dd_web_display --output geo/${geo_name} ${DETECTOR_PATH}/geo.xml
done done
## Lower-resolution display of the pfRICH sensors for global views
- sed -i 's/_default"\/>/_lores"\/>/' ${DETECTOR_PATH}/compact/pfrich.xml
## full geo with downstream beamline ## full geo with downstream beamline
- dd_web_display --output geo/detector_geo_full.root ${DETECTOR_PATH}/athena.xml - dd_web_display --output geo/detector_geo_full.root ${DETECTOR_PATH}/athena.xml
## only central detector geo ## only central detector geo
- sed -i '/forward_ion_beamline/d' ${DETECTOR_PATH}/athena.xml - sed -i '/forward_ion_beamline/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/far_forward/d' ${DETECTOR_PATH}/athena.xml - sed -i '/beampipe_hadron_B0/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/B0_/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/far_forward_offM/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/far_forward_detectors/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/roman_pots/d' ${DETECTOR_PATH}/athena.xml
- sed -i '/inner_vacuum_FF_magnets/d' ${DETECTOR_PATH}/athena.xml
- dd_web_display --output geo/detector_geo.root ${DETECTOR_PATH}/athena.xml - dd_web_display --output geo/detector_geo.root ${DETECTOR_PATH}/athena.xml
## print some useful output ## print some useful output
echo "Geometry viewer at:" echo "Geometry viewer at:"
echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipxyz;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all&" echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all"
echo " - Central detector view at: "
echo "https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all"
echo " - Subsystem view for `basename $xml .xml` at:" echo " - Subsystem view for `basename $xml .xml` at:"
echo " https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/${geo_name}?job=dump_geometry&item=default;1&opt=clipxyz;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all&" echo " https://eic.phy.anl.gov/geoviewer/index.htm?file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/${CI_JOB_ID}/artifacts/raw/geo/${geo_name}?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all"
done done
detector_documentation: detector_documentation:
...@@ -141,7 +158,7 @@ detector_documentation: ...@@ -141,7 +158,7 @@ detector_documentation:
- bash bin/build_documentation | tee doc/detector.md - bash bin/build_documentation | tee doc/detector.md
# xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/athena.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee doc/detector.md # xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/athena.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee doc/detector.md
# xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/ip6/ip6_defs.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true # xmllint --format --xpath '//comment/text()' ${DETECTOR_PATH}/ip6/definitions.xml | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
# for afile in ${DETECTOR_PATH}/compact/*.xml ; do # for afile in ${DETECTOR_PATH}/compact/*.xml ; do
# xmllint --format --xpath '//comment/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true # xmllint --format --xpath '//comment/text()' ${afile} | sed -re 's/<\/?\w+>//g' | sed 's/^[[:space:]]*#/#/' | tee -a doc/detector.md || true
# done # done
...@@ -162,7 +179,7 @@ report: ...@@ -162,7 +179,7 @@ report:
- view_20 - view_20
- dump_constants - dump_constants
- dump_geometry - dump_geometry
- convert_to_gdml - dump_gdml
script: script:
- pip3 install jinja2 && ls -lrth - pip3 install jinja2 && ls -lrth
- ./bin/make_images > doc/dawn_views.md - ./bin/make_images > doc/dawn_views.md
...@@ -180,19 +197,30 @@ overlap_check_tgeo: ...@@ -180,19 +197,30 @@ overlap_check_tgeo:
needs: needs:
- ["common:detector"] - ["common:detector"]
script: script:
## disable fibers in ECAL for normal overlap check
- sed -i '/<fiber/,+6d' ${DETECTOR_PATH}/compact/ecal_barrel_interlayers.xml
- sed -i '/<fiber/,+4d' ${DETECTOR_PATH}/ip6/far_forward/ZDC_Ecal_WSciFi.xml
- checkOverlaps -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_tgeo.out - checkOverlaps -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_tgeo.out
- echo "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l) overlaps..." - echo "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l) overlaps..."
