Skip to content
Snippets Groups Projects
Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Select Git revision
Target
  • EIC/detectors/athena
  • zwzhao/athena
  • FernandoTA/athena
  • palspeic/athena
4 results
Select Git revision
Show changes
Showing
with 1423 additions and 834 deletions
<lccdd>
<define>
<constant name="EcalEndcapP_rmax" value="Solenoid_rmax "/>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
<documentation level="10">
#### Forward (Positive Z) Endcap EM Calorimeter
A layered EM calorimeter with tungsten and silicon (or scintillator) strips
</documentation>
<detector id="ECalEndcapP_ID"
name="EcalEndcapP"
reflect="false"
type="athena_PolyhedraEndcapCalorimeter2"
readout="EcalEndcapPHits"
vis="EcalEndcapVis"
calorimeterType="EM_ENDCAP" >
<position x="0" y="0" z="-0"/>
<dimensions
numsides="CaloSides"
zmin="EcalEndcapP_zmin"
rmin="EcalEndcapP_rmin"
rmax="EcalEndcapP_rmax " />
<layer repeat="EcalEndcapPLayer1_NRepeat">
<slice material="Silicon" thickness="EcalSiliconThickness" sensitive="yes" limits="cal_limits"/>
<slice material="Copper" thickness="EcalCopperThickness"/>
<slice material="Kapton" thickness="EcalKaptonThickness"/>
<slice material="Air" thickness="EcalAir1Thickness"/>
</layer>
<layer repeat="EcalEndcapPLayer2_NRepeat">
<slice material="TungstenDens24" thickness="EcalThinTungstenThickness"/>
<slice material="Air" thickness="EcalAir2Thickness"/>
</layer>
<layer repeat="EcalEndcapPLayer3_NRepeat">
<slice material="TungstenDens24" thickness="EcalThickTungstenThickness"/>
</layer>
</detector>
</detectors>
<!-- Definition of the readout segmentation/definition -->
<readouts>
<readout name="EcalEndcapPHits">
<segmentation type="CartesianGridXY" grid_size_x="3.5 * mm" grid_size_y="3.5 * mm"/>
<id>system:8,barrel:3,module:4,layer:6,slice:5,x:32:-16,y:-16</id>
</readout>
</readouts>
<plugins>
</plugins>
</lccdd>
<display> <display>
<comment> <comment>
A coherent color scheme. Pick from these colors and (in theory) it should look pretty good. Colors tweaked to be displayable by geoViewer
</comment> </comment>
<vis name="AnlGreen" alpha="1" r="119/255" g="179/255" b="0"/> <vis name="AnlGreen" alpha="1" r="100/256" g="200/256" b="0/256"/>
<vis name="AnlViolet" alpha="1" r="91/256" g="0" b="145/256"/> <vis name="AnlViolet" alpha="1" r="100/256" g="0/256" b="150/256"/>
<vis name="AnlProcess_Blue" alpha="1" r="0/256" g="130/256" b="202/256"/> <vis name="AnlProcess_Blue" alpha="1" r="0/256" g="100/256" b="202/256"/>
<vis name="AnlOrange" alpha="1" r="255/256" g="121/256" b="0"/> <vis name="AnlOrange" alpha="1" r="255/256" g="121/256" b="0"/>
<vis name="AnlRed" alpha="1" r="205/256" g="32/256 " b="44/256"/> <vis name="AnlRed" alpha="1" r="205/256" g="45/256 " b="45/256"/>
<vis name="AnlGold" alpha="1" r="248/256" g="178/256" b="0/256"/> <vis name="AnlGold" alpha="1" r="248/256" g="188/256" b="0/256"/>
<vis name="AnlBlue" alpha="1" r="0/256" g="96/256" b="156/256"/> <vis name="AnlBlue" alpha="1" r="0/256" g="96/256" b="156/256"/>
<vis name="AnlTeal" alpha="1" r="0/256" g="161/256" b="156/256"/> <vis name="AnlTeal" alpha="1" r="0/256" g="161/256" b="156/256"/>
<vis name="AnlGray" alpha="1" r="102/256" g="102/256" b="102/256"/> <vis name="AnlGray" alpha="1" r="102/256" g="102/256" b="102/256"/>
<vis name="AnlLight_Gray" alpha="1" r="209/256" g="209/256" b="209/256"/> <vis name="AnlLight_Gray" alpha="1" r="209/256" g="209/256" b="209/256"/>
<vis name="AnlOff_White" alpha="1" r="242/256" g="242/256" b="242/256"/> <vis name="AnlLightGray" ref="AnlLight_Gray" />
<vis name="AnlDelta_Red" alpha="1" r="161/256" g="43/256" b="47/256"/> <!-- off-white (or white) don't work! -->
<vis name="AnlDelta_Green" alpha="1" r="0" g="120/256" b="54/256"/> <!--vis name="AnlOff_White" alpha="1" r="242/256" g="242/256" b="242/256"/-->
<vis name="AnlDelta_Blue" alpha="1" r="11/256" g="31/256" b="143/256"/> <vis name="AnlDarkRed" alpha="1" r="161/256" g="45/256" b="45/256"/>
<vis name="AnlDarkGreen" alpha="1" r="0" g="110/256" b="50/256"/>
<vis name="AnlDarkBlue" alpha="1" r="45/256" g="45/256" b="110/256"/>
<vis name="AnlDelta_Red" ref="AnlDarkRed"/>
<vis name="AnlDelta_Green" ref="AnlDarkGreen"/>
<vis name="AnlDelta_Blue" ref="AnlDarkBlue"/>
</display> </display>
<display>
<comment>
This is where another color scheme can be developed.
Note this is currently just a copy of colors.xml
</comment>
</display>
This diff is collapsed.