- if [[ "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi - if [[ "$(cat doc/overlap_check_tgeo.out | grep ovlp | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi
overlap_check_geant4:full: overlap_check_geant4:full_fast:
stage: test stage: test
needs: needs:
script: script:
## reduce the number of fibers in Hadron EMCal for overlap check
## not needed, as we are running with a different setup now
#- sed -i 's/radius="EcalEndcapP_FiberRadius"/radius="EcalEndcapP_FiberRadius*10"/' ${DETECTOR_PATH}/compact/ci_ecal_scfi.xml
- python scripts/checkOverlaps.py -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_geant4.out - python scripts/checkOverlaps.py -c ${DETECTOR_PATH}/athena.xml | tee doc/overlap_check_geant4.out
- echo "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l) overlaps..." - echo "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l) overlaps..."
- if [[ "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi - if [[ "$(cat doc/overlap_check_geant4.out | grep GeomVol1002 | wc -l)" -gt "0" ]] ; then echo "Overlaps exist!" && false ; fi
## TODO: add real full overlap check as child pipeline to run on branches only
overlap_check_geant4:inner_detector: overlap_check_geant4:inner_detector:
needs: needs:
...@@ -203,13 +231,19 @@ overlap_check_geant4:inner_detector: ...@@ -203,13 +231,19 @@ overlap_check_geant4:inner_detector:
convert_to_gdml: dump_gdml:
needs: needs:
script: script:
- python scripts/convert_to_gdml.py --compact ${DETECTOR_PATH}/athena.xml --output geo/athena.gdml - |
gdml_name=`basename $xml .xml`.gdml
python scripts/convert_to_gdml.py --compact ${DETECTOR_PATH}/geo.xml --output geo/${gdml_name}
done
tracking_geometry_debug: tracking_geometry_debug:
...@@ -236,5 +270,5 @@ benchmarks:detector: ...@@ -236,5 +270,5 @@ benchmarks:detector:
project: EIC/benchmarks/detector_benchmarks project: EIC/benchmarks/detector_benchmarks
strategy: depend strategy: depend
needs: needs:
- overlap_check_tgeo - overlap_check_geant4:full_fast
cmake_minimum_required(VERSION 3.3 FATAL_ERROR) cmake_minimum_required(VERSION 3.12 FATAL_ERROR)
# CMP0074: find_package() uses <PackageName>_ROOT variables
cmake_policy(SET CMP0074 NEW)
PROJECT(athena PROJECT(athena
VERSION 0.0.1 VERSION 0.0.1
LANGUAGES CXX LANGUAGES CXX
...@@ -6,13 +10,18 @@ PROJECT(athena ...@@ -6,13 +10,18 @@ PROJECT(athena
set(CMAKE_CXX_STANDARD 17) set(CMAKE_CXX_STANDARD 17)
find_package( DD4hep REQUIRED COMPONENTS DDCore DDG4) set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Werror")
find_package(Acts REQUIRED COMPONENTS Core PluginIdentification PluginTGeo PluginDD4hep )
find_package(fmt)
#find_library(FMT_LIBRARY fmt)
find_package(DD4hep REQUIRED COMPONENTS DDCore DDG4)
find_package(ActsDD4hep)
if(ActsDD4hep_FOUND)
add_compile_definitions(USE_ACTSDD4HEP)
set(ActsDD4hep ActsDD4hep::ActsDD4hep)
else()
find_package(Acts REQUIRED COMPONENTS Core PluginIdentification PluginTGeo PluginDD4hep)
set(ActsDD4hep ActsCore ActsPluginDD4hep)
endif()
find_package(fmt REQUIRED)
set(a_lib_name athena) set(a_lib_name athena)
...@@ -20,15 +29,16 @@ set(a_lib_name athena) ...@@ -20,15 +29,16 @@ set(a_lib_name athena)
dd4hep_configure_output() dd4hep_configure_output()
dd4hep_add_plugin(${a_lib_name} SOURCES dd4hep_add_plugin(${a_lib_name} SOURCES
src/BackwardGEMTracker_geo.cpp
src/BarrelBarDetectorWithSideFrame_geo.cpp src/BarrelBarDetectorWithSideFrame_geo.cpp
src/BarrelCalorimeter_geo.cpp src/BarrelCalorimeter_geo.cpp
src/BarrelCalorimeterHybrid_geo.cpp
src/BarrelCalorimeterInterlayers_geo.cpp src/BarrelCalorimeterInterlayers_geo.cpp
src/BarrelTrackerWithFrame_geo.cpp src/BarrelTrackerWithFrame_geo.cpp
src/CompositeTracker_geo.cpp
src/CylinderTrackerBarrel_geo.cpp src/CylinderTrackerBarrel_geo.cpp
src/DIRC_geo.cpp src/DIRC_geo.cpp
src/DRich_geo.cpp src/DRICH_geo.cpp
src/PFRICH_geo.cpp
src/FileLoader.cpp
src/FieldMapBrBz.cpp src/FieldMapBrBz.cpp
src/GaseousRICH_geo.cpp src/GaseousRICH_geo.cpp
src/GeometryHelpers.cpp src/GeometryHelpers.cpp
...@@ -36,15 +46,15 @@ dd4hep_add_plugin(${a_lib_name} SOURCES ...@@ -36,15 +46,15 @@ dd4hep_add_plugin(${a_lib_name} SOURCES
src/HybridCalorimeter_geo.cpp src/HybridCalorimeter_geo.cpp
src/MRich_geo.cpp src/MRich_geo.cpp
src/PolyhedraEndcapCalorimeter2_geo.cpp src/PolyhedraEndcapCalorimeter2_geo.cpp
src/ScFiCalorimeter_geo.cpp
src/ShashlikCalorimeter_geo.cpp src/ShashlikCalorimeter_geo.cpp
src/SimpleDiskTracker_geo.cpp src/SimpleDiskDetector_geo.cpp
src/SimpleRectangularTracker_geo.cpp
src/SolenoidCoil_geo.cpp src/SolenoidCoil_geo.cpp