...@@ -21,12 +21,12 @@ ...@@ -21,12 +21,12 @@
<define> <define>
<constant name="DIRC_rmin" value="BarrelTracking_rmax-11*cm"/> <constant name="DIRCFake_rmin" value="BarrelTracking_rmax-11*cm"/>
<constant name="DIRC_rotation" value="pi" comment="Allows DIRC flip"/> <constant name="DIRC_rotation" value="pi" comment="Allows DIRC flip"/>
<!-- <constant name="cb_DIRC_length" value="DIRCLength"/> --> <!-- <constant name="cb_DIRC_length" value="DIRCLength"/> -->
<!-- CLEANUP THIS if not sure. This is from the initial implementation <!-- CLEANUP THIS if not sure. This is from the initial implementation
<constant name="DIRC_length" value="285.500*cm"/> <constant name="DIRC_length" value="285.500*cm"/>
<constant name="DIRC_rmin" value="82.00*cm"/>--> <constant name="DIRCFake_rmin" value="82.00*cm"/>-->
<!-- Prism --> <!-- Prism -->
<constant name="DIRCPrism_width" value="360*mm"/> <constant name="DIRCPrism_width" value="360*mm"/>
...@@ -37,8 +37,8 @@ ...@@ -37,8 +37,8 @@
<constant name="DIRCPrism_height" value="DIRCPrism_long_edge"/> <constant name="DIRCPrism_height" value="DIRCPrism_long_edge"/>
<!-- DIRC length --> <!-- DIRC length -->
<constant name="DIRC_length" value="DIRCFull_length - DIRCPrism_length"/> <constant name="DIRCMain_length" value="DIRC_length"/>
<constant name="DIRC_offset" value="(CentralTracking_length - DIRC_length)/2.0 - DIRCExtra_offset"/> <constant name="DIRCFake_offset" value="DIRC_offset+15*cm"/>
<!-- Box - main DIRC modules --> <!-- Box - main DIRC modules -->
<constant name="DIRCBox_count" value="16" comment="Number of DIRC boxes per... DIRC. 16 - default"/> <constant name="DIRCBox_count" value="16" comment="Number of DIRC boxes per... DIRC. 16 - default"/>
...@@ -64,7 +64,7 @@ ...@@ -64,7 +64,7 @@
<!-- Bar - Each DIRC box consists of N "bars" --> <!-- Bar - Each DIRC box consists of N "bars" -->
<!-- BarAssembly - Bars + Glue --> <!-- BarAssembly - Bars + Glue -->
<constant name="DIRCBarAssm_length" value="DIRC_length - DIRCPrism_length - DIRCMirror_thickness - DIRCLens_thickness - DIRCFd_thickness" comment="Length of bars+glue assembly"/> <constant name="DIRCBarAssm_length" value="DIRCMain_length - DIRCPrism_length - DIRCMirror_thickness - DIRCLens_thickness - DIRCFd_thickness" comment="Length of bars+glue assembly"/>
<constant name="DIRCBar_count" value="11" comment="Number of bars per box"/> <constant name="DIRCBar_count" value="11" comment="Number of bars per box"/>
<constant name="DIRCBar_gap" value="0.15 * mm"/> <constant name="DIRCBar_gap" value="0.15 * mm"/>
<constant name="DIRCBar_height" value="17 * mm"/> <constant name="DIRCBar_height" value="17 * mm"/>
...@@ -77,7 +77,7 @@ ...@@ -77,7 +77,7 @@
RMax is calculated according to "rectangle inside ring" problem solution RMax is calculated according to "rectangle inside ring" problem solution
https://math.stackexchange.com/questions/4222684/calculate-rectangle-inside-ring-parameters/4222691#4222691 https://math.stackexchange.com/questions/4222684/calculate-rectangle-inside-ring-parameters/4222691#4222691
<constant name="DIRC_rmax" value="sqrt( (DIRC_rmin+DIRCPrism_height)^2 + 0.25*(DIRCPrism_height)^2 )"/> <constant name="DIRCFake_rmax" value="sqrt( (DIRCFake_rmin+DIRCPrism_height)^2 + 0.25*(DIRCPrism_height)^2 )"/>
</define> </define>
<materials> <materials>
...@@ -107,22 +107,22 @@ ...@@ -107,22 +107,22 @@
</regions> </regions>
<display> <display>
<vis name="DIRCTube" alpha="0.1" r="0" g="0.6" b="0.6" visible="true" showDaughters="true" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCTube" ref="AnlTeal" alpha="0.1" visible="true" showDaughters="true" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCBox" alpha="0.1" r="256/256" g="256/256" b="256/256" visible="true" showDaughters="true" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCBox" ref="AnlLight_Gray" alpha="0.1" visible="true" showDaughters="true" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCLens1" alpha="1" r="3/256" g="37/256" b="76/256" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCLens1" ref="AnlProcess_Blue" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCLens2" alpha="1" r="17/256" g="103/256" b="177/256" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCLens2" ref="AnlProcess_Blue" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCLens3" alpha="1" r="0/256" g="128/256" b="128/256" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCLens3" ref="AnlTeal" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCBar" alpha="1" r="0/256" g="128/256" b="128/256" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCBar" ref="AnlTeal" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCGlue" alpha="1" r="125/256" g="0/256" b="128/256" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCGlue" ref="AnlViolet" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCMirror" alpha="1" r="0" g="0" b="1" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCMirror" ref="AnlGray" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCPrism" alpha="1" r="212/256" g="175/256" b="55/256" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" /> <vis name="DIRCPrism" ref="AnlTeal" visible="true" showDaughters="false" lineStyle="solid" drawingStyle="solid" />
<vis name="DIRCFd" alpha="1" r="0.7" g="0" b="0" visible="true" showDaughters="false" /> <vis name="DIRCFd" ref="AnlRed" visible="true" showDaughters="false" />
<detectors> <detectors>
<detector id="BarrelDIRC_ID" name="cb_DIRC" type="cb_DIRC" readout="DIRCBarHits" vis="DIRCTube"> <detector id="BarrelDIRC_ID" name="cb_DIRC" type="cb_DIRC" readout="DIRCBarHits" vis="DIRCTube">
<dimensions rmin="DIRC_rmin" rmax="DIRC_rmax" length="DIRC_length" radius="DIRCRadius" dx="DIRCBars_DX" dy="DIRCBars_DY" number="DIRCNum" deltaphi="DIRCDPhi"/> <dimensions rmin="DIRCFake_rmin" rmax="DIRCFake_rmax" length="DIRCMain_length" radius="DIRCRadius" dx="DIRCBars_DX" dy="DIRCBars_DY" number="DIRCNum" deltaphi="DIRCDPhi"/>
<position x="0" y="0" z="DIRC_offset"/> <position x="0" y="0" z="DIRCFake_offset"/>
<rotation theta="DIRC_rotation"/> <rotation theta="DIRC_rotation"/>
<module name="DircBox" R="DIRCRadius" repeat="DIRCBox_count" width="DIRCPrism_width + 1*mm" height="DIRCPrism_height*2" length="DIRCBarAssm_length + 550*mm" vis="DIRCBox"> <module name="DircBox" R="DIRCRadius" repeat="DIRCBox_count" width="DIRCPrism_width + 1*mm" height="DIRCPrism_height*2" length="DIRCBarAssm_length + 550*mm" vis="DIRCBox">
<!-- Mirror (at the end of the module) --> <!-- Mirror (at the end of the module) -->
...@@ -10,46 +10,92 @@ ...@@ -10,46 +10,92 @@
<comment> <comment>
Tracking Visualizations Tracking Visualizations
<vis name="TrackerVis" ref="AnlRed" /> <vis name="TrackerVis" ref="AnlRed" />
<vis name="TrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="true" /> <vis name="TrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="true" />
<vis name="TrackerLayerVis" ref="AnlTeal" visible="true" showDaughters="true" /> <vis name="TrackerServiceVis" ref="AnlGold" showDaughters="false" />
<vis name="TrackerLayerVis" ref="AnlGray" visible="true" showDaughters="true" />
<vis name="TrackerModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" /> <vis name="TrackerModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" />
<vis name="TrackerMPGDVis" ref="AnlRed" visible="true" showDaughters="false" />
<vis name="VertexSupportVis" ref="AnlBlue" showDaughters="false" /> <comment> Visualization for Barrel MMGAS (apply to layers) and GEM endcap (apply to modules) </comment>
<vis name="VertexLayerVis" ref="AnlTeal" visible="true" showDaughters="true" /> <vis name="TrackerGEMModuleVis" ref="TrackerMPGDVis" visible="true" showDaughters="false" />
<vis name="TrackerMMGASLayerVis" ref="TrackerMPGDVis" visible="true" showDaughters="false" />
<vis name="VertexSupportLayerVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="VertexSupportVis" ref="VertexSupportLayerVis" visible="true" showDaughters="true" />
<vis name="VertexLayerVis" ref="AnlGray" visible="true" showDaughters="true" />
<vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" /> <vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" />
<vis name="TOFVis" ref="AnlGreen" showDaughters="true" /> <vis name="TOFVis" ref="AnlTeal" visible="true" showDaughters="true"/>
<vis name="TOFLayerVis" ref="TOFVis" visible="true" showdaughters="true"/>
<vis name="TOFModuleVis" ref="TOFVis" visible="true" showdaughters="true"/>
<vis name="TOFSupportVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="TOFSensorVis" ref="TOFVis" visible="true" showDaughters="true"/>
<comment> By default don't display the barrel module details </comment>
<vis name="TOFBarrelModuleVis" ref="TOFVis" visible="true" showdaughters="true"/>
<comment> extra detailed vizualizations for the barrel </comment>
<vis name="TOFHybridVis" ref="AnlGold" visible="true" showDaughters="true"/>
<vis name="TOFCoolingTube" ref="AnlRed" visible="true" showDaughters="true"/>
<vis name="TOFCoolant" ref="TrackerServiceVis" visible="true" showDaughters="true"/>
<vis name="TOFCSkinVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="TOFCFoamVis" ref="TrackerSupportVis" visible="true" showDaughters="true"/>
<vis name="TOFCHoneycombVis" ref="TrackerServiceVis" visible="true" showDaughters="true"/>
<vis name="FFTrackerVis" ref="AnlRed" />
<vis name="FFTrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="FFTrackerShieldingVis" ref="AnlGray" visible="true" showDaughters="false" />
<vis name="FFTrackerServiceVis" ref="AnlGold" visible="true" showDaughters="false" />
<vis name="FFTrackerLayerVis" ref="TrackerVis" visible="true" showDaughters="true" />
<vis name="FFTrackerModuleVis" ref="FFTrackerLayerVis" visible="true" showDaughters="true" />
<vis name="FFTrackerSurfaceVis" ref="FFTrackerLayerVis" visible="true" showDaughters="true" />
<comment> For shielded modules by default just display to module instead of 6 layers </comment>
<vis name="FFTrackerShieldedModuleVis" ref="FFTrackerModuleVis" visible="true" showDaughters="false" />
<comment> <comment>
ECal Vis ECal Vis
<vis name="EcalVis" ref="AnlGold" showDaughters="true" visible="true"/> <vis name="EcalVis" ref="AnlGold" showDaughters="true" visible="true"/>