src/TrapEndcapTracker_geo.cpp src/TrapEndcapTracker_geo.cpp
USES ActsCore ActsPluginDD4hep USES ${ActsDD4hep}
target_link_libraries(${a_lib_name} target_link_libraries(${a_lib_name}
PUBLIC DD4hep::DDCore DD4hep::DDRec fmt::fmt PUBLIC DD4hep::DDCore DD4hep::DDRec fmt::fmt
...@@ -60,3 +70,8 @@ install(DIRECTORY compact/ ...@@ -60,3 +70,8 @@ install(DIRECTORY compact/
install(FILES athena.xml install(FILES athena.xml
DESTINATION share/${PROJECT_NAME}/ DESTINATION share/${PROJECT_NAME}/
# Install the detector calibration files.
install(DIRECTORY calibrations/
DESTINATION share/${PROJECT_NAME}/calibrations
...@@ -3,22 +3,34 @@ Overview ...@@ -3,22 +3,34 @@ Overview
The Athena Detector at IP6 for Electron-Ion Collider experiment. The Athena Detector at IP6 for Electron-Ion Collider experiment.
**Detector geometry viewer:** **Detector geometry viewer:**
- [Central detector geometry](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/geo/detector_geo.root?job=report&item=default;1&opt=clipxyz;transp30;zoom100;ROTY0;ROTZ0;trz100;trr0;ctrl;all&) - [Central detector](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Full Detector geometry (including beamline)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/geo/detector_geo_full.root?job=report&item=default;1&opt=clipxyz;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all&) - [Full Detector (including beamline)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/detector_geo_full.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
- [Inner detector (without calorimetry)](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/inner_detector_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
<a href="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01.pdf?job=report"> - Subsystem views:
<img src="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01.png?job=report" width="400px" /> - [Calorimetry](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/calorimeters_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [PID](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/pid_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [dRICH](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/drich_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
- [pfRICH](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/pfrich_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom55;ROTY49;ROTZ350;trz0;trr0;ctrl;all&)
- [DIRC](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/dirc_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [ToF](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/tof_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom55;ROTY49;ROTZ350;trz0;trr0;ctrl;all&)
- [Tracking](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/tracking_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom75;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Vertex detector](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/vertex_only_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom120;ROTY320;ROTZ340;trz0;trr0;ctrl;all)
- [Far-forward](https://eic.phy.anl.gov/geoviewer/index.htm?nobrowser&file=https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/geo/ip6_geo.root?job=dump_geometry&item=default;1&opt=clipx;clipy;transp30;zoom40;ROTY290;ROTZ350;trz0;trr0;ctrl;all)
<a href="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01.png?job=report" width="400px" />
</a> </a>
<br /> <br />
<a href="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01_top.pdf?job=report"> <a href="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01_top.pdf?job=report">
<img src="https://eicweb.phy.anl.gov/api/v4/projects/473/jobs/artifacts/master/raw/images/view01_top.png?job=report" width="400px" /> <img src="https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/images/view01_top.png?job=report" width="400px" />
</a> </a>
[Browse latest](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/browse/images?job=report) [Browse latest](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/browse/images?job=report)
[Detector views](views/detector_views.md) [Detector views](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/doc/dawn_views.md?job=report)
[Constants listing](https://eicweb.phy.anl.gov/EIC/detectors/athena/-/jobs/artifacts/master/raw/doc/constants.out?job=report)
Getting Started Getting Started
...@@ -33,7 +33,8 @@ ...@@ -33,7 +33,8 @@
The ip6 (or other ip) defines should be included first. The ip6 (or other ip) defines should be included first.
These files have only a define tags. These files have only a define tags.
</documentation> </documentation>
<include ref="ip6/ip6_defs.xml" /> <include ref="ip6/definitions.xml" />
<include ref="ip6/far_forward/fields_275.xml" />
<include ref="compact/definitions.xml" /> <include ref="compact/definitions.xml" />
</define> </define>
...@@ -83,14 +84,6 @@ ...@@ -83,14 +84,6 @@
- and more... - and more...
<comment>
Beamline elements
</comment>
<include ref="ip6/forward_ion_beamline.xml"/>
<include ref="ip6/beampipe_hadron_B0.xml" />
<include ref="ip6/beampipe.xml" />
<documentation level="5"> <documentation level="5">
## Main magnet ## Main magnet
...@@ -98,81 +91,20 @@ ...@@ -98,81 +91,20 @@
<include ref="compact/solenoid.xml"/> <include ref="compact/solenoid.xml"/>
### Tracker subassemblies for ACTS
</documentation>
<detectors>
<detector id="VertexBarrelSubAssembly_ID"
name="VertexBarrelSubAssembly"
type="DD4hep_SubdetectorAssembly"
vis="TrackerSubAssemblyVis">
<composite name="VertexBarrel" />
</detector>
<detector id="VertexEndcapSubAssembly_ID"
name="VertexEndcapSubAssembly"
<composite name="VertexEndcapN" />
<composite name="VertexEndcapP" />
</detector>
<detector id="TrackerBarrelSubAssembly_Inner_ID"
name="TrackerBarrelSubAssembly_Inner"
<composite name="TrackerBarrel_Inner"/>
</detector>
<detector id="TrackerEndcapSubAssembly_Inner_ID"
name="TrackerEndcapSubAssembly_Inner"
<composite name="TrackerEndcapN_Inner"/>
<composite name="TrackerEndcapP_Inner"/>
</detector>
<detector id="TrackerBarrelSubAssembly_Outer_ID"
name="TrackerSubAssembly_Outer"
<composite name="TrackerBarrel_Outer"/>
<composite name="TrackerEndcapP_Outer"/>
<composite name="TrackerEndcapN_Outer"/>
</detector>
<comment>
TOF disabled for baseline
<detector id="OuterTrackingSubAssembly_ID"
name="OuterTrackingSubAssembly"
vis="TOFSubAssemblyVis">
<composite name="BarrelTOF"/>
<composite name="ForwardTOF"/>
<composite name="BackwardTOF"/>
</detector>
</comment>
vis="SubAssemblyVis">
<composite name="GEMTrackerEndcapP"/>
<composite name="GEMTrackerEndcapN"/>
</detector>
</detectors>
<documentation level="10"> <documentation level="10">
## Central tracking detectors ## Central tracking detectors
<include ref="compact/tracking_config_acadia.xml"/> <!--include ref="compact/tracking_config_acadia.xml"/-->
<!--include ref="compact/tracking_config_canyonlands.xml"/-->
<!--include ref="compact/tracking_config_mgpds.xml"/--> <include ref="compact/tracking_config_deathvalley.xml"/>
### PID detectors ### PID detectors
<include ref="compact/pid_config_acadia.xml" /> <!--include ref="compact/pid_config_acadia.xml" /-->
<!--include ref="compact/pid_config_canyonlands.xml" /-->
<include ref="compact/pid_config_deathvalley.xml" />
## Central calorimetry ## Central calorimetry
...@@ -180,74 +112,20 @@ ...@@ -180,74 +112,20 @@
<include ref="compact/ecal.xml"/> <include ref="compact/ecal.xml"/>
<include ref="compact/hcal.xml"/> <include ref="compact/hcal.xml"/>
<documentation level="11">
## Far foward detectors
</documentation>
<include ref="ip6/central_beampipe.xml"/>
<documentation level="11"> <documentation level="11">
## Far foward detectors ## Far foward detectors
<include ref="ip6/B0_tracker.xml"/> <include ref="ip6/far_forward.xml"/>
<include ref="ip6/B0_preshower.xml"/>
<include ref="ip6/far_forward_offM_tracker.xml"/>
<include ref="ip6/far_forward_detectors.xml"/>
<include ref="ip6/roman_pots_eRD24_design.xml"/>
<fields> <documentation level="11">
<field name="B0PF_Magnet" type="MultipoleMagnet"> ## Far backward detectors
<position x="B0PF_XPosition" y="0" z="B0PF_CenterPosition"/> </documentation>