<vis name="EcalEndcapVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalBarrelVis" ref="AnlGold" showDaughters="false" visible="true"/> <vis name="EcalBarrelVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalBarrelStaveVis" ref="AnlViolet" showDaughters="false" visible="true" /> <vis name="EcalBarrelStaveVis" ref="AnlOrange" showDaughters="false" visible="true" />
<vis name="EcalBarrelEnvelopeVis" ref="AnlViolet" showDaughters="false" visible="true" /> <vis name="EcalBarrelEnvelopeVis" ref="AnlGold" showDaughters="false" visible="true" />
<vis name="EcalBarrelSupportVis" ref="AnlOrange" showDaughters="false" visible="true"/> <vis name="EcalBarrelSupportVis" ref="AnlOrange" showDaughters="false" visible="true"/>
<vis name="EcalBarrelLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/> <vis name="EcalBarrelLayerVis" ref="AnlGold" showDaughters="true" visible="true"/>
<vis name="EcalBarrelSliceVis" ref="AnlBlue" showDaughters="false" visible="true"/> <vis name="EcalBarrelSliceVis" ref="AnlGray" showDaughters="false" visible="true"/>
<vis name="EcalBarrelFiberLayerVis" ref="AnlGold" showDaughters="false" visible="true" /> <vis name="EcalBarrelFiberLayerVis" ref="AnlGold" showDaughters="false" visible="true" />
<vis name="EcalEndcapNModuleVis" ref="AnlTeal" showDaughters="false" visible="true"/> <vis name="EcalEndcapVis" ref="AnlGold" showDaughters="true" visible="false"/>
<vis name="EcalEndcapLayerVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapBlockVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapNModuleVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="FFPreVis" ref="AnlGold" showDaughters="true" visible="true"/>
<vis name="FFPreLayerVis" ref="FFPreVis" showDaughters="true" visible="true"/>
<vis name="FFPreModuleVis" ref="FFPreLayerVis" showDaughters="true" visible="true"/>
<vis name="FFPreRadiatorVis" ref="FFPreModuleVis" showDaughters="true" visible="true"/>
<vis name="FFPreReadoutVis" ref="FFTrackerSurfaceVis" showDaughters="true" visible="true"/>
<comment> <comment>
HCal Vis HCal Vis
<vis name="HcalVis" ref="AnlViolet" showDaughters="false"/> <vis name="HcalVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalBarrelVis" ref="AnlViolet" showDaughters="false" visible="true" /> <vis name="HcalBarrelVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalBarrelStaveVis" ref="AnlViolet" showDaughters="false" visible="true" /> <vis name="HcalBarrelStaveVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalEndcapVis" ref="AnlProcess_Blue" showDaughters="false" visible="true" /> <vis name="HcalBarrelLayerVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalSensorVis" ref="AnlProcess_Blue" showDaughters="false" visible="false" /> <vis name="HcalEndcapVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalAbsorberVis" ref="AnlProcess_Blue" showDaughters="false" visible="false" /> <vis name="HcalEndcapLayerVis" ref="AnlBlue" showDaughters="false" visible="true"/>
<vis name="HcalSensorVis" ref="AnlBlue" showDaughters="false" visible="false"/>
<vis name="HcalAbsorberVis" ref="AnlGray" showDaughters="false" visible="false"/>
<comment>
Passive steel for flux return
</comment>
<vis name="PassiveSteelVis" ref="AnlViolet" showDaughters="false" visible="true"/>
<comment> <comment>
Solenoid Solenoid
<vis name="SolenoidCoilVis" ref="AnlLight_Gray" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" /> <vis name="SolenoidCoilVis" ref="AnlLightGray" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="SolenoidCryostatVis" ref="AnlGray" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" /> <vis name="SolenoidCryostatVis" ref="AnlGray" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="SolenoidYokeVis" ref="AnlLight_Gray" showDaughters="false" visible="true" lineStyle="solid" drawingStyle="solid" /> <vis name="SolenoidYokeVis" ref="AnlLight_Gray" showDaughters="false" visible="true" lineStyle="solid" drawingStyle="solid" />
...@@ -57,33 +103,48 @@ ...@@ -57,33 +103,48 @@
<comment> <comment>
PID Detectors PID Detectors
<vis name="RICHVis" ref="AnlViolet" showDaughters="true"/> <vis name="RICHVis" ref="AnlTeal" showDaughters="true"/>
<vis name="DIRCVis" ref="AnlTeal" showDaughters="true" visible="false"/>
<vis name="DIRCLayerVis" ref="AnlTeal" showDaughters="true" visible="false"/>
<vis name="DIRCModuleVis" ref="AnlTeal" showDaughters="true" visible="false"/>
<vis name="DIRCSupportVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<vis name="DIRCFrameVis" ref="AnlOrange" showDaughters="true" visible="true"/>
<vis name="DIRCBarVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<comment>
Beam line with magnets
</comment>
<vis name="BeamPipeVis" ref="AnlLightGray" showDaughters="true" visible="true"/>
<vis name="FFMagnetVis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="FFMagnetCoilVis" ref="AnlRed" showDaughters="true" visible="true"/>
<comment> <comment>
Beam line ZDC visualization
<vis name="BeamPipeVis" ref="AnlLight_Gray" showDaughters="true" visible="true"/>
<vis name="ffi_ZDC_ECAL_Vis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="cb_SolenoidVis" alpha="0.4" r= "0.1" g="0.0" b="0.1" showDaughters="true" visible="true"/> <vis name="ffi_ZDC_ECAL_module_Vis" ref="AnlRed" showDaughters="false" visible="true"/>