<rotation x="0" y="B0PF_RotationAngle" z="0"/> <include ref="ip6/far_backward.xml"/>
<shape type="Tube" rmin="0.0" rmax="B0PF_InnerRadius" dz="B0PF_Length*0.5"/>
<coefficient coefficient="B0PF_Bmax" skew="0.0*tesla"/>
<!--<coefficient coefficient="2.0*tesla/cm" skew="0.2*tesla/cm"/> -->
</field>
<field name="B0APF_Magnet" type="MultipoleMagnet">
<position x="B0APF_XPosition" y="0" z="B0APF_CenterPosition"/>
<rotation x="0" y="B0APF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B0APF_InnerRadius" dz="B0APF_Length*0.5"/>
<coefficient coefficient="B0APF_Bmax" skew="0.0*tesla"/>
</field>
<field name="Q1APF_Magnet" type="MultipoleMagnet">
<position x="Q1APF_XPosition" y="0" z="Q1APF_CenterPosition"/>
<rotation x="0" y="Q1APF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="Q1APF_InnerRadius" dz="Q1APF_Length*0.5"/>
<coefficient coefficient="Q1APF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="Q1APF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="Q1BPF_Magnet" type="MultipoleMagnet">
<position x="Q1BPF_XPosition" y="0" z="Q1BPF_CenterPosition"/>
<rotation x="0" y="Q1BPF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="Q1BPF_InnerRadius" dz="Q1BPF_Length*0.5"/>
<coefficient coefficient="Q1BPF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="Q1BPF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="Q2PF_Magnet" type="MultipoleMagnet">
<position x="Q2PF_XPosition" y="0" z="Q2PF_CenterPosition"/>
<rotation x="0" y="Q2PF_RotationAngle" z="pi/2.0"/>
<shape type="Tube" rmin="0.0" rmax="Q2PF_InnerRadius" dz="Q2PF_Length*0.5"/>
<coefficient coefficient="Q2PF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="Q2PF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="B1PF_Magnet" type="MultipoleMagnet">
<position x="B1PF_XPosition" y="0" z="B1PF_CenterPosition"/>
<rotation x="0" y="B1PF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B1PF_InnerRadius" dz="B1PF_Length*0.5"/>
<coefficient coefficient="B1PF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="B1PF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="B1APF_Magnet" type="MultipoleMagnet">
<position x="B1APF_XPosition" y="0" z="B1APF_CenterPosition"/>
<rotation x="0" y="B1APF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B1APF_InnerRadius" dz="B1APF_Length*0.5"/>
<coefficient coefficient="B1APF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="B1APF_GradientMax" skew="0.0*tesla/cm"/>
</field>
<field name="B2PF_Magnet" type="MultipoleMagnet">
<position x="B2PF_XPosition" y="0" z="B2PF_CenterPosition"/>
<rotation x="0" y="B2PF_RotationAngle" z="0"/>
<shape type="Tube" rmin="0.0" rmax="B2PF_InnerRadius" dz="B2PF_Length*0.5"/>
<coefficient coefficient="B2PF_Bmax" skew="0.0*tesla"/>
<coefficient coefficient="B2PF_GradientMax" skew="0.0*tesla/cm"/>
</field>
</fields>
<comment> <comment>
FB elements FB elements
...@@ -52,9 +52,9 @@ parser.add_argument('-t', '--tag', type=str,dest='file_tag', ...@@ -52,9 +52,9 @@ parser.add_argument('-t', '--tag', type=str,dest='file_tag',
help='Output file tag') help='Output file tag')
parser.add_argument('--timeout', type=int, parser.add_argument('--timeout', type=int,
default=60, default=3600,
help='Timeout in seconds') help='Timeout in seconds')
parser.add_argument('passthrough', nargs='*') parser.add_argument('passthrough', nargs='*')
args = parser.parse_args() args = parser.parse_args()
...@@ -71,6 +71,11 @@ args.out_dir = os.path.abspath(args.out_dir) ...@@ -71,6 +71,11 @@ args.out_dir = os.path.abspath(args.out_dir)
args.compact = os.path.abspath(args.compact) args.compact = os.path.abspath(args.compact)
macro = os.path.abspath(macro) macro = os.path.abspath(macro)
# adjust fiber radius to reduce the number of fibers
compact_dir = os.path.dirname(os.path.realpath(args.compact))
ci_ecal = os.path.join(compact_dir, 'compact', 'ci_ecal_scfi.xml')
os.system('sed -i \'s/radius=\"EcalEndcapP_FiberRadius\"/radius=\"EcalEndcapP_FiberRadius*10\"/\' {}'.format(ci_ecal))
prim_file = 'g4_0000.prim' prim_file = 'g4_0000.prim'
dawn_env = os.environ.copy() dawn_env = os.environ.copy()
dawn_env['DAWN_BATCH'] = 'a' dawn_env['DAWN_BATCH'] = 'a'
...@@ -138,6 +143,9 @@ for proc in psutil.process_iter(): ...@@ -138,6 +143,9 @@ for proc in psutil.process_iter():
print('kill {}, generated from {}'.format(pinfo, p.pid)) print('kill {}, generated from {}'.format(pinfo, p.pid))
os.kill(pinfo['pid'], signal.SIGTERM) os.kill(pinfo['pid'], signal.SIGTERM)
# revert the change
os.system('sed -i \'s/radius=\"EcalEndcapP_FiberRadius*10\"/radius=\"EcalEndcapP_FiberRadius\"/\' {}'.format(ci_ecal))
line = b'stderr outputs:\n' line = b'stderr outputs:\n'
while line: while line:
print(line.decode('utf-8'), end='') print(line.decode('utf-8'), end='')
...@@ -7,9 +7,15 @@ env = Environment( ...@@ -7,9 +7,15 @@ env = Environment(
autoescape=select_autoescape(['html', 'xml']) autoescape=select_autoescape(['html', 'xml'])
import os
import glob import glob
base_url = "https://eicweb.phy.anl.gov/api/v4/projects/390/jobs/artifacts/master/raw" if "CI_PROJECT_ID" in os.environ:
CI_PROJECT_ID = str(os.environ["CI_PROJECT_ID"])
else:
CI_PROJECT_ID = "473"
base_url = f"https://eicweb.phy.anl.gov/api/v4/projects/{CI_PROJECT_ID}/jobs/artifacts/master/raw"
#images = ["images/view2a.png","images/view2b.png", "images/view1.png"] #images = ["images/view2a.png","images/view2b.png", "images/view1.png"]
images = glob.glob("images/*.png") images = glob.glob("images/*.png")
#!/bin/bash
function print_the_help {
echo "USAGE: --ebeam E --pbeam E -c compact.xml"
echo "REQUIRED ARGUMENTS:"
echo " -h|--help Print this message"
echo " --ebeam Electron beam energy (5, 10 or 18)"
echo " --pbeam Ion beam energy (41, 100 or 275)"
echo " -c|--compact Compact file to set beam energy for"
exit
EBEAM=
PBEAM=
COMPACT=
while [ $# -gt 0 ]
do
key="$1"
case $key in
-h|--help)
print_the_help
--ebeam)
EBEAM=$2
shift
shift
--pbeam)
PBEAM=$2
shift
shift
-c|--compact)
COMPACT=$2
shift
shift
*) # unknown option
echo "unknown option"
exit 1
esac
done
echo "Setting beam energies to $EBEAM on $PBEAM for $COMPACT"
if [ -z $COMPACT ]; then
echo "Error: no compact file given, use -h for help"
exit 1
fi
if [ -z $EBEAM ]; then
echo "Error: --ebeam argument missing, use -h for help"
exit 1
fi
if [ -z $PBEAM ]; then
echo "Error: --pbeam argument missing, use -h for help"
exit 1
fi
if [[ $PBEAM != "41" && $PBEAM != "100" && $PBEAM != "275" ]]; then
echo "Error: Ion beam energy should be 41, 100, or 275 GeV"
exit 1
fi
if [[ $EBEAM != 5 && $EBEAM != 10 && $EBEAM != 18 ]]; then
echo "Error: Electron beam energy should be 5, 10, or 18 GeV"
exit 1
fi
if [ ! -f ${COMPACT} ]; then
echo "Error: Compact file ${COMPACT} does not exist"
exit 1
fi
sed -i "s?far_forward_fields_.\{2,3\}.xml?far_forward_fields_${PBEAM}.xml?" athena.xml
sed -i "s?far_backward_fields_.\{1,2\}.xml?far_backward_fields_${EBEAM}.xml?" athena.xml
## Calibrations for the ATHENA detector
Calibrations and constants for this ATHENA detector setup. These values are used in the
reconstruction. Each relevant subsystem that requires calibration data should have
its own subdirectory with relevant calibration files, preferably in JSON format.