<vis name="ffi_ZDC_ECAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="ffi_ZDC_HCAL_Vis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="ffi_ZDC_ECAL_module_Vis" alpha="1.0" r= "0.1" g="1.0" b="0.9" showDaughters="true" visible="true"/>
<vis name="ffi_ZDC_HCAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <comment>
<vis name="cb_CTDVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> PID visualization
<vis name="cb_CTD_Si_layerVis" alpha="1.0" r= "0.9" g="1.0" b="0.1" showDaughters="true" visible="true"/> </comment>
<vis name="ce_GEMVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="cb_GEM_layerVis" alpha="0.8" r= "0.8" g="0.4" b="0.3" showDaughters="true" visible="true"/> <vis name="DRICH_vessel_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="cb_VTX_BarrelVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="DRICH_gas_vis" ref="AnlGreen" alpha="0.5" showDaughters="true" visible="true" />
<vis name="cb_VTX_Barrel_layerVis" alpha="2.0" r= "0.0" g="0.2" b="0.8" showDaughters="true" visible="true"/> <vis name="DRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="ci_GEMVis" r= "0.8" g="0.4" b="0.3" alpha="0.8" showDaughters="true" visible="true"/>
<vis name="ci_HCALVis" r= "0.6" g="0" b="0.6" alpha="1.0" showDaughters="true" visible="true"/>
<vis name="DRICH_vessel_vis" alpha="1.0" r="1.0" g="1.0" b="1.0" showDaughters="true" visible="true" />
<vis name="DRICH_gas_vis" alpha="1.0" r="1.0" g="0.0" b="0.0" showDaughters="true" visible="true" />
<vis name="DRICH_aerogel_vis" alpha="1.0" r="0.0" g="1.0" b="1.0" showDaughters="true" visible="true" />
<vis name="DRICH_filter_vis" alpha="1.0" r="1.0" g="1.0" b="0.0" showDaughters="true" visible="true" /> <vis name="DRICH_filter_vis" alpha="1.0" r="1.0" g="1.0" b="0.0" showDaughters="true" visible="true" />
<vis name="DRICH_mirror_vis" alpha="1.0" r="0.5" g="0.5" b="0.5" showDaughters="true" visible="true" /> <vis name="DRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="DRICH_sensor_vis" alpha="1.0" r="0.0" g="1.0" b="0.0" showDaughters="true" visible="true" /> <vis name="DRICH_sensor_vis" ref="AnlBlue" showDaughters="true" visible="true" />
<vis name="PFRICH_sensor_vis" ref="AnlBlue" showDaughters="true" visible="true" />
<vis name="MRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="MRICH_frame_vis" ref="AnlGold" showDaughters="true" visible="true" />
<vis name="MRICH_lens_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="MRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="RICHServiceVis" ref="AnlGray" showDaughters="true" visible="true" />
...@@ -11,41 +11,84 @@ ...@@ -11,41 +11,84 @@
<comment> <comment>
<vis name="TrackerSupportVis" ref="AnlBlue" showDaughters="false" /> <vis name="TrackerVis" ref="AnlRed" />
<vis name="TrackerLayerVis" ref="AnlTeal" visible="true" showDaughters="true" /> <vis name="TrackerSupportVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="TrackerModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" /> <vis name="TrackerServiceVis" ref="AnlGold" showDaughters="false" />
<vis name="TrackerModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="true" />
<vis name="TrackerMPGDVis" ref="AnlRed" visible="true" showDaughters="true" />
<comment> Layer-based visualization for MPGD detectors as it looks better </comment>
<vis name="VertexSupportVis" ref="AnlBlue" showDaughters="false" /> <vis name="VertexLayerVis" ref="AnlGray" visible="true" showDaughters="false" />
<vis name="VertexLayerVis" ref="AnlTeal" visible="true" showDaughters="true" /> <vis name="VertexSupportLayerVis" ref="AnlBlue" visible="true" showDaughters="false" />
<vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="false" /> <vis name="VertexSupportVis" ref="VertexSupportLayerVis" visible="true" showDaughters="true" />
<vis name="VertexModuleVis" ref="TrackerLayerVis" visible="true" showDaughters="true" />
<comment> Display shielded modules in all their glory </comment>
<vis name="FFTrackerShieldedModuleVis" ref="FFTrackerModuleVis" visible="true" showDaughters="true" />
<comment> <comment>
ECal Vis ECal Vis
<vis name="EcalVis" ref="AnlGold" showDaughters="true" visible="true"/> <vis name="EcalBarrelLayerVis" ref="AnlGold" showDaughters="false" visible="true"/>
<vis name="EcalEndcapVis" ref="AnlGold" showDaughters="false" visible="true"/> <vis name="EcalBarrelEnvelopeVis" ref="AnlGold" showDaughters="true" visible="false" />
<vis name="EcalBarrelVis" ref="AnlGold" showDaughters="false" visible="true"/> <vis name="EcalBarrelStaveVis" ref="AnlGold" showDaughters="true" visible="true" />
<vis name="EcalBarrelSliceVis" ref="AnlGray"/>
<vis name="EcalBarrelSupportVis" ref="AnlOrange"/>
<vis name="EcalVis" ref="AnlGold" showDaughters="true" visible="false"/>
<vis name="EcalEndcapNModuleVis" ref="AnlTeal" showDaughters="false" visible="true"/> <vis name="FFPreVis" ref="AnlGold" showDaughters="true" visible="true"/>
<comment> <comment>
HCal Vis HCal Vis