Note that these calibrations are strongly versioned and tied directy to this specific
detector configuration. Therefore, please do not add an extra layer of versioning in the
file names, but rather only add those calibrations relevant for this particular setup.
"ecal_neg_endcap": {
"readout": "module",
"dynamicRange": "20*GeV",
"capacityBitsADC": 14,
"pedestalMean": 100,
"pedestalSigma": 1,
"thresholdValue": 3
"hcal_neg_endcap": {
"readout": "tile",
"dynamicRange": "20*MeV",
"capacityBitsADC": 8,
"pedestalMean": 20,
"pedestalSigma": 0.3,
"thresholdValue": 1
"ecal_pos_endcap": {
"dynamicRange": "3*GeV",
"pedestalSigma": 0.7,
"thresholdValue": 2
"hcal_pos_endcap": {
"readout": "tile",
"dynamicRange": "3.6*GeV",
"capacityBitsADC": 10,
"pedestalMean": 20,
"pedestalSigma": 0.8,
"thresholdValue": 3
"ecal_barrel_imaging": {
"readout": "pixel",
"dynamicRange": "3*MeV",
"capacityBitsADC": 13,
"pedestalSigma": 14,
"thresholdValue": 50
"ecal_barrel_scfi": {
"readout": "light_guide",
"dynamicRange": "750*MeV",
"pedestalMean": 20,
"thresholdValue": 1
"hcal_barrel": {
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 1
"pedestalSigma": 1,
"thresholdValue": 3
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 1
"thresholdValue": 2
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 3
"readout": "pixel",
"pedestalMean": 20,
"thresholdValue": 1
"hcal_barrel": {
"readout": "tile",
"pedestalMean": 20,
"thresholdValue": 1
calo_digi_canyonlands.json
\ No newline at end of file
File added
"electron": {
"particle_name": "electron",
"sampling_fraction": 0.1053739677993623,
"sampling_fraction_error": 0.00014385360879111712,
"sampling_fraction_error_img": 7.262477989358573e-05,
"sampling_fraction_error_scfi": 0.0001238835428684493,
"sampling_fraction_img": 0.006008855583640059,
"sampling_fraction_scfi": 0.09940809338992981,
"thrown_energy": 5.000000028019361
"ffi_zdc_ecal": {
"sampling_fraction": 1.0,
"minClusterCenterEdep": "3.*MeV",
"minClusterHitEdep": "0.1*MeV",
"localDistXY": ["50*mm", "50*mm"],
"splitCluster": true
"ffi_zdc_hcal": {
"minClusterCenterEdep": "1.*MeV",
"localDistXY": ["200*mm", "200*mm"],
"splitCluster": false
This diff is collapsed.