<vis name="HcalEndcapVis" ref="AnlProcess_Blue" showDaughters="false" visible="true" /> <vis name="HcalBarrelLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalAbsorberVis" ref="AnlProcess_Blue" showDaughters="false" visible="false" /> <vis name="HcalEndcapLayerVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalSensorVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="HcalAbsorberVis" ref="AnlGray" showDaughters="true" visible="true"/>
<comment>
</comment>
<comment> <comment>
Solenoid Solenoid
...@@ -57,43 +100,65 @@ ...@@ -57,43 +100,65 @@
<comment> <comment>
<vis name="DIRCVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<vis name="DIRCLayerVis" ref="AnlTeal" showDaughters="false" visible="true"/>
<vis name="DIRCModuleVis" ref="AnlTeal" showDaughters="true" visible="true"/>
<comment>
</comment>
<comment>
ZDC visualization
</comment>
<comment> <comment>
Beam line PID visualization
<vis name="cb_SolenoidVis" alpha="0.4" r= "0.1" g="0.0" b="0.1" showDaughters="true" visible="true"/> <vis name="DRICH_gas_vis" ref="AnlLightGray" alpha="0.2" showDaughters="true" visible="true" />
<vis name="ffi_ZDC_ECAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="DRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="ffi_ZDC_ECAL_module_Vis" alpha="1.0" r= "0.1" g="1.0" b="0.9" showDaughters="true" visible="true"/> <vis name="DRICH_filter_vis" alpha="1.0" r="1.0" g="1.0" b="0.0" showDaughters="true" visible="true" />
<vis name="ffi_ZDC_HCAL_Vis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="DRICH_mirror_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="cb_CTDVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="DRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" />
<vis name="cb_CTD_Si_layerVis" alpha="1.0" r= "0.9" g="1.0" b="0.1" showDaughters="true" visible="true"/> <vis name="PFRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" />
<vis name="cb_GEM_layerVis" alpha="0.8" r= "0.8" g="0.4" b="0.3" showDaughters="true" visible="true"/> <vis name="MRICH_aerogel_vis" ref="AnlTeal" showDaughters="true" visible="true" />
<vis name="cb_VTX_BarrelVis" alpha="0.1" r= "0.1" g="0.0" b="1.0" showDaughters="true" visible="true"/> <vis name="MRICH_frame_vis" ref="AnlGold" showDaughters="true" visible="true" />
<vis name="cb_VTX_Barrel_layerVis" alpha="2.0" r= "0.0" g="0.2" b="0.8" showDaughters="true" visible="true"/> <vis name="MRICH_lens_vis" ref="AnlGray" showDaughters="true" visible="true" />
<vis name="ci_HCALVis" r= "0.6" g="0" b="0.6" alpha="1.0" showDaughters="true" visible="true"/> <vis name="RICHServiceVis" ref="AnlGray" showDaughters="true" visible="true" />
<comment> <comment>
Deprecated colors. Deprecated values used for IP6 vis
vis name="GreenVis" alpha="1.0" r= "0.0" g="1.0" b="0.0" showDaughters="true" visible="true"/
vis name="RedVis" alpha="0.2" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/
vis name="RPVis" alpha="0.99" r= "1.0" g="0.0" b="0.0" showDaughters="true" visible="true"/
vis name="RPLayerVis" alpha="0.99" r= "0.0" g="0.7" b="0.3" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" /
vis name="BlueVis" alpha="1.0" r= "0.0" g="0.0" b="1.0" showDaughters="true" visible="true"/
vis name="OrangeVis" alpha="1.0" r= "1.0" g="0.45" b="0.0" showDaughters="true" visible="true"/
vis name="RedGreenVis" alpha="0.5" r= "1.0" g="1.0" b="0.0" showDaughters="true" visible="true"/
vis name="BlueGreenVis" alpha="0.5" r= "0.0" g="1.0" b="1.0" showDaughters="true" visible="true"/
vis name="PurpleVis" alpha="1.0" r= "1.0" g="0.0" b="1.0" showDaughters="true" visible="true"/
vis name="DoubleRedG" alpha="0.5" r= "2.0" g=".10" b="0.0" showDaughters="true" visible="true"/
vis name="RBG015" alpha="0.5" r= "0.0" g=".2" b="1.0" showDaughters="true" visible="true"/
vis name="RBG510" alpha="0.5" r= "1.0" g=".2" b="0.0" showDaughters="true" visible="true"/
vis name="RBG" alpha="0.5" r= "1.0" g="1.0" b="1.0" showDaughters="true" visible="true"/
vis name="GrayVis" alpha="1.0" r= "0.75" g="0.75" b="0.75" showDaughters="true" visible="true"/
<vis name="GreenVis" ref="AnlGreen" showDaughters="true" visible="true"/>
<vis name="RedVis" ref="AnlRed" showDaughters="true" visible="true"/>
<vis name="RPVis" ref="AnlDelta_Red" showDaughters="true" visible="true"/>
<vis name="RPLayerVis" ref="AnlTeal" showDaughters="true" visible="true" lineStyle="solid" drawingStyle="solid" />
<vis name="BlueVis" ref="AnlBlue" showDaughters="true" visible="true"/>
<vis name="OrangeVis" ref="AnlOrange" showDaughters="true" visible="true"/>
<vis name="BlueGreenVis" alpha="0.5" r= "0.0" g="1.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="PurpleVis" alpha="1.0" r= "1.0" g="0.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="DoubleRedG" alpha="0.5" r= "2.0" g=".10" b="0.0" showDaughters="true" visible="true"/>
<vis name="RBG015" alpha="0.5" r= "0.0" g=".2" b="1.0" showDaughters="true" visible="true"/>
<vis name="RBG510" alpha="0.5" r= "1.0" g=".2" b="0.0" showDaughters="true" visible="true"/>
<vis name="RBG" alpha="0.5" r= "1.0" g="1.0" b="1.0" showDaughters="true" visible="true"/>
<vis name="GrayVis" alpha="1.0" r= "0.75" g="0.75" b="0.75" showDaughters="true" visible="true"/>
<vis name="AnlRed_1" alpha="0.5" r="205/256" g="32/256" b="44/256"/>
<display>
<comment>
See compact/colors.xml for list of colors.
</comment>
<vis name="InvisibleNoDaughters" showDaughters="false" visible="false"/>
<vis name="InvisibleWithDaughters" showDaughters="true" visible="false"/>
<comment>
</comment>
<comment> Simple visualization for Barrel MMGAS (apply to layers) and GEM endcap (apply to modules) for better performance </comment>
<comment>
ECal Vis
</comment>
<comment>
HCal Vis
</comment>
<comment>
</comment>
<comment>
Solenoid
</comment>
<comment>
PID Detectors
</comment>
<comment>
</comment>
<comment>
ZDC visualization
</comment>
<comment>
PID visualization
</comment>
<vis name="PFRICH_sensor_vis" ref="AnlGreen" showDaughters="true" visible="true" /> <!-- invisible, to speedup graphics -->
<comment>
</comment>
</display>
...@@ -8,13 +8,11 @@ ...@@ -8,13 +8,11 @@
<documentation level="10"> <documentation level="10">
### Ecal configuration ### Ecal configuration
</documentation> </documentation>
<include ref="ci_ecal.xml"/> <!--include ref="ecal_forward_scfi.xml"/-->
<!--<include ref="compact/ci_ecal_shashlik.xml"/>--> <include ref="ecal_forward_homogenous.xml"/>
<!--<include ref="compact/ce_ecal.xml"/>-->
<!-- <include ref="ce_ecal_crystal_glass.xml"/>--> <include ref="ecal_backward_hybrid.xml"/>
<include ref="hybrid_ecal.xml"/>
<!-- <include ref="compact/ecal_barrel.xml"/> -->
<!-- <include ref="compact/ecal_barrel_hybrid.xml"/> -->
<include ref="ecal_barrel_interlayers.xml"/> <include ref="ecal_barrel_interlayers.xml"/>
</lccdd> </lccdd>
...@@ -27,13 +27,15 @@ ...@@ -27,13 +27,15 @@
<constant name="CrystalModule_width" value="20.00*mm"/> <constant name="CrystalModule_width" value="20.00*mm"/>
<constant name="CrystalModule_length" value="200.00*mm"/> <constant name="CrystalModule_length" value="200.00*mm"/>
<constant name="CrystalModule_wrap" value="0.50*mm"/> <constant name="CrystalModule_wrap" value="0.50*mm"/>
<constant name="CrystalModule_z0" value="10.*cm"/> <constant name="CrystalModule_z0" value="0.0*cm"/>
<constant name="GlassModule_width" value="2*CrystalModule_width"/> <constant name="GlassModule_width" value="2*CrystalModule_width"/>
<constant name="GlassModule_length" value="40.00*cm"/> <constant name="GlassModule_length" value="55.00*cm"/>
<constant name="GlassModule_wrap" value="2*CrystalModule_wrap"/> <constant name="GlassModule_wrap" value="2*CrystalModule_wrap"/>
<constant name="GlassModule_z0" value="0.0*cm"/> <constant name="GlassModule_z0" value="0.0*cm"/>
<constant name="EcalEndcapNIonCutout_dphi" value="30*degree"/>
<constant name="EcalEndcapN_thickness" value="GlassModule_length"/> <constant name="EcalEndcapN_thickness" value="GlassModule_length"/>
<constant name="EcalEndcapN_z0" value="-EcalEndcapN_zmin - EcalEndcapN_thickness/2"/> <constant name="EcalEndcapN_z0" value="-EcalEndcapN_zmin - EcalEndcapN_thickness/2"/>
<constant name="EcalEndcapNCrystal_rmax" value="40*cm"/> <constant name="EcalEndcapNCrystal_rmax" value="40*cm"/>
...@@ -21,7 +21,7 @@ ...@@ -21,7 +21,7 @@
<constant name="EcalBarrel_ModRepeat" value="CaloSides"/> <constant name="EcalBarrel_ModRepeat" value="CaloSides"/>
<constant name="EcalBarrel_ModLength" value="0.5*m"/> <constant name="EcalBarrel_ModLength" value="0.5*m"/>
<constant name="EcalBarrel_ModWidth" value="0.5*m"/> <constant name="EcalBarrel_ModWidth" value="0.5*m"/>
<constant name="EcalBarrel_AvailThickness" value="EcalBarrel_TotalThickness-EcalBarrel_Support_thickness"/> <constant name="EcalBarrel_AvailThickness" value="EcalBarrelRegion_thickness-EcalBarrel_Support_thickness"/>
<constant name="EcalBarrel_ReadoutLayerThickness" <constant name="EcalBarrel_ReadoutLayerThickness"
value="EcalBarrel_SiliconThickness value="EcalBarrel_SiliconThickness
+ EcalBarrel_ElectronicsThickness + EcalBarrel_ElectronicsThickness
...@@ -8,6 +8,12 @@ ...@@ -8,6 +8,12 @@
EM Calorimeter Parameters with AstroPix EM Calorimeter Parameters with AstroPix
<comment>
To change the number of imaging layers from, e.g., 9 to 6,
change EcalBarrelImagingLayers_nMax variable
</comment>
<constant name="EcalBarrelImagingLayers_nMax" value="6"/>
<constant name="EcalBarrel_Support_thickness" value="5*cm"/> <constant name="EcalBarrel_Support_thickness" value="5*cm"/>
<constant name="EcalBarrel_SiliconThickness" value="500*um"/> <constant name="EcalBarrel_SiliconThickness" value="500*um"/>
<constant name="EcalBarrel_ElectronicsThickness" value="150*um"/> <constant name="EcalBarrel_ElectronicsThickness" value="150*um"/>
...@@ -21,7 +27,6 @@ ...@@ -21,7 +27,6 @@
<constant name="EcalBarrel_FiberXSpacing" value="1.34*mm"/> <constant name="EcalBarrel_FiberXSpacing" value="1.34*mm"/>
<constant name="EcalBarrel_FiberZSpacing" value="1.22*mm"/> <constant name="EcalBarrel_FiberZSpacing" value="1.22*mm"/>