<lccdd>
<define>
<constant name="CrystalEndcap_rmin" value="VertexTrackerBarrel_rmin"/>
<constant name="CrystalEndcap_rmax" value="EcalEndcapN_rmin"/>
<constant name="CrystalBox_x_length" value="20.0*mm"/>
<constant name="CrystalBox_y_length" value="20.0*mm"/>
<constant name="CrystalBox_z_length" value="200.0*mm"/>
<constant name="CrystalBox_offset" value="0.000001*mm"/>
<constant name="CrystalEndcap_x_pos" value="0.0*m"/>
<constant name="CrystalEndcap_y_pos" value="0.0*m"/>
<constant name="CrystalEndcap_z_pos" value="-EcalEndcapN_zmin"/>
</define>
<limits>
</limits>
<regions>
</regions>
<!-- Common Generic visualization attributes -->
<comment>Common Generic visualization attributes</comment>
<display>
</display>
<detectors>
<comment>
Backwards Endcap EM Calorimeter
A layered EM calorimeter with tungsten and silicon (or scintillator) strips
</comment>
<detector id="ECalEndcapN_ID"
name="EcalEndcapN"
type="athena_PolyhedraEndcapCalorimeter2"
reflect="true"
readout="EcalEndcapHits"
vis="EcalEndcapVis"
calorimeterType="EM_ENDCAP">
<position x="0" y="0" z="0"/>
<dimensions
numsides="CaloSides"
zmin="EcalEndcapN_zmin"
rmin="EcalEndcapN_rmin"
rmax="TrackerBarrel_rmax" />
<layer repeat="EcalEndcapNLayer1_NRepeat">
<slice material="Silicon" thickness="EcalSiliconThickness" sensitive="yes" limits="cal_limits"/>
<slice material="Copper" thickness="EcalCopperThickness"/>
<slice material="Kapton" thickness="EcalKaptonThickness"/>
<slice material="Air" thickness="EcalAir1Thickness"/>
</layer>
<layer repeat="EcalEndcapNLayer2_NRepeat">
<slice material="TungstenDens24" thickness="EcalThinTungstenThickness"/>
<slice material="Air" thickness="EcalAir2Thickness"/>
</layer>
<layer repeat="EcalEndcapNLayer3_NRepeat">
<slice material="TungstenDens24" thickness="EcalThickTungstenThickness"/>
</layer>
</detector>
<comment>
Crystal Calorimeter
Backward (negative pseudorapidity) angle electron detector
</comment>
<detector
id="CrystalEndcap_ID"
name="ElectronECAL"
type="CrystalCalorimeterEndcap"
readout="CrystalEcalHits"
vis="GreenVis">
<position x="CrystalEndcap_x_pos" y="CrystalEndcap_y_pos" z="CrystalEndcap_z_pos" />
<dimensions rmin="CrystalEndcap_rmin" rmax="CrystalEndcap_rmax" x="CrystalBox_x_length" y="CrystalBox_y_length" z="CrystalBox_z_length" delta="CrystalBox_offset"/>
</detector>
</detectors>
<!-- Definition of the readout segmentation/definition -->
<readouts>
<readout name="PlaneTrackerHits">
<segmentation type="CartesianGridXY" grid_size_x="20.0*mm" grid_size_y="20.0*mm" />
<id>system:5,module:4,x:32:-16,y:-16</id>
</readout>
<readout name="CrystalEcalHits">
<segmentation type="CartesianGridXY" grid_size_x="CrystalBox_x_length" grid_size_y="CrystalBox_y_length" />
<id>system:8,sector:4,module:20,x:48:-8,y:-8</id>
</readout>
<readout name="EcalEndcapNHits">
<segmentation type="CartesianGridXY" grid_size_x="3.5 * mm" grid_size_y="3.5 * mm"/>
<id>system:8,barrel:3,module:4,layer:6,slice:5,x:32:-16,y:-16</id>
</readout>
</readouts>
<plugins>
</plugins>
</lccdd>
<lccdd>
<define>
<constant name="EcalEndcapP_rmax" value="Solenoid_rmax "/>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
#### Forward (Positive Z) Endcap EM Calorimeter
</documentation>
<detector id="ECalEndcapP_ID"
name="EcalEndcapP"
reflect="false"
readout="EcalEndcapPHits"
vis="EcalEndcapVis"
calorimeterType="EM_ENDCAP" >
<position x="0" y="0" z="-0"/>
<dimensions
zmin="EcalEndcapP_zmin"
rmin="EcalEndcapP_rmin"
rmax="EcalEndcapP_rmax " />
<layer repeat="EcalEndcapPLayer1_NRepeat">
</layer>
<layer repeat="EcalEndcapPLayer2_NRepeat">
</layer>
<layer repeat="EcalEndcapPLayer3_NRepeat">
</layer>
</detector>
</detectors>
<readouts>
<readout name="EcalEndcapPHits">
</readout>
</readouts>
<plugins>
</plugins>
</lccdd>