<constant name="EcalBarrel_SpaceBetween" value="0.1*mm"/> <constant name="EcalBarrel_SpaceBetween" value="0.1*mm"/>
<constant name="EcalBarrel_FiberChunkLayers_num" value = "15"/>
<comment> <comment>
For Pb/SiFi (GlueX): X0 ~ 1.45 cm For Pb/SiFi (GlueX): X0 ~ 1.45 cm
For W/SiFi (sPHENIX): X0 ~ 0.7 cm (but different fiber orientation) For W/SiFi (sPHENIX): X0 ~ 0.7 cm (but different fiber orientation)
...@@ -30,7 +35,8 @@ ...@@ -30,7 +35,8 @@
<constant name="EcalBarrel_ImagingLayerThickness" <constant name="EcalBarrel_ImagingLayerThickness"
...@@ -43,16 +49,27 @@ ...@@ -43,16 +49,27 @@
+ EcalBarrel_CarbonThickness + EcalBarrel_CarbonThickness
+ EcalBarrel_LayerSpacing"/> + EcalBarrel_LayerSpacing"/>
<constant name="EcalBarrelImagingLayers_num" <constant name="EcalBarrelImagingLayers_num"
value="min(EcalBarrelImagingLayers_nMax, value="min(EcalBarrelImagingLayers_nMax,
floor(EcalBarrel_AvailThickness/ floor((EcalBarrel_AvailThickness-EcalBarrel_ImagingLayerThickness)/
(EcalBarrel_ImagingLayerThickness+EcalBarrel_RadiatorThickness+EcalBarrel_SpaceBetween)))"/> (EcalBarrel_ImagingLayerThickness + EcalBarrel_ScFiLayerThickness +
<constant name="EcalBarrel_FiberLayerThickness_max" EcalBarrel_SpaceBetween)))"/>
value="max(0, EcalBarrel_AvailThickness- <comment>
(EcalBarrelImagingLayers_num*EcalBarrel_ImagingLayerThickness))"/> Adjusting size of the ScFi back chunk to match number of imiaging layers
<constant name="EcalBarrel_FiberLayerThickness" and 20 radiation lengths in total
value="min(EcalBarrel_FiberLayerThickness_max, EcalBarrel_FiberZSpacing*13*15)"/> </comment>
<constant name="EcalBarrel_FiberChunkLayers_num" value = "20-EcalBarrelImagingLayers_num+1"/>
<constant name="EcalBarrel_ImagingPartThickness"
value="(EcalBarrelImagingLayers_num-1)*(EcalBarrel_ImagingLayerThickness + EcalBarrel_ScFiLayerThickness + EcalBarrel_SpaceBetween)
+ EcalBarrel_ImagingLayerThickness + EcalBarrel_SpaceBetween"/>
<constant name="EcalBarrel_ScFiPartThickness_max"
value="max(0, EcalBarrel_AvailThickness-EcalBarrel_ImagingPartThickness)"/>
<constant name="EcalBarrel_ScFiPartThickness"
value="min(EcalBarrel_ScFiPartThickness_max,
EcalBarrel_FiberZSpacing*13*EcalBarrel_FiberChunkLayers_num)"/>
<constant name="EcalBarrel_SensitiveLayers_rmax"
value="EcalBarrel_rmin + EcalBarrel_ImagingPartThickness + EcalBarrel_ScFiPartThickness"/>
</define> </define>
<limits> <limits>
...@@ -134,7 +151,7 @@ ...@@ -134,7 +151,7 @@
<layer repeat="EcalBarrel_FiberChunkLayers_num" vis="EcalBarrelLayerVis" <layer repeat="EcalBarrel_FiberChunkLayers_num" vis="EcalBarrelLayerVis"
space_before="EcalBarrel_ImagingLayerThickness + EcalBarrel_SpaceBetween"> space_before="EcalBarrel_ImagingLayerThickness + EcalBarrel_SpaceBetween">
<slice material="Lead" <slice material="Lead"
thickness="EcalBarrel_FiberLayerThickness/EcalBarrel_FiberChunkLayers_num" thickness="EcalBarrel_ScFiPartThickness/EcalBarrel_FiberChunkLayers_num"
vis="EcalBarrelFiberLayerVis"> vis="EcalBarrelFiberLayerVis">
<fiber material="PlasticScint" <fiber material="PlasticScint"
sensitive="yes" sensitive="yes"
<lccdd>
<comment>
Simplified homogenous implementation of the forward ScFi calorimeter
</comment>
<define>
<constant name="EcalEndcapP_FiberRadius" value="0.235*cm"/>
<constant name="EcalEndcapP_FiberOffset" value="0.5*mm"/>
<constant name="EcalEndcapP_FiberSpaceX" value="0.265*mm"/>
<constant name="EcalEndcapP_FiberSpaceY" value="0.425*mm"/>
</define>
<limits>
</limits>
<regions>
</regions>
<!-- Common Generic visualization attributes -->
<comment>Common Generic visualization attributes</comment>
<display>
</display>
<detectors>
<comment>
An EM calorimeter with ScFi modules
</comment>
name="EcalEndcapP"
type="ScFiCalorimeter"
vis="EcalEndcapVis"
readout="EcalEndcapPHits">
<position x="0" y="0" z="EcalEndcapP_zmin + EcalEndcapP_length/2."/>
<dimensions rmin="EcalEndcapP_rmin" rmax="EcalEndcapP_rmax" length="EcalEndcapP_length"/>
<module sizex="25*mm" sizey="25*mm" sizez="170*mm" material="AvgTungstenScFi" vis="EcalEndcapBlockVis">
</module>
</detector>
</detectors>
<readouts>
<segmentation type="NoSegmentation"/>
<id>system:8,ring:8,module:20,fiber_x:8,fiber_y:8</id>
</readout>
</readouts>
<plugins>
</plugins>
</lccdd>
<lccdd>
<define>
</define>
<limits>
</limits>
<regions>
</regions>
<display>
</display>
<detectors>
<comment>
</comment>
name="EcalEndcapP"
vis="EcalEndcapVis"
<module sizex="25*mm" sizey="25*mm" sizez="170*mm" material="TungstenDens24" vis="EcalEndcapBlockVis">
<fiber material="Polystyrene"
radius="EcalEndcapP_FiberRadius"
offset="EcalEndcapP_FiberOffset"
spacex="EcalEndcapP_FiberSpaceX"
spacey="EcalEndcapP_FiberSpaceY"/>
</module>
</detector>
</detectors>
<readouts>
</readout>
</readouts>
<plugins>
</plugins>
</lccdd>
